Pull block fixes from Jens Axboe:
"A few fixes that should go into this release:
- NVMe controller error path reference fix (Chaitanya)
- Fix regression with IBM partitions on non-dasd devices (Christoph)
- Fix a missing clear in the compat CDROM packet structure (Peilin)"
* tag 'block5.9-2020-10-08' of git://git.kernel.dk/linux-block:
partitions/ibm: fix non-DASD devices
nvme-core: put ctrl ref when module ref get fail
block/scsi-ioctl: Fix kernel-infoleak in scsi_put_cdrom_generic_arg()
Pull vhost fixes from Michael Tsirkin:
"Some last minute vhost,vdpa fixes.
The last two of them haven't been in next but they do seem kind of
obvious, very small and safe, fix bugs reported in the field, and they
are both in a new mlx5 vdpa driver, so it's not like we can introduce
regressions"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
vdpa/mlx5: Fix dependency on MLX5_CORE
vdpa/mlx5: should keep avail_index despite device status
vhost-vdpa: fix page pinning leakage in error path
vhost-vdpa: fix vhost_vdpa_map() on error condition
vhost: Don't call log_access_ok() when using IOTLB
vhost: Use vhost_get_used_size() in vhost_vring_set_addr()
vhost: Don't call access_ok() when using IOTLB
vhost vdpa: fix vhost_vdpa_open error handling
Pull networking fixes from Jakub Kicinski:
"One more set of fixes from the networking tree:
- add missing input validation in nl80211_del_key(), preventing
out-of-bounds access
- last minute fix / improvement of a MRP netlink (uAPI) interface
introduced in 5.9 (current) release
- fix "unresolved symbol" build error under CONFIG_NET w/o
CONFIG_INET due to missing tcp_timewait_sock and inet_timewait_sock
BTF.
- fix 32 bit sub-register bounds tracking in the bpf verifier for OR
case
- tcp: fix receive window update in tcp_add_backlog()
- openvswitch: handle DNAT tuple collision in conntrack-related code
- r8169: wait for potential PHY reset to finish after applying a FW
file, avoiding unexpected PHY behaviour and failures later on
- mscc: fix tail dropping watermarks for Ocelot switches
- avoid use-after-free in macsec code after a call to the GRO layer
- avoid use-after-free in sctp error paths
- add a device id for Cellient MPL200 WWAN card
- rxrpc fixes:
- fix the xdr encoding of the contents read from an rxrpc key
- fix a BUG() for a unsupported encoding type.
- fix missing _bh lock annotations.
- fix acceptance handling for an incoming call where the incoming
call is encrypted.
- the server token keyring isn't network namespaced - it belongs
to the server, so there's no need. Namespacing it means that
request_key() fails to find it.
- fix a leak of the server keyring"
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (21 commits)
net: usb: qmi_wwan: add Cellient MPL200 card
macsec: avoid use-after-free in macsec_handle_frame()
r8169: consider that PHY reset may still be in progress after applying firmware
sctp: fix sctp_auth_init_hmacs() error path
bridge: Netlink interface fix.
net: wireless: nl80211: fix out-of-bounds access in nl80211_del_key()
bpf: Fix scalar32_min_max_or bounds tracking
net: usb: rtl8150: set random MAC address when set_ethernet_addr() fails
mptcp: more DATA FIN fixes
net: mscc: ocelot: warn when encoding an out-of-bounds watermark value
net: mscc: ocelot: divide watermark value by 60 when writing to SYS_ATOP
net: qrtr: ns: Fix the incorrect usage of rcu_read_lock()
rxrpc: Fix server keyring leak
rxrpc: The server keyring isn't network-namespaced
rxrpc: Fix accept on a connection that need securing
rxrpc: Fix some missing _bh annotations on locking conn->state_lock
rxrpc: Downgrade the BUG() for unsupported token type in rxrpc_read()
rxrpc: Fix rxkad token xdr encoding
Remove propmt for selecting MLX5_VDPA by the user and modify
MLX5_VDPA_NET to select MLX5_VDPA. Also modify MLX5_VDPA_NET to depend
on mlx5_core.
This fixes an issue where configuration sets 'y' for MLX5_VDPA_NET while
MLX5_CORE is compiled as a module causing link errors.
Reported-by: kernel test robot <lkp@intel.com>
Fixes: 1a86b377aa21 ("vdpa/mlx5: Add VDPA driver for supported mlx5 device")s
Signed-off-by: Eli Cohen <elic@nvidia.com>
Link: https://lore.kernel.org/r/20201007064011.GA50074@mtl-vdi-166.wap.labs.mlnx
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
A VM with mlx5 vDPA has below warnings while being reset:
vhost VQ 0 ring restore failed: -1: Resource temporarily unavailable (11)
vhost VQ 1 ring restore failed: -1: Resource temporarily unavailable (11)
We should allow userspace emulating the virtio device be
able to get to vq's avail_index, regardless of vDPA device
status. Save the index that was last seen when virtq was
stopped, so that userspace doesn't complain.
Signed-off-by: Si-Wei Liu <si-wei.liu@oracle.com>
Link: https://lore.kernel.org/r/1601583511-15138-1-git-send-email-si-wei.liu@oracle.com
Acked-by: Eli Cohen <elic@nvidia.com>
Add usb ids of the Cellient MPL200 card.
Signed-off-by: Wilken Gottwalt <wilken.gottwalt@mailbox.org>
Acked-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
De-referencing skb after call to gro_cells_receive() is not allowed.
We need to fetch skb->len earlier.
Fixes: 5491e7c6b1a9 ("macsec: enable GRO and RPS on macsec devices")
Cc: Paolo Abeni <pabeni@redhat.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
Some firmware files trigger a PHY soft reset and don't wait for it to
be finished. PHY register writes directly after applying the firmware
may fail or provide unexpected results therefore. Fix this by waiting
for bit BMCR_RESET to be cleared after applying firmware.
There's nothing wrong with the referenced change, it's just that the
fix will apply cleanly only after this change.
Fixes: 89fbd26cca7e ("r8169: fix firmware not resetting tp->ocp_base")
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Pull drm nouveau fixes from Dave Airlie:
"Karol found two last minute nouveau fixes, they both fix crashes, the
TTM one follows what other drivers do already, and the other is for
bailing on load on unrecognised chipsets.
- fix crash in TTM alloc fail path
- return error earlier for unknown chipsets"
* tag 'drm-fixes-2020-10-08' of git://anongit.freedesktop.org/drm/drm:
drm/nouveau/mem: guard against NULL pointer access in mem_del
drm/nouveau/device: return error for unknown chipsets
When try_module_get() fails in the nvme_dev_open() it returns without
releasing the ctrl reference which was taken earlier.
Put the ctrl reference which is taken before calling the
try_module_get() in the error return code path.
Fixes: 52a3974feb1a "nvme-core: get/put ctrl and transport module in nvme_dev_open/release()"
Signed-off-by: Chaitanya Kulkarni <chaitanya.kulkarni@wdc.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
other drivers seems to do something similar
Signed-off-by: Karol Herbst <kherbst@redhat.com>
Cc: dri-devel <dri-devel@lists.freedesktop.org>
Cc: Dave Airlie <airlied@redhat.com>
Cc: stable@vger.kernel.org
Link: https://patchwork.freedesktop.org/patch/msgid/20201006220528.13925-2-kherbst@redhat.com
Previously the code relied on device->pri to be NULL and to fail probing
later. We really should just return an error inside nvkm_device_ctor for
unsupported GPUs.
Fixes: 24d5ff40a732 ("drm/nouveau/device: rework mmio mapping code to get rid of second map")
Cc: dann frazier <dann.frazier@canonical.com>
Reviewed-by: Jeremy Cline <jcline@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20201006220528.13925-1-kherbst@redhat.com
git://git.kernel.org/pub/scm/linux/kernel/git/pdx86/platform-drivers-x86
Pull another x86 platform driver fix from Hans de Goede:
"One final pdx86 fix for Tablet Mode reporting regressions (which make
the keyboard and touchpad unusable) on various Asus notebooks.
These regressions were caused by the asus-nb-wmi and the intel-vbtn
drivers both receiving recent patches to start reporting Tablet Mode /
to report it on more models.
Due to a miscommunication between Andy and me, Andy's earlier pull-req
only contained the fix for the intel-vbtn driver and not the fix for
the asus-nb-wmi code.
This fix has been tested as a downstream patch in Fedora kernels for
approx two weeks with no problems being reported"
* tag 'platform-drivers-x86-v5.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/pdx86/platform-drivers-x86:
platform/x86: asus-wmi: Fix SW_TABLET_MODE always reporting 1 on many different models
Pull drm fixes from Dave Airlie:
"Daniel queued these up last week and I took a long weekend so didn't
get them out, but fixing the OOB access on get font seems like
something we should land and it's cc'ed stable as well.
The other big change is a partial revert for a regression on android
on the clcd fbdev driver, and one other docs fix.
fbdev:
- Re-add FB_ARMCLCD for android
- Fix global-out-of-bounds read in fbcon_get_font()
core:
- Small doc fix"
* tag 'drm-fixes-2020-10-06-1' of git://anongit.freedesktop.org/drm/drm:
drm: drm_dsc.h: fix a kernel-doc markup
Partially revert "video: fbdev: amba-clcd: Retire elder CLCD driver"
fbcon: Fix global-out-of-bounds read in fbcon_get_font()
Fonts: Support FONT_EXTRA_WORDS macros for built-in fonts
fbdev, newport_con: Move FONT_EXTRA_WORDS macros into linux/font.h
When get_registers() fails in set_ethernet_addr(),the uninitialized
value of node_id gets copied over as the address.
So, check the return value of get_registers().
If get_registers() executed successfully (i.e., it returns
sizeof(node_id)), copy over the MAC address using ether_addr_copy()
(instead of using memcpy()).
Else, if get_registers() failed instead, a randomly generated MAC
address is set as the MAC address instead.
Reported-by: syzbot+abbc768b560c84d92fd3@syzkaller.appspotmail.com
Tested-by: syzbot+abbc768b560c84d92fd3@syzkaller.appspotmail.com
Acked-by: Petko Manolov <petkan@nucleusys.com>
Signed-off-by: Anant Thazhemadam <anant.thazhemadam@gmail.com>
There is an upper bound to the value that a watermark may hold. That
upper bound is not immediately obvious during configuration, and it
might be possible to have accidental truncation.
Actually this has happened already, add a warning to prevent it from
happening again.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Tail dropping is enabled for a port when:
1. A source port consumes more packet buffers than the watermark encoded
in SYS:PORT:ATOP_CFG.ATOP.
AND
2. Total memory use exceeds the consumption watermark encoded in
SYS:PAUSE_CFG:ATOP_TOT_CFG.
The unit of these watermarks is a 60 byte memory cell. That unit is
programmed properly into ATOP_TOT_CFG, but not into ATOP. Actually when
written into ATOP, it would get truncated and wrap around.
Fixes: a556c76adc05 ("net: mscc: Add initial Ocelot switch support")
different models
Commit b0dbd97de1f1 ("platform/x86: asus-wmi: Add support for
SW_TABLET_MODE") added support for reporting SW_TABLET_MODE using the
Asus 0x00120063 WMI-device-id to see if various transformer models were
docked into their keyboard-dock (SW_TABLET_MODE=0) or if they were
being used as a tablet.
The new SW_TABLET_MODE support (naively?) assumed that non Transformer
devices would either not support the 0x00120063 WMI-device-id at all,
or would NOT set ASUS_WMI_DSTS_PRESENCE_BIT in their reply when querying
the device-id.
Unfortunately this is not true and we have received many bug reports about
this change causing the asus-wmi driver to always report SW_TABLET_MODE=1
on non Transformer devices. This causes libinput to think that these are
360 degree hinges style 2-in-1s folded into tablet-mode. Making libinput
suppress keyboard and touchpad events from the builtin keyboard and
touchpad. So effectively this causes the keyboard and touchpad to not work
on many non Transformer Asus models.
This commit fixes this by using the existing DMI based quirk mechanism in
asus-nb-wmi.c to allow using the 0x00120063 device-id for reporting
SW_TABLET_MODE on Transformer models and ignoring it on all other models.
Fixes: b0dbd97de1f1 ("platform/x86: asus-wmi: Add support for SW_TABLET_MODE")
Link: https://patchwork.kernel.org/patch/11780901/
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=209011
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1876997
Reported-by: Samuel Čavoj <samuel@cavoj.net>
git://anongit.freedesktop.org/drm/drm-misc into drm-fixes
drm-misc-fixes for v5.9:
- Small doc fix.
- Re-add FB_ARMCLCD for android.
- Fix global-out-of-bounds read in fbcon_get_font().
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/8585daa2-fcbc-3924-ac4f-e7b5668808e0@linux.intel.com
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform driver fixes from Andy Shevchenko:
"We have some fixes for Tablet Mode reporting in particular, that users
are complaining a lot about.
Summary:
- Attempt #3 of enabling Tablet Mode reporting w/o regressions
- Improve battery recognition code in ASUS WMI driver
- Fix Kconfig dependency warning for Fujitsu and LG laptop drivers
- Add fixes in Thinkpad ACPI driver for _BCL method and NVRAM polling
- Fix power supply extended topology in Mellanox driver
- Fix memory leak in OLPC EC driver
- Avoid static struct device in Intel PMC core driver
- Add support for the touchscreen found in MPMAN Converter9 2-in-1
- Update MAINTAINERS to reflect the real state of affairs"
* tag 'platform-drivers-x86-v5.9-2' of git://git.infradead.org/linux-platform-drivers-x86:
platform/x86: thinkpad_acpi: re-initialize ACPI buffer size when reuse
MAINTAINERS: Add Mark Gross and Hans de Goede as x86 platform drivers maintainers
platform/x86: intel-vbtn: Switch to an allow-list for SW_TABLET_MODE reporting
platform/x86: intel-vbtn: Revert "Fix SW_TABLET_MODE always reporting 1 on the HP Pavilion 11 x360"
platform/x86: intel_pmc_core: do not create a static struct device
platform/x86: mlx-platform: Fix extended topology configuration for power supply units
platform/x86: pcengines-apuv2: Fix typo on define of AMD_FCH_GPIO_REG_GPIO55_DEVSLP0
platform/x86: fix kconfig dependency warning for FUJITSU_LAPTOP
platform/x86: fix kconfig dependency warning for LG_LAPTOP
platform/x86: thinkpad_acpi: initialize tp_nvram_state variable
platform/x86: intel-vbtn: Fix SW_TABLET_MODE always reporting 1 on the HP Pavilion 11 x360
platform/x86: asus-wmi: Add BATC battery name to the list of supported
platform/x86: asus-nb-wmi: Revert "Do not load on Asus T100TA and T200TA"
platform/x86: touchscreen_dmi: Add info for the MPMAN Converter9 2-in-1
Documentation: laptops: thinkpad-acpi: fix underline length build warning
Platform: OLPC: Fix memleak in olpc_ec_probe
Pull networking fixes from David Miller:
1) Make sure SKB control block is in the proper state during IPSEC
ESP-in-TCP encapsulation. From Sabrina Dubroca.
2) Various kinds of attributes were not being cloned properly when we
build new xfrm_state objects from existing ones. Fix from Antony
Antony.
3) Make sure to keep BTF sections, from Tony Ambardar.
4) TX DMA channels need proper locking in lantiq driver, from Hauke
Mehrtens.
5) Honour route MTU during forwarding, always. From Maciej
Żenczykowski.
6) Fix races in kTLS which can result in crashes, from Rohit
Maheshwari.
7) Skip TCP DSACKs with rediculous sequence ranges, from Priyaranjan
Jha.
8) Use correct address family in xfrm state lookups, from Herbert Xu.
9) A bridge FDB flush should not clear out user managed fdb entries
with the ext_learn flag set, from Nikolay Aleksandrov.
10) Fix nested locking of netdev address lists, from Taehee Yoo.
11) Fix handling of 32-bit DATA_FIN values in mptcp, from Mat Martineau.
12) Fix r8169 data corruptions on RTL8402 chips, from Heiner Kallweit.
13) Don't free command entries in mlx5 while comp handler could still be
running, from Eran Ben Elisha.
14) Error flow of request_irq() in mlx5 is busted, due to an off by one
we try to free and IRQ never allocated. From Maor Gottlieb.
15) Fix leak when dumping netlink policies, from Johannes Berg.
16) Sendpage cannot be performed when a page is a slab page, or the page
count is < 1. Some subsystems such as nvme were doing so. Create a
"sendpage_ok()" helper and use it as needed, from Coly Li.
17) Don't leak request socket when using syncookes with mptcp, from
Paolo Abeni.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (111 commits)
net/core: check length before updating Ethertype in skb_mpls_{push,pop}
net: mvneta: fix double free of txq->buf
net_sched: check error pointer in tcf_dump_walker()
net: team: fix memory leak in __team_options_register
net: typhoon: Fix a typo Typoon --> Typhoon
net: hinic: fix DEVLINK build errors
net: stmmac: Modify configuration method of EEE timers
tcp: fix syn cookied MPTCP request socket leak
libceph: use sendpage_ok() in ceph_tcp_sendpage()
scsi: libiscsi: use sendpage_ok() in iscsi_tcp_segment_map()
drbd: code cleanup by using sendpage_ok() to check page for kernel_sendpage()
tcp: use sendpage_ok() to detect misused .sendpage
nvme-tcp: check page by sendpage_ok() before calling kernel_sendpage()
net: add WARN_ONCE in kernel_sendpage() for improper zero-copy send
net: introduce helper sendpage_ok() in include/linux/net.h
net: usb: pegasus: Proper error handing when setting pegasus' MAC address
net: core: document two new elements of struct net_device
netlink: fix policy dump leak
net/mlx5e: Fix race condition on nhe->n pointer in neigh update
net/mlx5e: Fix VLAN create flow
Evaluating ACPI _BCL could fail, then ACPI buffer size will be set to 0.
When reuse this ACPI buffer, AE_BUFFER_OVERFLOW will be triggered.
Re-initialize buffer size will make ACPI evaluate successfully.
Fixes: 46445b6b896fd ("thinkpad-acpi: fix handle locate for video and query of _BCL")
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
clang static analysis reports this problem:
drivers/net/ethernet/marvell/mvneta.c:3465:2: warning:
Attempt to free released memory
kfree(txq->buf);
When mvneta_txq_sw_init() fails to alloc txq->tso_hdrs,
it frees without poisoning txq->buf. The error is caught
in the mvneta_setup_txqs() caller which handles the error
by cleaning up all of the txqs with a call to
mvneta_txq_sw_deinit which also frees txq->buf.
Since mvneta_txq_sw_deinit is a general cleaner, all of the
partial cleaning in mvneta_txq_sw_deinit()'s error handling
is not needed.
Fixes: 2adb719d74f6 ("net: mvneta: Implement software TSO")
Signed-off-by: Tom Rix <trix@redhat.com>
The variable "i" isn't initialized back correctly after the first loop
under the label inst_rollback gets executed.
The value of "i" is assigned to be option_count - 1, and the ensuing
loop (under alloc_rollback) begins by initializing i--.
Thus, the value of i when the loop begins execution will now become
i = option_count - 2.
Thus, when kfree(dst_opts[i]) is called in the second loop in this
order, (i.e., inst_rollback followed by alloc_rollback),
dst_optsp[option_count - 2] is the first element freed, and
dst_opts[option_count - 1] does not get freed, and thus, a memory
leak is caused.
This memory leak can be fixed, by assigning i = option_count (instead of
option_count - 1).
Fixes: 80f7c6683fe0 ("team: add support for per-port options")
Reported-by: syzbot+69b804437cfec30deac3@syzkaller.appspotmail.com
Tested-by: syzbot+69b804437cfec30deac3@syzkaller.appspotmail.com
Pinned pages are not properly accounted particularly when
mapping error occurs on IOTLB update. Clean up dangling
pinned pages for the error path. As the inflight pinned
pages, specifically for memory region that strides across
multiple chunks, would need more than one free page for
book keeping and accounting. For simplicity, pin pages
for all memory in the IOVA range in one go rather than
have multiple pin_user_pages calls to make up the entire
region. This way it's easier to track and account the
pages already mapped, particularly for clean-up in the
error path.
Fixes: 4c8cf31885f6 ("vhost: introduce vDPA-based backend")
Link: https://lore.kernel.org/r/1601701330-16837-3-git-send-email-si-wei.liu@oracle.com
vhost_vdpa_map() should remove the iotlb entry just added
if the corresponding mapping fails to set up properly.
Link: https://lore.kernel.org/r/1601701330-16837-2-git-send-email-si-wei.liu@oracle.com
When the IOTLB device is enabled, the log_guest_addr that is passed by
userspace to the VHOST_SET_VRING_ADDR ioctl, and which is then written
to vq->log_addr, is a GIOVA. All writes to this address are translated
by log_user() to writes to an HVA, and then ultimately logged through
the corresponding GPAs in log_write_hva(). No logging will ever occur
with vq->log_addr in this case. It is thus wrong to pass vq->log_addr
and log_guest_addr to log_access_vq() which assumes they are actual
GPAs.
Introduce a new vq_log_used_access_ok() helper that only checks accesses
to the log for the used structure when there isn't an IOTLB device around.
Signed-off-by: Greg Kurz <groug@kaod.org>
Link: https://lore.kernel.org/r/160171933385.284610.10189082586063280867.stgit@bahia.lan
The open-coded computation of the used size doesn't take the event
into account when the VIRTIO_RING_F_EVENT_IDX feature is present.
Fix that by using vhost_get_used_size().
Fixes: 8ea8cf89e19a ("vhost: support event index")
Link: https://lore.kernel.org/r/160171932300.284610.11846106312938909461.stgit@bahia.lan
When the IOTLB device is enabled, the vring addresses we get
from userspace are GIOVAs. It is thus wrong to pass them down
to access_ok() which only takes HVAs.
Access validation is done at prefetch time with IOTLB. Teach
vq_access_ok() about that by moving the (vq->iotlb) check
from vhost_vq_access_ok() to vq_access_ok(). This prevents
vhost_vring_set_addr() to fail when verifying the accesses.
No behavior change for vhost_vq_access_ok().
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1883084
Fixes: 6b1e6cc7855b ("vhost: new device IOTLB API")
Cc: jasowang@redhat.com
CC: stable@vger.kernel.org # 4.14+
Acked-by: Jason Wang <jasowang@redhat.com>
Link: https://lore.kernel.org/r/160171931213.284610.2052489816407219136.stgit@bahia.lan
s/Typoon/Typhoon/
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Fix many (lots deleted here) build errors in hinic by selecting NET_DEVLINK.
ld: drivers/net/ethernet/huawei/hinic/hinic_hw_dev.o: in function `mgmt_watchdog_timeout_event_handler':
hinic_hw_dev.c:(.text+0x30a): undefined reference to `devlink_health_report'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_fw_reporter_dump':
hinic_devlink.c:(.text+0x1c): undefined reference to `devlink_fmsg_u32_pair_put'
hinic_devlink.c:(.text+0x126): undefined reference to `devlink_fmsg_binary_pair_put'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_hw_reporter_dump':
hinic_devlink.c:(.text+0x1ba): undefined reference to `devlink_fmsg_string_pair_put'
ld: hinic_devlink.c:(.text+0x227): undefined reference to `devlink_fmsg_u8_pair_put'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_devlink_alloc':
hinic_devlink.c:(.text+0xaee): undefined reference to `devlink_alloc'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_devlink_free':
hinic_devlink.c:(.text+0xb04): undefined reference to `devlink_free'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_devlink_register':
hinic_devlink.c:(.text+0xb26): undefined reference to `devlink_register'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_devlink_unregister':
hinic_devlink.c:(.text+0xb46): undefined reference to `devlink_unregister'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_health_reporters_create':
hinic_devlink.c:(.text+0xb75): undefined reference to `devlink_health_reporter_create'
ld: hinic_devlink.c:(.text+0xb95): undefined reference to `devlink_health_reporter_create'
ld: hinic_devlink.c:(.text+0xbac): undefined reference to `devlink_health_reporter_destroy'
ld: drivers/net/ethernet/huawei/hinic/hinic_devlink.o: in function `hinic_health_reporters_destroy':
Fixes: 51ba902a16e6 ("net-next/hinic: Initialize hw interface")
Cc: Bin Luo <luobin9@huawei.com>
Cc: Jakub Kicinski <kuba@kernel.org>
Cc: Aviad Krawczyk <aviad.krawczyk@huawei.com>
Cc: Zhao Chen <zhaochen6@huawei.com>
Ethtool manual stated that the tx-timer is the "the amount of time the
device should stay in idle mode prior to asserting its Tx LPI". The
previous implementation for "ethtool --set-eee tx-timer" sets the LPI TW
timer duration which is not correct. Hence, this patch fixes the
"ethtool --set-eee tx-timer" to configure the EEE LPI timer.
The LPI TW Timer will be using the defined default value instead of
"ethtool --set-eee tx-timer" which follows the EEE LS timer implementation.
Changelog V2
*Not removing/modifying the eee_timer.
*EEE LPI timer can be configured through ethtool and also the eee_timer
module param.
*EEE TW Timer will be configured with default value only, not able to be
configured through ethtool or module param. This follows the implementation
of the EEE LS Timer.
Fixes: d765955d2ae0 ("stmmac: add the Energy Efficient Ethernet support")
Signed-off-by: Vineetha G. Jaya Kumaran <vineetha.g.jaya.kumaran@intel.com>
Signed-off-by: Voon Weifeng <weifeng.voon@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fix from Juergen Gross:
"Fix a regression introduced in 5.9-rc3 which caused a system running
as fully virtualized guest under Xen to crash when using legacy
devices like a floppy"
* tag 'for-linus-5.9b-rc8-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/events: don't use chip_data for legacy IRQs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY fixes from Greg KH:
"Here are some small USB and PHY driver fixes for 5.9-rc8
The PHY driver fix resolves an issue found by Dan Carpenter for a
memory leak.
The USB fixes fall into two groups:
- usb gadget fix from Bryan that is a fix for a previous security fix
that showed up in in-the-wild testing
- usb core driver matching bugfixes. This fixes a bug that has
plagued the both the usbip driver and syzbot testing tools this -rc
release cycle. All is now working properly so usbip connections
will work, and syzbot can get back to fuzzing USB drivers properly.
All have been in linux-next for a while with no reported issues"
* tag 'usb-5.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usbcore/driver: Accommodate usbip
usbcore/driver: Fix incorrect downcast
usbcore/driver: Fix specific driver selection
Revert "usbip: Implement a match function to fix usbip"
USB: gadget: f_ncm: Fix NDP16 datagram validation
phy: ti: am654: Fix a leak in serdes_am654_probe()
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Some more driver fixes for i2c"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: npcm7xx: Clear LAST bit after a failed transaction.
i2c: cpm: Fix i2c_ram structure
i2c: i801: Exclude device from suspend direct complete optimization
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"A couple more driver quirks, now enabling newer trackpoints from
Synaptics for real"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: i8042 - add nopnp quirk for Acer Aspire 5 A515
Input: trackpoint - enable Synaptics trackpoints
git://git.kernel.org/pub/scm/linux/kernel/git/saeed/linux
This series introduces some fixes to mlx5 driver.
v1->v2:
- Patch #1 Don't return while mutex is held. (Dave)
v2->v3:
- Drop patch #1, will consider a better approach (Jakub)
- use cpu_relax() instead of cond_resched() (Jakub)
- while(i--) to reveres a loop (Jakub)
- Drop old mellanox email sign-off and change the committer email
(Jakub)
Please pull and let me know if there is any problem.
For -stable v4.15
('net/mlx5e: Fix VLAN cleanup flow')
('net/mlx5e: Fix VLAN create flow')
For -stable v4.16
('net/mlx5: Fix request_irqs error flow')
For -stable v5.4
('net/mlx5e: Add resiliency in Striding RQ mode for packets larger than MTU')
('net/mlx5: Avoid possible free of command entry while timeout comp handler')
For -stable v5.7
('net/mlx5e: Fix return status when setting unsupported FEC mode')
For -stable v5.8
('net/mlx5e: Fix race condition on nhe->n pointer in neigh update')
In iscsci driver, iscsi_tcp_segment_map() uses the following code to
check whether the page should or not be handled by sendpage:
if (!recv && page_count(sg_page(sg)) >= 1 && !PageSlab(sg_page(sg)))
The "page_count(sg_page(sg)) >= 1 && !PageSlab(sg_page(sg)" part is to
make sure the page can be sent to network layer's zero copy path. This
part is exactly what sendpage_ok() does.
This patch uses use sendpage_ok() in iscsi_tcp_segment_map() to replace
the original open coded checks.
Signed-off-by: Coly Li <colyli@suse.de>
Reviewed-by: Lee Duncan <lduncan@suse.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Vasily Averin <vvs@virtuozzo.com>
Cc: Cong Wang <amwang@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Chris Leech <cleech@redhat.com>
Cc: Hannes Reinecke <hare@suse.de>
In _drbd_send_page() a page is checked by following code before sending
it by kernel_sendpage(),
(page_count(page) < 1) || PageSlab(page)
If the check is true, this page won't be send by kernel_sendpage() and
handled by sock_no_sendpage().
This kind of check is exactly what macro sendpage_ok() does, which is
introduced into include/linux/net.h to solve a similar send page issue
in nvme-tcp code.
This patch uses macro sendpage_ok() to replace the open coded checks to
page type and refcount in _drbd_send_page(), as a code cleanup.
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Currently nvme_tcp_try_send_data() doesn't use kernel_sendpage() to
send slab pages. But for pages allocated by __get_free_pages() without
__GFP_COMP, which also have refcount as 0, they are still sent by
kernel_sendpage() to remote end, this is problematic.
The new introduced helper sendpage_ok() checks both PageSlab tag and
page_count counter, and returns true if the checking page is OK to be
sent by kernel_sendpage().
This patch fixes the page checking issue of nvme_tcp_try_send_data()
with sendpage_ok(). If sendpage_ok() returns true, send this page by
kernel_sendpage(), otherwise use sock_no_sendpage to handle this page.
Cc: Chaitanya Kulkarni <chaitanya.kulkarni@wdc.com>
Cc: Jan Kara <jack@suse.com>
Cc: Mikhail Skorzhinskii <mskorzhinskiy@solarflare.com>
Cc: Vlastimil Babka <vbabka@suse.com>
v2:
If reading the MAC address from eeprom fail don't throw an error, use randomly
generated MAC instead. Either way the adapter will soldier on and the return
type of set_ethernet_addr() can be reverted to void.
v1:
Fix a bug in set_ethernet_addr() which does not take into account possible
errors (or partial reads) returned by its helpers. This can potentially lead to
writing random data into device's MAC address registers.
Signed-off-by: Petko Manolov <petko.manolov@konsulko.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
"Some pin control fixes here. All of them are driver fixes, the Intel
Cherryview being the most interesting one.
- Fix a mux problem for I2C in the MVEBU driver.
- Fix a really hairy inversion problem in the Intel Cherryview
driver.
- Fix the register for the sdc2_clk in the Qualcomm SM8250 driver.
- Check the virtual GPIO boot failur in the Mediatek driver"
* tag 'pinctrl-v5.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: mediatek: check mtk_is_virt_gpio input parameter
pinctrl: qcom: sm8250: correct sdc2_clk
pinctrl: cherryview: Preserve CHV_PADCTRL1_INVRXTX_TXDATA flag on GPIOs
pinctrl: mvebu: Fix i2c sda definition for 98DX3236
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
- Fix rockchip regression in rockchip_pcie_valid_device() (Lorenzo
Pieralisi)
- Add Pali Rohár as aardvark PCI maintainer (Pali Rohár)
* tag 'pci-v5.9-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
MAINTAINERS: Add Pali Rohár as aardvark PCI maintainer
PCI: rockchip: Fix bus checks in rockchip_pcie_valid_device()
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"Two patches in driver frameworks. The iscsi one corrects a bug induced
by a BPF change to network locking and the other is a regression we
introduced"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: iscsi: iscsi_tcp: Avoid holding spinlock while calling getpeername()
scsi: target: Fix lun lookup for TARGET_SCF_LOOKUP_LUN_FROM_TAG case
Current neigh update event handler implementation takes reference to
neighbour structure, assigns it to nhe->n, tries to schedule workqueue task
and releases the reference if task was already enqueued. This results
potentially overwriting existing nhe->n pointer with another neighbour
instance, which causes double release of the instance (once in neigh update
handler that failed to enqueue to workqueue and another one in neigh update
workqueue task that processes updated nhe->n pointer instead of original
one):
[ 3376.512806] ------------[ cut here ]------------
[ 3376.513534] refcount_t: underflow; use-after-free.
[ 3376.521213] Modules linked in: act_skbedit act_mirred act_tunnel_key vxlan ip6_udp_tunnel udp_tunnel nfnetlink act_gact cls_flower sch_ingress openvswitch nsh nf_conncount nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mlx5_ib mlx5_core mlxfw pci_hyperv_intf ptp pps_core nfsv3 nfs_acl rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd
grace fscache ib_isert iscsi_target_mod ib_srpt target_core_mod ib_srp rpcrdma rdma_ucm ib_umad ib_ipoib ib_iser rdma_cm ib_cm iw_cm rfkill ib_uverbs ib_core sunrpc kvm_intel kvm iTCO_wdt iTCO_vendor_support virtio_net irqbypass net_failover crc32_pclmul lpc_ich i2c_i801 failover pcspkr i2c_smbus mfd_core ghash_clmulni_intel sch_fq_codel drm i2c
_core ip_tables crc32c_intel serio_raw [last unloaded: mlxfw]
[ 3376.529468] CPU: 8 PID: 22756 Comm: kworker/u20:5 Not tainted 5.9.0-rc5+ #6
[ 3376.530399] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
[ 3376.531975] Workqueue: mlx5e mlx5e_rep_neigh_update [mlx5_core]
[ 3376.532820] RIP: 0010:refcount_warn_saturate+0xd8/0xe0
[ 3376.533589] Code: ff 48 c7 c7 e0 b8 27 82 c6 05 0b b6 09 01 01 e8 94 93 c1 ff 0f 0b c3 48 c7 c7 88 b8 27 82 c6 05 f7 b5 09 01 01 e8 7e 93 c1 ff <0f> 0b c3 0f 1f 44 00 00 8b 07 3d 00 00 00 c0 74 12 83 f8 01 74 13
[ 3376.536017] RSP: 0018:ffffc90002a97e30 EFLAGS: 00010286
[ 3376.536793] RAX: 0000000000000000 RBX: ffff8882de30d648 RCX: 0000000000000000
[ 3376.537718] RDX: ffff8882f5c28f20 RSI: ffff8882f5c18e40 RDI: ffff8882f5c18e40
[ 3376.538654] RBP: ffff8882cdf56c00 R08: 000000000000c580 R09: 0000000000001a4d
[ 3376.539582] R10: 0000000000000731 R11: ffffc90002a97ccd R12: 0000000000000000
[ 3376.540519] R13: ffff8882de30d600 R14: ffff8882de30d640 R15: ffff88821e000900
[ 3376.541444] FS: 0000000000000000(0000) GS:ffff8882f5c00000(0000) knlGS:0000000000000000
[ 3376.542732] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3376.543545] CR2: 0000556e5504b248 CR3: 00000002c6f10005 CR4: 0000000000770ee0
[ 3376.544483] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 3376.545419] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 3376.546344] PKRU: 55555554
[ 3376.546911] Call Trace:
[ 3376.547479] mlx5e_rep_neigh_update.cold+0x33/0xe2 [mlx5_core]
[ 3376.548299] process_one_work+0x1d8/0x390
[ 3376.548977] worker_thread+0x4d/0x3e0
[ 3376.549631] ? rescuer_thread+0x3e0/0x3e0
[ 3376.550295] kthread+0x118/0x130
[ 3376.550914] ? kthread_create_worker_on_cpu+0x70/0x70
[ 3376.551675] ret_from_fork+0x1f/0x30
[ 3376.552312] ---[ end trace d84e8f46d2a77eec ]---
Fix the bug by moving work_struct to dedicated dynamically-allocated
structure. This enabled every event handler to work on its own private
neighbour pointer and removes the need for handling the case when task is
already enqueued.
Fixes: 232c001398ae ("net/mlx5e: Add support to neighbour update flow")
Signed-off-by: Vlad Buslov <vladbu@nvidia.com>
Reviewed-by: Roi Dayan <roid@nvidia.com>
Signed-off-by: Saeed Mahameed <saeedm@nvidia.com>
When interface is attached while in promiscuous mode and with VLAN
filtering turned off, both configurations are not respected and VLAN
filtering is performed.
There are 2 flows which add the any-vid rules during interface attach:
VLAN creation table and set rx mode. Each is relaying on the other to
add any-vid rules, eventually non of them does.
Fix this by adding any-vid rules on VLAN creation regardless of
promiscuous mode.
Fixes: 9df30601c843 ("net/mlx5e: Restore vlan filter after seamless reset")
Signed-off-by: Aya Levin <ayal@nvidia.com>
Reviewed-by: Moshe Shemesh <moshe@nvidia.com>
Prior to this patch unloading an interface in promiscuous mode with RX
VLAN filtering feature turned off - resulted in a warning. This is due
to a wrong condition in the VLAN rules cleanup flow, which left the
any-vid rules in the VLAN steering table. These rules prevented
destroying the flow group and the flow table.
The any-vid rules are removed in 2 flows, but none of them remove it in
case both promiscuous is set and VLAN filtering is off. Fix the issue by
changing the condition of the VLAN table cleanup flow to clean also in
case of promiscuous mode.
mlx5_core 0000:00:08.0: mlx5_destroy_flow_group:2123:(pid 28729): Flow group 20 wasn't destroyed, refcount > 1
mlx5_core 0000:00:08.0: mlx5_destroy_flow_group:2123:(pid 28729): Flow group 19 wasn't destroyed, refcount > 1
mlx5_core 0000:00:08.0: mlx5_destroy_flow_table:2112:(pid 28729): Flow table 262149 wasn't destroyed, refcount > 1
FW pages counter is 11560 after reclaiming all pages
WARNING: CPU: 1 PID: 28729 at
drivers/net/ethernet/mellanox/mlx5/core/pagealloc.c:660
mlx5_reclaim_startup_pages+0x178/0x230 [mlx5_core]
Call Trace:
mlx5_function_teardown+0x2f/0x90 [mlx5_core]
mlx5_unload_one+0x71/0x110 [mlx5_core]
remove_one+0x44/0x80 [mlx5_core]
pci_device_remove+0x3e/0xc0
device_release_driver_internal+0xfb/0x1c0
device_release_driver+0x12/0x20
pci_stop_bus_device+0x68/0x90
pci_stop_and_remove_bus_device+0x12/0x20
hv_eject_device_work+0x6f/0x170 [pci_hyperv]
? __schedule+0x349/0x790
process_one_work+0x206/0x400
worker_thread+0x34/0x3f0
? process_one_work+0x400/0x400
kthread+0x126/0x140
? kthread_park+0x90/0x90
ret_from_fork+0x22/0x30
---[ end trace 6283bde8d26170dc ]---
Verify the configured FEC mode is supported by at least a single link
mode before applying the command. Otherwise fail the command and return
"Operation not supported".
Prior to this patch, the command was successful, yet it falsely set all
link modes to FEC auto mode - like configuring FEC mode to auto. Auto
mode is the default configuration if a link mode doesn't support the
configured FEC mode.
Fixes: b5ede32d3329 ("net/mlx5e: Add support for FEC modes based on 50G per lane links")
Signed-off-by: Aya Levin <ayal@mellanox.com>
Reviewed-by: Eran Ben Elisha <eranbe@nvidia.com>
Declare GRE offload support with respect to the inner protocol. Add a
list of supported inner protocols on which the driver can offload
checksum and GSO. For other protocols, inform the stack to do the needed
operations. There is no noticeable impact on GRE performance.
Fixes: 2729984149e6 ("net/mlx5e: Support TSO and TX checksum offloads for GRE tunnels")
Reviewed-by: Tariq Toukan <tariqt@nvidia.com>
The cited commit introduced the following coverity issue at function
mlx5_tc_ct_rule_to_tuple_nat:
- Memory - corruptions (OVERRUN)
Overrunning array "tuple->ip.src_v6.in6_u.u6_addr32" of 4 4-byte
elements at element index 7 (byte offset 31) using index
"ip6_offset" (which evaluates to 7).
In case of IPv6 destination address rewrite, ip6_offset values are
between 4 to 7, which will cause memory overrun of array
"tuple->ip.src_v6.in6_u.u6_addr32" to array
"tuple->ip.dst_v6.in6_u.u6_addr32".
Fixed by writing the value directly to array
"tuple->ip.dst_v6.in6_u.u6_addr32" in case ip6_offset values are
between 4 to 7.
Fixes: bc562be9674b ("net/mlx5e: CT: Save ct entries tuples in hashtables")
Signed-off-by: Maor Dickman <maord@nvidia.com>
