path: root/drivers
2021-12-01usb: dwc2: hcd_queue: Fix use of floating point literalNathan Chancellor
commit 310780e825f3ffd211b479b8f828885a6faedd63 upstream. A new commit in LLVM causes an error on the use of 'long double' when '-mno-x87' is used, which the kernel does through an alias, '-mno-80387' (see the LLVM commit below for more details around why it does this). drivers/usb/dwc2/hcd_queue.c:1744:25: error: expression requires 'long double' type support, but target 'x86_64-unknown-linux-gnu' does not support it delay = ktime_set(0, DWC2_RETRY_WAIT_DELAY); ^ drivers/usb/dwc2/hcd_queue.c:62:34: note: expanded from macro 'DWC2_RETRY_WAIT_DELAY' #define DWC2_RETRY_WAIT_DELAY (1 * 1E6L) ^ 1 error generated. This happens due to the use of a 'long double' literal. The 'E6' part of '1E6L' causes the literal to be a 'double' then the 'L' suffix promotes it to 'long double'. There is no visible reason for a floating point value in this driver, as the value is only used as a parameter to a function that expects an integer type. Use NSEC_PER_MSEC, which is the same integer value as '1E6L', to avoid changing functionality but fix the error. Link: https://github.com/ClangBuiltLinux/linux/issues/1497 Link: https://github.com/llvm/llvm-project/commit/a8083d42b1c346e21623a1d36d1f0cadd7801d83 Fixes: 6ed30a7d8ec2 ("usb: dwc2: host: use hrtimer for NAK retries") Cc: stable <stable@vger.kernel.org> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: John Keeping <john@metanate.com> Acked-by: Minas Harutyunyan <Minas.Harutyunyan@synopsys.com> Signed-off-by: Nathan Chancellor <nathan@kernel.org> Link: https://lore.kernel.org/r/20211105145802.2520658-1-nathan@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01usb: dwc2: gadget: Fix ISOC flow for elapsed framesMinas Harutyunyan
commit 7ad4a0b1d46b2612f4429a72afd8f137d7efa9a9 upstream. Added updating of request frame number for elapsed frames, otherwise frame number will remain as previous use of request. This will allow function driver to correctly track frames in case of Missed ISOC occurs. Added setting request actual length to 0 for elapsed frames. In Slave mode when pushing data to RxFIFO by dwords, request actual length incrementing accordingly. But before whole packet will be pushed into RxFIFO and send to host can occurs Missed ISOC and data will not send to host. So, in this case request actual length should be reset to 0. Fixes: 91bb163e1e4f ("usb: dwc2: gadget: Fix ISOC flow for BDMA and Slave") Cc: stable <stable@vger.kernel.org> Reviewed-by: John Keeping <john@metanate.com> Signed-off-by: Minas Harutyunyan <Minas.Harutyunyan@synopsys.com> Link: https://lore.kernel.org/r/c356baade6e9716d312d43df08d53ae557cb8037.1636011277.git.Minas.Harutyunyan@synopsys.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01USB: serial: option: add Fibocom FM101-GL variantsMingjie Zhang
commit 88459e3e42760abb2299bbf6cb1026491170e02a upstream. Update the USB serial option driver support for the Fibocom FM101-GL Cat.6 LTE modules as there are actually several different variants. - VID:PID 2cb7:01a2, FM101-GL are laptop M.2 cards (with MBIM interfaces for /Linux/Chrome OS) - VID:PID 2cb7:01a4, FM101-GL for laptop debug M.2 cards(with adb interface for /Linux/Chrome OS) 0x01a2: mbim, tty, tty, diag, gnss 0x01a4: mbim, diag, tty, adb, gnss, gnss Here are the outputs of lsusb -v and usb-devices: T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 86 Spd=5000 MxCh= 0 D: Ver= 3.20 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1 P: Vendor=2cb7 ProdID=01a2 Rev= 5.04 S: Manufacturer=Fibocom Wireless Inc. S: Product=Fibocom FM101-GL Module S: SerialNumber=673326ce C:* #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=896mA A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00 I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=(none) I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=(none) I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=(none) I:* If#= 5 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=40 Driver=(none) Bus 002 Device 084: ID 2cb7:01a2 Fibocom Wireless Inc. Fibocom FM101-GL Module Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.20 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 9 idVendor 0x2cb7 idProduct 0x01a2 bcdDevice 5.04 iManufacturer 1 Fibocom Wireless Inc. iProduct 2 Fibocom FM101-GL Module iSerial 3 673326ce bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x015d bNumInterfaces 6 bConfigurationValue 1 iConfiguration 4 MBIM_DUN_DUN_DIAG_NMEA bmAttributes 0xa0 (Bus Powered) Remote Wakeup MaxPower 896mA Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 0 bInterfaceCount 2 bFunctionClass 2 Communications bFunctionSubClass 14 bFunctionProtocol 0 iFunction 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 14 bInterfaceProtocol 0 iInterface 5 Fibocom FM101-GL LTE Modem CDC Header: bcdCDC 1.10 CDC Union: bMasterInterface 0 bSlaveInterface 1 CDC MBIM: bcdMBIMVersion 1.00 wMaxControlMessage 4096 bNumberFilters 32 bMaxFilterSize 128 wMaxSegmentSize 2048 bmNetworkCapabilities 0x20 8-byte ntb input size CDC MBIM Extended: bcdMBIMExtendedVersion 1.00 bMaxOutstandingCommandMessages 64 wMTU 1500 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 9 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 0 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 bInterfaceProtocol 2 iInterface 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 1 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 bInterfaceProtocol 2 iInterface 6 MBIM Data Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x8e EP 14 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 6 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x0f EP 15 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 2 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 2 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 3 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x85 EP 5 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 4 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 48 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x86 EP 6 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 5 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x88 EP 8 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x87 EP 7 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x04 EP 4 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 85 Spd=5000 MxCh= 0 D: Ver= 3.20 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1 P: Vendor=2cb7 ProdID=01a4 Rev= 5.04 S: Manufacturer=Fibocom Wireless Inc. S: Product=Fibocom FM101-GL Module S: SerialNumber=673326ce C:* #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=896mA A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00 I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=(none) I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=(none) I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none) I:* If#= 5 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=40 Driver=(none) I:* If#= 6 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=40 Driver=(none) Bus 002 Device 085: ID 2cb7:01a4 Fibocom Wireless Inc. Fibocom FM101-GL Module Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.20 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 9 idVendor 0x2cb7 idProduct 0x01a4 bcdDevice 5.04 iManufacturer 1 Fibocom Wireless Inc. iProduct 2 Fibocom FM101-GL Module iSerial 3 673326ce bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0180 bNumInterfaces 7 bConfigurationValue 1 iConfiguration 4 MBIM_DIAG_DUN_ADB_GNSS_GNSS bmAttributes 0xa0 (Bus Powered) Remote Wakeup MaxPower 896mA Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 0 bInterfaceCount 2 bFunctionClass 2 Communications bFunctionSubClass 14 bFunctionProtocol 0 iFunction 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 14 bInterfaceProtocol 0 iInterface 5 Fibocom FM101-GL LTE Modem CDC Header: bcdCDC 1.10 CDC Union: bMasterInterface 0 bSlaveInterface 1 CDC MBIM: bcdMBIMVersion 1.00 wMaxControlMessage 4096 bNumberFilters 32 bMaxFilterSize 128 wMaxSegmentSize 2048 bmNetworkCapabilities 0x20 8-byte ntb input size CDC MBIM Extended: bcdMBIMExtendedVersion 1.00 bMaxOutstandingCommandMessages 64 wMTU 1500 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 9 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 0 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 bInterfaceProtocol 2 iInterface 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 1 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 bInterfaceProtocol 2 iInterface 6 MBIM Data Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x8e EP 14 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 6 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x0f EP 15 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 2 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 2 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 48 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 3 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 4 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 66 bInterfaceProtocol 1 iInterface 8 ADB Interface Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x85 EP 5 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 5 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x87 EP 7 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x86 EP 6 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x04 EP 4 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 6 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 64 iInterface 0 ** UNRECOGNIZED: 05 24 00 10 01 ** UNRECOGNIZED: 05 24 01 00 00 ** UNRECOGNIZED: 04 24 02 02 ** UNRECOGNIZED: 05 24 06 00 00 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x89 EP 9 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x000a 1x 10 bytes bInterval 9 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x88 EP 8 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x05 EP 5 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 0 Signed-off-by: Mingjie Zhang <superzmj@fibocom.com> Link: https://lore.kernel.org/r/20211123133757.37475-1-superzmj@fibocom.com Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01USB: serial: option: add Telit LE910S1 0x9200 compositionDaniele Palmas
commit e353f3e88720300c3d72f49a4bea54f42db1fa5e upstream. Add the following Telit LE910S1 composition: 0x9200: tty Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Link: https://lore.kernel.org/r/20211119140319.10448-1-dnlplm@gmail.com Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01USB: serial: pl2303: fix GC type detectionJohan Hovold
commit aa5721a9e0c9fb8a4bdfe0c8751377cd537d6174 upstream. At least some PL2303GC have a bcdDevice of 0x105 instead of 0x100 as the datasheet claims. Add it to the list of known release numbers for the HXN (G) type. Note the chip type could only be determined indirectly based on its package being of QFP type, which appears to only be available for PL2303GC. Fixes: 894758d0571d ("USB: serial: pl2303: tighten type HXN (G) detection") Cc: stable@vger.kernel.org # 5.13 Reported-by: Anton Lundin <glance@acc.umu.se> Link: https://lore.kernel.org/r/20211123071613.GZ108031@montezuma.acc.umu.se Link: https://lore.kernel.org/r/20211123091017.30708-1-johan@kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01ACPI: CPPC: Add NULL pointer check to cppc_get_perf()Rafael J. Wysocki
commit 935dff305da2be7957a5ce8f07f45d6c4c1c6984 upstream. Check cpc_desc against NULL in cppc_get_perf(), so it doesn't crash down the road if cpc_desc is NULL. Fixes: 0654cf05d17b ("ACPI: CPPC: Introduce cppc_get_nominal_perf()") Reported-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 5.15+ <stable@vger.kernel.org> # 5.15+ Tested-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01ACPI: Get acpi_device's parent from the parent fieldSakari Ailus
commit 9054fc6d57e80c27c0b0632966416144f2092c2b upstream. Printk modifier %pfw is used to print the full path of the device name. This is obtained device by device until a device no longer has a parent. On ACPI getting the parent fwnode is done by calling acpi_get_parent() which tries to down() a semaphore. But local IRQs are now disabled in vprintk_store() before the mutex is acquired. This is obviously a problem. Luckily struct device, embedded in struct acpi_device, has a parent field already. Use that field to get the parent instead of relying on acpi_get_parent(). Fixes: 3bd32d6a2ee6 ("lib/vsprintf: Add %pfw conversion specifier for printing fwnode names") Cc: 5.5+ <stable@vger.kernel.org> # 5.5+ Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-12-01scsi: sd: Fix sd_do_mode_sense() buffer length handlingDamien Le Moal
commit c749301ebee82eb5e97dec14b6ab31a4aabe37a6 upstream. For devices that explicitly asked for MODE SENSE(10) use, make sure that scsi_mode_sense() is called with a buffer of at least 8 bytes so that the sense header fits. Link: https://lore.kernel.org/r/20210820070255.682775-4-damien.lemoal@wdc.com Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25ice: Delete always true check of PF pointerLeon Romanovsky
commit 2ff04286a9569675948f39cec2c6ad47c3584633 upstream. PF pointer is always valid when PCI core calls its .shutdown() and .remove() callbacks. There is no need to check it again. Fixes: 837f08fdecbe ("ice: Add basic driver framework for Intel(R) E800 Series") Signed-off-by: Leon Romanovsky <leonro@nvidia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25ice: Fix VF true promiscuous modeBrett Creeley
commit 1a8c7778bcde5981463a5b9f9b2caa44a327ff93 upstream. When a VF requests promiscuous mode and it's trusted and true promiscuous mode is enabled the PF driver attempts to enable unicast and/or multicast promiscuous mode filters based on the request. This is fine, but there are a couple issues with the current code. [1] The define to configure the unicast promiscuous mode mask also includes bits to configure the multicast promiscuous mode mask, which causes multicast to be set/cleared unintentionally. [2] All 4 cases for enable/disable unicast/multicast mode are not handled in the promiscuous mode message handler, which causes unexpected results regarding the current promiscuous mode settings. To fix [1] make sure any promiscuous mask defines include the correct bits for each of the promiscuous modes. To fix [2] make sure that all 4 cases are handled since there are 2 bits (FLAG_VF_UNICAST_PROMISC and FLAG_VF_MULTICAST_PROMISC) that can be either set or cleared. Also, since either unicast and/or multicast promiscuous configuration can fail, introduce two separate error values to handle each of these cases. Fixes: 01b5e89aab49 ("ice: Add VF promiscuous support") Signed-off-by: Brett Creeley <brett.creeley@intel.com> Tested-by: Tony Brelinski <tony.brelinski@intel.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25usb: max-3421: Use driver data instead of maintaining a list of bound devicesUwe Kleine-König
commit fc153aba3ef371d0d76eb88230ed4e0dee5b38f2 upstream. Instead of maintaining a single-linked list of devices that must be searched linearly in .remove() just use spi_set_drvdata() to remember the link between the spi device and the driver struct. Then the global list and the next member can be dropped. This simplifies the driver, reduces the memory footprint and the time to search the list. Also it makes obvious that there is always a corresponding driver struct for a given device in .remove(), so the error path for !max3421_hcd can be dropped, too. As a side effect this fixes a data inconsistency when .probe() races with itself for a second max3421 device in manipulating max3421_hcd_list. A similar race is fixed in .remove(), too. Fixes: 2d53139f3162 ("Add support for using a MAX3421E chip as a host driver.") Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Link: https://lore.kernel.org/r/20211018204028.2914597-1-u.kleine-koenig@pengutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/amd/pm: avoid duplicate powergate/ungate settingEvan Quan
commit 6ee27ee27ba8b2e725886951ba2d2d87f113bece upstream. Just bail out if the target IP block is already in the desired powergate/ungate state. This can avoid some duplicate settings which sometimes may cause unexpected issues. Link: https://lore.kernel.org/all/YV81vidWQLWvATMM@zn.tnic/ Bug: https://bugzilla.kernel.org/show_bug.cgi?id=214921 Bug: https://bugzilla.kernel.org/show_bug.cgi?id=215025 Bug: https://gitlab.freedesktop.org/drm/amd/-/issues/1789 Fixes: bf756fb833cb ("drm/amdgpu: add missing cleanups for Polaris12 UVD/VCE on suspend") Signed-off-by: Evan Quan <evan.quan@amd.com> Tested-by: Borislav Petkov <bp@suse.de> Reviewed-by: Lijo Lazar <lijo.lazar@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/amdgpu: fix set scaling mode Full/Full aspect/Center not works on vga ↵hongao
and dvi connectors commit bf552083916a7f8800477b5986940d1c9a31b953 upstream. amdgpu_connector_vga_get_modes missed function amdgpu_get_native_mode which assign amdgpu_encoder->native_mode with *preferred_mode result in amdgpu_encoder->native_mode.clock always be 0. That will cause amdgpu_connector_set_property returned early on: if ((rmx_type != DRM_MODE_SCALE_NONE) && (amdgpu_encoder->native_mode.clock == 0)) when we try to set scaling mode Full/Full aspect/Center. Add the missing function to amdgpu_connector_vga_get_mode can fix this. It also works on dvi connectors because amdgpu_connector_dvi_helper_funcs.get_mode use the same method. Signed-off-by: hongao <hongao@uniontech.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915: Fix type1 DVI DP dual mode adapter heuristic for modern platformsVille Syrjälä
commit 1977e8eb40ed53f0cac7db1a78295726f4ac0b24 upstream. Looks like we never updated intel_bios_is_port_dp_dual_mode() when the VBT port mapping became erratic on modern platforms. This is causing us to look up the wrong child device and thus throwing the heuristic off (ie. we might end looking at a child device for a genuine DP++ port when we were supposed to look at one for a native HDMI port). Fix it up by not using the outdated port_mapping[] in intel_bios_is_port_dp_dual_mode() and rely on intel_bios_encoder_data_lookup() instead. Cc: stable@vger.kernel.org Tested-by: Randy Dunlap <rdunlap@infradead.org> Closes: https://gitlab.freedesktop.org/drm/intel/-/issues/4138 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20211025142147.23897-1-ville.syrjala@linux.intel.com Reviewed-by: Jani Nikula <jani.nikula@intel.com> (cherry picked from commit 32c2bc89c7420fad2959ee23ef5b6be8b05d2bde) Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/dp: Ensure max link params are always validImre Deak
commit cc99bc62ff6902688ee7bd3a7b25eefc620fbb6a upstream. Atm until the DPCD for a connector is read the max link rate and lane count params are invalid. If the connector is modeset, in intel_dp_compute_config(), intel_dp_common_len_rate_limit(max_link_rate) will return 0, leading to a intel_dp->common_rates[-1] access. Fix the above by making sure the max link params are always valid. The above access leads to an undefined behaviour by definition, though not causing a user visible problem to my best knowledge, see the previous patch why. Nevertheless it is an undefined behaviour and it triggers a BUG() in CONFIG_UBSAN builds, hence CC:stable. Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20211018094154.1407705-4-imre.deak@intel.com (cherry picked from commit 9ad87de4735620ffc555592e8c5f580478fa3ed0) Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/dp: Ensure sink rate values are always validImre Deak
commit 6c34bd4532a3f39952952ddc102737595729afc4 upstream. Atm, there are no sink rate values set for DP (vs. eDP) sinks until the DPCD capabilities are successfully read from the sink. During this time intel_dp->num_common_rates is 0 which can lead to a intel_dp->common_rates[-1] (*) access, which is an undefined behaviour, in the following cases: - In intel_dp_sync_state(), if the encoder is enabled without a sink connected to the encoder's connector (BIOS enabled a monitor, but the user unplugged the monitor until the driver loaded). - In intel_dp_sync_state() if the encoder is enabled with a sink connected, but for some reason the DPCD read has failed. - In intel_dp_compute_link_config() if modesetting a connector without a sink connected on it. - In intel_dp_compute_link_config() if modesetting a connector with a a sink connected on it, but before probing the connector first. To avoid the (*) access in all the above cases, make sure that the sink rate table - and hence the common rate table - is always valid, by setting a default minimum sink rate when registering the connector before anything could use it. I also considered setting all the DP link rates by default, so that modesetting with higher resolution modes also succeeds in the last two cases above. However in case a sink is not connected that would stop working after the first modeset, due to the LT fallback logic. So this would need more work, beyond the scope of this fix. As I mentioned in the previous patch, I don't think the issue this patch fixes is user visible, however it is an undefined behaviour by definition and triggers a BUG() in CONFIG_UBSAN builds, hence CC:stable. v2: Clear the default sink rates, before initializing these for eDP. Closes: https://gitlab.freedesktop.org/drm/intel/-/issues/4297 References: https://gitlab.freedesktop.org/drm/intel/-/issues/4298 Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20211018143417.1452632-1-imre.deak@intel.com (cherry picked from commit 3f61ef9777c0ab0f03f4af0ed6fd3e5250537a8d) Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/nouveau: clean up all clients on device removalJeremy Cline
commit f55aaf63bde0d0336c3823bb3713bd4a464abbcf upstream. The postclose handler can run after the device has been removed (or the driver has been unbound) since userspace clients are free to hold the file open as long as they want. Because the device removal callback frees the entire nouveau_drm structure, any reference to it in the postclose handler will result in a use-after-free. To reproduce this, one must simply open the device file, unbind the driver (or physically remove the device), and then close the device file. This was found and can be reproduced easily with the IGT core_hotunplug tests. To avoid this, all clients are cleaned up in the device finalization rather than deferring it to the postclose handler, and the postclose handler is protected by a critical section which ensures the drm_dev_unplug() and the postclose handler won't race. This is not an ideal fix, since as I understand the proposed plan for the kernel<->userspace interface for hotplug support, destroying the client before the file is closed will cause problems. However, I believe to properly fix this issue, the lifetime of the nouveau_drm structure needs to be extended to match the drm_device, and this proved to be a rather invasive change. Thus, I've broken this out so the fix can be easily backported. This fixes with the two previous commits CVE-2020-27820 (Karol). Cc: stable@vger.kernel.org # 5.4+ Signed-off-by: Jeremy Cline <jcline@redhat.com> Reviewed-by: Lyude Paul <lyude@redhat.com> Reviewed-by: Ben Skeggs <bskeggs@redhat.com> Tested-by: Karol Herbst <kherbst@redhat.com> Signed-off-by: Karol Herbst <kherbst@redhat.com> Link: https://patchwork.freedesktop.org/patch/msgid/20201125202648.5220-4-jcline@redhat.com Link: https://gitlab.freedesktop.org/drm/nouveau/-/merge_requests/14 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/nouveau: use drm_dev_unplug() during device removalJeremy Cline
commit aff2299e0d81b26304ccc6a1ec0170e437f38efc upstream. Nouveau does not currently support hot-unplugging, but it still makes sense to switch from drm_dev_unregister() to drm_dev_unplug(). drm_dev_unplug() calls drm_dev_unregister() after marking the device as unplugged, but only after any device critical sections are finished. Since nouveau isn't using drm_dev_enter() and drm_dev_exit(), there are no critical sections so this is nearly functionally equivalent. However, the DRM layer does check to see if the device is unplugged, and if it is returns appropriate error codes. In the future nouveau can add critical sections in order to truly support hot-unplugging. Cc: stable@vger.kernel.org # 5.4+ Signed-off-by: Jeremy Cline <jcline@redhat.com> Reviewed-by: Lyude Paul <lyude@redhat.com> Reviewed-by: Ben Skeggs <bskeggs@redhat.com> Tested-by: Karol Herbst <kherbst@redhat.com> Signed-off-by: Karol Herbst <kherbst@redhat.com> Link: https://patchwork.freedesktop.org/patch/msgid/20201125202648.5220-2-jcline@redhat.com Link: https://gitlab.freedesktop.org/drm/nouveau/-/merge_requests/14 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/nouveau: Add a dedicated mutex for the clients listJeremy Cline
commit abae9164a421bc4a41a3769f01ebcd1f9d955e0e upstream. Rather than protecting the nouveau_drm clients list with the lock within the "client" nouveau_cli, add a dedicated lock to serialize access to the list. This is both clearer and necessary to avoid lockdep being upset with us when we need to iterate through all the clients in the list and potentially lock their mutex, which is the same class as the lock protecting the entire list. Cc: stable@vger.kernel.org # 5.4+ Signed-off-by: Jeremy Cline <jcline@redhat.com> Reviewed-by: Lyude Paul <lyude@redhat.com> Reviewed-by: Ben Skeggs <bskeggs@redhat.com> Tested-by: Karol Herbst <kherbst@redhat.com> Signed-off-by: Karol Herbst <kherbst@redhat.com> Link: https://patchwork.freedesktop.org/patch/msgid/20201125202648.5220-3-jcline@redhat.com Link: https://gitlab.freedesktop.org/drm/nouveau/-/merge_requests/14 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/prime: Fix use after free in mmap with drm_gem_ttm_mmapAnand K Mistry
commit 8244a3bc27b3efd057da154b8d7e414670d5044f upstream. drm_gem_ttm_mmap() drops a reference to the gem object on success. If the gem object's refcount == 1 on entry to drm_gem_prime_mmap(), that drop will free the gem object, and the subsequent drm_gem_object_get() will be a UAF. Fix by grabbing a reference before calling the mmap helper. This issue was forseen when the reference dropping was adding in commit 9786b65bc61ac ("drm/ttm: fix mmap refcounting"): "For that to work properly the drm_gem_object_get() call in drm_gem_ttm_mmap() must be moved so it happens before calling obj->funcs->mmap(), otherwise the gem refcount would go down to zero." Signed-off-by: Anand K Mistry <amistry@google.com> Fixes: 9786b65bc61a ("drm/ttm: fix mmap refcounting") Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Maxime Ripard <mripard@kernel.org> Cc: Thomas Zimmermann <tzimmermann@suse.de> Cc: David Airlie <airlied@linux.ie> Cc: Daniel Vetter <daniel@ffwll.ch> Cc: dri-devel@lists.freedesktop.org Cc: <stable@vger.kernel.org> # v5.5+ Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de> Link: https://patchwork.freedesktop.org/patch/msgid/20210930085932.1.I8043d61cc238e0168e2f4ca5f4783223434aa587@changeid Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/udl: fix control-message timeoutJohan Hovold
commit 5591c8f79db1729d9c5ac7f5b4d3a5c26e262d93 upstream. USB control-message timeouts are specified in milliseconds and should specifically not vary with CONFIG_HZ. Fixes: 5320918b9a87 ("drm/udl: initial UDL driver (v4)") Cc: stable@vger.kernel.org # 3.4 Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: https://patchwork.freedesktop.org/patch/msgid/20211025115353.5089-1-johan@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/guc: Unwind context requests in reverse orderMatthew Brost
commit c39f51cc980dd918c5b3da61d54c4725785e766e upstream. When unwinding requests on a reset context, if other requests in the context are in the priority list the requests could be resubmitted out of seqno order. Traverse the list of active requests in reverse and append to the head of the priority list to fix this. Fixes: eb5e7da736f3 ("drm/i915/guc: Reset implementation for new GuC interface") Signed-off-by: Matthew Brost <matthew.brost@intel.com> Reviewed-by: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: John Harrison <John.C.Harrison@Intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20210909164744.31249-4-matthew.brost@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/guc: Don't drop ce->guc_active.lock when unwinding contextMatthew Brost
commit 88209a8ecb8b8752322908a3c3362a001bdc3a39 upstream. Don't drop ce->guc_active.lock when unwinding a context after reset. At one point we had to drop this because of a lock inversion but that is no longer the case. It is much safer to hold the lock so let's do that. Fixes: eb5e7da736f3 ("drm/i915/guc: Reset implementation for new GuC interface") Reviewed-by: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com> Signed-off-by: Matthew Brost <matthew.brost@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: John Harrison <John.C.Harrison@Intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20210909164744.31249-5-matthew.brost@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/guc: Workaround reset G2H is received after schedule done G2HMatthew Brost
commit 1ca36cff0166b0483fe3b99e711e9c800ebbfaa4 upstream. If the context is reset as a result of the request cancellation the context reset G2H is received after schedule disable done G2H which is the wrong order. The schedule disable done G2H release the waiting request cancellation code which resubmits the context. This races with the context reset G2H which also wants to resubmit the context but in this case it really should be a NOP as request cancellation code owns the resubmit. Use some clever tricks of checking the context state to seal this race until the GuC firmware is fixed. v2: (Checkpatch) - Fix typos v3: (Daniele) - State that is a bug in the GuC firmware Fixes: 62eaf0ae217d ("drm/i915/guc: Support request cancellation") Signed-off-by: Matthew Brost <matthew.brost@intel.com> Cc: <stable@vger.kernel.org> Reviewed-by: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com> Signed-off-by: John Harrison <John.C.Harrison@Intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20210909164744.31249-7-matthew.brost@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/guc: Don't enable scheduling on a banned context, guc_id invalid, ↵Matthew Brost
not registered commit 9888beaaf118b6878347e1fe2b369fc66d756d18 upstream. When unblocking a context, do not enable scheduling if the context is banned, guc_id invalid, or not registered. v2: (Daniele) - Add helper for unblock Fixes: 62eaf0ae217d ("drm/i915/guc: Support request cancellation") Signed-off-by: Matthew Brost <matthew.brost@intel.com> Reviewed-by: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: John Harrison <John.C.Harrison@Intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20210909164744.31249-10-matthew.brost@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/i915/guc: Fix outstanding G2H accountingMatthew Brost
commit 669b949c1a44d0cb2bcd18ff6ab4fd0c21e7cf6f upstream. A small race that could result in incorrect accounting of the number of outstanding G2H. Basically prior to this patch we did not increment the number of outstanding G2H if we encoutered a GT reset while sending a H2G. This was incorrect as the context state had already been updated to anticipate a G2H response thus the counter should be incremented. As part of this change we remove a legacy (now unused) path that was the last caller requiring a G2H response that was not guaranteed to loop. This allows us to simplify the accounting as we don't need to handle the case where the send fails due to the channel being busy. Also always use helper when decrementing this value. v2 (Daniele): update GEM_BUG_ON check, pull in dead code removal from later patch, remove loop param from context_deregister. Fixes: f4eb1f3fe946 ("drm/i915/guc: Ensure G2H response has space in buffer") Signed-off-by: Matthew Brost <matthew.brost@intel.com> Signed-off-by: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com> Cc: <stable@vger.kernel.org> Reviewed-by: John Harrison <John.C.Harrison@Intel.com> Signed-off-by: John Harrison <John.C.Harrison@Intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20210909164744.31249-3-matthew.brost@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/amd/display: Limit max DSC target bpp for specific monitorsRoman Li
commit 55eea8ef98641f6e1e1c202bd3a49a57c1dd4059 upstream. [Why] Some monitors exhibit corruption at 16bpp DSC. [How] - Add helpers for patching edid caps. - Use it for limiting DSC target bitrate to 15bpp for known monitors Reviewed-by: Rodrigo Siqueira <Rodrigo.Siqueira@amd.com> Acked-by: Qingqing Zhuo <qingqing.zhuo@amd.com> Signed-off-by: Roman Li <Roman.Li@amd.com> Cc: stable@vger.kernel.org Tested-by: Daniel Wheeler <Daniel.Wheeler@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/amd/display: Update swizzle mode enumsAlvin Lee
commit 58065a1e524de30df9a2d8214661d5d7eed0a2d9 upstream. [Why] Swizzle mode enum for DC_SW_VAR_R_X was existing, but not mapped correctly. [How] Update mapping and conversion for DC_SW_VAR_R_X. Reviewed-by: XiangBing Foo <XiangBing.Foo@amd.com> Reviewed-by: Martin Leung <Martin.Leung@amd.com> Acked-by: Qingqing Zhuo <qingqing.zhuo@amd.com> Signed-off-by: Alvin Lee <Alvin.Lee2@amd.com> Cc: stable@vger.kernel.org Tested-by: Daniel Wheeler <Daniel.Wheeler@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25parisc/sticon: fix reverse colorsSven Schnelle
commit bec05f33ebc1006899c6d3e59a00c58881fe7626 upstream. sticon_build_attr() checked the reverse argument and flipped background and foreground color, but returned the non-reverse value afterwards. Fix this and also add two local variables for foreground and background color to make the code easier to read. Signed-off-by: Sven Schnelle <svens@stackframe.org> Cc: <stable@vger.kernel.org> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25net: stmmac: Fix signed/unsigned wreckageThomas Gleixner
commit 3751c3d34cd5a750c86d1c8eaf217d8faf7f9325 upstream. The recent addition of timestamp correction to compensate the CDC error introduced a subtle signed/unsigned bug in stmmac_get_tx_hwtstamp() while it managed for some obscure reason to avoid that in stmmac_get_rx_hwtstamp(). The issue is: s64 adjust = 0; u64 ns; adjust += -(2 * (NSEC_PER_SEC / priv->plat->clk_ptp_rate)); ns += adjust; works by chance on 64bit, but falls apart on 32bit because the compiler knows that adjust fits into 32bit and then treats the addition as a u64 + u32 resulting in an off by ~2 seconds failure. The RX variant uses an u64 for adjust and does the adjustment via ns -= adjust; because consistency is obviously overrated. Get rid of the pointless zero initialized adjust variable and do: ns -= (2 * NSEC_PER_SEC) / priv->plat->clk_ptp_rate; which is obviously correct and spares the adjust obfuscation. Aside of that it yields a more accurate result because the multiplication takes place before the integer divide truncation and not afterwards. Stick the calculation into an inline so it can't be accidentally disimproved. Return an u32 from that inline as the result is guaranteed to fit which lets the compiler optimize the substraction. Cc: stable@vger.kernel.org Fixes: 3600be5f58c1 ("net: stmmac: add timestamp correction to rid CDC sync error") Reported-by: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Benedikt Spranger <b.spranger@linutronix.de> Tested-by: Kurt Kanzenbach <kurt@linutronix.de> # Intel EHL Link: https://lore.kernel.org/r/87mtm578cs.ffs@tglx Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25Drivers: hv: balloon: Use VMBUS_RING_SIZE() wrapper for dm_ring_sizeBoqun Feng
commit 8a7eb2d476c6823cd44d8c25a6230a52417d7ef8 upstream. Baihua reported an error when boot an ARM64 guest with PAGE_SIZE=64k and BALLOON is enabled: hv_vmbus: registering driver hv_balloon hv_vmbus: probe failed for device 1eccfd72-4b41-45ef-b73a-4a6e44c12924 (-22) The cause of this is that the ringbuffer size for hv_balloon is not adjusted with VMBUS_RING_SIZE(), which makes the size not large enough for ringbuffers on guest with PAGE_SIZE=64k. Therefore use VMBUS_RING_SIZE() to calculate the ringbuffer size. Note that the old size (20 * 1024) counts a 4k header in the total size, while VMBUS_RING_SIZE() expects the parameter as the payload size, so use 16 * 1024. Cc: <stable@vger.kernel.org> # 5.15.x Reported-by: Baihua Lu <baihua.lu@microsoft.com> Signed-off-by: Boqun Feng <boqun.feng@gmail.com> Tested-by: Vitaly Kuznetsov <vkuznets@redhat.com> Link: https://lore.kernel.org/r/20211101150026.736124-1-boqun.feng@gmail.com Signed-off-by: Wei Liu <wei.liu@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25net: stmmac: socfpga: add runtime suspend/resume callback for stratix10 platformMeng Li
commit 9119570039481d56350af1c636f040fb300b8cf3 upstream. According to upstream commit 5ec55823438e("net: stmmac: add clocks management for gmac driver"), it improve clocks management for stmmac driver. So, it is necessary to implement the runtime callback in dwmac-socfpga driver because it doesn't use the common stmmac_pltfr_pm_ops instance. Otherwise, clocks are not disabled when system enters suspend status. Fixes: 5ec55823438e ("net: stmmac: add clocks management for gmac driver") Cc: stable@vger.kernel.org Signed-off-by: Meng Li <Meng.Li@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25spi: fix use-after-free of the add_lock mutexMichael Walle
commit 6c53b45c71b4920b5e62f0ea8079a1da382b9434 upstream. Commit 6098475d4cb4 ("spi: Fix deadlock when adding SPI controllers on SPI buses") introduced a per-controller mutex. But mutex_unlock() of said lock is called after the controller is already freed: spi_unregister_controller(ctlr) -> put_device(&ctlr->dev) -> spi_controller_release(dev) -> mutex_unlock(&ctrl->add_lock) Move the put_device() after the mutex_unlock(). Fixes: 6098475d4cb4 ("spi: Fix deadlock when adding SPI controllers on SPI buses") Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Lukas Wunner <lukas@wunner.de> Cc: stable@vger.kernel.org # v5.15 Link: https://lore.kernel.org/r/20211111083713.3335171-1-michael@walle.cc Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25drm/cma-helper: Release non-coherent memory with dma_free_noncoherent()Thomas Zimmermann
commit 995f54ea962e03ec08b8bc6a4fe11a32b420edd3 upstream. The GEM CMA helpers allocate non-coherent (i.e., cached) backing storage with dma_alloc_noncoherent(), but release it with dma_free_wc(). Fix this with a call to dma_free_noncoherent(). Writecombining storage is still released with dma_free_wc(). Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de> Fixes: cf8ccbc72d61 ("drm: Add support for GEM buffers backed by non-coherent memory") Acked-by: Paul Cercueil <paul@crapouillou.net> Cc: Thomas Zimmermann <tzimmermann@suse.de> Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Maxime Ripard <mripard@kernel.org> Cc: David Airlie <airlied@linux.ie> Cc: Daniel Vetter <daniel@ffwll.ch> Cc: dri-devel@lists.freedesktop.org Cc: <stable@vger.kernel.org> # v5.14+ Link: https://patchwork.freedesktop.org/patch/msgid/20210708175146.10618-1-tzimmermann@suse.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25fbdev: Prevent probing generic drivers if a FB is already registeredJavier Martinez Canillas
commit fb561bf9abde49f7e00fdbf9ed2ccf2d86cac8ee upstream. The efifb and simplefb drivers just render to a pre-allocated frame buffer and rely on the display hardware being initialized before the kernel boots. But if another driver already probed correctly and registered a fbdev, the generic drivers shouldn't be probed since an actual driver for the display hardware is already present. This is more likely to occur after commit d391c5827107 ("drivers/firmware: move x86 Generic System Framebuffers support") since the "efi-framebuffer" and "simple-framebuffer" platform devices are registered at a later time. Link: https://lore.kernel.org/r/20211110200253.rfudkt3edbd3nsyj@lahvuun/ Fixes: d391c5827107 ("drivers/firmware: move x86 Generic System Framebuffers support") Reported-by: Ilya Trukhanov <lahvuun@gmail.com> Cc: <stable@vger.kernel.org> # 5.15.x Signed-off-by: Javier Martinez Canillas <javierm@redhat.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Tested-by: Ilya Trukhanov <lahvuun@gmail.com> Link: https://patchwork.freedesktop.org/patch/msgid/20211111115757.1351045-1-javierm@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25pinctrl: ralink: include 'ralink_regs.h' in 'pinctrl-mt7620.c'Sergio Paracuellos
commit a5b9703fe11cd1d6d7a60102aa2abe686dc1867f upstream. mt7620.h, included by pinctrl-mt7620.c, mentions MT762X_SOC_MT7628AN declared in ralink_regs.h. Fixes: 745ec436de72 ("pinctrl: ralink: move MT7620 SoC pinmux config into a new 'pinctrl-mt7620.c' file") Cc: stable@vger.kernel.org Signed-off-by: Luiz Angelo Daros de Luca <luizluca@gmail.com> Signed-off-by: Sergio Paracuellos <sergio.paracuellos@gmail.com> Link: https://lore.kernel.org/r/20211031064046.13533-1-sergio.paracuellos@gmail.com Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25scsi: qla2xxx: Fix mailbox direction flags in qla2xxx_get_adapter_id()Ewan D. Milne
commit 392006871bb26166bcfafa56faf49431c2cfaaa8 upstream. The SCM changes set the flags in mcp->out_mb instead of mcp->in_mb so the data was not actually being read into the mcp->mb[] array from the adapter. Link: https://lore.kernel.org/r/20211108183012.13895-1-emilne@redhat.com Fixes: 9f2475fe7406 ("scsi: qla2xxx: SAN congestion management implementation") Cc: stable@vger.kernel.org Reviewed-by: Himanshu Madhani <himanshu.madhani@oracle.com> Reviewed-by: Arun Easi <aeasi@marvell.com> Signed-off-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25ata: libata: add missing ata_identify_page_supported() callsDamien Le Moal
commit 06f6c4c6c3e8354dceddd77bd58f9a7a84c67246 upstream. ata_dev_config_ncq_prio() and ata_dev_config_devslp() both access pages of the IDENTIFY DEVICE data log. Before calling ata_read_log_page(), make sure to check for the existence of the IDENTIFY DEVICE data log and of the log page accessed using ata_identify_page_supported(). This avoids useless error messages from ata_read_log_page() and failures with some LLDD scsi drivers using libsas. Reported-by: Nikolay <knv418@gmail.com> Cc: stable@kernel.org # 5.15 Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com> Tested-by: Matthew Perkowski <mgperkow@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25ata: libata: improve ata_read_log_page() error messageDamien Le Moal
commit 23ef63d5e14f916c5bba39128ebef395859d7c0f upstream. If ata_read_log_page() fails to read a log page, the ata_dev_err() error message only print the page number, omitting the log number. In case of error, facilitate debugging by also printing the log number. Cc: stable@kernel.org # 5.15 Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com> Tested-by: Matthew Perkowski <mgperkow@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25Revert "drm/i915/tgl/dsi: Gate the ddi clocks after pll mapping"Vandita Kulkarni
commit f15863b27752682bb700c21de5f83f613a0fb77e upstream. This reverts commit 991d9557b0c4 ("drm/i915/tgl/dsi: Gate the ddi clocks after pll mapping"). The Bspec was updated recently with the pll ungate sequence similar to that of icl dsi enable sequence. Hence reverting. Bspec: 49187 Fixes: 991d9557b0c4 ("drm/i915/tgl/dsi: Gate the ddi clocks after pll mapping") Cc: <stable@vger.kernel.org> # v5.4+ Signed-off-by: Vandita Kulkarni <vandita.kulkarni@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20211109120428.15211-1-vandita.kulkarni@intel.com (cherry picked from commit 4579509ef181480f4e4510d436c691519167c5c2) Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25tun: fix bonding active backup with arp monitoringNicolas Dichtel
commit a31d27fbed5d518734cb60956303eb15089a7634 upstream. As stated in the bonding doc, trans_start must be set manually for drivers using NETIF_F_LLTX: Drivers that use NETIF_F_LLTX flag must also update netdev_queue->trans_start. If they do not, then the ARP monitor will immediately fail any slaves using that driver, and those slaves will stay down. Link: https://www.kernel.org/doc/html/v5.15/networking/bonding.html#arp-monitor-operation Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25dmaengine: remove debugfs #ifdefArnd Bergmann
commit b3b180e735409ca0c76642014304b59482e0e653 upstream. The ptdma driver has added debugfs support, but this fails to build when debugfs is disabled: drivers/dma/ptdma/ptdma-debugfs.c: In function 'ptdma_debugfs_setup': drivers/dma/ptdma/ptdma-debugfs.c:93:54: error: 'struct dma_device' has no member named 'dbg_dev_root' 93 | debugfs_create_file("info", 0400, pt->dma_dev.dbg_dev_root, pt, | ^ drivers/dma/ptdma/ptdma-debugfs.c:96:55: error: 'struct dma_device' has no member named 'dbg_dev_root' 96 | debugfs_create_file("stats", 0400, pt->dma_dev.dbg_dev_root, pt, | ^ drivers/dma/ptdma/ptdma-debugfs.c:102:52: error: 'struct dma_device' has no member named 'dbg_dev_root' 102 | debugfs_create_dir("q", pt->dma_dev.dbg_dev_root); | ^ Remove the #ifdef in the header, as this only saves a few bytes, but would require ugly #ifdefs in each driver using it. Simplify the other user while we're at it. Fixes: e2fb2e2a33fa ("dmaengine: ptdma: Add debugfs entries for PTDMA") Fixes: 26cf132de6f7 ("dmaengine: Create debug directories for DMA devices") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Link: https://lore.kernel.org/r/20210920122017.205975-1-arnd@kernel.org Signed-off-by: Vinod Koul <vkoul@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-25pinctrl: qcom: sm8350: Correct UFS and SDC offsetsBjorn Andersson
[ Upstream commit 62209e805b5c68577602a5803a71d8e2e11ee0d3 ] The downstream TLMM binding covers a group of TLMM-related hardware blocks, but the upstream binding only captures the particular block related to controlling the TLMM pins from an OS. In the translation of the driver from downstream, the offset of 0x100000 was lost for the UFS and SDC pingroups. Fixes: d5d348a3271f ("pinctrl: qcom: Add SM8350 pinctrl driver") Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Reviewed-by: Vinod Koul <vkoul@kernel.org> Reviewed-by: Vladimir Zapolskiy <vladimir.zapolskiy@linaro.org> Link: https://lore.kernel.org/r/20211104170835.1993686-1-bjorn.andersson@linaro.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25pinctrl: qcom: sdm845: Enable dual edge errataBjorn Andersson
[ Upstream commit 3a3a100473d2f6ebf9bdfe6efedd7e18de724388 ] It has been observed that dual edge triggered wakeirq GPIOs on SDM845 doesn't trigger interrupts on the falling edge. Enabling wakeirq_dual_edge_errata for SDM845 indicates that the PDC in SDM845 suffers from the same problem described, and worked around, by Doug in 'c3c0c2e18d94 ("pinctrl: qcom: Handle broken/missing PDC dual edge IRQs on sc7180")', so enable the workaround for SDM845 as well. The specific problem seen without this is that gpio-keys does not detect the falling edge of the LID gpio on the Lenovo Yoga C630 and as such consistently reports the LID as closed. Fixes: e35a6ae0eb3a ("pinctrl/msm: Setup GPIO chip in hierarchy") Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Tested-By: Steev Klimaszewski <steev@kali.org> Reviewed-by: Douglas Anderson <dianders@chromium.org> Reviewed-by: Stephen Boyd <swboyd@chromium.org> Link: https://lore.kernel.org/r/20211102034115.1946036-1-bjorn.andersson@linaro.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25ptp: ocp: Fix a couple NULL vs IS_ERR() checksDan Carpenter
[ Upstream commit c7521d3aa2fa7fc785682758c99b5bcae503f6be ] The ptp_ocp_get_mem() function does not return NULL, it returns error pointers. Fixes: 773bda964921 ("ptp: ocp: Expose various resources on the timecard.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25e100: fix device suspend/resumeJesse Brandeburg
[ Upstream commit 5d2ca2e12dfb2aff3388ca57b06f570fa6206ced ] As reported in [1], e100 was no longer working for suspend/resume cycles. The previous commit mentioned in the fixes appears to have broken things and this attempts to practice best known methods for device power management and keep wake-up working while allowing suspend/resume to work. To do this, I reorder a little bit of code and fix the resume path to make sure the device is enabled. [1] https://bugzilla.kernel.org/show_bug.cgi?id=214933 Fixes: 69a74aef8a18 ("e100: use generic power management") Cc: Vaibhav Gupta <vaibhavgupta40@gmail.com> Reported-by: Alexey Kuznetsov <axet@me.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Alexey Kuznetsov <axet@me.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25i40e: Fix display error code in dmesgGrzegorz Szczurek
[ Upstream commit 5aff430d4e33a0b48a6b3d5beb06f79da23f9916 ] Fix misleading display error in dmesg if tc filter return fail. Only i40e status error code should be converted to string, not linux error code. Otherwise, we return false information about the error. Fixes: 2f4b411a3d67 ("i40e: Enable cloud filters via tc-flower") Signed-off-by: Grzegorz Szczurek <grzegorzx.szczurek@intel.com> Signed-off-by: Mateusz Palczewski <mateusz.palczewski@intel.com> Tested-by: Dave Switzer <david.switzer@intel.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25i40e: Fix creation of first queue by omitting it if is not power of twoJedrzej Jagielski
[ Upstream commit 2e6d218c1ec6fb9cd70693b78134cbc35ae0b5a9 ] Reject TCs creation with proper message if the first queue assignment is not equal to the power of two. The first queue number was checked too late in the second queue iteration, if second queue was configured at all. Now if first queue value is not a power of two, then trying to create qdisc will be rejected. Fixes: 8f88b3034db3 ("i40e: Add infrastructure for queue channel support") Signed-off-by: Grzegorz Szczurek <grzegorzx.szczurek@intel.com> Signed-off-by: Jedrzej Jagielski <jedrzej.jagielski@intel.com> Tested-by: Tony Brelinski <tony.brelinski@intel.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25i40e: Fix warning message and call stack during rmmod i40e driverKaren Sornek
[ Upstream commit 3a3b311e3881172fc8e019b6508f04bc40c92d9d ] Restore part of reset functionality used when reset is called from the VF to reset itself. Without this fix warning message is displayed when VF is being removed via sysfs. Fix the crash of the VF during reset by ensuring that the PF receives the reset message successfully. Refactor code to use one function instead of two. Fixes: 5c3c48ac6bf5 ("i40e: implement virtual device interface") Signed-off-by: Grzegorz Szczurek <grzegorzx.szczurek@intel.com> Signed-off-by: Karen Sornek <karen.sornek@intel.com> Tested-by: Tony Brelinski <tony.brelinski@intel.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-25RDMA/mlx4: Do not fail the registration on port statsJack Wang
[ Upstream commit 378c67413de18b69fb3bb78d8c4f0f1192cfa973 ] If the FW doesn't support MLX4_DEV_CAP_FLAG2_DIAG_PER_PORT, mlx4 driver will fail the ib_setup_port_attrs, which is called from ib_register_device()/enable_device_and_get(), in the end leads to device not detected[1][2] To fix it, add a new mlx4_ib_hw_stats_ops1, w/o alloc_hw_port_stats if FW does not support MLX4_DEV_CAP_FLAG2_DIAG_PER_PORT. [1] https://bugzilla.redhat.com/show_bug.cgi?id=2014094 [2] https://lore.kernel.org/linux-rdma/CAMGffEn2wvEnmzc0xe=xYiCLqpphiHDBxCxqAELrBofbUAMQxw@mail.gmail.com Fixes: 4b5f4d3fb408 ("RDMA: Split the alloc_hw_stats() ops to port and device variants") Link: https://lore.kernel.org/r/20211115101519.27210-1-jinpu.wang@ionos.com Signed-off-by: Jack Wang <jinpu.wang@ionos.com> Reviewed-by: Leon Romanovsky <leonro@nvidia.com> Signed-off-by: Jason Gunthorpe <jgg@nvidia.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
