path: root/drivers
2009-01-03Merge branch 'master' of ↵Mike Travis
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask into merge-rr-cpumask Conflicts: arch/x86/kernel/io_apic.c kernel/rcuclassic.c kernel/sched.c kernel/time/tick-sched.c Signed-off-by: Mike Travis <travis@sgi.com> [ mingo@elte.hu: backmerged typo fix for io_apic.c ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-01percpu: fix percpu accessors to potentially !cpu_possible() cpus: pnpbiosRusty Russell
Impact: CPU iterator bugfixes Percpu areas are only allocated for possible cpus. In general, you shouldn't access random cpu's percpu areas. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Adam Belay <ambx1@neo.rr.com>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/mlx4: Fix reading SL field out of cqe->sl_vid RDMA/addr: Fix build breakage when IPv6 is disabled
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (104 commits) [SCSI] fcoe: fix configuration problems [SCSI] cxgb3i: fix select/depend problem [SCSI] fcoe: fix incorrect use of struct module [SCSI] cxgb3i: remove use of skb->sp [SCSI] cxgb3i: Add cxgb3i iSCSI driver. [SCSI] zfcp: Remove unnecessary warning message [SCSI] zfcp: Add support for unchained FSF requests [SCSI] zfcp: Remove busid macro [SCSI] zfcp: remove DID_DID flag [SCSI] zfcp: Simplify mask lookups for incoming RSCNs [SCSI] zfcp: Remove initial device data from zfcp_data [SCSI] zfcp: fix compile warning [SCSI] zfcp: Remove adapter list [SCSI] zfcp: Simplify SBAL allocation to fix sparse warnings [SCSI] zfcp: register with SCSI layer on ccw registration [SCSI] zfcp: Fix message line break [SCSI] qla2xxx: changes in multiq code [SCSI] eata: fix the data buffer accessors conversion regression [SCSI] ibmvfc: Improve async event handling [SCSI] lpfc : correct printk types on PPC compiles ...
2008-12-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (583 commits) V4L/DVB (10130): use USB API functions rather than constants V4L/DVB (10129): dvb: remove deprecated use of RW_LOCK_UNLOCKED in frontends V4L/DVB (10128): modify V4L documentation to be a valid XHTML V4L/DVB (10127): stv06xx: Avoid having y unitialized V4L/DVB (10125): em28xx: Don't do AC97 vendor detection for i2s audio devices V4L/DVB (10124): em28xx: expand output formats available V4L/DVB (10123): em28xx: fix reversed definitions of I2S audio modes V4L/DVB (10122): em28xx: don't load em28xx-alsa for em2870 based devices V4L/DVB (10121): em28xx: remove worthless Pinnacle PCTV HD Mini 80e device profile V4L/DVB (10120): em28xx: remove redundant Pinnacle Dazzle DVC 100 profile V4L/DVB (10119): em28xx: fix corrupted XCLK value V4L/DVB (10118): zoran: fix warning for a variable not used V4L/DVB (10116): af9013: Fix gcc false warnings V4L/DVB (10111a): usbvideo.h: remove an useless blank line V4L/DVB (10111): quickcam_messenger.c: fix a warning V4L/DVB (10110): v4l2-ioctl: Fix warnings when using .unlocked_ioctl = __video_ioctl2 V4L/DVB (10109): anysee: Fix usage of an unitialized function V4L/DVB (10104): uvcvideo: Add support for video output devices V4L/DVB (10102): uvcvideo: Ignore interrupt endpoint for built-in iSight webcams. V4L/DVB (10101): uvcvideo: Fix bulk URB processing when the header is erroneous ...
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Fix percpu counters deadlock cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits: net drivers/net/usb: use USB API functions rather than constants cls_cgroup: clean up Kconfig cls_cgroup: clean up for cgroup part cls_cgroup: fix an oops when removing a cgroup EtherExpress16: fix printing timed out status mlx4_en: Added "set_ringparam" Ethtool interface implementation mlx4_en: Always allocate RX ring for each interrupt vector mlx4_en: Verify number of RX rings doesn't exceed MAX_RX_RINGS IPVS: Make "no destination available" message more consistent between schedulers net: KS8695: removed duplicated #include tun: Fix SIOCSIFHWADDR error. smsc911x: compile fix re netif_rx signature changes netns: foreach_netdev_safe is insufficient in default_device_exit net: make xfrm_statistics_seq_show use generic snmp_fold_field net: Fix more NAPI interface netdev argument drop fallout. net: Fix unused variable warnings in pasemi_mac.c and spider_net.c
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: struct device - replace bus_id with dev_name() lguest: move the initial guest page table creation code to the host kvm-s390: implement config_changed for virtio on s390 virtio_console: support console resizing virtio: add PCI device release() function virtio_blk: fix type warning virtio: block: dynamic maximum segments virtio: set max_segment_size and max_sectors to infinite. virtio: avoid implicit use of Linux page size in balloon interface virtio: hand virtio ring alignment as argument to vring_new_virtqueue virtio: use KVM_S390_VIRTIO_RING_ALIGN instead of relying on pagesize virtio: use LGUEST_VRING_ALIGN instead of relying on pagesize virtio: Don't use PAGE_SIZE for vring alignment in virtio_pci. virtio: rename 'pagesize' arg to vring_init/vring_size virtio: Don't use PAGE_SIZE in virtio_pci.c virtio: struct device - replace bus_id with dev_name(), dev_set_name() virtio-pci queue allocation not page-aligned
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (33 commits) ide-cd: remove dead dsc_overlap setting ide: push local_irq_{save,restore}() to do_identify() ide: remove superfluous local_irq_{save,restore}() from ide_dump_status() ide: move legacy ISA/VLB ports handling to ide-legacy.c (v2) ide: move Power Management support to ide-pm.c ide: use ATA_DMA_* defines in ide-dma-sff.c ide: checkpatch.pl fixes for ide-lib.c ide: remove inline tags from ide-probe.c ide: remove redundant code from ide_end_drive_cmd() ide: struct device - replace bus_id with dev_name(), dev_set_name() ide: rework handling of serialized ports (v2) cy82c693: remove superfluous ide_cy82c693 chipset type trm290: add IDE_HFLAG_TRM290 host flag ide: add ->max_sectors field to struct ide_port_info rz1000: apply chipset quirks early (v2) ide: always set nIEN on idle devices ide: fix ->quirk_list checking in ide_do_request() gayle: set IDE_HFLAG_SERIALIZE explictly cmd64x: set IDE_HFLAG_SERIALIZE explictly for CMD646 ali14xx: doesn't use shared IRQs ...
2008-12-30Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_sil: add Large Block Transfer support [libata] ata_piix: cleanup dmi strings checking DMI: add dmi_match libata: blacklist NCQ on OCZ CORE 2 SSD (resend) [libata] Update kernel-doc comments to match source code libata: perform port detach in EH libata: when restoring SControl during detach do the PMP links first libata: beef up iterators
2008-12-30Merge branch 'oprofile-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: oprofile: select RING_BUFFER ring_buffer: adding EXPORT_SYMBOLs oprofile: fix lost sample counter oprofile: remove nr_available_slots() oprofile: port to the new ring_buffer ring_buffer: add remaining cpu functions to ring_buffer.h oprofile: moving cpu_buffer_reset() to cpu_buffer.h oprofile: adding cpu_buffer_entries() oprofile: adding cpu_buffer_write_commit() oprofile: adding cpu buffer r/w access functions ftrace: remove unused function arg in trace_iterator_increment() ring_buffer: update description for ring_buffer_alloc() oprofile: set values to default when creating oprofilefs oprofile: implement switch/case in buffer_sync.c x86/oprofile: cleanup IBS init/exit functions in op_model_amd.c x86/oprofile: reordering IBS code in op_model_amd.c oprofile: fix typo oprofile: whitspace changes only oprofile: update comment for oprofile_add_sample() oprofile: comment cleanup
2008-12-30Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (37 commits) drm/i915: fix modeset devname allocation + agp init return check. drm/i915: Remove redundant test in error path. drm: Add a debug node for vblank state. drm: Avoid use-before-null-test on dev in drm_cleanup(). drm/i915: Don't print to dmesg when taking signal during object_pin. drm: pin new and unpin old buffer when setting a mode. drm/i915: un-EXPORT and make 'intelfb_panic' static drm/i915: Delete unused, pointless i915_driver_firstopen. drm/i915: fix sparse warnings: returning void-valued expression drm/i915: fix sparse warnings: move 'extern' decls to header file drm/i915: fix sparse warnings: make symbols static drm/i915: fix sparse warnings: declare one-bit bitfield as unsigned drm/i915: Don't double-unpin buffers if we take a signal in evict_everything(). drm/i915: Fix fbcon setup to align display pitch to 64b. drm/i915: Add missing userland definitions for gem init/execbuffer. i915/drm: provide compat defines for userspace for certain struct members. drm: drop DRM_IOCTL_MODE_REPLACEFB, add+remove works just as well. drm: sanitise drm modesetting API + remove unused hotplug drm: fix allowing master ioctls on non-master fds. drm/radeon: use locked rmmap to remove sarea mapping. ...
2008-12-30Merge branch 'agp-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/intel: Fix broken ® symbol in device name. agp/intel: add support for G41 chipset
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: (98 commits) sparc: move select of ARCH_SUPPORTS_MSI sparc: drop SUN_IO sparc: unify sections.h sparc: use .data.init_task section for init_thread_union sparc: fix array overrun check in of_device_64.c sparc: unify module.c sparc64: prepare module_64.c for unification sparc64: use bit neutral Elf symbols sparc: unify module.h sparc: introduce CONFIG_BITS sparc: fix hardirq.h removal fallout sparc64: do not export pus_fs_struct sparc: use sparc64 version of scatterlist.h sparc: Commonize memcmp assembler. sparc: Unify strlen assembler. sparc: Add asm/asm.h sparc: Kill memcmp_32.S code which has been ifdef'd out for centuries. sparc: replace for_each_cpu_mask_nr with for_each_cpu sparc: fix sparse warnings in irq_32.c sparc: add include guards to kernel.h ...
2008-12-30Merge branch 'for-2.6.29' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.29' of git://git.kernel.dk/linux-2.6-block: (43 commits) bio: get rid of bio_vec clearing bounce: don't rely on a zeroed bio_vec list cciss: simplify parameters to deregister_disk function cfq-iosched: fix race between exiting queue and exiting task loop: Do not call loop_unplug for not configured loop device. loop: Flush possible running bios when loop device is released. alpha: remove dead BIO_VMERGE_BOUNDARY Get rid of CONFIG_LSF block: make blk_softirq_init() static block: use min_not_zero in blk_queue_stack_limits block: add one-hit cache for disk partition lookup cfq-iosched: remove limit of dispatch depth of max 4 times quantum nbd: tell the block layer that it is not a rotational device block: get rid of elevator_t typedef aio: make the lookup_ioctx() lockless bio: add support for inlining a number of bio_vecs inside the bio bio: allow individual slabs in the bio_set bio: move the slab pointer inside the bio_set bio: only mempool back the largest bio_vec slab cache block: don't use plugging on SSD devices ...
2008-12-30Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, sparseirq: clean up Kconfig entry x86: turn CONFIG_SPARSE_IRQ off by default sparseirq: fix numa_migrate_irq_desc dependency and comments sparseirq: add kernel-doc notation for new member in irq_desc, -v2 locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP sparseirq, xen: make sure irq_desc is allocated for interrupts sparseirq: fix !SMP building, #2 x86, sparseirq: move irq_desc according to smp_affinity, v7 proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ sparse irqs: add irqnr.h to the user headers list sparse irqs: handle !GENIRQ platforms sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build sparseirq: fix Alpha build failure sparseirq: fix typo in !CONFIG_IO_APIC case x86, MSI: pass irq_cfg and irq_desc x86: MSI start irq numbering from nr_irqs_gsi x86: use NR_IRQS_LEGACY sparse irq_desc[] array: core kernel and x86 changes genirq: record IRQ_LEVEL in irq_desc[] irq.h: remove padding from irq_desc on 64bits
2008-12-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: fix warning in kernel/hrtimer.c x86: make sure we really have an hpet mapping before using it x86: enable HPET on Fujitsu u9200 linux/timex.h: cleanup for userspace posix-timers: simplify de_thread()->exit_itimers() path posix-timers: check ->it_signal instead of ->it_pid to validate the timer posix-timers: use "struct pid*" instead of "struct task_struct*" nohz: suppress needless timer reprogramming clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI nohz: no softirq pending warnings for offline cpus hrtimer: removing all ur callback modes, fix hrtimer: removing all ur callback modes, fix hotplug hrtimer: removing all ur callback modes x86: correct link to HPET timer specification rtc-cmos: export second NVRAM bank Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c manually.
2008-12-30Merge branches 'cma' and 'mlx4' into for-linusRoland Dreier
2008-12-30IB/mlx4: Fix reading SL field out of cqe->sl_vidRoland Dreier
Commit f780a9f1 ("mlx4_core: Add ethernet fields to CQE struct") introduced a bug in how wc->sl is set in mlx4_ib_poll_one() -- since cqe->sl_vid is a big-endian value, the shift must be done after converting to host endianness. This bug was found using sparse endianness checking. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-12-30[SCSI] fcoe: fix configuration problemsJames Bottomley
fcoe selects libfc and requires SCSI and PCI (the SCSI requirement is implicitly covered by an enclosing if). Fix them both up so they cannot be configured in an invalid state: make LIBFC select SCSI_FC_ATTRS and make FCOE depend on PCI and select LIBFC. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-30[SCSI] cxgb3i: fix select/depend problemJames Bottomley
cxgb3i requires the cxgb3 net driver, so it selects it. However, cxgb3 has dependencies which the select cannot see. Fix this by separating out the cxgb3 dependencies into a separate hidden config option (CONFIG_CHELSIO_T3_DEPENDS) and make both cxgb3 and cxgb3i depend on it. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-30[SCSI] fcoe: fix incorrect use of struct moduleJames Bottomley
This structure may not be defined if CONFIG_MODULE=n, so never deref it. Change uses of module->name to module_name(module) and corrects some dyslexic printks and docbook comments. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-30[SCSI] cxgb3i: remove use of skb->spKaren Xie
The cxgb3i was using skb->sp pointer for some internal book-keeping which is not related to the secure path. Changed it to use skb->cb[] instead. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-30[SCSI] cxgb3i: Add cxgb3i iSCSI driver.Karen Xie
This patch implements the cxgb3i iscsi connection acceleration for the open-iscsi initiator. The cxgb3i driver offers the iscsi PDU based offload: - digest insertion and verification - payload direct-placement into host memory buffer. Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-30V4L/DVB (10130): use USB API functions rather than constantsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_is_isoc_in(epd) usb_endpoint_is_isoc_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10129): dvb: remove deprecated use of RW_LOCK_UNLOCKED in frontendsSteven Rostedt
Impact: clean up RW_LOCK_UNLOCKED is deprecated. This patch replaces it with the __RW_LOCK_UNLOCKED(lock) macro. This change was a little trickier than others due to the macro being used in another macro that fills an array. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10127): stv06xx: Avoid having y unitializedErik Andrén
As pointed by gcc: drivers/media/video/gspca/stv06xx/stv06xx_hdcs.c: In function ‘hdcs_set_size’: drivers/media/video/gspca/stv06xx/stv06xx_hdcs.c:301: warning: ‘y’ may be used uninitialized in this function Signed-off-by: Erik Andrén <erik.andren@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10125): em28xx: Don't do AC97 vendor detection for i2s audio devicesDevin Heitmueller
The current code was trying to query the AC97 registers for the vendor information even if it was clearly not a AC97 audio device (resulting in errors in the dmesg output). This was due to a bug in the way we did the check. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10124): em28xx: expand output formats availableDevin Heitmueller
Add additional output formats, which will be useful for the Pinnacle PCTV Ultimate 880e integration with the saa7136. Thanks to Ray Lu from Empia for providing the em2860/em2880 datasheet. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10123): em28xx: fix reversed definitions of I2S audio modesDevin Heitmueller
Noticed when doing the audio support for the Pinnacle PCTV HD Ultimate 808e that the modes were incorrect (the 808e uses I2S in 5 sample mode) Thanks for Ray Lu from Empia for providing the em2860/em2880 datasheet. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10122): em28xx: don't load em28xx-alsa for em2870 based devicesDevin Heitmueller
Like the em2874, the em2870 does not have any analog support, so don't bother loading the em28xx-alsa module. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10121): em28xx: remove worthless Pinnacle PCTV HD Mini 80e device ↵Devin Heitmueller
profile The Pinnacle 80e cannot be supported since Micronas yanked their driver support for the drx-j chipset at the last minute. Remove the device profile since it cannot work without the drx driver and it being there is only likely to confuse people into thinking the device is supported but not working. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10120): em28xx: remove redundant Pinnacle Dazzle DVC 100 profileDevin Heitmueller
The DVC 100 profile is redundant since we already have an existing identical profile named "Pinnacle Dazzle DVC 90/DVC 100" Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10119): em28xx: fix corrupted XCLK valueDevin Heitmueller
Correct problem introduced during the board refactoring where the XCLK frequency would get zero'd out. The sequence of events was as follows: em28xx_pre_card_setup() called em28xx_set_model() em28xx_set_model() would memcpy to dev->board configuration em28xx_pre_card_setup() would set the dev->board.xclk if not set em28xx_pre_card_setup() would set the XCLK register based on dev->board.xclk ... em28xx_card_setup() would call em28xx_set_model() em28xx_set_model() would memcpy to dev->board configuration (clearing out value of dev->board.xclk set in em28xx_pre_card_setup) ... em28xx_audio_analog_set() sets the XCLK register based on dev->board.xclk (which now contains zero) The change sets the default XCLK and I2C Clock fields in the board definition inside of em28xx_set_model() so that subsequent calls do not cause the values to be overwritten. Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10118): zoran: fix warning for a variable not usedMauro Carvalho Chehab
Fix this warning: drivers/media/video/zoran/zoran_card.c:156: warning: ‘zr36067_pci_tbl’ defined but not used Currently, zoran driver relies on a find routine that doesn't use the pci table. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10116): af9013: Fix gcc false warningsMauro Carvalho Chehab
drivers/media/dvb/frontends/af9013.c: In function ‘af9013_set_coeff’: drivers/media/dvb/frontends/af9013.c:231: warning: ‘ns_coeff2_8k’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c:230: warning: ‘ns_coeff2_2k’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c:229: warning: ‘ns_coeff1_8193nu’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c:228: warning: ‘ns_coeff1_8192nu’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c:227: warning: ‘ns_coeff1_8191nu’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c:226: warning: ‘ns_coeff1_2048nu’ may be used uninitialized in this function drivers/media/dvb/frontends/af9013.c: In function ‘af9013_update_snr’: drivers/media/dvb/frontends/af9013.c:1012: warning: ‘snr_table’ may be used uninitialized in this function Cc: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10111a): usbvideo.h: remove an useless blank lineMauro Carvalho Chehab
This is needed to sync with the development tree. Probably, a merge conflict were solved by adding this blank line. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10111): quickcam_messenger.c: fix a warningMauro Carvalho Chehab
drivers/media/video/usbvideo/quickcam_messenger.c: In function ‘qcm_sensor_init’: drivers/media/video/usbvideo/quickcam_messenger.c:450: warning: operation on ‘ret’ may be undefined Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10110): v4l2-ioctl: Fix warnings when using .unlocked_ioctl = ↵Mauro Carvalho Chehab
__video_ioctl2 This patch fixes this warning: drivers/media/video/gspca/gspca.c:1811: warning: initialization from incompatible pointer type The reason is that the returned argument should be a long, not an integer. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10109): anysee: Fix usage of an unitialized functionMauro Carvalho Chehab
drivers/media/dvb/dvb-usb/anysee.c: In function ‘anysee_master_xfer’: drivers/media/dvb/dvb-usb/anysee.c:156: warning: ‘ret’ may be used uninitialized By looking at the function, altrough very unlikely, this might eventually be true if num = 0. So, better to fix the warning by initializing with ret = 0. Cc: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10104): uvcvideo: Add support for video output devicesLaurent Pinchart
Extend the range of supported UVC devices by allowing video output devices matching the following structure: TT_STREAMING -> VC_PROCESSING_UNIT -> VC_EXTENSION_UNIT{0,n} -> OTT_* Video output devices are reported with the V4L2_CAP_VIDEO_OUTPUT capability flag and are subject to the same restrictions as video input devices. Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10102): uvcvideo: Ignore interrupt endpoint for built-in iSight ↵Laurent Pinchart
webcams. Built-in iSight webcams have an interrupt endpoint but spit proprietary data that don't conform to the UVC status endpoint messages. Don't try to handle the interrupt endpoint for those cameras. Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10101): uvcvideo: Fix bulk URB processing when the header is erroneousLaurent Pinchart
When the first bulk URB of a video payload contains an erroneous header, or when no V4L2 buffer is available, the whole payload must be dropped. Change the skip logic to drop all bulk URBs until the end of the payload instead of the first one only. Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10099): soc-camera: add support for MT9T031 CMOS camera sensor from ↵Guennadi Liakhovetski
Micron This camera is rather similar to MT9M001, but also has a couple of enhanced features, like pixel binning. create mode 100644 drivers/media/video/mt9t031.c Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10098): ov772x: fix try_fmt calculation methodKuninori Morimoto
Don't modify driver's state in try_fmt, just verify format acceptability or adjust it to driver's capabilities. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10097): ov772x: clear i2c client data on error and removeKuninori Morimoto
2008-12-30V4L/DVB (10096): ov772x: change dev_info to dev_dbgKuninori Morimoto
2008-12-30V4L/DVB (10095): The failure of set_fmt is solved in tw9910Kuninori Morimoto
priv->scale is checked in start_capture. Therefore, it should be NULL if failing in set_fmt. This patch resolve this problem. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (10094): Add tw9910 driverKuninori Morimoto
This patch adds tw9910 driver that use soc_camera framework. It was tested on SH Migo-r board and mplayer. create mode 100644 drivers/media/video/tw9910.c create mode 100644 include/media/tw9910.h Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
