path: root/drivers
2010-08-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: pxa27x_keypad - remove input_free_device() in pxa27x_keypad_remove() Input: mousedev - fix regression of inverting axes Input: uinput - add devname alias to allow module on-demand load Input: hil_kbd - fix compile error USB: drop tty argument from usb_serial_handle_sysrq_char() Input: sysrq - drop tty argument form handle_sysrq() Input: sysrq - drop tty argument from sysrq ops handlers
2010-08-25libata-sff: remove harmful BUG_ON from ata_bmdma_qc_issueMark Lord
Remove harmful BUG_ON() from ata_bmdma_qc_issue(), as it casts too wide of a net and breaks sata_mv. It also crashes the kernel while doing the BUG_ON(). There's already a WARN_ON_ONCE() further down to catch the case of POLLING for a BMDMA operation. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
2010-08-25sata_mv: fix broken DSM/TRIM support (v2)Mark Lord
Fix DSM/TRIM commands in sata_mv (v2). These need to be issued using old-school "BM DMA", rather than via the EDMA host queue. Since the chips don't have proper BM DMA status, we need to be more careful with setting the ATA_DMA_INTR bit, since DSM/TRIM often has a long delay between "DMA complete" and "command complete". GEN_I chips don't have BM DMA, so no TRIM for them. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
2010-08-25libata: be less of a drama queen on empty data commandsTejun Heo
ata_qc_issue() BUG_ON()s on data commands w/o data, which may be submitted via SG_IO. Be less of a drama queen and just trigger WARN_ON_ONCE() and fail the command with AC_ERR_SYSTEM. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stefan Hübner <stefan.huebner@stud.tu-ilmenau.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25[libata] sata_dwc_460ex: signdness bugDan Carpenter
dma_dwc_xfer_setup() returns an int and "dma_chan" needs to be signed for the error handling to work. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25ahci: add HFLAG_YES_FBS and apply it to 88SE9128Tejun Heo
88SE9128 can do FBS and sets it in HOST_CAP but forgets to set FBSCP in PORT_CMD. Implement AHCI_HFLAG_YES_FBS and apply it to 88SE9128. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25libata: remove no longer needed pata_winbond driverBartlomiej Zolnierkiewicz
Winbond W83759A controller is fully supported by pata_legacy driver so remove no longer needed pata_winbond driver. Leave PATA_WINBOND_VLB config option for compatibility reasons and teach pata_legacy to preserve the old behavior of pata_winbond driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25pata_cmd64x: revert commit d62f5576Tejun Heo
Commit d62f5576 (pata_cmd64x: fix handling of address setup timings) incorrectly called ata_timing_compute() on UDMA mode on 0 @UT leading to devide by zero fault. Revert it until better fix is available. This is reported in bko#16607 by Milan Kocian who also root caused it. https://bugzilla.kernel.org/show_bug.cgi?id=16607 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-root-caused-by: Milan Kocian <milan.kocian@wq.cz> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: MAINTAINERS: hwmon/coretemp: Change maintainers hwmon: (k8temp) Differentiate between AM2 and ASB1 hwmon: (ads7871) Fix ads7871_probe error paths hwmon: (coretemp) Fix harmless build warning
2010-08-25Merge branch 'upstream/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/core' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen: handle events as edge-triggered xen: use percpu interrupts for IPIs and VIRQs
2010-08-25Input: pxa27x_keypad - remove input_free_device() in pxa27x_keypad_remove()Axel Lin
No need to call input_free_device() after input_unregister_device(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-25Input: mousedev - fix regression of inverting axesChristoph Fritz
Introduced by 987a6c0298260b7aa40702b349282554d6180e4b a swap in max/min calculation gets fixed by this patch. Reported-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-25hwmon: (k8temp) Differentiate between AM2 and ASB1Andreas Herrmann
Commit 8bf0223ed515be24de0c671eedaff49e78bebc9c (hwmon, k8temp: Fix temperature reporting for ASB1 processor revisions) fixed temperature reporting for ASB1 CPUs. But those CPU models (model 0x6b, 0x6f, 0x7f) were packaged both as AM2 (desktop) and ASB1 (mobile). Thus the commit leads to wrong temperature reporting for AM2 CPU parts. The solution is to determine the package type for models 0x6b, 0x6f, 0x7f. This is done using BrandId from CPUID Fn8000_0001_EBX[15:0]. See "Constructing the processor Name String" in "Revision Guide for AMD NPT Family 0Fh Processors" (Rev. 3.46). Cc: Rudolf Marek <r.marek@assembler.cz> Cc: stable@kernel.org [.32.x, .33.x, .34.x, .35.x] Reported-by: Vladislav Guberinic <neosisani@gmail.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-25hwmon: (ads7871) Fix ads7871_probe error pathsAxel Lin
1. remove 'status' variable 2. remove unneeded initialization of 'err' variable 3. return missing error code if sysfs_create_group fail. 4. fix the init sequence as: - check hardware existence - kzalloc for ads7871_data - sysfs_create_group - hwmon_device_register Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-25hwmon: (coretemp) Fix harmless build warningJean Delvare
Fix the following build warning: CC [M] drivers/hwmon/coretemp.o drivers/hwmon/coretemp.c: In function "coretemp_init": drivers/hwmon/coretemp.c:521: warning: unused variable "n" drivers/hwmon/coretemp.c:521: warning: unused variable "p" Introduced by commit 851b29cb3b196cb66452ec964ab5f66c9c9cd1ed. When you drop code, you also have to drop the variables this code was using. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com>
2010-08-24drm/i915: fix vblank wait test conditionJesse Barnes
When converting this to the new wait_for macro I inverted the wait condition, which causes all sorts of problems. So correct it to fix several failures caused by the bad wait (flickering, bad output detection, tearing, etc.). Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24xen: handle events as edge-triggeredJeremy Fitzhardinge
Xen events are logically edge triggered, as Xen only calls the event upcall when an event is newly set, but not continuously as it remains set. As a result, use handle_edge_irq rather than handle_level_irq. This has the important side-effect of fixing a long-standing bug of events getting lost if: - an event's interrupt handler is running - the event is migrated to a different vcpu - the event is re-triggered The most noticable symptom of these lost events is occasional lockups of blkfront. Many thanks to Tom Kopec and Daniel Stodden in tracking this down. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Tom Kopec <tek@acm.org> Cc: Daniel Stodden <daniel.stodden@citrix.com> Cc: Stable Kernel <stable@kernel.org>
2010-08-24xen: use percpu interrupts for IPIs and VIRQsJeremy Fitzhardinge
IPIs and VIRQs are inherently per-cpu event types, so treat them as such: - use a specific percpu irq_chip implementation, and - handle them with handle_percpu_irq This makes the path for delivering these interrupts more efficient (no masking/unmasking, no locks), and it avoid problems with attempts to migrate them. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stable Kernel <stable@kernel.org>
2010-08-24intel_scu_ipc: fix IPC i2c write bugJianwei Yang
We should pass the data to the data register. Signed-off-by: Jianwei Yang <jianwei.yang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24rar: Fix off by one errorOssama Othman
It looks like there is an off-by-one error in one of your changes to drivers/staging/rar_register/rar_register.c: Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24V4L/DVB: mantis: Fix IR_CORE dependencyIngo Molnar
This build bug triggers: drivers/built-in.o: In function `mantis_exit': (.text+0x377413): undefined reference to `ir_input_unregister' drivers/built-in.o: In function `mantis_input_init': (.text+0x3774ff): undefined reference to `__ir_input_register' If MANTIS_CORE is enabled but IR_CORE is not. Add the correct dependency. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (25 commits) powerpc: Fix config dependency problem with MPIC_U3_HT_IRQS via-pmu: Add compat_pmu_ioctl powerpc: Wire up fanotify_init, fanotify_mark, prlimit64 syscalls powerpc/pci: Fix checking for child bridges in PCI code. powerpc: Fix typo in uImage target powerpc: Initialise paca->kstack before early_setup_secondary powerpc: Fix bogus it_blocksize in VIO iommu code powerpc: Inline ppc64_runlatch_off powerpc: Correct smt_enabled=X boot option for > 2 threads per core powerpc: Silence xics_migrate_irqs_away() during cpu offline powerpc: Silence __cpu_up() under normal operation powerpc: Re-enable preemption before cpu_die() powerpc/pci: Drop unnecessary null test powerpc/powermac: Drop unnecessary null test powerpc/powermac: Drop unnecessary of_node_put powerpc/kdump: Stop all other CPUs before running crash handlers powerpc/mm: Fix vsid_scrample typo powerpc: Use is_32bit_task() helper to test 32 bit binary powerpc: Export memstart_addr and kernstart_addr on ppc64 powerpc: Make rwsem use "long" type ...
2010-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: Staging: sep: remove driver Staging: batman-adv: Don't write in not allocated packet_buff Staging: batman-adv: Don't use net_dev after dev_put Staging: batman-adv: Create batman_if only on register event Staging: batman-adv: fix own mac address detection Staging: batman-adv: always reply batman icmp packets with primary mac Staging: batman-adv: fix batman icmp originating from secondary interface Staging: batman-adv: unify orig_hash_lock spinlock handling to avoid deadlocks Staging: batman-adv: Fix merge of linus tree Staging: spectra: removes unused functions Staging: spectra: initializa lblk variable Staging: spectra: removes unused variable Staging: spectra: remove duplicate GLOB_VERSION definition Staging: spectra: don't use locked_ioctl, fix build Staging: use new REQ_FLUSH flag, fix build breakage Staging: spectra: removes q->prepare_flush_fn, fix build breakage
2010-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: 68328serial: check return value of copy_*_user() instead of access_ok() synclink: add mutex_unlock() on error path rocket: add a mutex_unlock() ip2: return -EFAULT on copy_to_user errors ip2: remove unneeded NULL check serial: print early console device address in hex
2010-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: kobject_uevent: fix typo in comments firmware_class: fix typo in error path kobject: Break the kobject namespace defs into their own header
2010-08-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (29 commits) ARM: imx: fix build failure concerning otg/ulpi USB: ftdi_sio: add product ID for Lenz LI-USB USB: adutux: fix misuse of return value of copy_to_user() USB: iowarrior: fix misuse of return value of copy_to_user() USB: xHCI: update ring dequeue pointer when process missed tds USB: xhci: Remove buggy assignment in next_trb() USB: ftdi_sio: Add ID for Ionics PlugComputer USB: serial: io_ti.c: don't return 0 if writing the download record failed USB: otg: twl4030: fix wrong assumption of starting state USB: gadget: Return -ENOMEM on memory allocation failure USB: gadget: fix composite kernel-doc warnings USB: ssu100: set tty_flags in ssu100_process_packet USB: ssu100: add disconnect function for ssu100 USB: serial: export symbol usb_serial_generic_disconnect USB: ssu100: rework logic for TIOCMIWAIT USB: ssu100: add register parameter to ssu100_setregister USB: ssu100: remove duplicate #defines in ssu100 USB: ssu100: refine process_packet in ssu100 USB: ssu100: add locking for port private data in ssu100 USB: r8a66597-udc: return -ENOMEM if kzalloc() fails ...
2010-08-24via-pmu: Add compat_pmu_ioctlAndreas Schwab
The ioctls are actually compatible, but due to historical mistake the numbers differ between 32bit and 64bit. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-23USB: ftdi_sio: add product ID for Lenz LI-USBGalen Seitz
Add ftdi product ID for Lenz LI-USB, a model train interface. This was NOT tested against 2.6.35, but a similar patch was tested with the CentOS 2.6.18-194.11.1.el5 kernel. It wasn't clear to me what ordering is being used in ftdi_sio.c, so I inserted the ID after another model train entry(SPROG_II). Signed-off-by: Galen Seitz <galens@seitzassoc.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: adutux: fix misuse of return value of copy_to_user()Kulikov Vasiliy
copy_to_user() returns number of not copied bytes, not error code. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: iowarrior: fix misuse of return value of copy_to_user()Kulikov Vasiliy
2010-08-23USB: xHCI: update ring dequeue pointer when process missed tdsAndiry Xu
This patch fixes a isoc transfer bug reported by Sander Eikelenboom. When ep->skip is set, endpoint ring dequeue pointer should be updated when processed every missed td. Although ring dequeue pointer will also be updated when ep->skip is clear, leave it intact during missed tds processing may cause two issues: 1). If the very next valid transfer following missed tds is a short transfer, its actual_length will be miscalculated; 2). If there are too many missed tds during transfer, new inserted tds may found the transfer ring full and urb enqueue fails. Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Tested-by: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: xhci: Remove buggy assignment in next_trb()John Youn
The code to increment the TRB pointer has a slight ambiguity that could lead to a bug on different compilers. The ANSI C specification does not specify the precedence of the assignment operator over the postfix operator. gcc 4.4 produced the correct code (increment the pointer and assign the value), but a MIPS compiler that one of John's clients used assigned the old (unincremented) value. Remove the unnecessary assignment to make all compilers produce the correct assembly. Signed-off-by: John Youn <johnyoun@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ftdi_sio: Add ID for Ionics PlugComputerMartin Michlmayr
Add the ID for the Ionics PlugComputer (<http://ionicsplug.com/>). Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: serial: io_ti.c: don't return 0 if writing the download record failedRoel Kluin
If the write download record failed we shouldn't return 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: otg: twl4030: fix wrong assumption of starting stateFelipe Balbi
The reset state of twl4030-usb is not sleeping, it starts up awaken and we need to disable it if we have booted with a disconnected cable to avoid over consumption on the default state. To avoid problems later, we read the current state of the transceiver from the PHY_PWR_CTRL register. The bootloader can, anyways, put the device to sleep before us. Tested on a custom OMAP board. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: gadget: Return -ENOMEM on memory allocation failureJulia Lawall
In this code, 0 is returned on memory allocation failure, even though other failures return -ENOMEM or other similar values. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression ret; expression x,e1,e2,e3; @@ ret = 0 ... when != ret = e1 *x = \(kmalloc\|kcalloc\|kzalloc\)(...) ... when != ret = e2 if (x == NULL) { ... when != ret = e3 return ret; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: gadget: fix composite kernel-doc warningsRandy Dunlap
Warning(include/linux/usb/composite.h:284): No description found for parameter 'disconnect' Warning(drivers/usb/gadget/composite.c:744): No description found for parameter 'c' Warning(drivers/usb/gadget/composite.c:744): Excess function parameter 'cdev' description in 'usb_string_ids_n' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: set tty_flags in ssu100_process_packetBill Pemberton
flag was never set in ssu100_process_packet. Add logic to set it before calling tty_insert_flip_* Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: add disconnect function for ssu100Bill Pemberton
Add a disconnect function to the functions of this device. The disconnect is a call to usb_serial_generic_disconnect() so it requires that symbol to be exported from generic.c. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: serial: export symbol usb_serial_generic_disconnectBill Pemberton
This is needed by the ssu100 driver to use this function. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: rework logic for TIOCMIWAITBill Pemberton
Rework the logic for TIOCMIWAIT to use wait_event_interruptible. This also adds support for TIOCGICOUNT. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: add register parameter to ssu100_setregisterBill Pemberton
The function ssu100_setregister was hard coded to only set the MCR register. Add a register parameter so that other registers can be set. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: remove duplicate #defines in ssu100Bill Pemberton
The ssu100 uses a TI16C550C UART so the SERIAL_ defines in this code are duplicates of those found in serial_reg.h. Remove the defines in ssu100.c and use the ones in the header file. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: refine process_packet in ssu100Bill Pemberton
The status information does not appear at the start of each incoming packet so the check for len < 4 at the start of ssu100_process_packet is wrong. Remove it. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ssu100: add locking for port private data in ssu100Bill Pemberton
2010-08-23USB: r8a66597-udc: return -ENOMEM if kzalloc() failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: io_ti: check firmware version before updatingGreg Kroah-Hartman
If we can't read the firmware for a device from the disk, and yet the device already has a valid firmware image in it, we don't want to replace the firmware with something invalid. So check the version number to be less than the current one to verify this is the correct thing to do. Reported-by: Chris Beauchamp <chris@chillibean.tv> Tested-by: Chris Beauchamp <chris@chillibean.tv> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: ftdi_sio: fix endianess of max packet sizeMichael Wileczka
The USB max packet size (always little-endian) was not being byte swapped on big-endian systems. Applicable since [USB: ftdi_sio: fix hi-speed device packet size calculation] approx 2.6.31 Signed-off-by: Michael Wileczka <mikewileczka@yahoo.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: CP210x Fix Break On/OffCraig Shelley
The definitions for BREAK_ON and BREAK_OFF are inverted, causing break requests to fail. This patch sets BREAK_ON and BREAK_OFF to the correct values. Signed-off-by: Craig Shelley <craig@microtron.org.uk> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-23USB: pl2303: New vendor and product idJef Driesen
Add support for the Zeagle N2iTiON3 dive computer interface. Since Zeagle devices are actually manufactured by Seiko, this patch will support other Seiko based models as well. Signed-off-by: Jef Driesen <jefdriesen@telenet.be> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
