Ryos uses a new return value for critical errors, others have been
confirmed.
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- a partial revert of exponent parsing changes to make "Unit" exponent
item work properly again, by Nikolai Kondrashov
- a few new device IDs additions piggy-backing, by AceLan Kao and David
Herrmann
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: wiimote: add LEGO-wiimote VID
HID: Fix unit exponent parsing again
HID: usbhid: quirk for SiS Touchscreen
HID: usbhid: quirk for Synaptics Large Touchccreen
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"The only interesting bit is ata_eh_qc_retry() update which fixes a
problem where a SG_IO command may fail across suspend/resume cycle
without the command actually being at fault.
Other changes are low level driver specific and fairly low impact"
* 'for-3.12-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libahci: fix turning on LEDs in ahci_start_port()
libata: make ata_eh_qc_retry() bump scmd->allowed on bogus failures
ahci_platform: use dev_info() instead of printk()
ahci: use dev_info() instead of printk()
pata_isapnp: Don't use invalid I/O ports
The LEGO-wiimote uses a different VID than the Nintendo ID. The device is
technically the same so add the ID.
Cc: <stable@vger.kernel.org> # 3.11+
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Pull ACPI and power management fixes from Rafael Wysocki:
- intel_pstate fix for misbehavior after system resume if sysfs
attributes are set in a specific way before the corresponding suspend
from Dirk Brandewie.
- A recent intel_pstate fix has no effect if unsigned long is 32-bit,
so fix it up to cover that case as well.
- The s3c64xx cpufreq driver was not updated when the index field of
struct cpufreq_frequency_table was replaced with driver_data, so
update it now. From Charles Keepax.
- The Kconfig help text for ACPI_BUTTON still refers to
/proc/acpi/event that has been dropped recently, so modify it to
remove that reference. From Krzysztof Mazur.
- A Lan Tianyu's change adds a missing mutex unlock to an error code
path in acpi_resume_power_resources().
- Some code related to ACPI power resources, whose very purpose is
questionable to put it lightly, turns out to cause problems to happen
during testing on real systems, so remove it completely (we may
revisit that in the future if there's a compelling enough reason).
From Rafael J Wysocki and Aaron Lu.
* tag 'pm+acpi-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PM: Drop two functions that are not used any more
ATA / ACPI: remove power dependent device handling
cpufreq: s3c64xx: Rename index to driver_data
ACPI / power: Drop automaitc resume of power resource dependent devices
intel_pstate: Fix type mismatch warning
cpufreq / intel_pstate: Fix max_perf_pct on resume
ACPI: remove /proc/acpi/event from ACPI_BUTTON help
ACPI / power: Release resource_lock after acpi_power_get_state() return error
Revert some changes done in 774638386826621c984ab6994439f474709cac5e.
Revert all changes done in hidinput_calc_abs_res as it mistakingly used
"Unit" item exponent nibbles to affect resolution value. This wasn't
breaking resolution calculation of relevant axes of any existing
devices, though, as they have only one dimension to their units and thus
1 in the corresponding nible.
Revert to reading "Unit Exponent" item value as a signed integer in
hid_parser_global to fix reading specification-complying values. This
fixes resolution calculation of devices complying to the HID standard,
including Huion, KYE, Waltop and UC-Logic graphics tablets which have
their report descriptors fixed by the drivers.
Explanations follow.
There are two "unit exponents" in HID specification and it is important
not to mix them. One is the global "Unit Exponent" item and another is
nibble values in the global "Unit" item. See 6.2.2.7 Global Items.
The "Unit Exponent" value is just a signed integer and is used to scale
the integer resolution unit values, so fractions can be expressed.
The nibbles of "Unit" value are used to select the unit system (nibble
0), and presence of a particular basic unit type in the unit formula and
its *exponent* (or power, nibbles 1-6). And yes, the latter is in two
complement and zero means absence of the unit type.
Taking the representation example of (integer) joules from the
specification:
[mass(grams)][length(centimeters)^2][time(seconds)^-2] * 10^-7
the "Unit Exponent" would be -7 (or 0xF9, if stored as a byte) and the
"Unit" value would be 0xE121, signifying:
Nibble Part Value Meaning
0 System 1 SI Linear
1 Length 2 Centimeters^2
2 Mass 1 Grams
3 Time -2 Seconds^-2
To give the resolution in e.g. hundredth of joules the "Unit Exponent"
item value should have been -9.
See also the examples of "Unit" values for some common units in the same
chapter.
However, there is a common misunderstanding about the "Unit Exponent"
value encoding, where it is assumed to be stored the same as nibbles in
"Unit" item. This is most likely due to the specification being a bit
vague and overloading the term "unit exponent". This also was and still
is proliferated by the official "HID Descriptor Tool", which makes this
mistake and stores "Unit Exponent" as such. This format is also
mentioned in books such as "USB Complete" and in Microsoft's hardware
design guides.
As a result many devices currently on the market use this encoding and
so the driver should support them.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
* acpi-fixes:
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fix from Greg KH:
"Here is one fix for the hotplug memory path that resolves a regression
when removing memory that showed up in 3.12-rc1"
* tag 'driver-core-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
driver core: Release device_hotplug_lock when store_mem_state returns EINVAL
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB fixes and new device ids for 3.12-rc6
The largest change here is a bunch of new device ids for the option
USB serial driver for new Huawei devices. Other than that, just some
small bug fixes for issues that people have reported (run-time and
build-time), nothing major"
* tag 'usb-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: usb_phy_gen: refine conditional declaration of usb_nop_xceiv_register
usb: misc: usb3503: Fix compile error due to incorrect regmap depedency
usb/chipidea: fix oops on memory allocation failure
usb-storage: add quirk for mandatory READ_CAPACITY_16
usb: serial: option: blacklist Olivetti Olicard200
USB: quirks: add touchscreen that is dazzeled by remote wakeup
Revert "usb: musb: gadget: fix otg active status flag"
USB: quirks.c: add one device that cannot deal with suspension
USB: serial: option: add support for Inovia SEW858 device
USB: serial: ti_usb_3410_5052: add Abbott strip port ID to combined table as well.
USB: support new huawei devices in option.c
usb: musb: start musb on the udc side, too
xhci: Fix spurious wakeups after S5 on Haswell
xhci: fix write to USB3_PSSEN and XUSB2PRM pci config registers
xhci: quirk for extra long delay for S4
xhci: Don't enable/disable RWE on bus suspend/resume.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull serial driver fixes from Greg KH:
"Here are two serial driver fixes for your tree. One is a revert of a
patch that causes a build error, the other is a fix to provide the
correct brace placement which resolves a bug where the driver was not
working properly"
* tag 'tty-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
serial: vt8500: add missing braces
Revert "serial: i.MX: evaluate linux,stdout-path property"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are some small iio and w1 driver fixes for 3.12-rc6.
There is also a hyper-v fix in here, which turned out to be incorrect,
so it was reverted. That will probably have to wait unto 3.13-rc1 to
get accepted as it's still being discussed"
* tag 'char-misc-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Revert "Drivers: hv: vmbus: Fix a bug in channel rescind code"
iio:buffer: Free active scan mask in iio_disable_all_buffers()
iio: frequency: adf4350: add missing clk_disable_unprepare() on error in adf4350_probe()
w1 - call request_module with w1 master mutex unlocked
w1 - fix fops in w1_bus_notify
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-linus
Jonathan writes:
Third set of IIO fixes for the 3.12 cycle.
Two little ones this time:
1) A missing clk_unprepare in adf4350.
2) A missing free of the active_scan_mask when iio_disable_all_buffers is
called during an unexpected device removal. This leak was introduced by
the fix
a87c82e454f184a9473f8cdfd4d304205f585f65 iio: Stop sampling when the device is removed
and hence is a regression fix.
This reverts commit 90d33f3ec519db19d785216299a4ee85ef58ec97 as it's not
the correct fix for this issue, and it causes a build warning to be
added to the kernel tree.
Cc: K. Y. Srinivasan <kys@microsoft.com>
Two functions defined in device_pm.c, acpi_dev_pm_add_dependent()
and acpi_dev_pm_remove_dependent(), have no callers and may be
dropped, so drop them.
Moreover, they are the only functions adding entries to and removing
entries from the power_dependent list in struct acpi_device, so drop
that list too.
Previously, we wanted SCSI devices corrsponding to ATA devices to
be runtime resumed when the power resource for those ATA device was
turned on by some other device, so we added the SCSI device to the
dependent device list of the ATA device's ACPI node. However, this
code has no effect after commit 41863fc (ACPI / power: Drop automaitc
resume of power resource dependent devices) and the mechanism it was
supposed to implement is regarded as a bad idea now, so drop it.
[rjw: Changelog]
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
When inserting a wrong value to /sys/devices/system/memory/memoryX/state file,
following messages are shown. And device_hotplug_lock is never released.
[ BUG: lock held when returning to user space! ]
3.12.0-rc4-debug+ #3 Tainted: G W
bash/6442 is leaving the kernel with locks still held!
1 lock held by bash/6442:
#0: (device_hotplug_lock){+.+.+.}, at: [<ffffffff8146cbb5>] lock_device_hotplug_sysfs+0x15/0x50
This issue was introdued by commit fa2be40 (drivers: base: use standard
device online/offline for state change).
This patch releases device_hotplug_lcok when store_mem_state returns EINVAL.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
CC: Seth Jennings <sjenning@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device-mapper fix from Alasdair Kergon:
"A patch to avoid data corruption in a device-mapper snapshot.
This is primarily a data corruption bug that all users of
device-mapper snapshots will want to fix. The CVE is due to a data
leak under specific circumstances if, for example, the snapshot is
presented to a virtual machine: a block written as data inside the VM
can get interpreted incorrectly on the host outside the VM as
metadata, causing the host to provide the VM with access to blocks it
would not otherwise see. This is likely to affect few, if any,
people"
* tag 'dm-3.12-fix-cve' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm snapshot: fix data corruption
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull gpio fixes from Linus Walleij:
"Three GPIO fixes for the v3.12 series:
- A fix to the Lynxpoint IRQ handler
- Two late fixes to fallout from the gpiod refactoring"
* tag 'gpio-v3.12-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpiolib: let gpiod_request() return -EPROBE_DEFER
gpiolib: safer implementation of desc_to_gpio()
gpio/lynxpoint: check if the interrupt is enabled in IRQ handler
The index field of cpufreq_frequency_table has been renamed to
driver_data by commit 5070158 (cpufreq: rename index as driver_data
in cpufreq_frequency_table).
This patch updates the s3c64xx driver to match.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: 3.11+ <stable@vger.kernel.org> # 3.11+
The mechanism causing devices depending on a given power resource
(that is, devices that can be in D0 only if that power resource is
on) to be resumed automatically when the power resource is turned
on (and their "inferred" power state becomes D0 as a result) is
inherently racy and in fact unnecessary.
It is racy, because if the power resource is turned on and then
immediately off, the device resume triggered by the first transition
to "on" may still happen, causing the power resource to be turned
on again. That again will trigger the "resume of dependent devices"
mechanism, but if the devices in question are not in use, they will
be suspended in the meantime causing the power resource to be turned
off. However, the "resume of dependent devices" will next resume
them again and so on. In some cases (USB port PM in particular) that
leads to an endless busy loop of flipping the resource on and off
continuously.
It is needless, because whoever turns a power resource on will most
likely turn it off at some point and the devices that go into "D0"
as a result of turning it on will then go back into D3cold
(generally, the state they were in before).
Moreover, turning on all power resources a device needs to go into
D0 is not sufficient for a full transition into D0 in general.
Namely, _PS0 may need to be executed in addition to that in some
cases. This means that the whole rationale of the "resume of
dependent devices" mechanism was incorrect to begin with and it's
best to remove it entirely.
The expression in line 398 of intel_pstate.c causes the following
warning to be emitted:
drivers/cpufreq/intel_pstate.c:398:3: warning: left shift count >= width of type
which happens because unsigned long is 32-bit on some architectures.
Fix that by using a helper u64 variable and simplify the code
slightly.
Tested-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Rescind of subchannels were not being correctly handled. Fix the bug.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Cc: <stable@vger.kernel.org> [3.11+]
The USB3503 driver had an incorrect depedency on REGMAP, instead of
REGMAP_I2C. This caused the build to fail since the necessary regmap
i2c pieces were not available.
Signed-off-by: Matthew Dawson <matthew@mjdsystems.ca>
When CMA fails to initialize in v3.12-rc4, the chipidea driver oopses
the kernel while trying to remove and put the HCD which doesn't exist:
WARNING: CPU: 0 PID: 6 at /home/rmk/git/linux-rmk/arch/arm/mm/dma-mapping.c:511
__dma_alloc+0x200/0x240()
coherent pool not initialised!
Modules linked in:
CPU: 0 PID: 6 Comm: kworker/u2:0 Tainted: G W 3.12.0-rc4+ #56
Workqueue: deferwq deferred_probe_work_func
Backtrace:
[<c001218c>] (dump_backtrace+0x0/0x10c) from [<c0012328>] (show_stack+0x18/0x1c)
r6:c05fd9cc r5:000001ff r4:00000000 r3:df86ad00
[<c0012310>] (show_stack+0x0/0x1c) from [<c05f3a4c>] (dump_stack+0x70/0x8c)
[<c05f39dc>] (dump_stack+0x0/0x8c) from [<c00230a8>] (warn_slowpath_common+0x6c/0x8c)
r4:df883a60 r3:df86ad00
[<c002303c>] (warn_slowpath_common+0x0/0x8c) from [<c002316c>] (warn_slowpath_fmt+0x38/0x40)
r8:ffffffff r7:00001000 r6:c083b808 r5:00000000 r4:df2efe80
[<c0023134>] (warn_slowpath_fmt+0x0/0x40) from [<c00196bc>] (__dma_alloc+0x200/0x240)
r3:00000000 r2:c05fda00
[<c00194bc>] (__dma_alloc+0x0/0x240) from [<c001982c>] (arm_dma_alloc+0x88/0xa0)
[<c00197a4>] (arm_dma_alloc+0x0/0xa0) from [<c03e2904>] (ehci_setup+0x1f4/0x438)
[<c03e2710>] (ehci_setup+0x0/0x438) from [<c03cbd60>] (usb_add_hcd+0x18c/0x664)
[<c03cbbd4>] (usb_add_hcd+0x0/0x664) from [<c03e89f4>] (host_start+0xf0/0x180)
[<c03e8904>] (host_start+0x0/0x180) from [<c03e7c34>] (ci_hdrc_probe+0x360/0x670
r6:df2ef410 r5:00000000 r4:df2c3010 r3:c03e8904
[<c03e78d4>] (ci_hdrc_probe+0x0/0x670) from [<c0311044>] (platform_drv_probe+0x20/0x24)
[<c0311024>] (platform_drv_probe+0x0/0x24) from [<c030fcac>] (driver_probe_device+0x9c/0x234)
---[ end trace c88ccaf3969e8422 ]---
Unable to handle kernel NULL pointer dereference at virtual address 00000028
pgd = c0004000
[00000028] *pgd=00000000
Internal error: Oops: 17 [#1] SMP ARM
Modules linked in:
task: df86ad00 ti: df882000 task.ti: df882000
PC is at usb_remove_hcd+0x10/0x150
LR is at host_stop+0x1c/0x3c
pc : [<c03cacec>] lr : [<c03e88e4>] psr: 60000013
sp : df883b50 ip : df883b78 fp : df883b74
r10: c11f4c54 r9 : c0836450 r8 : df30c400
r7 : fffffff4 r6 : df2ef410 r5 : 00000000 r4 : df2c3010
r3 : 00000000 r2 : 00000000 r1 : df86b0a0 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 2f29404a DAC: 00000015
Process kworker/u2:0 (pid: 6, stack limit = 0xdf882240)
Stack: (0xdf883b50 to 0xdf884000)
Backtrace:
[<c03cacdc>] (usb_remove_hcd+0x0/0x150) from [<c03e88e4>] (host_stop+0x1c/0x3c)
[<c03e88c8>] (host_stop+0x0/0x3c) from [<c03e8aa0>] (ci_hdrc_host_destroy+0x1c/0x20)
[<c03e8a84>] (ci_hdrc_host_destroy+0x0/0x20) from [<c03e7c80>] (ci_hdrc_probe+0x3ac/0x670)
[<c030fc10>] (driver_probe_device+0x0/0x234) from [<c030ff28>] (__device_attach+0x44/0x48)
---[ end trace c88ccaf3969e8423 ]---
Fix this so at least we can continue booting and get to a shell prompt.
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Some USB drive enclosures do not correctly report an
overflow condition if they hold a drive with a capacity
over 2TB and are confronted with a READ_CAPACITY_10.
They answer with their capacity modulo 2TB.
The generic layer cannot cope with that. It must be told
to use READ_CAPACITY_16 from the beginning.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Cc: stable <stable@vger.kernel.org>
Interface 6 of this device speaks QMI as per tests done by us.
Credits go to Antonella for providing the hardware.
Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com>
Signed-off-by: Antonella Pellizzari <anto.pellizzari83@gmail.com>
Tested-by: Dan Williams <dcbw@redhat.com>
Due to missing braces on an if statement, in presence of a device_node a
port was always assigned -1, regardless of any alias entries in the
device tree. Conversely, if device_node was NULL, an unitialized port
ended up being used.
This patch adds the missing braces, fixing the issues.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
The device descriptors are messed up after remote wakeup
This patch fixes a particular type of data corruption that has been
encountered when loading a snapshot's metadata from disk.
When we allocate a new chunk in persistent_prepare, we increment
ps->next_free and we make sure that it doesn't point to a metadata area
by further incrementing it if necessary.
When we load metadata from disk on device activation, ps->next_free is
positioned after the last used data chunk. However, if this last used
data chunk is followed by a metadata area, ps->next_free is positioned
erroneously to the metadata area. A newly-allocated chunk is placed at
the same location as the metadata area, resulting in data or metadata
corruption.
This patch changes the code so that ps->next_free skips the metadata
area when metadata are loaded in function read_exceptions.
The patch also moves a piece of code from persistent_prepare_exception
to a separate function skip_metadata to avoid code duplication.
CVE-2013-4299
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Cc: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Pull device tree fixes and reverts from Grant Likely:
"One bug fix and three reverts. The reverts back out the slightly
controversial feeding the entire device tree into the random pool and
the reserved-memory binding which isn't fully baked yet. Expect the
reserved-memory patches at least to resurface for v3.13.
The bug fixes removes a scary but harmless warning on SPARC that was
introduced in the v3.12 merge window. v3.13 will contain a proper fix
that makes the new code work on SPARC.
On the plus side, the diffstat looks *awesome*. I love removing lines
of code"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Revert "drivers: of: add initialization code for dma reserved memory"
Revert "ARM: init: add support for reserved memory defined by device tree"
Revert "of: Feed entire flattened device tree into the random pool"
of: fix unnecessary warning on missing /cpus node
If the system is suspended while max_perf_pct is less than 100 percent
or no_turbo set policy->{min,max} will be set incorrectly with scaled
values which turn the scaled values into hard limits.
References: https://bugzilla.kernel.org/show_bug.cgi?id=61241
Reported-by: Patrick Bartels <petzicus@googlemail.com>
Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen fixes from Stefano Stabellini:
"A small fix for Xen on x86_32 and a build fix for xen-tpmfront on
arm64"
* tag 'stable/for-linus-3.12-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: Fix possible user space selector corruption
tpm: xen-tpmfront: fix missing declaration of xen_domain
Commit 1696d9d (ACPI: Remove the old /proc/acpi/event interface)
left /proc/acpi/event in the ACPI_BUTTON help in Kconfig, so
remove it from there.
[rjw: Changelog]
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
In acpi_resume_power_resources() resource_lock should be released
when acpi_power_get_state() fails and before passing to next power
resource on the list.
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Usually the active scan mask is freed in __iio_update_buffers() when the buffer
is disabled. But when the device is still sampling when it is removed we'll end
up disabling the buffers in iio_disable_all_buffers(). So we also need to free
the active scan mask here, otherwise it will be leaked.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
If EM Transmit bit is busy during init ata_msleep() is called. It is
wrong - msleep() should be used instead of ata_msleep(), because if EM
Transmit bit is busy for one port, it will be busy for all other ports
too, so using ata_msleep() causes wasting tries for another ports.
The most common scenario looks like that now
(six ports try to transmit a LED meaasege):
- port #0 tries for the 1st time and succeeds
- ports #1-5 try for the 1st time and sleeps
- port #1 tries for the 2nd time and succeeds
- ports #2-5 try for the 2nd time and sleeps
- port #2 tries for the 3rd time and succeeds
- ports #3-5 try for the 3rd time and sleeps
- port #3 tries for the 4th time and succeeds
- ports #4-5 try for the 4th time and sleeps
- port #4 tries for the 5th time and succeeds
- port #5 tries for the 5th time and sleeps
At this moment port #5 wasted all its five tries and failed to
initialize. Because there are only 5 (EM_MAX_RETRY) tries available
usually only five ports succeed to initialize. The sixth port and next
ones usually will fail.
If msleep() is used instead of ata_msleep() the first port succeeds to
initialize in the first try and next ones usually succeed to
initialize in the second try.
tj: updated comment
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is
still no consensus on the bindings for the reserved memory and various
drawbacks of the proposed solution has been shown, so the best now is to
revert it completely and start again from scratch later.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Pull vfio fix from Alex Williamson:
"Fix an incorrect break out of nested loop in iommu mapping code"
* tag 'vfio-v3.12-rc5' of git://github.com/awilliam/linux-vfio:
VFIO: vfio_iommu_type1: fix bug caused by break in nested loop
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband updates from Roland Dreier:
"Last batch of IB changes for 3.12: many mlx5 hardware driver fixes
plus one trivial semicolon cleanup"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB: Remove unnecessary semicolons
IB/mlx5: Ensure proper synchronization accessing memory
IB/mlx5: Fix alignment of reg umr gather buffers
IB/mlx5: Fix eq names to display nicely in /proc/interrupts
mlx5: Fix error code translation from firmware to driver
IB/mlx5: Fix opt param mask according to firmware spec
mlx5: Fix opt param mask for sq err to rts transition
IB/mlx5: Disable atomic operations
mlx5: Fix layout of struct mlx5_init_seg
mlx5: Keep polling to reclaim pages while any returned
IB/mlx5: Avoid async events on invalid port number
IB/mlx5: Decrease memory consumption of mr caches
mlx5: Remove checksum on command interface commands
IB/mlx5: Fix memory leak in mlx5_ib_create_srq
IB/mlx5: Flush cache workqueue before destroying it
IB/mlx5: Fix send work queue size calculation
This reverts commit 9b0a1de3c85d99d881c86a29b3d52da7b9c7bd61.
Aaro writes:
With v3.12-rc4 I can no longer connect to N800 (OMAP2) with USB
(peripheral, g_ether).
According to git bisect this is caused by:
9b0a1de3c85d99d881c86a29b3d52da7b9c7bd61 is the first bad commit
So revert this patch, as Felipe says:
It's unfortunate that tusb6010 is so messed up
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Bin Liu <b-liu@ti.com>
The device is not responsive when resumed, unless it is reset.
CC: stable@vger.kernel.org
These aren't necessary after switch blocks.
Signed-off-by: Roland Dreier <roland@purestorage.com>
"These fix two recent bugs in ACPIPHP (ACPI-based PCI hotplug) and
update a bunch of web links and e-mail addresses in MAINTAINERS, docs
and Kconfig that either are stale or will expire soon.
Specifics:
- The WARN_ON() in acpiphp_enumerate_slots() triggers as a false
positive in some cases, so drop it.
- Add a missing pci_dev_put() to an error code path in
acpiphp_enumerate_slots().
- Replace my old e-mail address that's going to expire with a new
one.
- Update ACPI web links and git tree information in MAINTAINERS.
- Update links to the Linux-ACPI project's page in MAINTAINERS.
- Update some stale links and e-mail addresses under Documentation
and in the ACPI Kconfig file"
* tag 'pm+acpi-3.12-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots()
ACPI / hotplug / PCI: Fix error code path in acpiphp_enumerate_slots()
ACPI / PM / Documentation: Replace outdated project links and addresses
MAINTAINERS / ACPI: Update links to the Linux-ACPI project web page
MAINTAINERS / ACPI: Update links and git tree information
MAINTAINERS / Documentation: Update Rafael's e-mail address
This reverts commit 109b6236294b53d8eaa50be7d9e9ad37079f5f7e.
Tim Bird expressed concern that this will have a bad effect on boot
time, and while simple tests have shown it to be okay with simple tree,
a device tree blob can potentially be quite large and
add_device_randomness() is not a fast function. Rather than do this for
all platforms unconditionally, I'm reverting this patch and would like
to see it revisited. Instead of feeding the entire tree into the random
pool, it would probably be appropriate to hash the tree and feed the
hash result into the pool. There really isn't a lot of randomness in a
device tree anyway. In the majority of cases only a handful of
properties are going to be different between machines with the same
baseboard.
Not all DT platforms have all the cpus collected under a /cpus node.
That just happens to be a details of FDT, ePAPR and PowerPC platforms.
Sparc does something different, but unfortunately the current code
complains with a warning if /cpus isn't there. This became a problem
with commit f86e4718, "driver/core cpu: initialize of_node in cpu's
device structure", which caused the function to get called for all
architectures.
This commit is a temporary fix to fail silently if the cpus node isn't
present. A proper fix will come later to allow arch code to provide a
custom mechanism for decoding the CPU hwid if the 'reg' property isn't
appropriate.
Cc: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Pull watchdog fixes from Wim Van Sebroeck:
"This will fix a deadlock on the ts72xx_wdt driver, fix bitmasks in the
kempld_wdt driver and fix a section mismatch in the sunxi_wdt driver"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: sunxi: Fix section mismatch
watchdog: kempld_wdt: Fix bit mask definition
watchdog: ts72xx_wdt: locking bug in ioctl
This driver has a section mismatch, for probe and remove functions,
leading to the following warning during the compilation.
WARNING: drivers/watchdog/built-in.o(.data+0x24): Section mismatch in
reference from the variable sunxi_wdt_driver to the function
.init.text:sunxi_wdt_probe()
The variable sunxi_wdt_driver references
the function __init sunxi_wdt_probe()
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
STAGE_CFG bits are defined as [5:4] bits. However, '(((x) & 0x30) << 4)'
handles [9:8] bits. Thus, it should be fixed in order to handle
[5:4] bits.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a
interruptible deadlock.
