path: root/drivers
2008-05-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (21 commits) Blackfin Serial Driver: abstract away DLAB differences into header Blackfin Serial Driver: macro away the IER differences between processors [Blackfin] arch: remove useless IRQ_SW_INT defines [Blackfin] arch: protect linux/usb/musb.h include until the driver gets mainlined [Blackfin] arch: protect linux/usb/isp1362.h include until the driver gets mainlined [Blackfin] arch: add EBIU supporting for BF54x EZKIT SMSC LAN911x/LAN921x families embedded ethernet driver [Blackfin] arch: Set spi flash partition on bf527 as like bf548. [Blackfin] arch: fix bug - Remove module will not free L1 memory used [Blackfin] arch: fix wrong header name in comment [Blackfin] arch: Fix BUG - spi flash on bf527 ezkit would fail at mount [Blackfin] arch: add twi_lcd and twi_keypad i2c board info to bf527-ezkit [Blackfin] arch: Add physmap partition for BF527-EZkit [Blackfin] arch: fix gdb testing regression [Blackfin] arch: disable single stepping when delivering a signal [Blackfin] arch: Delete unused (copied from m68k) entries in asm-offsets.c. [Blackfin] arch: In the double fault handler, set up the PT_RETI slot [Blackfin] arch: Support for CPU_FREQ and NOHZ [Blackfin] arch: Functional power management support: Add CPU and platform voltage scaling support [Blackfin] arch: fix bug - breaking the atomic sections code. [Blackfin] arch: Equalize include files: Add VR_CTL masks ...
2008-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (37 commits) SH: catch negative denormal_subf1() retval in denormal_add() sh: Fix DMAC base address for SH7709S sh: update smc91x platform data for se7206. sh: Stub in cpu_to_node() and friends for NUMA build. sh: intc register modify fix sh: no high level trigger on some sh3 cpus sh: clean up sh7710 and sh7720 intc tables sh: add interrupt ack code to sh3 sh: unify external irq pin code for sh3 sh-sci: avoid writing to nonexistent registers sh-sci: sh7722 lacks scsptr registers sh-sci: improve sh7722 support sh: reset hardware from early printk sh: drain and wait for early printk sh: use sci_out() for early printk sh: add memory resources to /proc/iomem sh: add kernel bss resource sh: fix sh7705 interrupt vector typo sh: update smc91x platform data for se7722 sh: update smc91x platform data for MigoR ...
2008-05-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) net: Added ASSERT_RTNL() to dev_open() and dev_close(). can: Fix can_send() handling on dev_queue_xmit() failures netns: Fix arbitrary net_device-s corruptions on net_ns stop. netfilter: Kconfig: default DCCP/SCTP conntrack support to the protocol config values netfilter: nf_conntrack_sip: restrict RTP expect flushing on error to last request macvlan: Fix memleak on device removal/crash on module removal net/ipv4: correct RFC 1122 section reference in comment tcp FRTO: SACK variant is errorneously used with NewReno e1000e: don't return half-read eeprom on error ucc_geth: Don't use RX clock as TX clock. cxgb3: Use CAP_SYS_RAWIO for firmware pcnet32: delete non NAPI code from driver. fs_enet: Fix a memory leak in fs_enet_mdio_probe [netdrvr] eexpress: IPv6 fails - multicast problems 3c59x: use netstats in net_device structure 3c980-TX needs EXTRA_PREAMBLE fix warning in drivers/net/appletalk/cops.c e1000e: Add support for BM PHYs on ICH9 uli526x: fix endianness issues in the setup frame uli526x: initialize the hardware prior to requesting interrupts ...
2008-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: [ALSA] soc at91 minor bug fixes [ALSA] soc - at91-pcm - Fix line wrapping pcspkr: fix dependancies
2008-05-08Fix drivers/media build for modular buildsIngo Molnar
Fix allmodconfig build bug introduced in latest -git by commit 7c91f0624a9 ("V4L/DVB(7767): Move tuners to common/tuners"): LD kernel/built-in.o LD drivers/built-in.o ld: drivers/media/built-in.o: No such file: No such file or directory which happens if all media drivers are modular: http://redhat.com/~mingo/misc/config-Wed_Apr_30_09_24_48_CEST_2008.bad In that case there's no obj-y rule connecting all the built-in.o files and the link tree breaks. The fix is to add a guaranteed obj-y rule for the core vmlinux to build. (which results in an empty object file if all media drivers are modular) Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ehca: Wait for async events to finish before destroying QP IB/ipath: Fix SDMA error recovery in absence of link status change IB/ipath: Need to always request and handle PIO avail interrupts IB/ipath: Fix count of packets received by kernel IB/ipath: Return the correct opcode for RDMA WRITE with immediate IB/ipath: Fix bug that can leave sends disabled after freeze recovery IB/ipath: Only increment SSN if WQE is put on send queue IB/ipath: Only warn about prototype chip during init RDMA/cxgb3: Fix severe limit on userspace memory registration size RDMA/cxgb3: Don't add PBL memory to gen_pool in chunks
2008-05-08Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: Revert "relay: fix splice problem" docbook: fix bio missing parameter block: use unitialized_var() in bio_alloc_bioset() block: avoid duplicate calls to get_part() in disk stat code cfq-iosched: make io priorities inherit CPU scheduling class as well as nice block: optimize generic_unplug_device() block: get rid of likely/unlikely predictions in merge logic vfs: splice remove_suid() cleanup cfq-iosched: fix RCU race in the cfq io_context destructor handling block: adjust tagging function queue bit locking block: sysfs store function needs to grab queue_lock and use queue_flag_*()
2008-05-08Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] guest page hinting light [S390] tty3270: fix put_char fail/success conversion. [S390] compat ptrace cleanup [S390] s390mach compile warning [S390] cio: Fix parsing mechanism for blacklisted devices. [S390] cio: Remove cio_msg kernel parameter. [S390] s390-kvm: leave sie context on work. Removes preemption requirement [S390] s390: Optimize user and work TIF check
2008-05-08drivers/scsi/dpt_i2o.c: fix build on alphaAndrew Morton
alpha: drivers/scsi/dpt_i2o.c:1997: error: implicit declaration of function 'adpt_alpha_info' drivers/scsi/dpt_i2o.c: At top level: drivers/scsi/dpt_i2o.c:2032: warning: conflicting types for 'adpt_alpha_info' drivers/scsi/dpt_i2o.c:2032: error: static declaration of 'adpt_alpha_info' follows non-static declaration drivers/scsi/dpt_i2o.c:1997: error: previous implicit declaration of 'adpt_alpha_info' was here Due to a copy-n-paste error in drivers/scsi/dpti.h. Fix that up and remove some of the many daft static-declarations-in-a-header which this driver enjoys. Cc: Miquel van Smoorenburg <miquels@cistron.nl> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08vt: fix canonical input in UTF-8 modeSamuel Thibault
For e.g. proper TTY canonical support, IUTF8 termios flag has to be set as appropriate. Linux used to not care about setting that flag for VT TTYs. This patch fixes that by activating it according to the current mode of the VT, and sets the default value according to the vt.default_utf8 parameter. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Willy Tarreau <w@1wt.eu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08usb/asix: add Buffalo LUA-U2-GT 10/100/1000Mattia Dongili
The USB net adapter Buffalo LUA-U2-GT (0411:006e) carries a AX88178 chip. Tested on the above HW. Signed-off-by: Mattia Dongili <malattia@linux.it> Acked-off-by: David Hollis <dhollis@davehollis.com> Cc: Greg KH <greg@kroah.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08sx.c: fix printk warnings on sparc32Andrew Morton
drivers/char/sx.c: In function 'sx_set_real_termios': drivers/char/sx.c:973: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'long unsigned int' drivers/char/sx.c:999: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'tcflag_t' drivers/char/sx.c:1012: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'tcflag_t' sparc32 seems to use weird types for its tty things. [ Fine by me but this is ancient debug and most of the debug in sx just wants deleting eventually. - Alan ] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08misc: fix integer as NULL pointer warningsHarvey Harrison
drivers/md/raid10.c:889:17: warning: Using plain integer as NULL pointer drivers/media/video/cx18/cx18-driver.c:616:12: warning: Using plain integer as NULL pointer sound/oss/kahlua.c:70:12: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08fix irq flags for iuu_phoenix.cSteven Rostedt
The file drivers/usb/serial/iuu_phoenix.c uses "int" for flags. This can cause hard to find bugs on some architectures. This patch converts the flags to use "long" instead. This bug was discovered by doing an allyesconfig make on the -rt kernel where checks are done to ensure all flags are of size sizeof(long). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08fix irq flags in rtc-ds1511Steven Rostedt
The file in drivers/rtc/rtc-ds1551.c uses "int" for flags. This can cause hard to find bugs on some architectures. This patch converts the flags to use "long" instead. This bug was discovered by doing an allyesconfig make on the -rt kernel where checks are done to ensure all flags are of size sizeof(long). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08fix irq flags in saa7134Steven Rostedt
Some files in the drivers/media/video/saa7134 directory uses "int" for flags. This can cause hard to find bugs on some architectures. This patch converts the flags to use "long" instead. This bug was discovered by doing an allyesconfig make on the -rt kernel where checks are done to ensure all flags are of size sizeof(long). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08serial: access after NULL check in uart_flush_buffer()Tetsuo Handa
I noticed that static void uart_flush_buffer(struct tty_struct *tty) { struct uart_state *state = tty->driver_data; struct uart_port *port = state->port; unsigned long flags; /* * This means you called this function _after_ the port was * closed. No cookie for you. */ if (!state || !state->info) { WARN_ON(1); return; } is too late for checking state != NULL. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Kconfig: improved help for CONFIG_ACCESSIBILITYSamuel Thibault
Add a small explanation of what accessibility is. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Merge branch 'upstream-davem' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-05-08macvlan: Fix memleak on device removal/crash on module removalPatrick McHardy
As noticed by Ben Greear, macvlan crashes the kernel when unloading the module. The reason is that it tries to clean up the macvlan_port pointer on the macvlan device itself instead of the underlying device. A non-NULL pointer is taken as indication that the macvlan_handle_frame_hook is valid, when receiving the next packet on the underlying device it tries to call the NULL hook and crashes. Clean up the macvlan_port on the correct device to fix this. Signed-off-by; Patrick McHardy <kaber@trash.net> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08sh-sci: avoid writing to nonexistent registersMagnus Damm
Only write to hardware in SCI_OUT() if the register size is valid. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh-sci: sh7722 lacks scsptr registersMagnus Damm
The sh7722 serial ports all lack SCSPTR registers, so mark them as nonexistent in the register table. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh-sci: improve sh7722 supportMagnus Damm
Improve sh7722 support for SCIF1 and SCIF2 and separate code from sh7366 implementation. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08rtc: rtc-sh: Fixup for 64-bit resources.Paul Mundt
ioremap() and friends get the size information right, so force everything to go through there. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08input: i8042: sh64 IRQ definitions depend on cayman board.Paul Mundt
2008-05-08sh: Enable use of the clk fwk on SH-5.Paul Mundt
2008-05-08mtd: solutionengine flash map depends on solution engine mach group.Paul Mundt
2008-05-08sh: remove the broken SH_MPC1211 supportAdrian Bunk
SH_MPC1211 has been marked as BROKEN for some time. Unless someone is working on reviving it now, I'd therefore suggest this patch to remove it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-07IB/ehca: Wait for async events to finish before destroying QPStefan Roscher
This is necessary because, in a multicore environment, a race between uverbs async handler and destroy QP could occur. Signed-off-by: Stefan Roscher <stefan.roscher at de.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Fix SDMA error recovery in absence of link status changeJohn Gregor
What's fixed: in ipath_cancel_sends() We need to unconditionally set ABORTING. So, swap the tests so the set_bit() isn't shadowed by the &&. If we've disarmed the piobufs, then we need to unconditionally set DISARMED. So, move it out from the overly protective if at the bottom. in sdma_abort_task() Abort_task was written knowing that the SDMA engine would always be reset (and restarted) on error. A recent change broke that fundamental assumption by taking the restart portion and making it conditional on a link status change. But, SDMA can go boom without a link status change in some conditions. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Need to always request and handle PIO avail interruptsDave Olson
Now that we always use PIO for vl15 on 7220, we could get stuck forever if we happened to run out of PIO buffers from the verbs code, because the setup code wouldn't run; the interrupt was also ignored if SDMA was supported. We also have to reduce the pio update threshold if we have fewer kernel buffers than the existing threshold. Clean up the initialization a bit to get ordering safer and more sensible, and use the existing ipath_chg_kernavail call to do init, rather than doing it separately. Drop unnecessary clearing of pio buffer on pio parity error. Drop incorrect updating of pioavailshadow when exitting freeze mode (software state may not match chip state if buffer has been allocated and not yet written). If we couldn't get a kernel buffer for a while, make sure we are in sync with hardware, mainly to handle the exitting freeze case. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Fix count of packets received by kernelMichael Albaugh
The loop in ipath_kreceive() that processes packets increments the loop-index 'i' once too often, because the exit condition does not depend on it, and is checked after the increment. By adding a check for !last to the iterator in the for loop, we correct that in a way that is not so likely to be re-broken by changes in the loop body. Signed-off-by: Michael Albaugh <micheal.albaugh@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Return the correct opcode for RDMA WRITE with immediateRalph Campbell
This patch fixes a bug in the RC responder which generates a completion entry with the wrong opcode when an RDMA WRITE with immediate is received. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Fix bug that can leave sends disabled after freeze recoveryDave Olson
The semantics of cancel_sends changed, but the code using it was missed. Don't leave sends and pioavail updates disabled, and add a comment as to why the force update is needed. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Only increment SSN if WQE is put on send queueRalph Campbell
If a send work request has immediate errors and is not put on the send queue, we shouldn't update any of the QP state. The increment of the SSN wasn't obeying this. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Only warn about prototype chip during initMichael Albaugh
We warn about prototype chips, but the function that checks for support is also called as a result of a get_portinfo request, which can clutter the logs. Restrict warning to only appear during initialization. Signed-off-by: Michael Albaugh <michael.albaugh@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07pcspkr: fix dependanciesStas Sergeev
fix pcspkr dependancies: make the pcspkr platform drivers to depend on a platform device, and not the other way around. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> CC: Vojtech Pavlik <vojtech@suse.cz> CC: Michael Opdenacker <michael-lists@free-electrons.com> [fixed for 2.6.26-rc1 by tiwai] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-07block: avoid duplicate calls to get_part() in disk stat codeJens Axboe
get_part() is fairly expensive, as it O(N) loops over partitions to find the right one. In lots of normal IO paths we end up looking up the partition twice, to make matters even worse. Change the stat add code to accept a passed in partition instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07[S390] tty3270: fix put_char fail/success conversion.Heiko Carstens
The wrong function got coverted ;) CC drivers/s390/char/tty3270.o drivers/s390/char/tty3270.c:1747: warning: initialization from incompatible pointer type Acked-by: Alan Cox <alan@redhat.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] s390mach compile warningMartin Schwidefsky
Fix the following compile warning: drivers/s390/s390mach.c: In function 's390_collect_crw_info': drivers/s390/s390mach.c:77: warning: ignoring return value of 'down_interruptibl Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] cio: Fix parsing mechanism for blacklisted devices.Michael Ernst
New format cssid.ssid.devno is now parsed correctly. Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] cio: Remove cio_msg kernel parameter.Michael Ernst
The only sporadically used CIO_DEBUG messages are replaced by ordinary CIO_MSG_EVENT messages. The CIO_MSG_EVENT messages debug levels are consolidated. Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07Blackfin Serial Driver: abstract away DLAB differences into headerMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-07Blackfin Serial Driver: macro away the IER differences between processorsMike Frysinger
2008-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix initrd regression. usb: Sparc build fix, make USB_ISP1760_OF depend on PPC_OF sparc64: remove online_page() sparc64: use compat_sys_utimes instead of home-grown local copy. sbus: Fix bpp driver build. sparc video: make blank use proper constant Revert "[SPARC64]: Wrap SMP IPIs with irq_enter()/irq_exit()." sparc: tcx.c remove unnecessary function
2008-05-06RDMA/cxgb3: Fix severe limit on userspace memory registration sizeRoland Dreier
Currently, iw_cxgb3 is severely limited on the amount of userspace memory that can be registered in in a single memory region, which causes big problems for applications that expect to be able to register 100s of MB. The problem is that the driver uses a single kmalloc()ed buffer to hold the physical buffer list (PBL) for the entire memory region during registration, which means that 8 bytes of contiguous memory are required for each page of memory being registered. For example, a 64 MB registration will require 128 KB of contiguous memory with 4 KB pages, and it unlikely that such an allocation will succeed on a busy system. This is purely a driver problem: the temporary page list buffer is not needed by the hardware, so we can fix this by writing the PBL to the hardware in page-sized chunks rather than all at once. We do this by splitting the memory registration operation up into several steps: - Allocate PBL space in adapter memory for the full registration - Copy PBL to adapter memory in chunks - Allocate STag and enable memory region This also allows several other cleanups to the __cxio_tpt_op() interface and related parts of the driver. This change leaves the reregister memory region and memory window operations broken, but they already didn't work due to other longstanding bugs, so fixing them will be left to a later patch. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-06usb: Sparc build fix, make USB_ISP1760_OF depend on PPC_OFDavid S. Miller
Sparc doesn't have some of the OF interfaces this driver wants to use. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-06RDMA/cxgb3: Don't add PBL memory to gen_pool in chunksRoland Dreier
Current iw_cxgb3 code adds PBL memory to the driver's gen_pool in 2 MB chunks. This limits the largest single allocation that can be done to the same size, which means that with 4 KB pages, each of which takes 8 bytes of PBL memory, the largest memory region that can be allocated is 1 GB (256K PBL entries * 4 KB/entry). Remove this limit by adding all the PBL memory in a single gen_pool chunk, if possible. Add code that falls back to smaller chunks if gen_pool_add() fails, which can happen if there is not sufficient contiguous lowmem for the internal gen_pool bitmap. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-06Fix bogus warning in sysdev_driver_register()OGAWA Hirofumi
if ((drv->entry.next != drv->entry.prev) || (drv->entry.next != NULL)) { warns list_empty(&drv->entry). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Greg KH <gregkh@suse.de> Cc: Len Brown <lenb@kernel.org> [ Version 2 totally redone based on suggestions from Linus & Greg ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-06e1000e: don't return half-read eeprom on errorKok, Auke
On a read error, e1000e might have returned uninitialized block of eeprom data back to userspace. The convention is that 0xff is "empty", so mark the entire eeprom as empty in case of an error. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
