* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits)
mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE
mmc: tmio_mmc: Move some defines into a shared header
mmc: tmio: support aggressive clock gating
mmc: tmio: fix power-mode interpretation
mmc: tmio: remove work-around for unmasked SDIO interrupts
sh: fix SDHI IO address-range
ARM: mach-shmobile: fix SDHI IO address-range
mmc: tmio: only access registers above 0xff, if available
mfd: remove now redundant sh_mobile_sdhi.h header
sh: convert boards to use linux/mmc/sh_mobile_sdhi.h
ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h
mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver
sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD
mmc: tmio: split core functionality, DMA and MFD glue
mmc: tmio: use PIO for short transfers
mmc: tmio-mmc: Improve DMA stability on sh-mobile
mmc: fix mmc_app_send_scr() for dma transfer
mmc: sdhci-esdhc: enable esdhc on imx53
mmc: sdhci-esdhc: use writel/readl as general APIs
mmc: sdhci: add the abort CMDTYPE bits definition
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Use new irq_move functions
xen: Convert genirq namespace
xen: fix p2m section mismatches
xen/p2m: Allocate p2m tracking pages on override
xen-gntdev: unlock on error path in gntdev_mmap()
xen-gntdev: return -EFAULT on copy_to_user failure
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: softdog.c: enhancement to optionally invoke panic instead of reboot on timer expiry
watchdog: fix nv_tco section mismatch
watchdog: sp5100_tco.c: Check if firmware has set correct value in tcobase.
watchdog: Convert release_resource to release_region/release_mem_region
watchdog: s3c2410_wdt.c: Convert release_resource to release_region/release_mem_region
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Fix potential memleak
* 'irq-final-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (111 commits)
gpio: ab8500: Mark broken
genirq: Remove move_*irq leftovers
genirq: Remove compat code
drivers: Final irq namespace conversion
mn10300: Use generic show_interrupts()
mn10300: Cleanup irq_desc access
mn10300: Convert genirq namespace
frv: Use generic show_interrupts()
frv: Convert genirq namespace
frv: Select GENERIC_HARDIRQS_NO_DEPRECATED
frv: Convert cpu irq_chip to new functions
frv: Convert mb93493 irq_chip to new functions
frv: Convert mb93093 irq_chip to new function
frv: Convert mb93091 irq_chip to new functions
frv: Fix typo from __do_IRQ overhaul
frv: Remove stale irq_chip.end
m68k: Convert irq function namespace
xen: Cleanup genirq namespace
unicore32: Use generic show_interrupts()
This patch fixes information leakage to the userspace by initializing
the data buffer to zero.
Reported-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com>
[ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way
deeper problems than a simple multiplication can fix. - Linus ]
We check the pointers together but at least one of them could be invalid
due to failed allocation. Since we cannot continue if either of the two
allocations has failed, exit early by freeing them both.
Cc: <stable@kernel.org> # 38.x
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
xfrm: Restrict extended sequence numbers to esp
xfrm: Check for esn buffer len in xfrm_new_ae
xfrm: Assign esn pointers when cloning a state
xfrm: Move the test on replay window size into the replay check functions
netdev: bfin_mac: document TE setting in RMII modes
drivers net: Fix declaration ordering in inline functions.
cxgb3: Apply interrupt coalescing settings to all queues
net: Always allocate at least 16 skb frags regardless of page size
ipv4: Don't ip_rt_put() an error pointer in RAW sockets.
net: fix ethtool->set_flags not intended -EINVAL return value
mlx4_en: Fix loss of promiscuity
tg3: Fix inline keyword usage
tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h>
net: use CHECKSUM_NONE instead of magic number
Net / jme: Do not use legacy PCI power management
myri10ge: small rx_done refactoring
bridge: notify applications if address of bridge device changes
ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo()
can: c_can: Fix tx_bytes accounting
can: c_can_platform: fix irq check in probe
These functions take irq_data as an argument and avoid a redundant
lookup in the sparse irq case.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Converted with coccinelle.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
This driver is broken in several aspects.
1) old style irq_chip functions. Sigh
2) Abuse of the unlock callback. That's not supposed to be a state
machine for evrything and some more.
Scripted with coccinelle.
Convert to the new function names. Scripted with coccinelle.
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: linux-parisc@vger.kernel.org
This is needed for determining the reason for failure when a softdog
timeout occurs.
We use softdog to watch for critical application failures and at the
minimum a snapshot of the system would help to determine the cause. In
such a scenario the application could fail but there isn't a softlockup as
such, hence the detect softlockup feature does not help.
The patch adds a module parameter soft_panic which when set to 1 causes
softdog to invoke panic instead of reboot when the softdog timer expires.
By invoking panic we execute kdump if it is configured and the vmcore
generated by kdump should provide atleast a minimal idea of the reason for
failure.
Based on an original patch by Ken Sugawara <sugaken.r3@gmail.com>
Signed-off-by: Anithra P J <anithra@linux.vnet.ibm.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Fix section mismatch warning:
Mark the called nv_tco_getdevice() as __devinit, just like its caller.
WARNING: drivers/watchdog/nv_tco.o(.devinit.text+0x16): Section mismatch in reference from the function nv_tco_init() to the function .init.text:nv_tco_getdevice()
The function __devinit nv_tco_init() references
a function __init nv_tco_getdevice().
If nv_tco_getdevice is only used by nv_tco_init then
annotate nv_tco_getdevice with a matching annotation.
Stefano found SP5100 TCO watchdog driver using wrong address.
[ 9.148536] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01
[ 9.148628] DEBUG __ioremap_caller WARNING address=b8fe00 size=8 valid=1 reserved=1
and e820 said that range is RAM.
We should check if we can use that reading out. BIOS could just program wrong address there.
Reported-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by:Yinghai Lu <yinghai@kernel.org>
Acked-by: Mike Waychison <mikew@google.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: stable <stable@kernel.org>
Request_mem_region should be used with release_mem_region, not
release_resource.
In pnx4008_wdt.c, a missing clk_put is added as well.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E;
*x = request_mem_region(...)
... when != release_mem_region(x)
when != x = E
* release_resource(x);
// </smpl>
release_resource.
The semantic match that finds this problem is as follows:
// <smpl>
expression x,E;
when != x = E
// </smpl>
The current code sometimes generates build warnings due to how it checks
the silicon revision, so clean it up and properly document things.
The correct usage should be "static inline void" instead of "static void inline"
Signed-off-by: G.Balaji <balajig81@gmail.com>
While testing the performance of different receive interrupt
coalescing settings on a single stream TCP benchmark, I noticed two
very different results. With rx-usecs=50, most of the time a
connection would hit 8280 Mbps but once in a while it would hit
9330 Mbps.
It turns out we are only applying the interrupt coalescing settings
to the first queue and whenever the rx hash would direct us onto
that queue we ran faster.
With this patch applied and rx-usecs=50, I get 9330 Mbps
consistently.
Acked-by: Divy Le Ray <divy@chelsio.com>
We incorrectly returned -EINVAL when none of the devices in the array
had an integrity profile. This in turn prevented mdadm from starting
the metadevice. Fix this so we only return errors on mismatched
profiles and memory allocation failures.
Reported-by: Giacomo Catenazzi <cate@cateee.net>
Reported-by: Thomas Gleixner <tglx@linutronix.de>
* 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
vlynq: Convert irq functions
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq; Fix cleanup fallout
genirq: Fix typo and remove unused variable
genirq: Fix new kernel-doc warnings
genirq: Add setter for AFFINITY_SET in irq_data state
genirq: Provide setter inline for IRQD_IRQ_INPROGRESS
genirq: Remove handle_IRQ_event
arm: Ns9xxx: Remove private irq flow handler
powerpc: cell: Use the core flow handler
genirq: Provide edge_eoi flow handler
genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_data
genirq: Split irq_set_affinity() so it can be called with lock held.
genirq: Add chip flag for restricting cpu_on/offline calls
genirq: Add chip hooks for taking CPUs on/off line.
genirq: Add irq disabled flag to irq_data state
genirq: Reserve the irq when calling irq_set_chip()
Fixes this build error:
drivers/memstick/host/r592.c:26: error: 'enable_dma' redeclared as different kind of symbol
arch/powerpc/include/asm/dma.h:189: note: previous definition of 'enable_dma' was here
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Alex Dubov <oakad@yahoo.com>
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (81 commits)
xo15-ebook: Remove device.wakeup_count
ips: use interruptible waits in ips-monitor
acer-wmi: does not poll device status when WMI event is available
acer-wmi: does not set persistence state by rfkill_init_sw_state
platform-drivers: x86: fix common misspellings
acer-wmi: use pr_<level> for messages
asus-wmi: potential NULL dereference in show_call()
asus-wmi: signedness bug in read_brightness()
platform-driver-x86: samsung-laptop: make dmi_check_cb to return 1 instead of 0
platform-driver-x86: fix wrong merge for compal-laptop.c
msi-laptop: use pr_<level> for messages
Platform: add Samsung Laptop platform driver
acer-wmi: Fix WMI ID
acer-wmi: deactive mail led when power off
msi-laptop: send out touchpad on/off key
acer-wmi: set the touchpad toggle key code to KEY_TOUCHPAD_TOGGLE
platform-driver-x86: intel_mid_thermal: fix unterminated platform_device_id table
sony-laptop: potential null dereference
sony-laptop: handle allocation failures
sony-laptop: return negative on failure in sony_nc_add()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson
* 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
mach-ux500: configure board for the TPS61052 regulator v2
mach-ux500: provide ab8500 init vector
mach-ux500: board support for AB8500 GPIO driver
gpio: driver for 42 AB8500 GPIO pins
The acpi video driver attempts to explicitly create a sysfs link between
the acpi device and the associated PCI device. However, we're now also
doing this from the backlight core, which means that we get a backtrace
caused by a duplicate file. Remove the code and leave it up to the
backlight core.
Reported-by: Jeff Chua <jeff.chua.linux@gmail.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Tested-by: Alessandro Suardi <alessandro.suardi@gmail.com>
Convert to the new irq_chip functions and the new namespace.
Acked-by: Florian Fainelli <florian@openwrt.org>
LKML-Reference: <alpine.LFD.2.00.1103252150180.31464@localhost6.localdomain6>
Stephen ran into the following build error:
drivers/mfd/cs5535-mfd.c:30:22: error: asm/olpc.h: No such file or directory
olpc.h exists only on x86 (and in the future, ARM). Rather than
wrapping the include in an #ifdef, just change cs5535-mfd to only build
on x86.
Signed-off-by: Andres Salomon <dilinger@queued.net>
In commit 95a0f10cddbf ("drbd: store in-core bitmap little endian,
regardless of architecture") drbd had made the sane choice to use
little-endian bitmap functions everywhere. However, it used the
horrible old functions names from <asm-generic/bitops/le.h>, that were
never really meant to be exported.
In the meantime, things got cleaned up, and in commit c4945b9ed472
("asm-generic: rename generic little-endian bitops functions") we
renamed the LE bitops to something sane, exactly so that they could be
used in random code without people gouging their eyes out when seeing
the crazy jumble of letters that were the old internal names.
As a result the drbd thing merged cleanly (commit 8d49a77568d1: "Merge
branch 'for-2.6.39/drivers' of git://git.kernel.dk/linux-2.6-block"),
since there was no data conflict - but the end result obviously doesn't
actually compile.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Cc: Jens Axboe <jaxboe@fusionio.com>
Fix build breakage on platforms, not providing readsw and writesw
functions, e.g., on x86(_64).
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
This is handled automatically now.
This is what I intended to do since:
1) the driver handles variable waits just fine, and
2) interruptible waits aren't reported as load in the load avg.
Reported-and-tested-by: Andreas Hartmann <andihartmann@freenet.de>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acer WMI hotkey event's result include current device status, just
need sync the status to killswitch after acer-wmi driver receive
hotkey event but not always poll device status. This is good for
performance.
But, if use EC raw mode, Acer BIOS will not emit wmi event and
leave EC to control device status. So, still startup polling job
when doesn't detect WMI event GUID or user choice to use ec_raw_mode.
Tested on Acer TravelMate 8572 notebook.
Cc: Carlos Corbacho <carlos@strangeworlds.co.uk>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Thomas Renninger <trenn@suse.de>
Signed-off-by: Lee, Chun-Yi <jlee@novell.com>
Acer BIOS keeps devices state when system reboot, but reset to default
device states (Wlan on, Bluetooth off, wwan on) if system cold boot.
That means BIOS's initial state is not always real persistence.
So, removed rfkill_init_sw_state because it sets initial state to
persistence then replicate to other new killswitch when rfkill-input
enabled.
After removed it, acer-wmi set initial soft-block state after rfkill
register, and doesn't allow set_block until rfkill initial finished.
Reference: bko#31002
https://bugzilla.kernel.org/show_bug.cgi?id=31002
Cc: OldÅich JedliÄka <oldium.pro@seznam.cz>
Cc: Johannes Berg <johannes@sipsolutions.net>
In the earlier check we assumed that "obj" could be NULL. I looked at
some of the other places that call evaluate_object() and they check
for NULL as well.
"err" needs to be signed for the error handling to work.
dmi_check_system() walks the table running matching functions until
someone returns non zero or we hit the end.
This patch makes dmi_check_cb to return 1 so dmi_check_system() return
immediately when a match is found.
I found the commit 80183a4b
"compal-laptop/fujitsu-laptop/msi-laptop: make dmi_check_cb to return 1 instead of 0"
has wrong patch merge.
The original patch change the return value for dmi_check_cb():
https://lkml.org/lkml/2010/7/2/88
But commit 80183a4b changed the return value for set_backlight_level.
This adds the samsung-laptop driver to the kernel. It now supports
all known Samsung laptops that use the SABI interface.
This patch change WMI ID to upper characters. With this patch module
acer-wmi is automatically loaded when WMI ID is detected.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
This patch deactive mail led when laptop is going to hibernete/suspend
or power off. After resume from hibernate/suspend correctly restore
mail led state.
