path: root/drivers/xen
2012-07-24Merge tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug: - Add MMCONFIG support for hot-added host bridges (Jiang Liu) Device hotplug: - Move fixups from __init to __devinit (Sebastian Andrzej Siewior) - Call FINAL fixups for hot-added devices, too (Myron Stowe) - Factor out generic code for P2P bridge hot-add (Yinghai Lu) - Remove all functions in a slot, not just those with _EJx (Amos Kong) Dynamic resource management: - Track bus number allocation (struct resource tree per domain) (Yinghai Lu) - Make P2P bridge 1K I/O windows work with resource reassignment (Bjorn Helgaas, Yinghai Lu) - Disable decoding while updating 64-bit BARs (Bjorn Helgaas) Power management: - Add PCIe runtime D3cold support (Huang Ying) Virtualization: - Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex Williamson) - Add quirks for devices with broken INTx masking (Jan Kiszka) Miscellaneous: - Fix some PCI Express capability version issues (Myron Stowe) - Factor out some arch code with a weak, generic, pcibios_setup() (Myron Stowe)" * tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits) PCI: hotplug: ensure a consistent return value in error case PCI: fix undefined reference to 'pci_fixup_final_inited' PCI: build resource code for M68K architecture PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width() PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits PCI: acpiphp: merge acpiphp_debug and debug PCI: acpiphp: remove unused res_lock sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: disable MEM decoding while updating 64-bit MEM BARs PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()' ...
2012-07-19xen PVonHVM: move shared_info to MMIO before kexecOlaf Hering
Currently kexec in a PVonHVM guest fails with a triple fault because the new kernel overwrites the shared info page. The exact failure depends on the size of the kernel image. This patch moves the pfn from RAM into MMIO space before the kexec boot. The pfn containing the shared_info is located somewhere in RAM. This will cause trouble if the current kernel is doing a kexec boot into a new kernel. The new kernel (and its startup code) can not know where the pfn is, so it can not reserve the page. The hypervisor will continue to update the pfn, and as a result memory corruption occours in the new kernel. One way to work around this issue is to allocate a page in the xen-platform pci device's BAR memory range. But pci init is done very late and the shared_info page is already in use very early to read the pvclock. So moving the pfn from RAM to MMIO is racy because some code paths on other vcpus could access the pfn during the small window when the old pfn is moved to the new pfn. There is even a small window were the old pfn is not backed by a mfn, and during that time all reads return -1. Because it is not known upfront where the MMIO region is located it can not be used right from the start in xen_hvm_init_shared_info. To minimise trouble the move of the pfn is done shortly before kexec. This does not eliminate the race because all vcpus are still online when the syscore_ops will be called. But hopefully there is no work pending at this point in time. Also the syscore_op is run last which reduces the risk further. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen: enable platform-pci only in a Xen guestOlaf Hering
While debugging kexec issues in a PVonHVM guest I modified xen_hvm_platform() to return false to disable all PV drivers. This caused a crash in platform_pci_init() because it expects certain data structures to be initialized properly. To avoid such a crash make sure the driver is initialized only if running in a Xen guest. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/pv-on-hvm kexec: shutdown watches from old kernelOlaf Hering
Add xs_reset_watches function to shutdown watches from old kernel after kexec boot. The old kernel does not unregister all watches in the shutdown path. They are still active, the double registration can not be detected by the new kernel. When the watches fire, unexpected events will arrive and the xenwatch thread will crash (jumps to NULL). An orderly reboot of a hvm guest will destroy the entire guest with all its resources (including the watches) before it is rebuilt from scratch, so the missing unregister is not an issue in that case. With this change the xenstored is instructed to wipe all active watches for the guest. However, a patch for xenstored is required so that it accepts the XS_RESET_WATCHES request from a client (see changeset 23839:42a45baf037d in xen-unstable.hg). Without the patch for xenstored the registration of watches will fail and some features of a PVonHVM guest are not available. The guest is still able to boot, but repeated kexec boots will fail. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/acpi: Fix potential memory leak.Konrad Rzeszutek Wilk
Coverity points out that we do not free in one case the pr_backup - and sure enough we forgot. Found by Coverity (CID 401970) Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/mce: add .poll method for mcelog device driverLiu, Jinsong
If a driver leaves its poll method NULL, the device is assumed to be both readable and writable without blocking. This patch add .poll method to xen mcelog device driver, so that when mcelog use system calls like ppoll or select, it would be blocked when no data available, and avoid spinning at CPU. Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/mce: schedule a workqueue to avoid sleep in atomic contextLiu, Jinsong
copy_to_user might sleep and print a stack trace if it is executed in an atomic spinlock context. Like this: (XEN) CMCI: send CMCI to DOM0 through virq BUG: sleeping function called from invalid context at /home/konradinux/kernel.h:199 in_atomic(): 1, irqs_disabled(): 0, pid: 4581, name: mcelog Pid: 4581, comm: mcelog Tainted: G O 3.5.0-rc1upstream-00003-g149000b-dirty #1 [<ffffffff8109ad9a>] __might_sleep+0xda/0x100 [<ffffffff81329b0b>] xen_mce_chrdev_read+0xab/0x140 [<ffffffff81148945>] vfs_read+0xc5/0x190 [<ffffffff81148b0c>] sys_read+0x4c/0x90 [<ffffffff815bd039>] system_call_fastpath+0x16 This patch schedule a workqueue for IRQ handler to poll the data, and use mutex instead of spinlock, so copy_to_user sleep in atomic context would not occur. Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/pcpu: Xen physical cpus online/offline sys interfaceLiu, Jinsong
This patch provide Xen physical cpus online/offline sys interface. User can use it for their own purpose, like power saving: by offlining some cpus when light workload it save power greatly. Its basic workflow is, user online/offline cpu via sys interface, then hypercall xen to implement, after done xen inject virq back to dom0, and then dom0 sync cpu status. Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/mce: Add mcelog support for Xen platformLiu, Jinsong
When MCA error occurs, it would be handled by Xen hypervisor first, and then the error information would be sent to initial domain for logging. This patch gets error information from Xen hypervisor and convert Xen format error into Linux format mcelog. This logic is basically self-contained, not touching other kernel components. By using tools like mcelog tool users could read specific error information, like what they did under native Linux. To test follow directions outlined in Documentation/acpi/apei/einj.txt Acked-and-tested-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Ke, Liping <liping.ke@intel.com> Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-06-15Merge tag 'stable/for-linus-3.5-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull five Xen bug-fixes from Konrad Rzeszutek Wilk: - When booting as PVHVM we would try to use PV console - but would not validate the parameters causing us to crash during restore b/c we re-use the wrong event channel. - When booting on machines with SR-IOV PCI bridge we didn't check for the bridge and tried to use it. - Under AMD machines would advertise the APERFMPERF resulting in needless amount of MSRs from the guest. - A global value (xen_released_pages) was not subtracted at bootup when pages were added back in. This resulted in the balloon worker having the wrong account of how many pages were truly released. - Fix dead-lock when xen-blkfront is run in the same domain as xen-blkback. * tag 'stable/for-linus-3.5-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: mark local pages as FOREIGN in the m2p_override xen/setup: filter APERFMPERF cpuid feature out xen/balloon: Subtract from xen_released_pages the count that is populated. xen/pci: Check for PCI bridge before using it. xen/events: Add WARN_ON when quick lookup found invalid type. xen/hvc: Check HVM_PARAM_CONSOLE_[EVTCHN|PFN] for correctness. xen/hvc: Fix error cases around HVM_PARAM_CONSOLE_PFN xen/hvc: Collapse error logic.
2012-06-12PCI: create common pcibios_err_to_errnoAlex Williamson
For returning errors out to non-PCI code. Re-name xen's version. Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-05-30xen/pci: Check for PCI bridge before using it.Zhang, Yang Z
Some SR-IOV devices may use more than one bus number, but there is no real bridges because that have internal routing mechanism. So need to check whether the bridge is existing before using it. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-30xen/events: Add WARN_ON when quick lookup found invalid type.Konrad Rzeszutek Wilk
All of the bind_XYZ_to_irq do a quick lookup to see if the event exists. And if it does, then the initialized IRQ number is returned instead of initializing a new IRQ number. This patch adds an extra logic to check that the type returned is proper one and that there is an IRQ handler setup for it. This patch has the benefit of being able to find drivers that are doing something naught. [v1: Enhanced based on Stefano's review] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-29Merge branch 'x86-trampoline-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 trampoline rework from H. Peter Anvin: "This code reworks all the "trampoline"/"realmode" code (various bits that need to live in the first megabyte of memory, most but not all of which runs in real mode at some point) in the kernel into a single object. The main reason for doing this is that it eliminates the last place in the kernel where we needed pages to be mapped RWX. This code separates all that code into proper R/RW/RX pages." Fix up conflicts in arch/x86/kernel/Makefile (mca removed next to reboot code), and arch/x86/kernel/reboot.c (reboot code moved around in one branch, modified in this one), and arch/x86/tools/relocs.c (mostly same code came in earlier due to working around the ld bugs just before the 3.4 release). Also remove stale x86-relocs entry from scripts/.gitignore as per Peter Anvin. * commit '61f5446169046c217a5479517edac3a890c3bee7': (36 commits) x86, realmode: Move end signature into header.S x86, relocs: When printing an error, say relative or absolute x86, relocs: More relocations which may end up as absolute x86, relocs: Workaround for binutils 2.22.52.0.1 section bug xen-acpi-processor: Add missing #include <xen/xen.h> acpi, bgrd: Add missing <linux/io.h> to drivers/acpi/bgrt.c x86, realmode: Change EFER to a single u64 field x86, realmode: Move kernel/realmode.c to realmode/init.c x86, realmode: Move not-common bits out of trampoline_common.S x86, realmode: Mask out EFER.LMA when saving trampoline EFER x86, realmode: Fix no cache bits test in reboot_32.S x86, realmode: Make sure all generated files are listed in targets x86, realmode: build fix: remove duplicate build x86, realmode: read cr4 and EFER from kernel for 64-bit trampoline x86, realmode: fixes compilation issue in tboot.c x86, realmode: move relocs from scripts/ to arch/x86/tools x86, realmode: header for trampoline code x86, realmode: flattened rm hierachy x86, realmode: don't copy real_mode_header x86, realmode: fix 64-bit wakeup sequence ...
2012-05-24Merge tag 'stable/for-linus-3.5-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen updates from Konrad Rzeszutek Wilk: "Features: * Extend the APIC ops implementation and add IRQ_WORKER vector support so that 'perf' can work properly. * Fix self-ballooning code, and balloon logic when booting as initial domain. * Move array printing code to generic debugfs * Support XenBus domains. * Lazily free grants when a domain is dead/non-existent. * In M2P code use batching calls Bug-fixes: * Fix NULL dereference in allocation failure path (hvc_xen) * Fix unbinding of IRQ_WORKER vector during vCPU hot-unplug * Fix HVM guest resume - we would leak an PIRQ value instead of reusing the existing one." Fix up add-add onflicts in arch/x86/xen/enlighten.c due to addition of apic ipi interface next to the new apic_id functions. * tag 'stable/for-linus-3.5-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: do not map the same GSI twice in PVHVM guests. hvc_xen: NULL dereference on allocation failure xen: Add selfballoning memory reservation tunable. xenbus: Add support for xenbus backend in stub domain xen/smp: unbind irqworkX when unplugging vCPUs. xen: enter/exit lazy_mmu_mode around m2p_override calls xen/acpi/sleep: Enable ACPI sleep via the __acpi_os_prepare_sleep xen: implement IRQ_WORK_VECTOR handler xen: implement apic ipi interface xen/setup: update VA mapping when releasing memory during setup xen/setup: Combine the two hypercall functions - since they are quite similar. xen/setup: Populate freed MFNs from non-RAM E820 entries and gaps to E820 RAM xen/setup: Only print "Freeing XXX-YYY pfn range: Z pages freed" if Z > 0 xen/gnttab: add deferred freeing logic debugfs: Add support to print u32 array in debugfs xen/p2m: An early bootup variant of set_phys_to_machine xen/p2m: Collapse early_alloc_p2m_middle redundant checks. xen/p2m: Allow alloc_p2m_middle to call reserve_brk depending on argument xen/p2m: Move code around to allow for better re-usage.
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-21xen: do not map the same GSI twice in PVHVM guests.Stefano Stabellini
PV on HVM guests map GSIs into event channels. At restore time the event channels are resumed by restore_pirqs. Device drivers might try to register the same GSI again through ACPI at restore time, but the GSI has already been mapped and bound by restore_pirqs. This patch detects these situations and avoids mapping the same GSI multiple times. Without this patch we get: (XEN) irq.c:2235: dom4: pirq 23 or emuirq 28 already mapped and waste a pirq. CC: stable@kernel.org Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-21xen: Add selfballoning memory reservation tunable.Jana Saout
Currently, the memory target in the Xen selfballooning driver is mainly driven by the value of "Committed_AS". However, there are cases in which it is desirable to assign additional memory to be available for the kernel, e.g. for local caches (which are not covered by cleancache), e.g. dcache and inode caches. This adds an additional tunable in the selfballooning driver (accessible via sysfs) which allows the user to specify an additional constant amount of memory to be reserved by the selfballoning driver for the local domain. Signed-off-by: Jana Saout <jana@saout.de> Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-21xenbus: Add support for xenbus backend in stub domainDaniel De Graaf
Add an ioctl to the /dev/xen/xenbus_backend device allowing the xenbus backend to be started after the kernel has booted. This allows xenstore to run in a different domain from the dom0. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-17xen-acpi-processor: Add missing #include <xen/xen.h>H. Peter Anvin
This file depends on <xen/xen.h>, but the dependency was hidden due to: <asm/acpi.h> -> <asm/trampoline.h> -> <asm/io.h> -> <xen/xen.h> With the removal of <asm/trampoline.h>, this exposed the missing Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Len Brown <lenb@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-05-15frontswap: s/put_page/store/g s/get_page/loadKonrad Rzeszutek Wilk
Sounds so much more natural. Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-07xen: enter/exit lazy_mmu_mode around m2p_override callsStefano Stabellini
This patch is a significant performance improvement for the m2p_override: about 6% using the gntdev device. Each m2p_add/remove_override call issues a MULTI_grant_table_op and a __flush_tlb_single if kmap_op != NULL. Batching all the calls together is a great performance benefit because it means issuing one hypercall total rather than two hypercall per page. If paravirt_lazy_mode is set PARAVIRT_LAZY_MMU, all these calls are going to be batched together, otherwise they are issued one at a time. Adding arch_enter_lazy_mmu_mode/arch_leave_lazy_mmu_mode around the m2p_add/remove_override calls forces paravirt_lazy_mode to PARAVIRT_LAZY_MMU, therefore makes sure that they are always batched. However it is not safe to call arch_enter_lazy_mmu_mode if we are in interrupt context or if we are already in PARAVIRT_LAZY_MMU mode, so check for both conditions before doing so. Changes in v4: - rebased on 3.4-rc4: all the m2p_override users call gnttab_unmap_refs and gnttab_map_refs; - check whether we are in interrupt context and the lazy_mode we are in before calling arch_enter/leave_lazy_mmu_mode. Changes in v3: - do not call arch_enter/leave_lazy_mmu_mode in xen_blkbk_unmap, that can be called in interrupt context. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> [v5: s/int lazy/bool lazy/] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-07xen/acpi/sleep: Enable ACPI sleep via the __acpi_os_prepare_sleepKonrad Rzeszutek Wilk
Provide the registration callback to call in the Xen's ACPI sleep functionality. This means that during S3/S5 we make a hypercall XENPF_enter_acpi_sleep with the proper PM1A/PM1B registers. Based of Ke Yu's <ke.yu@intel.com> initial idea. [ From http://xenbits.xensource.com/linux-2.6.18-xen.hg change c68699484a65 ] [v1: Added Copyright and license] [v2: Added check if PM1A/B the 16-bits MSB contain something. The spec only uses 16-bits but might have more in future] Signed-off-by: Liang Tang <liang.tang@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-07xen/Kconfig: fix Kconfig layoutAndrew Morton
Fit it into 80 columns so that it is readable in menuconfig. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-26xen/acpi: Workaround broken BIOSes exporting non-existing C-states.Konrad Rzeszutek Wilk
We did a similar check for the P-states but did not do it for the C-states. What we want to do is ignore cases where the DSDT has definition for sixteen CPUs, but the machine only has eight CPUs and we get: xen-acpi-processor: (CX): Hypervisor error (-22) for ACPI CPU14 Reported-by: Tobias Geiger <tobias.geiger@vido.info> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-26xen: use the pirq number to check the pirq_eoi_mapStefano Stabellini
In pirq_check_eoi_map use the pirq number rather than the Linux irq number to check whether an eoi is needed in the pirq_eoi_map. The reason is that the irq number is not always identical to the pirq number so if we wrongly use the irq number to check the pirq_eoi_map we are going to check for the wrong pirq to EOI. As a consequence some interrupts might not be EOI'ed by the guest correctly. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Tested-by: Tobias Geiger <tobias.geiger@vido.info> [v1: Added some extra wording to git commit] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-19xen/resume: Fix compile warnings.Konrad Rzeszutek Wilk
linux/drivers/xen/manage.c: In function 'do_suspend': linux/drivers/xen/manage.c:160:5: warning: 'si.cancelled' may be used uninitialized in this function Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-19xen/xenbus: Add quirk to deal with misconfigured backends.Konrad Rzeszutek Wilk
A rather annoying and common case is when booting a PVonHVM guest and exposing the PV KBD and PV VFB - as broken toolstacks don't always initialize the backends correctly. Normally The HVM guest is using the VGA driver and the emulated keyboard for this (though upstream version of QEMU implements PV KBD, but still uses a VGA driver). We provide a very basic two-stage wait mechanism - where we wait for 30 seconds for all devices, and then for 270 for all them except the two mentioned. That allows us to wait for the essential devices, like network or disk for the full 6 minutes. To trigger this, put this in your guest config: vfb = [ 'vnc=1, vnclisten=0.0.0.0 ,vncunused=1'] instead of this: vnc=1 vnclisten="0.0.0.0" CC: stable@kernel.org Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> [v3: Split delay in non-essential (30 seconds) and essential devices per Ian and Stefano suggestion] [v4: Added comments per Stefano suggestion] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-18Merge commit 'c104f1fa1ecf4ee0fc06e31b1f77630b2551be81' into ↵Konrad Rzeszutek Wilk
stable/for-linus-3.4 * commit 'c104f1fa1ecf4ee0fc06e31b1f77630b2551be81': (14566 commits) cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUS sparc64: Eliminate obsolete __handle_softirq() function sparc64: Fix bootup crash on sun4v. kconfig: delete last traces of __enabled_ from autoconf.h Revert "kconfig: fix __enabled_ macros definition for invisible and un-selected symbols" kconfig: fix IS_ENABLED to not require all options to be defined irq_domain: fix type mismatch in debugfs output format staging: android: fix mem leaks in __persistent_ram_init() staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl() staging: iio: hmc5843: Fix crash in probe function. panic: fix stack dump print on direct call to panic() drivers/rtc/rtc-pl031.c: enable clock on all ST variants Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()" hugetlb: fix race condition in hugetlb_fault() drivers/rtc/rtc-twl.c: use static register while reading time drivers/rtc/rtc-s3c.c: add placeholder for driver private data drivers/rtc/rtc-s3c.c: fix compilation error MAINTAINERS: add PCDP console maintainer memcg: do not open code accesses to res_counter members drivers/rtc/rtc-efi.c: fix section mismatch warning ...
2012-04-17xen/gnttab: add deferred freeing logicJan Beulich
Rather than just leaking pages that can't be freed at the point where access permission for the backend domain gets revoked, put them on a list and run a timer to (infrequently) retry freeing them. (This can particularly happen when unloading a frontend driver when devices are still present, and the backend still has them in non-closed state or hasn't finished closing them yet.) Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-17xen/gntdev: do not set VM_PFNMAPStefano Stabellini
Since we are using the m2p_override we do have struct pages corresponding to the user vma mmap'ed by gntdev. Removing the VM_PFNMAP flag makes get_user_pages work on that vma. An example test case would be using a Xen userspace block backend (QDISK) on a file on NFS using O_DIRECT. CC: stable@kernel.org Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-17xen/grant-table: add error-handling code on failure of gnttab_resumeJulia Lawall
Jump to the label ini_nomem as done on the failure of the page allocations above. The code at ini_nomem is modified to accommodate different return values. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-16Fix typo in various Kconfig fileMasanari Iida
Correct spelling typo in various Kconfig file. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-06Merge tag 'stable/for-linus-3.4-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull xen fixes from Konrad Rzeszutek Wilk: "Two fixes for regressions: * one is a workaround that will be removed in v3.5 with proper fix in the tip/x86 tree, * the other is to fix drivers to load on PV (a previous patch made them only load in PVonHVM mode). The rest are just minor fixes in the various drivers and some cleanup in the core code." * tag 'stable/for-linus-3.4-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pcifront: avoid pci_frontend_enable_msix() falsely returning success xen/pciback: fix XEN_PCI_OP_enable_msix result xen/smp: Remove unnecessary call to smp_processor_id() xen/x86: Workaround 'x86/ioapic: Add register level checks to detect bogus io-apic entries' xen: only check xen_platform_pci_unplug if hvm
2012-04-06xen/pciback: fix XEN_PCI_OP_enable_msix resultJan Beulich
Prior to 2.6.19 and as of 2.6.31, pci_enable_msix() can return a positive value to indicate the number of vectors (less than the amount requested) that can be set up for a given device. Returning this as an operation value (secondary result) is fine, but (primary) operation results are expected to be negative (error) or zero (success) according to the protocol. With the frontend fixed to match the XenoLinux behavior, the backend can now validly return zero (success) here, passing the upper limit on the number of vectors in op->value. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-03-28X86 & IA64: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [removed swiotlb related changes and replaced it with wrappers, merged with IA64 patch to avoid inter-patch dependences in intel-iommu code] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Luck <tony.luck@intel.com>
2012-03-24Merge tag 'stable/for-linus-3.4-tag-two' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull more xen updates from Konrad Rzeszutek Wilk: "One tiny feature that accidentally got lost in the initial git pull: * Add fast-EOI acking of interrupts (clear a bit instead of hypercall) And bug-fixes: * Fix CPU bring-up code missing a call to notify other subsystems. * Fix reading /sys/hypervisor even if PVonHVM drivers are not loaded. * In Xen ACPI processor driver: remove too verbose WARN messages, fix up the Kconfig dependency to be a module by default, and add dependency on CPU_FREQ. * Disable CPU frequency drivers from loading when booting under Xen (as we want the Xen ACPI processor to be used instead). * Cleanups in tmem code." * tag 'stable/for-linus-3.4-tag-two' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/acpi: Fix Kconfig dependency on CPU_FREQ xen: initialize platform-pci even if xen_emul_unplug=never xen/smp: Fix bringup bug in AP code. xen/acpi: Remove the WARN's as they just create noise. xen/tmem: cleanup xen: support pirq_eoi_map xen/acpi-processor: Do not depend on CPU frequency scaling drivers. xen/cpufreq: Disable the cpu frequency scaling drivers from loading. provide disable_cpufreq() function to disable the API.
2012-03-24xen/acpi: Fix Kconfig dependency on CPU_FREQKonrad Rzeszutek Wilk
The functions: "acpi_processor_*" sound like they depend on CONFIG_ACPI_PROCESSOR but in reality they are exposed when CONFIG_CPU_FREQ=[y|m]. As such update the Kconfig to have this dependency and fix compile issues: ERROR: "acpi_processor_unregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_notify_smm" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_register_performance" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_preregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined! Note: We still need the CONFIG_ACPI Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-22Merge tag 'stable/for-linus-3.4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull xen updates from Konrad Rzeszutek Wilk: "which has three neat features: - PV multiconsole support, so that there can be hvc1, hvc2, etc; This can be used in HVM and in PV mode. - P-state and C-state power management driver that uploads said power management data to the hypervisor. It also inhibits cpufreq scaling drivers to load so that only the hypervisor can make power management decisions - fixing a weird perf bug. There is one thing in the Kconfig that you won't like: "default y if (X86_ACPI_CPUFREQ = y || X86_POWERNOW_K8 = y)" (note, that it all depends on CONFIG_XEN which depends on CONFIG_PARAVIRT which by default is off). I've a fix to convert that boolean expression into "default m" which I am going to post after the cpufreq git pull - as the two patches to make this work depend on a fix in Dave Jones's tree. - Function Level Reset (FLR) support in the Xen PCI backend. Fixes: - Kconfig dependencies for Xen PV keyboard and video - Compile warnings and constify fixes - Change over to use percpu_xxx instead of this_cpu_xxx" Fix up trivial conflicts in drivers/tty/hvc/hvc_xen.c due to changes to a removed commit. * tag 'stable/for-linus-3.4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen kconfig: relax INPUT_XEN_KBDDEV_FRONTEND deps xen/acpi-processor: C and P-state driver that uploads said data to hypervisor. xen: constify all instances of "struct attribute_group" xen/xenbus: ignore console/0 hvc_xen: introduce HVC_XEN_FRONTEND hvc_xen: implement multiconsole support hvc_xen: support PV on HVM consoles xenbus: don't free other end details too early xen/enlighten: Expose MWAIT and MWAIT_LEAF if hypervisor OKs it. xen/setup/pm/acpi: Remove the call to boot_option_idle_override. xenbus: address compiler warnings xen: use this_cpu_xxx replace percpu_xxx funcs xen/pciback: Support pci_reset_function, aka FLR or D3 support. pci: Introduce __pci_reset_function_locked to be used when holding device_lock. xen: Utilize the restore_msi_irqs hook.
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-22xen: initialize platform-pci even if xen_emul_unplug=neverIgor Mammedov
When xen_emul_unplug=never is specified on kernel command line reading files from /sys/hypervisor is broken (returns -EBUSY). It is caused by xen_bus dependency on platform-pci and platform-pci isn't initialized when xen_emul_unplug=never is specified. Fix it by allowing platform-pci to ignore xen_emul_unplug=never, and do not intialize xen_[blk|net]front instead. Signed-off-by: Igor Mammedov <imammedo@redhat.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-21xen/acpi: Remove the WARN's as they just create noise.Konrad Rzeszutek Wilk
When booting the kernel under machines that do not have P-states we would end up with: ------------[ cut here ]------------ WARNING: at drivers/xen/xen-acpi-processor.c:504 xen_acpi_processor_init+0x286/0 x2e0() Hardware name: ProLiant BL460c G6 Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.39-200.0.3.el5uek #1 Call Trace: [<ffffffff8191d056>] ? xen_acpi_processor_init+0x286/0x2e0 [<ffffffff81068300>] warn_slowpath_common+0x90/0xc0 [<ffffffff8191cdd0>] ? check_acpi_ids+0x1e0/0x1e0 [<ffffffff8106834a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8191d056>] xen_acpi_processor_init+0x286/0x2e0 [<ffffffff8191cdd0>] ? check_acpi_ids+0x1e0/0x1e0 [<ffffffff81002168>] do_one_initcall+0xe8/0x130 .. snip.. Which is OK - the machines do not have P-states, so we fail to register to process the _PXX states. But there is no need to WARN the user of it. Oracle BZ# 13871288 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-20xen/tmem: cleanupJan Beulich
Use 'bool' for boolean variables. Do proper section placement. Eliminate an unnecessary export. Signed-off-by: Jan Beulich <jbeulich@suse.com> Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-20xen: support pirq_eoi_mapStefano Stabellini
The pirq_eoi_map is a bitmap offered by Xen to check which pirqs need to be EOI'd without having to issue an hypercall every time. We use PHYSDEVOP_pirq_eoi_gmfn_v2 to map the bitmap, then if we succeed we use pirq_eoi_map to check whether pirqs need eoi. Changes in v3: - explicitly use PHYSDEVOP_pirq_eoi_gmfn_v2 rather than PHYSDEVOP_pirq_eoi_gmfn; - introduce pirq_check_eoi_map, a function to check if a pirq needs an eoi using the map; -rename pirq_needs_eoi into pirq_needs_eoi_flag; - introduce a function pointer called pirq_needs_eoi that is going to be set to the right implementation depending on the availability of PHYSDEVOP_pirq_eoi_gmfn_v2. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-20xen/acpi-processor: Do not depend on CPU frequency scaling drivers.Konrad Rzeszutek Wilk
With patch "xen/cpufreq: Disable the cpu frequency scaling drivers from loading." we do not have to worry about said drivers loading themselves before the xen-acpi-processor driver. Hence we can remove the default selection (=y if CPU frequency drivers were built-in, or =m if CPU frequency drivers were built as modules), and just select =m for the default case. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-19Merge branch 'stable/cleancache.v13' into linux-nextKonrad Rzeszutek Wilk
* stable/cleancache.v13: mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-14xen/acpi-processor: C and P-state driver that uploads said data to hypervisor.Konrad Rzeszutek Wilk
This driver solves three problems: 1). Parse and upload ACPI0007 (or PROCESSOR_TYPE) information to the hypervisor - aka P-states (cpufreq data). 2). Upload the the Cx state information (cpuidle data). 3). Inhibit CPU frequency scaling drivers from loading. The reason for wanting to solve 1) and 2) is such that the Xen hypervisor is the only one that knows the CPU usage of different guests and can make the proper decision of when to put CPUs and packages in proper states. Unfortunately the hypervisor has no support to parse ACPI DSDT tables, hence it needs help from the initial domain to provide this information. The reason for 3) is that we do not want the initial domain to change P-states while the hypervisor is doing it as well - it causes rather some funny cases of P-states transitions. For this to work, the driver parses the Power Management data and uploads said information to the Xen hypervisor. It also calls acpi_processor_notify_smm() to inhibit the other CPU frequency scaling drivers from being loaded. Everything revolves around the 'struct acpi_processor' structure which gets updated during the bootup cycle in different stages. At the startup, when the ACPI parser starts, the C-state information is processed (processor_idle) and saved in said structure as 'power' element. Later on, the CPU frequency scaling driver (powernow-k8 or acpi_cpufreq), would call the the acpi_processor_* (processor_perflib functions) to parse P-states information and populate in the said structure the 'performance' element. Since we do not want the CPU frequency scaling drivers from loading we have to call the acpi_processor_* functions to parse the P-states and call "acpi_processor_notify_smm" to stop them from loading. There is also one oddity in this driver which is that under Xen, the physical online CPU count can be different from the virtual online CPU count. Meaning that the macros 'for_[online|possible]_cpu' would process only up to virtual online CPU count. We on the other hand want to process the full amount of physical CPUs. For that, the driver checks if the ACPI IDs count is different from the APIC ID count - which can happen if the user choose to use dom0_max_vcpu argument. In such a case a backup of the PM structure is used and uploaded to the hypervisor. [v1-v2: Initial RFC implementations that were posted] [v3: Changed the name to passthru suggested by Pasi Kärkkäinen <pasik@iki.fi>] [v4: Added vCPU != pCPU support - aka dom0_max_vcpus support] [v5: Cleaned up the driver, fix bug under Athlon XP] [v6: Changed the driver to a CPU frequency governor] [v7: Jan Beulich <jbeulich@suse.com> suggestion to make it a cpufreq scaling driver made me rework it as driver that inhibits cpufreq scaling driver] [v8: Per Jan's review comments, fixed up the driver] [v9: Allow to continue even if acpi_processor_preregister_perf.. fails] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-14xen: constify all instances of "struct attribute_group"Jan Beulich
The functions these get passed to have been taking pointers to const since at least 2.6.16. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
