path: root/drivers/watchdog/gef_wdt.c
2013-03-01watchdog: gef_wdt.c: add missing remove callbackDevendra Naga
this module missed a remove callback in the platform ops. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-11-28watchdog: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: gef_wdt: fix MODULE_ALIASAxel Lin
Remove the space between "platform:" prefix and the driver name. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-02watchdog: gef_wdt: include fs.hWolfram Sang & Martyn Welch
Add missing include "linux/fs.h". This fixes compile failure. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-02of/watchdog: gef_wdt.c: fix build breakageAnatolij Gustschin
Fixes build error caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] gef_wdt: Author corrections following split of GE Fanuc joint ventureMartyn Welch
This patch corrects author and copyright notices following the split-up of the GE Fanuc joint venture. Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-05[WATCHDOG] gef_wdt.c: fsl_get_sys_freq() failure not noticedRoel Kluin
fsl_get_sys_freq() may return -1 when 'soc' isn't found, but in gef_wdt_probe() 'freq' is unsigned, so the test doesn't catch that. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-01-12[WATCHDOG] Basic support for GE Fanuc's FPGA based watchdog timerMartyn Welch
GE Fanuc SBC610 Support for the FPGA based watchdog timer as found on GE Fanuc's SBC310, SBC610 and PPC9A Single Board Computers. This patch adds support for the watchdog timer found in one of the devices FPGAs. There are two identical watchdog timers at different offsets in the above mentioned boards, this driver is capable of supporting one of them. The watchdog timers are also capable of generating interrupts at a user-configurable threshold, though support for this operation is currently not supported by the driver. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
