path: root/drivers/watchdog/Kconfig
2009-12-18watchdog: update geodewdt for new MFGPT APIAndres Salomon
Update to the new cs5535_mfgpt* API. The geode-specific wording should eventually be dropped from this driver... Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17MIPS: eXcite: Remove platform.Ralf Baechle
The platform has never been fully merged Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-kernel@vger.kernel.org Cc: linux-mtd@lists.infradead.org Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be>
2009-12-08mpc52xx/wdt: remove obsolete old WDT implementationAlbrecht Dreß
Remove the old WDT implementation. Signed-off-by: Albrecht Dreß <albrecht.dress@arcor.de> Acked-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-09-25[WATCHDOG] Add support for the Avionic Design Xanthos watchdog timer.Thierry Reding
This patch adds support for the watchdog timer on Avionic Design Xanthos boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-09-18[WATCHDOG] Add support for WM831x watchdogMark Brown
The WM831x series of devices provide a watchdog with configurable behaviour on timer expiry. Currently this driver support refreshes via a register or GPIO line and autonomous refreshes from a hardware source (eg, a clock). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-09-18[WATCHDOG] Add watchdog driver for NUC900Wan ZongShun
Add watchdog device driver for the Nuvoton NUC900 series SoCs. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-09-18[WATCHDOG] add SBC-FITPC2 watchdog driverDenis Turischev
Add support for watchdog found on SBC-FITPC2 board. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-06-23[WATCHDOG] wdt_pci.c: remove #ifdef CONFIG_WDT_501_PCIWim Van Sebroeck
Change the wdt_pci.c watchdog driver so that the code is the same for both the PCI-WDT500 as the PCI-WDT501 card. The selection of the card is now being done via the module parameter: 'type' instead of the config option CONFIG_WDT_501_PCI. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-20[WATCHDOG] add bcm47xx watchdog drivermatthieu castet
This add watchdog driver for broadcom 47xx device. It uses the ssb subsytem to access embeded watchdog device. Because the watchdog timeout is very short (about 2s), a soft timer is used to increase the watchdog period. Note : A patch for exporting the ssb_watchdog_timer_set will be submitted on next linux-mips merge. Without this patch it can't be build as a module. Signed-off-by: Aleksandar Radovanovic <biblbroks@sezampro.rs> Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Tested-by: Florian Fainelli <florian@openwrt.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-06-20[WATCHDOG] Freescale STMP: watchdog driverdmitry pervushin
Add watchdog timer support for Freescale STMP3xxx boards Signed-off-by: Vitaly Wool <vital@embeddedalley.com> Signed-off-by: Dmitry Pervushin <dpervushin@embeddedalley.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-20[WATCHDOG] twl4030 watchdog driverTimo Kokkonen
Implementation of twl4030 watchdog driver. Signed-off-by: Timo Kokkonen <timo.t.kokkonen@nokia.com> Signed-off-by: Atal Shargorodsky <ext-atal.shargorodsky@nokia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-20[WATCHDOG] U300 COH 901 327 watchdog driverLinus Walleij
This patch adds support for the U300 COH 901 327 watchdog for the U300 platform recently added to RMK:s ARM tree. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-20[WATCHDOG] Add pnx833x_wdtDaniel Laird
Add support for PNX833x watchdog timer. Signed-off-by: Daniel Laird <daniel.j.laird@nxp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-08[ARM] Orion/Kirkwood: rename orion5x_wdt to orion_wdtNicolas Pitre
The Orion watchdog driver is also used on Kirkwood. Convention is to use orion5x for stuff specific to 88F5xxx Orion chips and simply "orion" for shared stuff across SoCs including Kirkwood. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-06-08[ARM] Kirkwood: Add the watchdog timer as a platform device.Thomas Reitmayr
The Kirkwood architecture uses the same watchdog device as the Orion architecture. This patch adds orion5x_wdt as a platform device for Kirkwood. Signed-off-by: Thomas Reitmayr <treitmayr@devbase.at> Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-04-08[WATCHDOG] remove ARM26 sectionsPaulius Zaleckas
Removes ARM26 sections from Kconfig and Makefile, because ARM26 is long gone. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-25[WATCHDOG] wdt.c: remove #ifdef CONFIG_WDT_501Alan Cox
Change the wdt.c watchdog driver so that the code is the same for both the WDT500 as the WDT501-P card. The selection of the card is now being done via the module parameter: 'type' instead of the config option CONFIG_WDT_501. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-19powerpc/86xx: Board support for GE Fanuc's PPC9AMartyn Welch
Support for the PPC9A VME Single Board Computer from GE Fanuc (PowerPC MPC8641D). This is the basic board support for GE Fanuc's PPC9A, a 6U single board computer, based on Freescale's MPC8641D. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-18Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/pgtable-ppc32.h
2009-02-14[WATCHDOG] iTCO_wdt: fix SMI_EN regression 2Wim Van Sebroeck
bugzilla: #12363 commit 7cd5b08be3c489df11b559fef210b81133764ad4 added a second regression: some Dell's and Compaq's lockup on boot. So we revert most of the code. The ICH9 reboot issue remains in place and will need some more fixing... :-( Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-01-28powerpc/86xx: Board support for GE Fanuc SBC310Martyn Welch
Support for the SBC310 VPX Single Board Computer from GE Fanuc (PowerPC MPC8641D). This is the basic board support for GE Fanuc's SBC310, a 3U single board computer, based on Freescale's MPC8641D. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-24[ARM] omap: watchdog: allow OMAP watchdog driver on OMAP34xx platformsRussell King
The driver was updated for OMAP34xx, but the Kconfig file was missed. So this adds the missing parts from d99241c in Tony Lindgren's tree: Add watchdog timer support for TI OMAP3430. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-12[WATCHDOG] Pika Warp appliance watchdog timerSean MacLennan
The FPGA based watchdog timer used by the Pika Warp appliance. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-01-12[WATCHDOG] Basic support for GE Fanuc's FPGA based watchdog timerMartyn Welch
GE Fanuc SBC610 Support for the FPGA based watchdog timer as found on GE Fanuc's SBC310, SBC610 and PPC9A Single Board Computers. This patch adds support for the watchdog timer found in one of the devices FPGAs. There are two identical watchdog timers at different offsets in the above mentioned boards, this driver is capable of supporting one of them. The watchdog timers are also capable of generating interrupts at a user-configurable threshold, though support for this operation is currently not supported by the driver. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-12-31[WATCHDOG] Add support for the WM8350 watchdogMark Brown
This driver implements support for the watchdog functionality provided by the Wolfson Microelectronics WM8350, a multi-function audio and power management subsystem intended for use in embedded systems. It is based on a driver originally written by Graeme Gregory, though it has been extensively modified since then. Use of a GPIO to kick the watchdog is not yet supported. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-12-31[WATCHDOG] Add SMSC SCH311x Watchdog Timer.Wim Van Sebroeck
Add a watchdog driver for the hardware watchdog timer on the SMSC SCH3112, SCH3114 and SCH3116 Super IO chipset. Tested-by: Marco Chiappero <marco@absence.it> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-11-06[WATCHDOG] SAM9 watchdog - supported on all SAM9 and CAP9 processorsAndrew Victor
The SAM9 watchdog driver is usable on the whole family of AT91SAM9 and CAP9 processors. Update the configuration to indicate this and allow the driver to be selected. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-10-10[WATCHDOG] Orion: add hardware watchdog supportSylver Bruneau
This patch allows the use of the hardware watchdog in the Marvell Orion series of ARM SoCs. Signed-off-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10[WATCHDOG] Add AT91SAM9X watchdogRenaud CERRATO
Add a driver for the watchdog timer embedded into AT91SAM9X chips. Signed-off-by: Renaud Cerrato <r.cerrato@til-technologies.fr> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10[WATCHDOG] Add driver for winbond w83697ug/uf watchdog featureFlemming Frandsen
Adapted the w83627hf_wdt.c driver to work with the w83697ug/uf chip, found on MSI Fuzzy CX700 boards. The method used is taken directly from the winbond datasheet and surprisingly it differs slightly from all the other winbond watchdogs. So far it has only been tested on the CX700 board that I have, but it seems to work nicely. Signed-off-by: Flemming Frandsen <ff@nrvissing.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10[WATCHDOG] add watchdog driver IT8716 IT8726 IT8712J/KOliver Schuster
Add it87xx watchdog driver IT8716 IT8718 IT8726 IT8712-J IT8712-K Signed-off-by: Oliver Schuster <olivers137@aol.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-26[WATCHDOG] Add support for the IDT RC32434 watchdogFlorian Fainelli
Add driver for the IDT RC32434 SoC built-in watchdog. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-26[WATCHDOG] Add support for the built-int RDC R-321x SoC watchdogFlorian Fainelli
This patch adds support for the built-in RDC R-321x SoC watchdog. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-26[WATHDOG] delete unused driver mpc8xx_wdt.cJochen Friedrich
The watchdog driver mpc8xx_wdt.c was a device interface to arch/ppc/syslib/m8xx_wdt.c for MPC8xx hardware. Now that ARCH=ppc is gone, this driver is of no more use. For ARCH=powerpc, MPC8xx hardware is supported by mpc8xxx_wdt.c. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-08-12ALi M7101 PMU also available on Sun Netra's tooAlexander Clouter
My Sun Netra T1 AC200 has one of these... bit harsh not letting me use it and all :) ========== alex@woodchuck:~$ lspci -nn 00:01.0 PCI bridge [0604]: Sun Microsystems Computer Corp. Simba Advanced PCI Bridge [108e:5000] (rev 13) 00:01.1 PCI bridge [0604]: Sun Microsystems Computer Corp. Simba Advanced PCI Bridge [108e:5000] (rev 13) 01:03.0 Non-VGA unclassified device [0000]: ALi Corporation M7101 Power Management Controller [PMU] [10b9:7101] 01:05.1 Ethernet controller [0200]: Sun Microsystems Computer Corp. RIO GEM [108e:1101] (rev 01) 01:05.3 USB Controller [0c03]: Sun Microsystems Computer Corp. RIO USB [108e:1103] (rev 01) 01:07.0 ISA bridge [0601]: ALi Corporation M1533/M1535 PCI to ISA Bridge [Aladdin IV/V/V+] [10b9:1533] 01:0c.0 Bridge [0680]: Sun Microsystems Computer Corp. RIO EBUS [108e:1100] (rev 01) 01:0c.1 Ethernet controller [0200]: Sun Microsystems Computer Corp. RIO GEM [108e:1101] (rev 01) 01:0c.3 USB Controller [0c03]: Sun Microsystems Computer Corp. RIO USB [108e:1103] (rev 01) 01:0d.0 IDE interface [0101]: ALi Corporation M5229 IDE [10b9:5229] (rev c3) 02:08.0 SCSI storage controller [0100]: LSI Logic / Symbios Logic 53C896/897 [1000:000b] (rev 07) 02:08.1 SCSI storage controller [0100]: LSI Logic / Symbios Logic 53C896/897 [1000:000b] (rev 07) ========== Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] mpc8xxx_wdt: add support for MPC8xx watchdogsAnton Vorontsov
The mpc8xxx_wdt driver is using two registers: SWSRR to push magic numbers, and SWCRR to control the watchdog. Both registers are available on the MPC8xx, and seem to have the same offsets and semantics as in MPC83xx/MPC86xx watchdogs. The only difference is prescale value. So this driver simply works on the MPC8xx CPUs. One quirk is needed for the MPC8xx, though. It has small prescale value and slow CPU, so the watchdog resets board prior to the driver has time to load. To solve this we should split initialization in two steps: start ping the watchdog early, and register the watchdog userspace interface later. MPC823 seem to be the first CPU in MPC8xx line, so we use fsl,mpc823-wdt compatible matching. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Tested-by: Jochen Friedrich <jochen@scram.de> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-08-06[WATCHDOG] mpc83xx_wdt: rename to mpc8xxx_wdtAnton Vorontsov
Rename the driver because now we support some MPC86xx processors. There are no changes to the mpc83xx_wdt.c file, yet. When possible, we do file renames and changes separately (because Linus once asked so, because it helps git to track the renamed files). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-08-06[WATCHDOG] mpc83xx_wdt: add support for MPC86xx CPUsAnton Vorontsov
On MPC86xx the watchdog could be enabled only at power-on-reset, and could not be disabled afterwards. We must ping the watchdog from the kernel until the userspace handles it. MPC83xx CPUs are only differ in a way that watchdog could be disabled once, but after it was enabled via software it becomes just the same as MPC86xx. Thus, to support MPC86xx I added the kernel timer which pings the watchdog until the userspace opens it. Since we implemented the timer, now we're able to implement proper handling for the CONFIG_WATCHDOG_NOWAYOUT case, for MPC83xx and MPC86xx. Also move the probe code into subsys_initcall, because we want start pinging the watchdog ASAP, and misc devices are available in subsys_initcall. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-07-24remove the v850 portAdrian Bunk
Trying to compile the v850 port brings many compile errors, one of them exists since at least kernel 2.6.19. There also seems to be noone willing to bring this port back into a usable state. This patch therefore removes the v850 port. If anyone ever decides to revive the v850 port the code will still be available from older kernels, and it wouldn't be impossible for the port to reenter the kernel if it would become actively maintained again. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-25[WATCHDOG] Add a watchdog driver based on the CS5535/CS5536 MFGPT timersJordan Crouse
Add a watchdog timer based on the MFGPT timers in the CS5535/CS5536 companion chips to the AMD Geode GX and LX processors. Only caveat is that the BIOS must provide at least a one free timer, and most do not. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-02-18[WATCHDOG] HP ProLiant WatchDog driverThomas Mingarelli
Hp is providing a Hardware WatchDog Timer driver that will only work with the specific HW Timer located in the HP ProLiant iLO 2 ASIC. The iLO 2 HW Timer will generate a Non-maskable Interrupt (NMI) 9 seconds before physically resetting the server, by removing power, so that the event can be logged to the HP Integrated Management Log (IML), a Non-Volatile Random Access Memory (NVRAM). The logging of the event is performed using the HP ProLiant ROM via an Industry Standard access known as a BIOS Service Directory Entry. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-02-18[WATCHDOG] Add support for SB1 hardware watchdogAndrew Sharp
Support watchdog timers built into SiByte MIPS SoCs. Signed-off-by: Andy Sharp <andy.sharp@onstor.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-01-29[WATCHDOG] use SGI_HAS_INDYDOG for INDYDOG dependsThomas Bogendoerfer
Use SGI_HAS_INDYDOG for INDYDOG depends. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-01-25[WATCHDOG] TXx9 watchdog driverAtsushi Nemoto
This is a driver for watchdog timer built into TXx9 MIPS SoCs. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-01-25[AVR32] Add support for AT32AP7001 and AT32AP7002Haavard Skinnemoen
These are derivatives of the AT32AP7000 chip, which means that most of the code stays the same. Rename a few files, functions, definitions and config symbols to reflect that they apply to all AP700x chips, and exclude some platform devices from chips where they aren't present. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-04[WATCHDOG] add Nano 7240 driverGilles Gigan
Adds support for the built-in watchdog on EPIC Nano 7240 boards from IEI. Tested on Nano-7240RS. Hardware documentation of the platform (including watchdog) can be found on the IEI website: http://www.ieiworld.com Signed-off-by: Gilles Gigan <gilles.gigan@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
