These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Initial implementation of W1 master driver for Tegra SoCs.
Tested with DS2781 slave driver.
Change-Id: I6cda1ea152d25a789ae6cdca96b710da72884033
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
commit 9fe678fa2feb4aaac0b4220de63e1b7f8ccebae6 upstream.
Adds a nolock function to the w1 interface to avoid locking the
mutex if needed.
Signed-off-by: Clifton Barnes <cabarnes@indesign-llc.com>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
The for loop was looking for i <= 0 instead of i >= 0 so this function
never did anything. Also we started with i = NB_SYSFS_BIN_FILES instead
of "NB_SYSFS_BIN_FILES - 1" which is an off by one bug.
Reported-by: Bojan Prtvar <prtvar.b@gmail.com>
Acked-by: Jean-Franois Dagenais <dagenaisj@sonatest.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
This fixes a regression in 3.0 reported by Paul Parsons regarding the
removal of the msleep(1) in the ds1wm_reset() function:
: The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying"
: error messages on an HP iPAQ hx4700 PDA (XScale-PXA270):
: <snip>
: Driver for 1-wire Dallas network protocol.
: DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
: 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko
: ds1wm ds1wm: pass: 1 bus error, retrying
: ds1wm ds1wm: pass: 2 bus error, retrying
: ds1wm ds1wm: pass: 3 bus error, retrying
: ds1wm ds1wm: pass: 4 bus error, retrying
: ds1wm ds1wm: pass: 5 bus error, retrying
: The visible result is that the battery charging LED is erratic; sometimes
: it works, mostly it doesn't.
: The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1,
: 3.0-rc2, or 3.0-rc3.
This sleep should not be required on normal circuitry provided the
pull-ups on the bus are correctly adapted to the slaves. Unfortunately,
this is not always the case. The sleep is restored but as a parameter to
the probe function in the pdata.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com>
On m68k (which doesn't support generic hardirqs yet):
drivers/w1/masters/ds1wm.c: In function `ds1wm_probe':
drivers/w1/masters/ds1wm.c: error: implicit declaration of function `irq_set_irq_type'
Cc: Jean-Franois Dagenais <dagenaisj@sonatest.com>
Cc: Matt Reimer <mreimer@vpop.net>
Add support for the Maxim/Dallas DS2780 Stand-Alone Fuel Gauge IC.
It was suggested to combine this functionality with the current ds2782
driver. Unfortunately, I'm unable to commit the time to refactoring this
driver to that extent and I don't have a platform with the ds2782 part to
validate that there are no regression issues by adding this functionality.
[akpm@linux-foundation.org: use min_t()]
Tested-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Reorganize so the netlink connector one wire search command will update
the kernel list of detected slave devices. Otherwise, a newly detected
device is unusable because unless it's in the kernel list of known devices
any commands will result in ENODEV status.
Signed-off-by: David Fries <David@Fries.net>
This adds multi-slave support of the w1 bus for the ds1wm Synthesizable
1-Wire Bus Master. Also many fixes and tweaks based on the rev3 of the
datasheet http://datasheets.maxim-ic.com/en/ds/DS1WM.pdf
Cc: Szabolcs Gyurko <szabolcs.gyurko@tlt.hu>
This DS2408 w1 slave driver is not complete for all the features of the
chip, but its sufficient if you use it as a simple IO expander.
[randy.dunlap@oracle.com: fix w1_ds2408.c printk formats]
The first patch adds generic functionnality to w1_io for Resume Command
[A5h] lots of slaves support. I found it useful for multi-commands/reset
workflows with the same slave on a multi-slave bus.
chip, but its sufficient if you use it as a simple IO expander. Enjoy!
The ds1wm had Kconfig dependencies towards ARM && HAVE_CLK. I took them
out since I was using the ds1wm on an x86_64 platform (ds1wm in a FPGA
through pcie) and found them irrelevant.
The clock freq/divisors at the top of ds1wm.c did not have the MSB set to
1. This bit is CLK_EN which turns the whole prescaler and dividers on.
The driver never mentionned this bit either, so I just included this bit
right in the table entries. I also took the liberty to add a couple of
entries to the table. The spec doesn't explicitely mentions these
possibilities but the description and examination of the core shows the
prescalers & dividers can be used for more than the table explicitely
shows. The table I enlarged still doesn't cover all possibilities, but
it's a good start.
I also made a few tweaks to a couple of the read and write algorithms
which made sense while I had my head very deep in the ds1wm documentation.
We stressed it a lot with 10+ slaves on the bus, many ds2408, ds2431 and
ds2433 at the same time doing extensive interaction. It proved quite
stable in our production environment.
This patch:
Add generic functionnality to w1_io for Resume Command [A5h] lots of
slaves support.
With the addition of the platform device mfd_cell pointer, we can now
cleanly pass the sub device drivers platform data pointers through the
regular device platform_data one, and get rid of mfd_get_data().
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Scripted with coccinelle.
mfd_get_cell returns a const, so change the ds1wm client to store
a const mfd cell. This silences type mismatch warnings.
Since we're guaranteed to have the mfd_cell, we can also simplify
the code a bit to get rid of a temporary variable and NULL check.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Use mfd_data for passing information from mfd drivers to mfd
clients. The mfd_cell's driver_data field is being phased out.
Clients that were using driver_data now access .mfd_data
via mfd_get_data(). This changes ds1wm only; mfd drivers with
other cells are not modified, with the exception of led_cell.
The led_cell.driver_data line is dropped from htc-pasic3.c in this
patch as well. It's not used in mainline (there's no leds-pasic3
platform driver), so it should be safe to take care of that here.
No need to explicitly set the cell's platform_data/data_size.
Modify clients to use mfd_get_cell helper function instead of
accessing platform_data directly.
'devel-ti816x' into omap-for-linus
This code makes two calls to clk_get, then test both return values and
fails if either failed.
The problem is that in the first inner if, where the first call to
clk_get has failed, it don't know if the second call has failed as well.
So it don't know whether clk_get should be called on the result of the
second call. Of course, it would be possible to test that value again.
A simpler solution is just to test the result of calling clk_get
directly after each call.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
position p1,p2;
expression e;
statement S;
e = clk_get@p1(...)
if@p2 (IS_ERR(e)) S
expression e;
statement S;
identifier l;
position r.p1, p2 != r.p2;
*e = clk_get@p1(...)
... when != clk_put(e)
*if@p2 (...)
* return ...;
}// </smpl>
Acked-by: Amit Kucheria <amit.kucheria@canonical.com>
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest
are nowadays just subcategories of these.
Search and replace the following:
ARCH_OMAP2420 SOC_OMAP2420
ARCH_OMAP2430 SOC_OMAP2430
ARCH_OMAP3430 SOC_OMAP3430
No functional changes.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Sourav Poddar <sourav.poddar@ti.com>
This is a 1-wire/w1 DS2423 slave driver for reading the values from all 4
counters available DS2423 devices by using standard w1_slave file. In
ds2423 the counters are tied to ram pages 12-15 in and each of those
ram-pages. Each of these counter values (and asoociated ram page values)
are represented as a own line in w1_slave file. Driver has been tested on
mips and x86.
usage example:
cat /sys/bus/w1/devices/1d-00000009b964/w1_slave
00 02 00 00 00 00 00 00 00 6d 38 00 ff ff 00 00 fe ff 00 00 ff ff 00 00 ff
ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=2
00 02 00 00 00 00 00 00 00 e0 1f 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff
00 5a 0e 5f 18 00 00 00 00 0b 28 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff
ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=408882778
00 05 00 00 00 00 00 00 00 8d 39 ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff crc=YES c=5
Patch includes also the documentation.
[randy.dunlap@oracle.com: fix ds2423 build, needs to select CRC16]
Signed-off-by: Mika Laitio <lamikr@pilppa.org>
The search/pullup/add/remove device attributes were 0666 which would allow
arbitrary users to affect the 1 wire bus. Change to 0664 to prevent that.
I found this patch in the Android tree, apparently this has never been
sent upstream so doing it now.
Signed-off-by: Brian Swetland <swetland@google.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Fixes the following error:
drivers/w1/masters/omap_hdq.c: In function 'hdq_wait_for_flag':
drivers/w1/masters/omap_hdq.c:137: error: implicit declaration of function 'schedule_timeout_uninterruptible'
drivers/w1/masters/omap_hdq.c: In function 'hdq_write_byte':
drivers/w1/masters/omap_hdq.c:177: error: 'TASK_UNINTERRUPTIBLE' undeclared (first use in this function)
drivers/w1/masters/omap_hdq.c:177: error: (Each undeclared identifier is reported only once
drivers/w1/masters/omap_hdq.c:177: error: for each function it appears in.)
drivers/w1/masters/omap_hdq.c:177: error: implicit declaration of function 'schedule_timeout'
drivers/w1/masters/omap_hdq.c: In function 'hdq_isr':
drivers/w1/masters/omap_hdq.c:221: error: 'TASK_NORMAL' undeclared (first use in this function)
drivers/w1/masters/omap_hdq.c: In function 'omap_hdq_break':
drivers/w1/masters/omap_hdq.c:316: error: 'TASK_UNINTERRUPTIBLE' undeclared (first use in this function)
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
Fix regression caused by commit 507e2fbaaacb6f164b4125b87c5002f95143174b
("w1: w1 temp calculation overflow fix") whereby negative temperatures for
the DS18B20 are not converted properly.
When the temperature exceeds 32767 milli-degrees the temperature overflows
to -32768 millidegrees. These are both well within the -55 - +125 degree
range for the sensor.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=12646
Signed-of-by: Ian Dall <ian@beware.dropbear.id.au>
Tested-by: Karsten Elfenbein <kelfe@gmx.de>
Cc: <stable@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
This fixes the section mismatch warning for mxc_w1_probe()
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
With `while (++retries < DS2482_WAIT_IDLE_TIMEOUT)' retries reaches
DS2482_WAIT_IDLE_TIMEOUT after the loop
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
A pointer to omap_hdq_probe is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Stanley.Miao <stanley.miao@windriver.com>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Madhusudhan Chikkature <madhu.cr@ti.com>
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Replace ARCH_OMAP34XX with ARCH_OMAP3
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of
drivers/w1/w1.c
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
There is no point in implementing a detect callback for the DS2482, as
this device can't be detected. It was there solely to handle "force"
module parameters to instantiate devices, but now we have a better sysfs
interface that can do the same.
So we can get rid of the ugly module parameters and the detect callback.
This shrinks the binary module size by 21%.
Acked-by: Ben Gardner <gardner.ben@gmail.com>
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com>
arch/microblaze/include/asm/socket.h
This was found using a semantic patch, more info can be found at:
http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu>
Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
The connector documentation states that the argument to the callback
function is always a pointer to a struct cn_msg, but rather than encode it
in the API itself, it uses a void pointer everywhere. This doesn't make
much sense to encode the pointer in documentation as it prevents proper C
type checking from occurring and can easily allow people to use the wrong
pointer type. So convert the argument type to an explicit struct cn_msg
pointer.
* git://git.infradead.org/battery-2.6:
da9030_battery: Fix race between event handler and monitor
Add MAX17040 Fuel Gauge driver
w1: ds2760_battery: add support for sleep mode feature
w1: ds2760: add support for EEPROM read and write
ds2760_battery: cleanups in ds2760_battery_probe()
On embedded devices, sleep mode conditions can be tricky to handle,
Especially when processors tend to pull-down the w1 bus during sleep. Bus
slaves (such as the ds2760) may interpret this as a reason for power-down
conditions and entirely switch off the device.
This patch adds a callback function pointer to let users switch on and off
the external pull-up resistor. This lets the outside world know whether
the processor is currently actively driving the bus or not.
When this callback is not provided, the code behaviour won't change.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Ville Syrjala <syrjala@sci.fi>
.ko is normally not included in Kconfig help, make it consistent.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
This adds support for ds2760's sleep mode feature. With this feature
enabled, the chip enters a deep sleep mode and disconnects from the
battery when the w1 line is held down for more than 2 seconds.
This new behaviour can be switched on and off using a new module
parameter.
Acked-by: Matt Reimer <mreimer@vpop.net>
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
In order to modify the DS2762's status registers and to add support for
sleep mode, there is need for functions to write the internal EEPROM.
Acked-by: Szabolcs Gyurko <szabolcs.gyurko@tlt.hu>
This driver requests a clock that usually is supplied by the MFD in which
the DS1WM is contained. Currently, it is impossible for a MFD to register
their clocks with the generic clock API due to different implementations
across architectures.
For now, this patch removes the clock handling from DS1WM altogether,
trusting that the MFD enable/disable functions will switch the clock if
needed. The clock rate is obtained from a new parameter in driver_data.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
This patch converts the DS1WM driver into an MFD cell. It also
calculates the bus_shift parameter from the memory resource size.
This fixes a number of coding style issues I stubled over.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
