path: root/drivers/w1/w1.c
2013-03-20w1: fix oops when w1_search is called from netlink connectorMarcin Jurkowski
commit 9d1817cab2f030f6af360e961cc69bb1da8ad765 upstream. On Sat, Mar 02, 2013 at 10:45:10AM +0100, Sven Geggus wrote: > This is the bad commit I found doing git bisect: > 04f482faf50535229a5a5c8d629cf963899f857c is the first bad commit > commit 04f482faf50535229a5a5c8d629cf963899f857c > Author: Patrick McHardy <kaber@trash.net> > Date: Mon Mar 28 08:39:36 2011 +0000 Good job. I was too lazy to bisect for bad commit;) Reading the code I found problematic kthread_should_stop call from netlink connector which causes the oops. After applying a patch, I've been testing owfs+w1 setup for nearly two days and it seems to work very reliable (no hangs, no memleaks etc). More detailed description and possible fix is given below: Function w1_search can be called from either kthread or netlink callback. While the former works fine, the latter causes oops due to kthread_should_stop invocation. This patch adds a check if w1_search is serving netlink command, skipping kthread_should_stop invocation if so. Signed-off-by: Marcin Jurkowski <marcin1j@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Josh Boyer <jwboyer@gmail.com> Tested-by: Sven Geggus <lists@fuchsschwanzdomain.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-05-26w1: have netlink search update kernel listDavid Fries
Reorganize so the netlink connector one wire search command will update the kernel list of detected slave devices. Otherwise, a newly detected device is unusable because unless it's in the kernel list of known devices any commands will result in ENODEV status. Signed-off-by: David Fries <David@Fries.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27w1: don't allow arbitrary users to remove w1 devicesBrian Swetland
The search/pullup/add/remove device attributes were 0666 which would allow arbitrary users to affect the 1 wire bus. Change to 0664 to prevent that. I found this patch in the Android tree, apparently this has never been sent upstream so doing it now. Signed-off-by: Brian Swetland <swetland@google.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-05w1: add __init/__exit macros to w1.cPeter Huewe
Trivial patch which adds the __init/__exit macros to the module_init/ module_exit functions of drivers/w1/w1.c Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06w1: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16W1: w1.c s/printk/dev_dbg/David Fries
s/printk/dev_dbg/ Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: w1_slave_read_id read bug, use device_attributeDavid Fries
Fix bug reading the id sysfs file. If less than the full 8 bytes were read, the next read would start at the first byte instead of continuing. It needed the offset added to memcpy, or the better solution was to replace it with the device attribute instead of bin attribute. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: recode w1_slave_found logicDavid Fries
Simplified the logic in w1_slave_found by using the new w1_attach_slave_device function to find a slave and mark it as active or add the device if the crc checks. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: be able to manually add and remove slavesDavid Fries
sysfs entries were added to manually add and remove slave devices. This is useful if the automatic bus searching is disabled, and the device ids are already known. [akpm@linux-foundation.org: fix printk types] Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: feature, enable hardware strong pullupDavid Fries
Add a strong pullup option to the w1 system. This supplies extra power for parasite powered devices. There is a w1_master_pullup sysfs entry and enable_pullup module parameter to enable or disable the strong pullup. The one wire bus requires at a minimum one wire and ground. The common wire is used for sending and receiving data as well as supplying power to devices that are parasite powered of which temperature sensors can be one example. The bus must be idle and left high while a temperature conversion is in progress, in addition the normal pullup resister on larger networks or even higher temperatures might not supply enough power. The pullup resister can't provide too much pullup current, because devices need to pull the bus down to write a value. This enables the strong pullup for supported hardware, which can supply more current when requested. Unsupported hardware will just delay with the bus high. The hardware USB 2490 one wire bus master has a bit on some commands which will enable the strong pullup as soon as the command finishes executing. To use strong pullup, call the new w1_next_pullup function to register the duration. The next write command will call set_pullup before sending the data, and reset the duration to zero once it returns. Switched from simple_strtol to strict_strtol. Signed-off-by: David Fries <david@fries.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: w1_process, block or sleepDavid Fries
The w1_process thread's sleeping and termination has been modified. msleep_interruptible was replaced by schedule_timeout and schedule to allow for kthread_stop and wake_up_process to interrupt the sleep and the unbounded sleeping when a bus search is disabled. The W1_MASTER_NEED_EXIT and flags variable were removed as they were redundant with kthread_should_stop and kthread_stop. If w1_process is sleeping, requesting a search will immediately wake it up rather than waiting for the end of msleep_interruptible previously. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: don't delay search startDavid Fries
Move the creation of the w1_process thread to after the device has been initialized. This way w1_process doesn't have to check to see if it has been initialized and the bus search can proceed without sleeping. That also eliminates two checks in the w1_process loop. The sleep now happens at the end of the loop not the beginning. Also added a comment for why the atomic_set was 2. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: abort search early on on exitDavid Fries
Early abort if the master driver or the hardware goes away in the middle of a bus search operation. The alternative is to spam the print buffer up to 64*64 times with read errors in the case of USB. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: fix deadlocks and remove w1_control_threadDavid Fries
w1_control_thread was removed which would wake up every second and process newly registered family codes and complete some final cleanup for a removed master. Those routines were moved to the threads that were previously requesting those operations. A new function w1_reconnect_slaves takes care of reconnecting existing slave devices when a new family code is registered or removed. The removal case was missing and would cause a deadlock waiting for the family code reference count to decrease, which will now happen. A problem with registering a family code was fixed. A slave device would be unattached if it wasn't yet claimed, then attached at the end of the list, two unclaimed slaves would cause an infinite loop. The struct w1_bus_master.search now takes a pointer to the struct w1_master device to avoid searching for it, which would have caused a lock ordering deadlock with the removal of w1_control_thread. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1: remove unused and confusing variable.Evgeniy Polyakov
Remvoe variable which actually is not used (except assigning it a value) and confusing break out of the family checking loop. Found by Harry Mason. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Harry J Mason <hjm03r@ecs.soton.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-14w1: decrement slave counter only in ->release() callbackEvgeniy Polyakov
Decrement the slave counter only in ->release() callback instead of both in ->release() and w1 control. Patch is based on debug work and preliminary patch made by Henri Laakso. Henri noticed in debug that this counter becomes negative after w1 slave device is physically removed. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Henri Laakso <henri.laakso@wapice.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-25missing null termination in one wire ueventStephen Hemminger
Need to null terminate environment. Found by inspection while looking for similar problems to platform uevent bug Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08W1 printk format warning fixEvgeniy Polyakov
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] w1: warning fixAndrew Morton
drivers/w1/w1.c:423: warning: long long unsigned int format, __u64 arg (arg 8) u64 is not, never has been and never will be "unsigned long long"! While we're there, fix up some code layout - it looks awful in an 80-col display. Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] W1: cleanupsEvgeniy Polyakov
Nice cleanup spotted by Adrian Bunk, which was lost due to moving to the completely new functionality. Shame-shame-shame on me. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Use mutexes instead of semaphores.Evgeniy Polyakov
Use mutexes instead of semaphores. Patch tested on x86_64 and i386 with test bus master driver. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Userspace communication protocol over connector.Evgeniy Polyakov
There are three types of messages between w1 core and userspace: 1. Events. They are generated each time new master or slave device found either due to automatic or requested search. 2. Userspace commands. Includes read/write and search/alarm search comamnds. 3. Replies to userspace commands. From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Added default generic read/write operations.Evgeniy Polyakov
Special file in each w1 slave device's directory called "rw" is created each time new slave and no appropriate w1 family is registered. "rw" file supports read and write operations, which allows to perform almost any kind of operations. Each logical operation is a transaction in nature, which can contain several (two or one) low-level operations. Let's see how one can read EEPROM context: 1. one must write control buffer, i.e. buffer containing command byte and two byte address. At this step bus is reset and appropriate device is selected using either W1_SKIP_ROM or W1_MATCH_ROM command. Then provided control buffer is being written to the wire. 2. reading. This will issue reading eeprom response. It is possible that between 1. and 2. w1 master thread will reset bus for searching and slave device will be even removed, but in this case 0xff will be read, since no device was selected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] w1: use kthread api.Evgeniy Polyakov
This patch removes old-style kernel thread initialization and changes w1 to use kthread api. It is based on Christoph Hellwig <hch@lst.de> work. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] W1: u64 is not long longAndrew Morton
You don't know what type a u64 is, hence you cannot print it without a cast. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] w1: misc cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global code static - declarations for global code belong into header files - w1.c: #if 0 the unused struct w1_slave_device Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] W1: Change the type 'unsigned long' member of 'struct w1_bus_master' ↵Evgeniy Polyakov
to 'void *'. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-14[PATCH] Dallas's 1-wire bus compile errorEvgeniy Polyakov
drivers/built-in.o: In function `w1_alloc_dev': undefined reference to `netlink_kernel_create' drivers/built-in.o: In function `w1_alloc_dev': undefined reference to `sock_release' Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] w1: Decreased debug level.Evgeniy Polyakov
2005-09-08[PATCH] w1: Detouching bug fixed.Evgeniy Polyakov
2005-09-08[PATCH] w1: Added add/remove slave callbacks.Evgeniy Polyakov
Patch is based on work from Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] w1: Added inline functions on top of container_of().Evgeniy Polyakov
2005-09-08[PATCH] w1: Fixed 64bit compilation warning.Evgeniy Polyakov
Fixed 64bit compilation warning. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] w1: hotplug support.Evgeniy Polyakov
Here is W1 hotplug in addition to netlink notifications. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-12[PATCH] w1: more debug level decrease.Evgeniy Polyakov
Do not spam syslog each 10 seconds when there is nothing on the wire. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[PATCH] w1: fix CRC calculation on bigendian platforms.Evgeniy Polyakov
In the 2.6.13-rc1 code the "rn" structure is in the wrong-endianness when passed to w1_attach_slave_device(). This causes problems like the family and crc being swapped around. Signed-off-by: Roger Blofeld <blofeldus@yahoo.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] w1: reconnect feature.Evgeniy Polyakov
I've created reconnect feature - if on start there are no registered families all new devices will have defailt family, later when driver for appropriate family is loaded, slaves, which were faound earlier, will still have defult family instead of right one. Reconnect feature will force control thread to run through all master devices and all slaves found and search for slaves with default family id and try to reconnect them. It does not store newly registered family and does not check only those slaves which have reg_num.family the same as being registered one - all slaves with default family are reconnected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Adds a default family so that new slave families will show up in ↵Evgeniy Polyakov
sysfs. Adds a default family so that new slave families will show up in sysfs. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Adds a sysfs entry (w1_master_search) that allows you to ↵Evgeniy Polyakov
disable/enable periodic searches. Adds a sysfs entry (w1_master_search) that allows you to disable/enable periodic searches. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Added the triplet w1 master method and changes w1_search() to ↵Evgeniy Polyakov
use it. Adds the triplet w1 master method and changes w1_search() to use it. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: new family structure.Evgeniy Polyakov
Removed some fields which are not required. First step for writing operations. Now only read and read name remain. Patch depends on w1 cleanups patch. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
