This patch replaces busy waiting with the cpu_relax() call. This makes
scrolling faster.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
This patch replaces busy waiting with cpu_relax() call. This makes scrolling
faster.
ps3fb: Add a `mode' parameter to ps3fb_get_res_table(), as in some cases it
should check the full-screen flag of the _new_ video mode instead of the
current video mode.
This bug caused spurious mode change failures when switching between
fullscreen and non-fullscreen modes using fbset, while ps3-video-mode worked
fine.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
CC: Geoff Levand <geoffrey.levand@am.sony.com>
Allow generic frame-buffer code to correctly write texts and blit images for
1, 2 and 4 bit per pixel frame-buffer organizations when pixels in bytes are
organized to in opposite order than bytes in long type.
Overhead should be reasonable. If option is not selected, than compiler
should eliminate completely all overhead.
The feature is disabled at compile time if CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is
not set.
[adaplas]
Convert helper functions to macros if feature is not enabled.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
There are a few nvidia hardware where the i2c port assignments are reversed,
i.e., the 1st i2c port is assigned to the secondary display and the 2nd i2c
port to the primary display. In most cases, if only 1 display is attached, or
if only 1 flatpanel and 1 analog display is attached, the port reversal is of
no consequence. However if 2 flatpanels are attached, it can cause display
problems.
There is no sane way of determining if the hardware reversed the i2c port
assignment, so the simplest fix is to add a boot/module option, "reverse_i2c
to explicitly reverse the i2c port.
This also restores i2c ordering back to the pre-2.6.22 state.
Signed-off-by: Antonino Daplas <adaplas@gail.com>
Currently, if the refresh rate is not specified, fb_find_mode() returns the
first known video mode with the requested resolution, which provides no
guarantees wrt the refresh rate. Change this so that the mode with the
highest refresh rate is returned when the driver provides a custom video mode
database and the monitor limits, and a mode with the safe 60 Hz refresh rate
otherwise.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Intel framebuffer now supports interlaced video modes.
Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Changed things:
1. vmalloc()/vfree() replaced with rvmalloc()/rvfree() (taken from
drivers/media/video/se401.c)
2. mmap method implemented (mostly taken from drivers/media/video/se401.c)
3. smem_start and smem_len fields of struct fb_fix_screeninfo initialized.
(smem_start initialized with virtual address, don't know if it is really
bad...)
[adaplas: sparse warning fix]
This patch:
- disallows setting of virtual height above 2048 as it does
not work for accelerated copyarea and imageblit
- fixes blinking of pm2v cursor by pushing cursor outside
the display (x=2047)
- fixes hardware cursor position on Permedia 2 chips with
panning enabled
- enables hardware cursor by default
This patch adds hardware cursor support for the Permedia 2 chip.
This patch removes:
- redundant fields from the cirrusfb_regs structure
- one redundant header
- fixes two includes ("" to <>)
This patch does some "short-range" code improvements like merging identical
switch clauses, replacing conditional branches with calculation of values,
merging only once-used functions into place they are called from.
This patch removes unused or redundant fields from cirrusfb_info structure.
This patch replaces "typedef enum" with "enum type" constructs. Using the
typedef is error for the checkpatch.pl script.
This patch fixes over 850 errors and warnings pointed out by the checkpatch.pl
script.
This patch changes mode selection to always prefer default mode if possible
and always honor type of display set by default mode settings.
This patch is required in case the same display modes were defined for
different panels (e.g. STN and TFT).
This patch removes lcdcon1 register field from the s3c2410fb_display as all
bits are calculated from other fields.
This patch adds pixelclock field to the s3c2410fb_display structure and make
use of it in the driver.
The Bast machine defined 9 modes but pixclock and margin values are defined
only for the 640x480 modes so I removed other modes.
This patch also fixes wrong display type constant for the SMDK2440 board.
This patch:
- moves more display mode preparations to s3c2410fb_check_var()
- reduces number of fields in s3c2410fb_info
- removes redundant values setting in s3c2410fb_probe()
- removes static mach_info pointer
- releases fb_info structure in s3c2410fb_remove()
- changes s3c2410fb_init to __init from __devinit
- fixes few typos in comments and removes unused includes
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the
checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver
does not use it.
Akpm's patch "newport_con warning fix" got me to look at the console drivers
again and one thing that I noticed was that none of the fonts was using ISO
initializers for it's fonts.
atyfb: Move the pseudo palette into the card-specific atyfb_par, so it's no
longer shared among multiple cards
This patch sets correct bits related to the byte ordering of the
framebuffer. This was tested on little endian kernel only. The big endian
kernel may require different settings.
The patch also adds 32 bpp mode which is called 24 bpp by Samsung. One
pixel takes 32 bits but only 24 bits are used in this mode.
This patch adds missing virtual register offsets where
appropriate. This fixes crashes in the driver.
This patch removes unused lcdcon2 and lcdcon3 register value
from the s3c2410fb_display structure.
This patch adds synchronization pulse lenght fields to
the s3c2410fb_display structure and makes use of them
in the driver.
This patch makes use of vertical margins fields in
This patch removes unused lcdcon3 register from the
This patch makes use of margins fields in the s3c2410fb_display
structure.
This patch adds a new structure to describe and handle
more than one panel (display mode) for the s3c2410 framebuffer.
This structure is added after the pxafb driver.
This patch removes redundant fb field from
the s3c2410fb_info structure. This breaks circular
reference fb_info -> s3c2410fb_info -> fb_info again.
This patch cleans up the driver a bit. It contains
coding style fixes (pointed by Lindent and checkpatch),
white space clean ups and few minor code improvements.
This patch adds hardware cursor support to the pm3fb driver.
This patch adds hardware cursor support for Permedia 2V chips.
The hardware cursor is disabled by default. It does not blink - the
same issue is mentioned in the x11 driver.
Looking at the code flow, `int first' in fb_create_modedb() should be static.
[adaplas]
Better for 'int first' to be moved outside the loop.
[akpm@linux-foundation.org: kill stray semicolon]
drivers/video/geode/lxfb_core.c: In function 'lxfb_setup':
drivers/video/geode/lxfb_core.c:564: warning: unused variable 'opt'
Signed-off-by: Eugene Teo <eugeneteo@kernel.sg>
This patch fixes all errors detected by checkpatch.pl script in the pm3fb.c
file.
This patch fixes all errors detected by checkpatch.pl script in the pm2fb.c
file.
This patch adds mtrr support to the tdfxfb driver. It also kills one
redundant include and initialization value.
[akpm@linux-foundation.org: cleanups]
This patch adds hardware cursor support to the tdfxfb driver.
This patch improves source code mainly by killing redundant variable loads,
reducing number of variables, simplifying conditional branches, etc.
Reported by: John Lumby <johnlumby@hotmail.com>
Some of the entries in the mode database does not match the comments and/or
the refresh field. Adjust the timings so they match with both the comments
and the refresh rate.
The logo code is not and should not be used by modules.
This patch fixes:
- palette setting in 8-bit mode (aka 'funky penguin')
- grayscale handling
- adds proper barriers in xxx_inb/outb functions
This patch fixes 3 issues:
- transparency handling in tdfxfb
- panning with more than 4096 virtual height and acceleration (acceleration
with x & y > 4096)
- exit paths on errors in tdfxfb_probe()
Additionally it sets a FBINFO_READS_FAST flag to use smart blitter scrolling
(speed up on tdfxfb).
This patch contains coding style improvements to the tdfxfb driver (white
spaces, indentations, long lines).
It also moves fb_ops structure to the end of file, so forward declarations of
ops functions are redundant.
This patch contains coding style improvements to the tridentfb driver (white
It also moves fb_ops structure after fb api functions are defined.
This patch adds support for the other three palette formats possible with
the PXA LCD controller. This is required on boards where an LCD is connected
with all its 18 bits. With this patch, it's possible to use an 8-bit mode
with 18-bit palette entries. This used to be possible in 2.4 kernels but
disappeared in 2.6. With current kernels, you can only get wrong colours
out of an LCD connected this way.
Users can choose the palette format by doing something like this
in their board definition:
static struct pxafb_mach_info my_fb_info = {
.lccr3 = LCCR3_OutEnH | LCCR3_PixFlEdg | LCCR3_PDFOR_3,
.lccr4 = LCCR4_PAL_FOR_2,
Signed-off-by: Hans J. Koch <hjk@linutronix.de>
This contains the following changes:
* Overlay surface alpha is configured separately from the overlay. This
prevents display glitches (configure and fill the overlay first, set
alpha to a visible value next)
* Added an ioctl for configuring transparency of the Overlay and graphics
planes. Blend mode, colorkey mode and global alpha mode are supported.
* Added an ioctl for setting the plane order. The overlay plance can be placed
over or
under the graphics plane.
* Added an ioctl for setting and reading chip registers, with mask.
* Updated copyright for 2007
[adaplas]
* Coding style changes
Signed-off-by: Raphael Assenat <raph@8d.com>
When we setup the panel interface whilst configuring the
framebuffer, we should ensure the panel interface is not
in tristate, in case the bootloader or previous setup has
not enabled it.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
