path: root/drivers/video/vt8623fb.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05vt8623fb: fix kernel oopsOndrej Zajicek
commit 20e061fb750d36ec0ffcb2e44ed7dafa9018223b Author: Ondrej Zajicek <santiago@crfreenet.org> Date: Mon Apr 28 02:15:18 2008 -0700 fbdev: framebuffer_alloc() fixes Correct the dev arg of framebuffer_alloc() in arkfb, s3fb and vt8623fb. causes a null-pointer deref because "info->dev is NULL, info was just kzallocated". Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Reported-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net> Tested-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <stable@kernel.org> [2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30drivers/video: release mutex in error handling codeJulia Lawall
The mutex is released on a successful return, so it would seem that it should be released on an error return as well. The semantic patch finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression l; @@ mutex_lock(l); ... when != mutex_unlock(l) when any when strict ( if (...) { ... when != mutex_unlock(l) + mutex_unlock(l); return ...; } | mutex_unlock(l); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: framebuffer_alloc() fixesOndrej Zajicek
Correct the dev arg of framebuffer_alloc() in arkfb, s3fb and vt8623fb. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: vt8623fb: better resume from STROndrej Zajicek
After resume from STR, image is shifted by 8 pixels to the left. This patch fixes it. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: add removed option "mode" to keep compatibilityKrzysztof Helt
Add removed option "mode" to keep compatibility with existing setups. The option is back for pm2fb, tridentfb and vt8623fb drivers. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vt8623fb: change option mode to mode_optionKrzysztof Helt
Change the option "mode" into "mode_option". This is one step toward changing all fb drivers to have common "mode_option" parameter. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17vt8623fb.c: make code staticAdrian Bunk
This patch makes needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01vt8623fb: arkfb: null pointer dereference fixOndrej Zajicek
This patch prevents null pointer dereference in arkfb and vt8623fb. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09svgalib: move fb_get_caps to svgalibAntonino A. Daplas
Move fb_get_caps() method to svgalib.c as svga_get_caps() so it can be used by s3fb, arkfb and vt8623fb. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09vt8623fb: new framebuffer driver for VIA VT8623Ondrej Zajicek
This patch adds fbdev driver for graphics core in VIA VT8623 [adaplas@gmail.com: build fixes] Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
