path: root/drivers/video/vesafb.c
2010-08-16vesafb: fix comment a typoJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-18fbdev: allow passing more than one aperture for handoffMarcin Slusarz
It removes a hack from nouveau code which had to detect which region to pass to kick vesafb/efifb. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Eric Anholt <eric@anholt.net> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Peter Jones <pjones@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-07vesafb: use platform_driver_probe() instead of platform_driver_register()Jan Beulich
Commit c2e13037e6794bd0d9de3f9ecabf5615f15c160b ("platform-drivers: move probe to .devinit.text in drivers/video") introduced a huge amount of section mismatch warnings in vesafb code. Rather than converting all of the annotations, do the obvious and revert the __init -> __devinit change, and use the recommended (in that patch) alternative to calling platform_driver_register(): vesafb depends on information obtained from by kernel at boot time, cannot be a module, and no post-boot devices can ever show up. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Greg KH <greg@kroah.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07platform-drivers: move probe to .devinit.text in drivers/videoUwe Kleine-König
A pointer to a probe callback is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Adrian Bunk <bunk@stusta.de> Cc: Alberto Mardegan <mardy@users.sourceforge.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andriy Skulysh <askulysh@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Frans Pop <elendil@planet.nl> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Helge Deller <deller@gmx.de> Cc: Huang Ying <ying.huang@intel.com> Cc: Ian Molton <spyro@f2s.com> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Kaj-Michael Lang <milang@tal.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Magnus Damm <damm@igel.co.jp> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Roland Stigge <stigge@antcom.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Vincent Sanders <vince@simtec.co.uk> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Peter Jones <pjones@redhat.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-16fbdev: add support for handoff from firmware to hw framebuffersDave Airlie
With KMS we have ran into an issue where we really want the KMS fb driver to be the one running the console, so panics etc can be shown by switching out of X etc. However with vesafb/efifb built-in, we end up with those on fb0 and the KMS fb driver on fb1, driving the same piece of hw, so this adds an fb info flag to denote a firmware fbdev, and adds a new aperture base/size range which can be compared when the hw drivers are installed to see if there is a conflict with a firmware driver, and if there is the firmware driver is unregistered and the hw driver takes over. It uses new aperture_base/size members instead of comparing on the fix smem_start/length, as smem_start/length might for example only cover the first 1MB of the PCI aperture, and we could allocate the kms fb from 8MB into the aperture, thus they would never overlap. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Airlie <airlied@redhat.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vesafb: bitwise OR has higher precedence than ?:Roel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Michal Januszewski <michalj@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] annotate some variables in vesafb driver as __read_mostlyHelge Deller
- annotate some variables in vesafb driver as __read_mostly Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ioremap balanced with iounmap for drivers/video/vesafbAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] vesafb: Prefer VGA registers over PMIAntonino A. Daplas
- As per VESA specs, use the VGA registers to set the palette if the mode is VGA compatible. Otherwise, use the protected mode interface. - Make pmi_setpal default to 1 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] vesafb: Fix return code of vesafb_setcolregAntonino A. Daplas
If the hardware palette cannot be accessed, make vesafb_setcolreg return a nonzero value. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] vesafb: Update platform codeAntonino A. Daplas
Update platform code to dynamically allocate the platform device Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] vesafb: Fix incorrect logo colors in x86_64Antonino A. Daplas
Bugzilla Bug 6299: A pixel size of 8 bits produces wrong logo colors in x86_64. The driver has 2 methods for setting the color map, using the protected mode interface provided by the video BIOS and directly writing to the VGA registers. The former is not supported in x86_64 and the latter is enabled only in i386. Fix by enabling the latter method in x86_64 only if supported by the BIOS. If both methods are unsupported, change the visual of vesafb to STATIC_PSEUDOCOLOR. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Fix vesafb display panning regressionAntonino A. Daplas
Fix vesafb hang when scroll mode is REDRAW. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] vesafb: Trim vesafb_pan_displayAntonino A. Daplas
Remove error checking from vesafb_pan_display. This is guaranteed to be done by the core layer. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] vesafb: Drop blank hookAntonino A. Daplas
From: Bugzilla Bug 5351 "After resuming from S3 (suspended while in X), the LCD panel stays black . However, the laptop is up again, and I can SSH into it from another machine. I can get the panel working again, when I first direct video output to the CRT output of the laptop, and then back to LCD (done by repeatedly hitting Fn+F5 buttons on the Toshiba, which directs output to either LCD, CRT or TV) None of this ever happened with older kernels." This bug is due to the recently added vesafb_blank() method in vesafb. It works with CRT displays, but has a high incidence of problems in laptop users. Since CRT users don't really get that much benefit from hardware blanking, drop support for this. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] make vesafb build without CONFIG_MTRRJan Beulich
vesafb did not build without CONFIG_MTRR. Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] vesafb: Disable mtrr as the defaultAntonino A. Daplas
vesafb occassionally gets the size wrong when setting the mtrr. When X or DRI attempts to set the mtrr, it will fail due to range overlap significantly affecting their performance. Disable mtrr and let the user explicitly enable it with the mtrr:n option. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] vesafb: Fix color palette handlingAntonino A. Daplas
Fix out-of-bounds bug. The pseudopalette has room only for 16 entries, thus, write only the first 16 entries to the pseudopalette. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-18[PATCH] vesafb: Fix display corruption on display blankAntonino A. Daplas
Reported by: Bob Tracy <rct@gherkin.frus.com> "...I've got a Toshiba notebook (730XCDT -- Pentium 150MMX) for which I'm using the Vesa FB driver. When the machine has been idle for some time and the driver attempts to powerdown the display, rather than the display going blank, it goes gray with several strange lines. When I hit the "shift" key or other-wise wake up the display, the old video state is not fully restored..." vesafb recently added a blank method which has only 2 states, powerup and powerdown. The powerdown state is used for all blanking levels, but in his case, powerdown does not work correctly for higher levels of display powersaving. Thus, for intermediate power levels, use software blanking, and use only hardware blanking for an explicit powerdown. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] vesafb: Add blanking supportAntonino A. Daplas
Add rudimentary support by manipulating the VGA registers. However, not all vesa modes are VGA compatible, so VGA compatiblity is checked first. Only 2 levels are supported, powerup and powerdown. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] vesafb: Fix mtrr bugsAntonino A. Daplas
>> vesafb: mode is 800x600x16, linelength=1600, pages=16 >> vesafb: scrolling: redraw >> vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0 >> mtrr: type mismatch for fc000000,1000000 old: write-back new: write- >> combining Range is already set to write-back, vesafb attempts to add a write-combining mtrr (default for vesafb). >> mtrr: size and base must be multiples of 4 kiB This is a bug, vesafb attempts to add a size < PAGE_SIZE triggering the messages below. To eliminate the warning messages, you can add the option mtrr:2 to add a write-back mtrr for vesafb. Or just use nomtrr option. 1. Fix algorithm for finding the best power of 2 size with mtrr_add(). 2. Add option to choose the mtrr type by extending the mtrr boot option: mtrr:n where n 0 = no mtrr (equivalent to using the nomtrr option) 1 = uncachable 2 = write back 3 = write combining (default) 4 = write through Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Fix vesafb/mtrr scaling problem.Dave Jones
vesafb will do really silly things like.. mtrr: type mismatch for e0000000,8000000 old: write-back new: write-combining mtrr: type mismatch for e0000000,4000000 old: write-back new: write-combining mtrr: type mismatch for e0000000,2000000 old: write-back new: write-combining mtrr: type mismatch for e0000000,1000000 old: write-back new: write-combining mtrr: type mismatch for e0000000,800000 old: write-back new: write-combining mtrr: type mismatch for e0000000,400000 old: write-back new: write-combining mtrr: type mismatch for e0000000,200000 old: write-back new: write-combining mtrr: type mismatch for e0000000,100000 old: write-back new: write-combining mtrr: type mismatch for e0000000,80000 old: write-back new: write-combining mtrr: type mismatch for e0000000,40000 old: write-back new: write-combining mtrr: type mismatch for e0000000,20000 old: write-back new: write-combining mtrr: type mismatch for e0000000,10000 old: write-back new: write-combining mtrr: type mismatch for e0000000,8000 old: write-back new: write-combining mtrr: type mismatch for e0000000,4000 old: write-back new: write-combining mtrr: type mismatch for e0000000,2000 old: write-back new: write-combining mtrr: type mismatch for e0000000,1000 old: write-back new: write-combining mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x800 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x400 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x200 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x100 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x80 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x40 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x20 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x10 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x8 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x4 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x2 base: 0xe0000000 mtrr: size and base must be multiples of 4 kiB mtrr: size: 0x1 base: 0xe0000000 Stop scaling down at PAGE_SIZE. Also fix up some broken indentation. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] some vesafb fixesGerd Knorr
Fix the size passed to release_mem_region in an error path. Also adjust the message printed when vesafb cannot load; the comment there already says this must not be fatal, so the message should also not mention the word 'abort' otherwise indicating a problem to worry about in the log. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Gerd Knorr <kraxel@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] fbdev: edid.h cleanupsAdrian Bunk
This patch removes some completely unused code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
