path: root/drivers/video/tdfxfb.c
2010-08-05VIDEO: Correct use of request_region/request_mem_regionJulia Lawall
request_region should be used with release_region, not request_mem_region. Geert Uytterhoeven pointed out that in the case of drivers/video/gbefb.c, the problem is actually the other way around; request_mem_region should be used instead of request_region. The semantic patch that finds/fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ expression start; @@ request_region(start,...) @b1@ expression r1.start; @@ request_mem_region(start,...) @depends on !b1@ expression r1.start; expression E; @@ - release_mem_region + release_region (start,E) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-15i2c: Do not probe for TV chips on Voodoo3 adaptersJean Delvare
There's no point in giving the I2C bus of Voodoo3 adapters a class value, there's no video chip driver checking for it anymore. If support is ever needed, the video device should be instantiated explicitly rather than probed. To the best of my knowledge the only video chip that can be found on these boards is a BT869 video encoder, for which no support exists currently. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
2009-04-07tdfxfb: make use of DDC information about connected monitorKrzysztof Helt
Read DDC information from a connected monitor and use it to select initial mode (if the mode is not specified). Also, use the information to protect against modes outside the monitor specs. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: move I2C functionality into the tdfxfbKrzysztof Helt
The I2C functionality provided by the i2c-voodoo3 driver is moved into the tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no conflict between the i2c driver and the fb driver. The tdfxfb does not make use from the DDC functionality yet but provides all the functionality of the i2c-voodoo3 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01tdfxfb: fix memory leaks in removal pathAndres Salomon
We were leaking the cmap memory. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tdfxfb: do not make changes to default tdfx_fixKrzysztof Helt
This was suggested by Geert Uytterhoeven to avoid overwriting of default values from the tdfx_fix. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02tdfxfb: fix frame buffer name overrunKrzysztof Helt
If there are more then one graphics card handled by the tdfxfb driver the name of the frame buffer overruns reserved size. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02tdfxfb: fix SDRAM memory size detectionKrzysztof Helt
Fix memory detection on Voodoo3 cards with SDRAM memory. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tdfxfb: remove ypan checks done by a higher layerKrzysztof Helt
These checks and assignments are done by a higher layer so remove them from the driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tdfxfb: add mode_option module parameterKrzysztof Helt
Small step toward unification of mode setting parameter. This is required to fix the Bugzilla's bug 9847 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06tdfxfb: fix section mismatch warningsRandy Dunlap
tdfxfb_setup() can be __init. This fixes the modpost section mismatch warnings: WARNING: vmlinux.o(.text+0x4cff9b): Section mismatch: reference to .init.data:mode_option (between 'tdfxfb_setup' and 'getclkMHz') WARNING: vmlinux.o(.text+0x4cffa8): Section mismatch: reference to .init.data: (between 'tdfxfb_setup' and 'getclkMHz') [krzysztof.h1@poczta.fm: use __init, not __devinit] Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: checkpatch fixesKrzysztof Helt
This patch fixes all errors pointed by the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: replace busy waiting with cpu_relaxKrzysztof Helt
This patch replaces busy waiting with cpu_relax() call. This makes scrolling faster. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: mtrr supportKrzysztof Helt
This patch adds mtrr support to the tdfxfb driver. It also kills one redundant include and initialization value. [akpm@linux-foundation.org: cleanups] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: hardware cursorKrzysztof Helt
This patch adds hardware cursor support to the tdfxfb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: code improvementsKrzysztof Helt
This patch improves source code mainly by killing redundant variable loads, reducing number of variables, simplifying conditional branches, etc. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: palette fixesKrzysztof Helt
This patch fixes: - palette setting in 8-bit mode (aka 'funky penguin') - grayscale handling - adds proper barriers in xxx_inb/outb functions Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: 3 fixesKrzysztof Helt
This patch fixes 3 issues: - transparency handling in tdfxfb - panning with more than 4096 virtual height and acceleration (acceleration with x & y > 4096) - exit paths on errors in tdfxfb_probe() Additionally it sets a FBINFO_READS_FAST flag to use smart blitter scrolling (speed up on tdfxfb). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: coding style improvementKrzysztof Helt
This patch contains coding style improvements to the tdfxfb driver (white spaces, indentations, long lines). It also moves fb_ops structure to the end of file, so forward declarations of ops functions are redundant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] tdfxfb: Fix buffer overrunAntonino A. Daplas
The pseudo_palette has room only for 16 entries, but tdfxfb_setcolreg may attempt to write more. Coverity Bug 557 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] drivers/video/: possible cleanupsAdrian Bunk
This patch contains the possible cleanups including the following: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static - kyro/STG4000Interface.h: #include video/kyro.h and linux/pci.h instead of a manual "struct pci_dev" - i810_main.{c,h}: prototypes for static functions belong to the C file Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: tdfxfb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - move memory for pseudo_palette inside struct tdfxfb_par - whitespace changes Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Clean-up and bug fix for tdfxfb framebuffer size detectionRichard Drummond
Attached is a patch against 2.6.11.7 which tidies up the tdfxfb framebuffer size detection code a little and fixes the broken support for Voodoo4/5 cards. (I haven't tested this on a Voodoo5, however, because I don't have the hardware). Signed-off-by: Richard Drummond <evilrich@rcdrummond.net> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Better PLL frequency matching for tdfxfb driverRichard Drummond
Improve the PLL frequency matching in the tdfxfb driver. Instead of requiring 64260 iterations to obtain the closest supported PLL frequency, this code does it with the same degree of accuracy in at most 768 iterations. Signed-off-by: Richard Drummond <evilrich@rcdrummond.net> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
