The drivers/video directory is a mess. It contains generic video related
files, directories for backlight, console, linux logo, lots of fbdev
device drivers, fbdev framework files.
Make some order into the chaos by creating drivers/video/fbdev
directory, and move all fbdev related files there.
No functionality is changed, although I guess it is possible that some
subtle Makefile build order related issue could be created by this
patch.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
removes unnecessary semicolon
Found by Coccinelle: http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
The file is not needed.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Thomas Winischhofer <thomas@winischhofer.net>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
There is no need to alias CONFIG #defines.
This patch removes compat code for older kernel versions.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: <thomas@winischhofer.net>
Convert:
FALSE -> false
TRUE -> true
BOOLEAN -> bool
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Cc: Thomas Hellstrom <thomas@tungstengraphics.com>
Cc: James Simmons <jsimmons@infradead.org>
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This lifts sisfb from version 1.7.17 to version 1.8.9. Changes include:
- Added support for XGI V3XT, V5, V8, Z7 chipsets, including POSTing of
all of these chipsets.
- Added support for latest SiS chipsets (761).
- Added support for SiS76x memory "hybrid" mode.
- Added support for new LCD resolutions (eg 1280x854, 856x480).
- Fixed support for 320x240 STN panels (for embedded devices).
- Fixed many HDTV modes (525p, 750p, 1080i).
- Fixed PCI config register reading/writing to use proper kernel
functions for this purpose.
- Fixed PCI ROM handling to use the kernel's proper functions.
- Removed lots of "typedef"s.
- Removed lots of code which was for X.org/XFree86 only.
- Fixed coding style in many places.
- Removed lots of 2.4 cruft.
- Reduced stack size by unifying two previously separate structs into
one.
- Added new hooks for memory allocation (for DRM). Now the driver can
truly handle multiple cards, including memory management.
- Fixed numerous minor bugs.
Signed-off-by: Thomas Winischhofer <thomas@winischhofer.net>
