path: root/drivers/video/sgivwfb.c
2006-06-29[PATCH] fix sgivwfb compileAdrian Bunk
drivers/built-in.o: In function `sgivwfb_set_par': sgivwfb.c:(.text+0x88583): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.text+0x88596): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.text+0x885a8): undefined reference to `sgivwfb_mem_phys' drivers/built-in.o: In function `sgivwfb_check_var': sgivwfb.c:(.text+0x88ad0): undefined reference to `sgivwfb_mem_size' drivers/built-in.o: In function `sgivwfb_mmap': sgivwfb.c:(.text+0x88c75): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.text+0x88c7f): undefined reference to `sgivwfb_mem_phys' drivers/built-in.o: In function `sgivwfb_probe': sgivwfb.c:(.init.text+0x4060): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4065): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x4076): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x409c): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x410e): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4113): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x4162): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4168): undefined reference to `sgivwfb_mem_phys' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-05[DRIVER MODEL] Fix sgivwfbRussell King
Statically allocated devices in module data is a potential cause of oopsen. The device may be in use by a userspace process, which will keep a reference to the device. If the module is unloaded, the module data will be freed. Subsequent use of the platform device will cause a kernel oops. Use generic platform device allocation/release code in modules. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
