path: root/drivers/video/s3c2410fb.c
2006-06-26[PATCH] s3c2410fb: Fix resumeArnaud Patard
regs.lcdcon1 was not updated on suspend. The result was a garbaged display on resume. This bug was first noticed by Christer Weinigel. This patch is a modified version of the one he sent to me. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[ARM] remove duplicate #includesHerbert Poetzl
Signed-off-by: Herbert P?tzl <herbert@13thfloor.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-10[PATCH] s3c2410fb: cleanup and fixArnaud Patard
Here are some cleanups for the s3c2410fb drivers. It : * Removes a buggy call to s3c2410fb_init_registers. There was two calls to this function but the first was done without all initialisations done. No oops but it may confuse some LCDs. * Makes two functions static. Signed-Off-By: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-Off-By: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07[ARM] Move asm/hardware/clock.h to linux/clk.hRussell King
This is needs to be visible to other architectures using the AMBA bus and peripherals. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-03[ARM] Remove clk_use()/clk_unuse()Russell King
It seems that clk_use() and clk_unuse() are additional complexity which isn't required anymore. Remove them from the clock framework to avoid the additional confusion which they cause, and update all ARM machine types except for OMAP. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] s3c2410fb: initialise device_driver .ownerBen Dooks
Initialise the .owner field, so that if the driver is built as a module, the system has a link to the owner Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-29[PATCH] s3c2410fb: Minor warning fixBen Dooks
The function s3c2410fb_activate_var does not return a value, therefore it should be declared void. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] s3c2410fb: ARM S3C2410 framebuffer driverArnaud Patard
This set of two patches add support for the framebuffer of the Samsung S3C2410 ARM SoC. This driver was started about one year ago and is now used on iPAQ h1930/h1940, Acer n30 and probably other s3c2410-based machines I'm not aware of. I've also heard yesterday that it's working also on iPAQ rx3715/rx3115 (s3c2440-based machines). Signed-Off-By: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Ben Dooks <ben@trinity.fluff.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
