path: root/drivers/video/pm2fb.c
2014-04-17video: move fbdev to drivers/video/fbdevTomi Valkeinen
The drivers/video directory is a mess. It contains generic video related files, directories for backlight, console, linux logo, lots of fbdev device drivers, fbdev framework files. Make some order into the chaos by creating drivers/video/fbdev directory, and move all fbdev related files there. No functionality is changed, although I guess it is possible that some subtle Makefile build order related issue could be created by this patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rob Clark <robdclark@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-10-29framebuffer: Use fb_<level>Joe Perches
Neaten and shorten the code using the new fb_<level> macros. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-09-19video: pm2fb: remove unnecessary pci_set_drvdata()Jingoo Han
From 9e2c37ee1d5c2145fac113c483c9e6dd408f10fe Mon Sep 17 00:00:00 2001 From: Jingoo Han <jg1.han@samsung.com> Date: Thu, 12 Sep 2013 15:11:07 +0900 Subject: [PATCH 14/21] video: pm2fb: remove unnecessary pci_set_drvdata() The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-06-24video: Fix speficied typoJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-15pm2fb: use display information in info not in var for panningLaurent Pinchart
We must not use any information in the passed var besides xoffset, yoffset and vmode as otherwise applications might abuse it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-02-05tree-wide: s/widht/width/g typo in commentsDaniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Jiri Kosina <trivial@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-16fbdev: use framebuffer_release() for freeing fb_info structuresKrzysztof Helt
Use the framebuffer_release() for freeing fb_info structures allocated with framebuffer_alloc(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20pm2fb: free cmap memory on module removeKrzysztof Helt
Release cmap memory allocated in the probe function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: add removed option "mode" to keep compatibilityKrzysztof Helt
Add removed option "mode" to keep compatibility with existing setups. The option is back for pm2fb, tridentfb and vt8623fb drivers. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pm2fb: change option mode to mode_optionKrzysztof Helt
Change the option "mode_option" into "mode". This is one step toward changing all fb drivers to have common "mode_option" parameter. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Alain Kalker <miki@dds.nl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pm2fb: correct error values returned from probe functionKrzysztof Helt
Fix error values returned in some code branches in the pm2fb_probe() function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06pm2fb: big endian fixKrzysztof Helt
Fix garbled letters on big endian machines with acceleration enabled. This makes pm2fb works fine with full acceleration on sparc machine (card known as Sun PGX-32 or TechSource Raptor GFX-8P). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: replace busy waiting with cpu_relaxKrzysztof Helt
This patch replaces busy waiting with the cpu_relax() call. This makes scrolling faster. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: panning and hardware cursor fixesKrzysztof Helt
This patch: - disallows setting of virtual height above 2048 as it does not work for accelerated copyarea and imageblit - fixes blinking of pm2v cursor by pushing cursor outside the display (x=2047) - fixes hardware cursor position on Permedia 2 chips with panning enabled - enables hardware cursor by default Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: hardware cursor support for the Permedia2Krzysztof Helt
This patch adds hardware cursor support for the Permedia 2 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: Permedia 2V hardware cursor supportKrzysztof Helt
This patch adds hardware cursor support for Permedia 2V chips. The hardware cursor is disabled by default. It does not blink - the same issue is mentioned in the x11 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: checkpatch fixesKrzysztof Helt
This patch fixes all errors detected by checkpatch.pl script in the pm2fb.c file. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: accelerated 24-bit fillrectKrzysztof Helt
This patch adds accelerated fillrect for 24-bit depth. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: Permedia 2V initialization fixesKrzysztof Helt
This patch: - initializes correctly the Permedia2V chip if it is not initialized by BIOS - puts back clock frequency for the ELSA WINNER board to 100kHz - fixes returned error values from setcolreg() function - uses more general classes for PCI ids Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: source code improvementsKrzysztof Helt
This patch concentrates on source compacting, simplification and more conformance to kernel coding standards. The major changes: - RD32() and WR() functions are merged into pm2_RD() and pm2_WR() - conditional (with switch()) RDAC functions are separated in two unconditional ones - the conditional pm2fb_block_op() function is merged into pm2fb_fillrect() and pm2fb_copyarea() - WAIT_FIFO() values are corrected Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: accelerated imageblitKrzysztof Helt
This patch adds accelerated imageblit function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: mtrr support and noaccel optionKrzysztof Helt
This patch adds usage of MTRR registers and two new options: noaccel and nomtrr. [bunk@kernel.org: make pm3fb_init() static again] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17pm2fb: white spaces clean upKrzysztof Helt
This patch removes trailing spaces and tabs and spaces before tabs. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23pm2fb: RDAC_WR barriers clean upKrzysztof Helt
This patch fixes a possible barriers problem in RDAC_WR functions, then remove redudant ones. It also removes one unneeded register load from blitter function(). Signed-off-by: Krzysztof.Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11pm2fb: fb_sync addedAntonino A. Daplas
Convert internal wait_pm2() function to fb API fb_sync() method. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: fix of jumps in pm2fb_probeKrzysztof Helt
This patch fixes incorrect targets of jumps when an error occurs in the pm2fb_probe. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: removal of pm2fb_par fieldsKrzysztof Helt
This patch removes two redundant fields in the pm2fb_par structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: accelerated fillrect and copyareaKrzysztof Helt
This is a port of accelerated functions from 2.4 kernel. Only fillrect and copyarea are accelerated. Fillrect is not accelerated in 24-bit mode. [adaplas] Add appropriate flags Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: memclock setting correctionsKrzysztof Helt
This patch disables a memory clock setting if a board has been initialized by BIOS. This allows using the memory clock set by manufacturer of the board. This patch also sets default clock for 3dlabs Permedia 2V reference board's clock to 75MHz (BIOS setting for EONtronic Permedia 2Vboard), because the default 83MHz can be too high. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: reset transparency settingskrzysztof.h1@wp.pl
This patch resets transparency settings when depth changes. Otherwise the 16 and 24-bit modes work incorrectly after switching from 32-bit mode. Signed-off-by: Krzysztof Helt < krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: pixclock setting restrictionKrzysztof Helt
This patch adds restrictions to calculations of m, n and p factors which sets the pixclock for the Permedia 2V. I found during tests that synchronization is unstable if m (divisor) is bigger than half of the n (numerator). The patch disallows such settings combination. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: Permedia 2V memory clock settingKrzysztof Helt
Permedia 2V uses its own registers to set a memory clock. The patch adds these registers and uses them in the set_memclock() function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: 3dlabs Permedia 2V reference board addedKrzysztof Helt
This patch adds support for 3dlabs Permedia reference board. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] fix section mismatch in pm2fb.oDarren Jenkins
WARNING: drivers/video/pm2fb.o - Section mismatch: reference to .init.data: from .text after 'pm2fb_set_par' (at offset 0xd5d) WARNING: drivers/video/pm2fb.o - Section mismatch: reference to .init.data: from .text after 'pm2fb_set_par' (at offset 0xd82) They are caused because pm2fb_set_par() uses lowhsync and lowvsync which are marked __devinitdata. Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: pm2fb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - move memory for pseudo_palette inside struct pm2fb_par Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] pm2fb: Manual configuration of timings for Elsa Winner 2000 OfficePeter 'p2' De Schrijver
Attached is a small patch which configures the correct memory clock and timings on the Elsa Winner 2000 Office pm2 based card. This is necessary when the card is used on a platform which does not support PC style BIOS initialization. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
