This is the result of a brute-force attempt to update the kernel to 2.6.23.
Now that we have a git tree, our effort will be a little nicer in the future.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/kernel/xtensa_ksyms.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
ioremap must be balanced by an iounmap and failing to do so can result in a
memory leak.
Signed-off-by: Amol Lad <amol@verismonetworks.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
This patch first splits of_device.c and of_platform.c, the later containing
the bits relative to of_platform_device's. On the "breaks" side of things,
drivers uisng of_platform_device(s) need to include asm/of_platform.h now
and of_(un)register_driver is now of_(un)register_platform_driver.
In addition to a few utility functions to locate of_platform_device(s),
the main new addition is of_platform_bus_probe() which allows the platform
code to trigger an automatic creation of of_platform_devices for a whole
tree of devices.
The function acts based on the type of the various "parent" devices encountered
from a provided root, using either a default known list of bus types that can be
"probed" or a passed-in list. It will only register devices on busses matching
that list, which mean that typically, it will not register PCI devices, as
expected (since they will be picked up by the PCI layer).
This will be used by Cell platforms using 4xx-type IOs in the Axon bridge
and can be used by any embedded-type device as well.
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a
function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h
allows all of the framebuffer and VT console drivers to remove their
dependency on tty.h.
[akpm@osdl.org: fix alpha build]
Signed-off-by: Jon Smirl <jonsmir@gmail.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The pre-parsed addrs/n_addrs fields in struct device_node are finally
gone. Remove the dodgy heuristics that did that parsing at boot and
remove the fields themselves since we now have a good replacement with
the new OF parsing code. This patch also fixes a bunch of drivers to use
the new code instead, so that at least pmac32, pseries, iseries and g5
defconfigs build.
The platinumfb driver used only on some powermacs has an issue with some
video modes & limited VRAM. This patch fixes it.
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for
drivers that do not support hardware cursors is redundant. The soft_cursor
function is usable by all drivers because it is just a wrapper around
fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is
moved to the console directory.
Thus, drivers that do not support hardware cursors can leave the fb_cursor
field blank. For drivers that do, they can fill up this field with their own
version.
The end result is a smaller code size. And if the framebuffer console is not
loaded, module/kernel size is also reduced because the soft_cursor module will
also not be loaded.
This converts the usage of struct of_match to struct of_device_id,
similar to pci_device_id. This allows a device table to be generated,
which can be parsed by depmod(8) to generate a map file for module
loading.
In order for hotplug to work with macio devices, patches to
module-init-tools and hotplug must be applied. Those patches are
available at:
ftp://ftp.suse.com/pub/people/jeffm/linux/macio-hotplug/
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
infrastructure for it.
Let it rip!
