path: root/drivers/video/omap
2013-04-10ARM: OMAP: remove "config FB_OMAP_CONSISTENT_DMA_SIZE"Paul Bolle
The only user of Kconfig symbol FB_OMAP_CONSISTENT_DMA_SIZE got removed in v3.8, with commit 6ba54ab4a49bbad736b0254aa6bdf0cb83013815 ("ARM: OMAP: Remove omap_init_consistent_dma_size()"). Remove this symbol too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-03-22omapfb: fix broken build on OMAP1Aaro Koskinen
Fix the following build regression in 3.9-rc1 by including <mach/hardware.h>: drivers/video/omap/omapfb_main.c: In function 'set_fb_var': drivers/video/omap/omapfb_main.c:505:3: error: implicit declaration of function 'cpu_is_omap15xx' [-Werror=implicit-function-declaration] Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-03-04ARM: OMAP1: Fix build related to kgdb.h no longer including serial_8250.hTony Lindgren
Commit 16559ae4 (kgdb: remove #include <linux/serial_8250.h> from kgdb.h) had a side effect of breaking omap1_defconfig build as some headers were included indirectly: arch/arm/mach-omap1/board-h2.c:249: error: ‘INT_KEYBOARD’ undeclared here (not in a function) ... This worked earlier as linux/serial_8250.h included linux/serial_core.h, via linux/serial_8250.h from linux/kgdb.h. Fix this by including the necessary headers directly. Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-21drivers/video/omap: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Tomi Valkeinen <tomi.valkeinen@ti.com> CC: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-30ARM: OMAP: Move plat-omap/dma-omap.h to include/linux/omap-dma.hTony Lindgren
Based on earlier discussions[1] we attempted to find a suitable location for the omap DMA header in commit 2b6c4e73 (ARM: OMAP: DMA: Move plat/dma.h to plat-omap/dma-omap.h) until the conversion to dmaengine is complete. Unfortunately that was before I was able to try to test compile of the ARM multiplatform builds for omap2+, and the end result was not very good. So I'm creating yet another all over the place patch to cut the last dependency for building omap2+ for ARM multiplatform. After this, we have finally removed the driver dependencies to the arch/arm code, except for few drivers that are being worked on. The other option was to make the <plat-omap/dma-omap.h> path to work, but we'd have to add some new header directory to for multiplatform builds. Or we would have to manually include arch/arm/plat-omap/include again from arch/arm/Makefile for omap2+. Neither of these alternatives sound appealing as they will likely lead addition of various other headers exposed to the drivers, which we want to avoid for the multiplatform kernels. Since we already have a minimal include/linux/omap-dma.h, let's just use that instead and add a note to it to not use the custom omap DMA functions any longer where possible. Note that converting omap DMA to dmaengine depends on dmaengine supporting automatically incrementing the FIFO address at the device end, and converting all the remaining legacy drivers. So it's going to be few more merge windows. [1] https://patchwork.kernel.org/patch/1519591/# cc: Russell King <linux@arm.linux.org.uk> cc: Kevin Hilman <khilman@ti.com> cc: "Benoît Cousson" <b-cousson@ti.com> cc: Herbert Xu <herbert@gondor.apana.org.au> cc: "David S. Miller" <davem@davemloft.net> cc: Vinod Koul <vinod.koul@intel.com> cc: Dan Williams <djbw@fb.com> cc: Mauro Carvalho Chehab <mchehab@infradead.org> cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> cc: David Woodhouse <dwmw2@infradead.org> cc: Kyungmin Park <kyungmin.park@samsung.com> cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Tomi Valkeinen <tomi.valkeinen@ti.com> cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> cc: Hans Verkuil <hans.verkuil@cisco.com> cc: Vaibhav Hiremath <hvaibhav@ti.com> cc: Lokesh Vutla <lokeshvutla@ti.com> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> cc: Afzal Mohammed <afzal@ti.com> cc: linux-crypto@vger.kernel.org cc: linux-media@vger.kernel.org cc: linux-mtd@lists.infradead.org cc: linux-usb@vger.kernel.org cc: linux-fbdev@vger.kernel.org Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17ARM: OMAP: Make plat/fpga.h local to arch/arm/plat-omapTony Lindgren
There's no need to have this file in plat/fpga.h. We can make it local to plat-omap replacing fpga_read/write functions directly with readb/writeb as that's how they are already defined in fpga.h. Note that 2420 based H4 is also using the fpga, so let's keep the led support around in plat-omap until we flip over mach-omap2 to device tree. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-fbdev@vger.kernel.org Cc: Felipe Balbi <balbi@ti.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP: DMA: Move plat/dma.h to plat-omap/dma-omap.hLokesh Vutla
Move plat/dma.h to plat-omap/dma-omap.h as part of single zImage work Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-12Merge tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: "This includes: - large updates for OMAP - basic OMAP5 DSS support for DPI and DSI outputs - large cleanups and restructuring - some update to Exynos and da8xx-fb - removal of the pnx4008 driver (arch removed) - various other small patches" Fix up some trivial conflicts (mostly just include line changes, but also some due to the renaming of the deferred work functions by Tejun). * tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits) gbefb: fix compile error video: mark nuc900fb_map_video_memory as __devinit video/mx3fb: set .owner to prevent module unloading while being used video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare drivers/video/exynos/exynos_mipi_dsi.c: fix error return code drivers/video/savage/savagefb_driver.c: fix error return code video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare da8xx-fb: save and restore LCDC context across suspend/resume cycle da8xx-fb: add pm_runtime support video/udlfb: fix line counting in fb_write OMAPDSS: add missing include for string.h OMAPDSS: DISPC: Configure color conversion coefficients for writeback OMAPDSS: DISPC: Add manager like functions for writeback OMAPDSS: DISPC: Configure writeback FIFOs OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup() OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup OMAPDSS: DISPC: Add function to set channel in for writeback OMAPDSS: DISPC: Don't set chroma resampling bit for writeback OMAPDSS: DISPC: Downscale chroma if plane is writeback OMAPDSS: DISPC: Configure input and output sizes for writeback ...
2012-09-20ARM: OMAP1: Move board-ams-delta.h from plat to machTony Lindgren
This is only used by omap1. And to fix things properly, this should not be included from the drivers at all. Acked-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-fbdev@vger.kernel.org Cc: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Cc: linux-mtd@lists.infradead.org Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: linux-input@vger.kernel.org Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: alsa-devel@alsa-project.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP1: Make plat/mux.h omap1 onlyTony Lindgren
We are moving omap2+ to use the device tree based pinctrl-single.c and will be removing the old mux framework. This will remove the omap1 specific parts from plat-omap. Acked-by: Felipe Balbi <balbi@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-usb@vger.kernel.org Cc: linux-pcmcia@lists.infradead.org Cc: spi-devel-general@lists.sourceforge.net Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-09-07OMAPFB1: remove a non-used tableTomi Valkeinen
The old omapfb driver contains a table for DMA element types, which is not used. Remove it. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-09-07OMAPFB1: remove unnecessary includesTomi Valkeinen
Remove unnecessary includes from the old omapfb driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-04-23OMAPFB: remove unused FB_OMAP_BOOTLOADER_INIT config optionPeter Meerwald
code depending on FB_OMAP_BOOTLOADER_INIT has been removed long before (e.g. Tomi Valkeinen, 03 Mar 2011: OMAP: DSS2: Remove FB_OMAP_BOOTLOADER_INIT support), but the option still exists Kconfig and has no use Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-03-27Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: board specific updates" from Arnd Bergmann/Olof Johansson: "These changes are all specific to one board only. We're trying to keep the number of board files low, but generally board level updates are ok on platforms that are working on moving towards DT based probing, which will eventually lead to removing them. The board-ams-delta.c board file gets a conflict between the removal of ams_delta_config and the addition of a lot of other data. The Kconfig file has two changes in the same line, and in exynos, the power domain cleanup conflicts with the addition of the image sensor device. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: Amended a fix for a mismerge to board-omap4panda.c] Signed-off-by: Olof Johansson <olof@lixom.net>" Fixed up some fairly trivial conflicts manually. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (82 commits) i.MX35-PDK: Add Camera support ARM : mx35: 3ds-board: add framebuffer device pxa/hx4700: Remove pcmcia platform_device structure ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35% ARM: pxa/hx4700: Remove unwanted request for GPIO105 ARM: EXYNOS: support Exynos4210-bus Devfreq driver on Nuri board ARM: EXYNOS: Register JPEG on nuri ARM: EXYNOS: Register JPEG on universal_c210 ARM: S5PV210: Enable JPEG on SMDKV210 ARM: S5PV210: Add JPEG board definition ARM: EXYNOS: Enable JPEG on Origen ARM: EXYNOS: Enable JPEG on SMDKV310 ARM: EXYNOS: Add __init attribute to universal_camera_init() ARM: EXYNOS: Add __init attribute to nuri_camera_init() ARM: S5PV210: Enable FIMC on SMDKC110 ARM: S5PV210: Enable FIMC on SMDKV210 ARM: S5PV210: Enable MFC on SMDKC110 ARM: S5PV210: Enable MFC on SMDKV210 ARM: EXYNOS: Enable G2D on SMDKV310 ARM: tegra: update defconfig ...
2012-03-20Merge branch 'for-3.4' of git://gitorious.org/linux-omap-dss2/linux into ↵Florian Tobias Schandinat
fbdev-next
2012-03-01ARM: OMAP1: ams-delta: clean up init data section assignmentsJanusz Krzysztofik
The main purpose of this patch is to fix several section mismatch warnings from the board file and a few board specific drivers, introduced with recent Amstrad Delta patch series, some of them rising up only when building with CONFIG_MODULES not set. While being at it, section tagging of all init data found in the board file have been revised and hopefully corrected and/or optimized. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAPFB: remove remaining OMAP arch checksTomi Valkeinen
Now that the old omapfb driver is only omap1 display driver, there's no need to check if the arch is omap1. This patch removes the few remaining checks for the arch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAPFB: Move old omapfb private structs to a private include fileTomi Valkeinen
include/linux/omapfb.h contains structs that are used only by the omapfb driver. Move the structs into drivers/video/omap/omapfb.h. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-02-23OMAPFB: remove mem info from platform_dataTomi Valkeinen
omapfb driver used platform_data to get fb memory areas and formats defined by the board file. This patch removes omapfb's (both old and new omapfb) use of the memory data in platform_data, because: - No board uses them currently - It's not board file's job to define things like amount of default framebuffer memory. These should come from the bootloader via command line parameters. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-02-23OMAP: N770: remove HWA742 platform dataTomi Valkeinen
In an effort to clean up the old omapfb driver, this patch removes HWA742 (the display chip used in N770) platform data. This can be done as N770 is the only user of HWA742, and the platform data contains only one field, te_connected, which we can just presume to be true in the HWA742 driver. This allows us to remove omapfb_set_ctrl_platform_data(), and the mechanism to pass the platform data, in a later patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAPFB: Remove video SRAM support (old omapfb)Tomi Valkeinen
OMAP SRAM can be used as video memory on OMAP1 and 2. However, there usually is very little SRAM available, thus limiting its use, and no board supported by the kernel currently uses it. This patch removes the use of SRAM as video ram for the old omapfb driver to simplify memory handling. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-22OMAPFB: Remove OMAP2/3 support from old omapfb driverTomi Valkeinen
Old omapfb driver (drivers/video/omap/) is no longer used for OMAP2+ devices, and thus we can remove OMAP2+ support from it and make it an OMAP1 omapfb driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-02-22OMAPFB: remove old blizzard driverTomi Valkeinen
N8x0's blizzard driver has been ported to new omapdss driver, so we can now remove the old blizzard driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-01-28video: convert drivers/video/* to use module_spi_driver()Axel Lin
This patch converts the drivers in drivers/video/* to use the module_spi_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Imre Deak <imre.deak@nokia.com> Cc: Roger Quadros <roger.quadros@nokia.com> Cc: Steve Sakoman <steve@sakoman.com> Cc: Erik Gilling <konkers@android.com> Cc: Gražvydas Ignotas <notasas@gmail.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-01-28video: use gpio_request_oneJingoo Han
Using gpio_request_one can make the code simpler because it can set the direction and initial value in one shot. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-01-20Merge branch 'omap1-part2' into omap1Tony Lindgren
Conflicts: drivers/leds/leds-ams-delta.c
2012-01-14Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (175 commits) module_param: make bool parameters really bool (drivers/video/i810) Revert "atmel_lcdfb: Adjust HFP calculation so it matches the manual." OMAPDSS: HDMI: Disable DDC internal pull up OMAPDSS: HDMI: Move duplicate code from boardfile OMAPDSS: add OrtusTech COM43H4M10XTC display support OMAP: DSS2: Support for UMSH-8173MD TFT panel ASoC: OMAP: HDMI: Move HDMI codec trigger function to generic HDMI driver OMAPDSS: HDMI: Create function to enable HDMI audio ASoC: OMAP: HDMI: Correct signature of ASoC functions ASoC: OMAP: HDMI: Introduce driver data for audio codec grvga: fix section mismatch warnings video: s3c-fb: Don't keep device runtime active when open video: s3c-fb: Hold runtime PM references when touching registers video: s3c-fb: Take a runtime PM reference when unblanked video: s3c-fb: Disable runtime PM in error paths from probe video: s3c-fb: Use s3c_fb_enable() to enable the framebuffer video: s3c-fb: Make runtime PM functional again drivers/video: fsl-diu-fb: merge fsl_diu_alloc() into map_video_memory() drivers/video: fsl-diu-fb: add default platform ops functions drivers/video: fsl-diu-fb: remove broken reference count enabling the display ...
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-08Merge branch 'for-florian' of git://gitorious.org/linux-omap-dss2/linux into ↵Florian Tobias Schandinat
fbdev-next
2012-01-02misc latin1 to utf8 conversionsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-02video: omap: convert drivers/video/omap/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/video/omap/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Jonathan McDowell <noodles@earth.li> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Laurent Gonzalez <palmte.linux@free.fr> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-01-02video: omap: Staticise non-exported symbolsAxel Lin
These symbols are not used outside it's driver so no need to make the symbol global. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-12-22omapfb: lcd_ams_delta: drive control lines over GPIOJanusz Krzysztofik
Don't use Amstrad Delta custom I/O functions any longer, use GPIO API instead. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-12-03video: Remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register(), so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-fbdev@vger.kernel.org Cc: linux-omap@vger.kernel.org Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2011-11-18OMAPFB: fix compilation warnings due to missing includeTomi Valkeinen
Fix warnings similar to this by including module.h: drivers/video/omap/dispc.c:276:1: warning: data definition has no type or storage class drivers/video/omap/dispc.c:276:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-10-31video: Add module.h to drivers/video files who really use it.Paul Gortmaker
They were getting this implicitly by an include of module.h from device.h -- but we are going to clean that up and break that include chain, so include module.h explicitly now. [ with contributions from Axel Lin <axel.lin@gmail.com> ] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-30Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (270 commits) video: platinumfb: Add __devexit_p at necessary place drivers/video: fsl-diu-fb: merge diu_pool into fsl_diu_data drivers/video: fsl-diu-fb: merge diu_hw into fsl_diu_data drivers/video: fsl-diu-fb: only DIU modes 0 and 1 are supported drivers/video: fsl-diu-fb: remove unused panel operating mode support drivers/video: fsl-diu-fb: use an enum for the AOI index drivers/video: fsl-diu-fb: add several new video modes drivers/video: fsl-diu-fb: remove broken screen blanking support drivers/video: fsl-diu-fb: move some definitions out of the header file drivers/video: fsl-diu-fb: fix some ioctls video: da8xx-fb: Increased resolution configuration of revised LCDC IP OMAPDSS: picodlp: add missing #include <linux/module.h> fb: fix au1100fb bitrot. mx3fb: fix NULL pointer dereference in screen blanking. video: irq: Remove IRQF_DISABLED smscufx: change edid data to u8 instead of char OMAPDSS: DISPC: zorder support for DSS overlays OMAPDSS: DISPC: VIDEO3 pipeline support OMAPDSS/OMAP_VOUT: Fix incorrect OMAP3-alpha compatibility setting video/omap: fix build dependencies ... Fix up conflicts in: - drivers/staging/xgifb/XGI_main_26.c Changes to XGIfb_pan_var() - drivers/video/omap/{lcd_apollon.c,lcd_ldp.c,lcd_overo.c} Removed (or in the case of apollon.c, merged into the generic DSS panel in drivers/video/omap2/displays/panel-generic-dpi.c)
2011-09-30OMAPDSS: Port the Apollon display driver to DSS2Tomi Valkeinen
Port the old omapfb panel driver for Apollon to DSS2. Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAPDSS: Port the H4 display driver to DSS2Tomi Valkeinen
Port the old omapfb panel driver for H4 to DSS2. Cc: Imre Deak <imre.deak@nokia.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAPDSS: Port 2430sdp display driver to DSS2Tomi Valkeinen
Port the old omapfb panel driver for 2430SDP to DSS2. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAPFB: Remove unused lcd driversTomi Valkeinen
drivers/video/omap/ contains some lcd drivers which are not used by any board. They can be removed. Cc: Arun C <arunedarath@mistralsolutions.com> Acked-by: Koen Kooi <koen@openembedded.org> Acked-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-08-08ARM: gpio: omap: convert drivers to use asm/gpio.h rather than mach/gpio.hRussell King
2011-05-26Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits) OMAP3: PM: Boot message is not an error, and not helpful, remove it OMAP3: cpuidle: change the power domains modes determination logic OMAP3: cpuidle: code rework for improved readability OMAP3: cpuidle: re-organize the C-states data OMAP3: clean-up mach specific cpuidle data structures OMAP3 cpuidle: remove useless SDP specific timings usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled usb: otg: OMAP4430: Fixing the omap4430_phy_init function usb: musb: am35x: fix compile error when building am35x usb: musb: OMAP4430: Power down the PHY during board init omap: drop board-igep0030.c omap: igep0020: add support for IGEP3 omap: igep0020: minor refactoring omap: igep0020: name refactoring for future merge with IGEP3 omap: Remove support for omap2evm arm: omap2plus: GPIO cleanup omap: musb: introduce default board config omap: move detection of NAND CS to common-board-devices omap: use common initialization for PMIC i2c bus omap: consolidate touch screen initialization among different boards ...
2011-05-13omap: Remove support for omap2evmTony Lindgren
The board support has never been merged for it as noticed by Russell King <linux@arm.linux.org.uk>. So let's remove the related dead code. Cc: linux-fbdev@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12OMAPFB: fix wrong clock aliases and device nameTomi Valkeinen
The clock aliases and the dss platform device name have changed, and omapfb fails to initialize. Update the names to correct ones. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-03-22omap: use list_move() instead of list_del()/list_add() combinationKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
