path: root/drivers/video/omap/dispc.c
2012-02-22OMAPFB: Remove OMAP2/3 support from old omapfb driverTomi Valkeinen
Old omapfb driver (drivers/video/omap/) is no longer used for OMAP2+ devices, and thus we can remove OMAP2+ support from it and make it an OMAP1 omapfb driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-11-18OMAPFB: fix compilation warnings due to missing includeTomi Valkeinen
Fix warnings similar to this by including module.h: drivers/video/omap/dispc.c:276:1: warning: data definition has no type or storage class drivers/video/omap/dispc.c:276:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-05-12OMAPFB: fix wrong clock aliases and device nameTomi Valkeinen
The clock aliases and the dss platform device name have changed, and omapfb fails to initialize. Update the names to correct ones. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-11OMAP: OMAPFB: fix clk_get for RFBITomi Valkeinen
omapfb platform device was still used to get clocks inside rfbi.c Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Tested-by: Sergey Lapin <slapin@ossfans.org>
2009-12-09OMAP: OMAPFB: add omapdss deviceTomi Valkeinen
The upcoming new display subsystem driver is divided to two devices, omapdss and omapfb, of which omapdss handles the actual hardware. This patch adds a dummy omapdss platform device for the current omapfb driver, which is then used to get the clocks. This will make it possible for the current and the new display drivers to co-exist. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com>
2009-12-09OMAP: OMAPFB: split omapfb.hTomi Valkeinen
Split arch/arm/plat-omap/include/mach/omapfb.h into two files: include/linux/omapfb.h - ioctls etc for userspace and some kernel stuff for board files drivers/video/omap/omapfb.h - for omapfb internal use This cleans up omapfb.h and also makes it easier for the upcoming new DSS driver to co-exist with the old driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: Use ioremap in dispc.cTony Lindgren
Use ioremap in dispc.c Cc: Imre Deak <imre.deak@nokia.com> Cc: Tomi Valkeinen <tomi.valkeinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omapfb: dispc: allow multiple external IRQ handlersDaniel Stone
Previously, the only external (to dispc.c) IRQ handler was RFBI's frame done handler. dispc's IRQ framework was very dumb: you could only have one handler, and the semantics of {request,free}_irq were odd, to say the least. The new framework allows multiple consumers to register arbitrary IRQ masks. Signed-off-by: Daniel Stone <daniel.stone@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Imre Deak <imre.deak@nokia.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omapfb: dispc: enable wake up capabilityJouni Hogander
Without wakeup enable omap doesn't wake up on dispc interrupts. This causes problems in a case where mpu is in sleep state and dispc interrupt fires. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Imre Deak <imre.deak@nokia.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omapfb: dispc: disable iface clocks along with func clocksJouni Hogander
Leaving interface clocks enabled causes dss pwrdm to stay in active state when mpu is in active state. This fix puts dss to sleep state when it is not needed. Earlier version broke framebuffer on 24xx. This is fixed by enabling clocks before trying to access DISPC_IRQSTATUS register. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Imre Deak <imre.deak@nokia.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omapfb: dispc: various typo fixesImre Deak
- value and register offset was swapped in a dispc write - DISPC_CONTROL register was used instead of DISPC_SYSCONFIG - FIFO size bit field had incorrect length for OMAP3 Fixed-by: arun <arunedarath@mistralsolutions.com> Fixed-by: Kalle Jokiniemi <ext-kalle.jokiniemi@nokia.com> Fixed-by: Andrzej Zaborowski <balrog@zabor.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Imre Deak <imre.deak@nokia.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-28OMAP: Remove OMAP_IO_ADDRESS, use OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS insteadTony Lindgren
Search and replace OMAP_IO_ADDRESS with OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS, and convert omap_read/write into a functions instead of a macros. Also rename OMAP_MPUIO_VBASE to OMAP1_MPUIO_VBASE. In the long run, most code should use ioremap + __raw_read/write instead. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-16ARM: OMAP2/3: Change omapfb to use clkdev for dispc and rfbi, v2Tony Lindgren
This makes the framebuffer work on omap3. Also fix the clk_get usage for checkpatch.pl "ERROR: do not use assignment in if condition". Cc: Imre Deak <imre.deak@nokia.com> Cc: linux-fbdev-devel@lists.sourceforge.net Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-09-05[ARM] omap: Fix IO_ADDRESS() macrosRussell King
OMAP1_IO_ADDRESS(), OMAP2_IO_ADDRESS() and IO_ADDRESS() returns cookies for use with __raw_{read|write}* for accessing registers. Therefore, these macros should return (void __iomem *) cookies, not integer values. Doing this improves typechecking, and means we can find those places where, eg, DMA controllers are incorrectly given virtual addresses to DMA to, or physical addresses are thrown through a virtual to physical address translation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-05[ARM] omap: convert OMAP drivers to use ioremap()Russell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17OMAP: add TI OMAP2 internal display controller support.Imre Deak
- Adds Texas Instruments OMAP2 processor series (OMAP2420/2430) internal display controller interface support. Signed-off-by: Trilok Soni <soni.trilok@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
