path: root/drivers/video/nvidia/nvidia.c
2014-04-17video: move fbdev to drivers/video/fbdevTomi Valkeinen
The drivers/video directory is a mess. It contains generic video related files, directories for backlight, console, linux logo, lots of fbdev device drivers, fbdev framework files. Make some order into the chaos by creating drivers/video/fbdev directory, and move all fbdev related files there. No functionality is changed, although I guess it is possible that some subtle Makefile build order related issue could be created by this patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rob Clark <robdclark@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-17video: nvidiafb: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12drivers/video/nvidia/nvidia.c: fix warningAndrew Morton
Fix the int/bool confusion in there. drivers/video/nvidia/nvidia.c:1602: warning: return from incompatible pointer type Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01nvidiafb: remove open_lock mutexAlessio Igor Bogani
Remove mutex from the nvidiafb_open/nvidiafb_release functions as these operations are mutexed at fb layer. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: nv: drop useless MODULE ifdefsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fb: nvidiafb: Try harder at initial mode setting.Paul Mundt
The current nvidiafb_check_var() simply bails out if the selected mode is out of range of the panel dimensions. A good question would be why the bogus mode is being selected in the first place -- the panel dimensions that are read back are certainly bogus, but alas, I have no idea where to even begin looking at the i2c/EDID/DDC mess: nvidiafb: Device ID: 10de0165 nvidiafb: CRTC0 analog not found nvidiafb: CRTC1 analog not found nvidiafb: EDID found from BUS1 nvidiafb: CRTC 0 is currently programmed for DFP nvidiafb: Using DFP on CRTC 0 nvidiafb: Panel size is 1280 x 1024 nvidiafb: Panel is TMDS nvidiafb: unable to setup MTRR nvidiafb: Flat panel dithering disabled nvidiafb: PCI nVidia NV16 framebuffer (64MB @ 0xC0000000) In my .config I presently have: CONFIG_FIRMWARE_EDID=y CONFIG_FB_DDC=y CONFIG_FB_NVIDIA_I2C=y I've not tried fiddling with these options, as I haven't the vaguest idea what I should be looking at. As a workaround, simply groveling for a new mode based on the probed dimensions seems to work ok. While it would be nice to debug this further and sort out why the panel information is bogus, I think it's still worth retrying the mode based on the panel information at hand as a last-ditch effort, rather than simply bailing out completely. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16nvidiafb: Add boot option to reverse i2c port assignmentAntonino A. Daplas
There are a few nvidia hardware where the i2c port assignments are reversed, i.e., the 1st i2c port is assigned to the secondary display and the 2nd i2c port to the primary display. In most cases, if only 1 display is attached, or if only 1 flatpanel and 1 analog display is attached, the port reversal is of no consequence. However if 2 flatpanels are attached, it can cause display problems. There is no sane way of determining if the hardware reversed the i2c port assignment, so the simplest fix is to add a boot/module option, "reverse_i2c to explicitly reverse the i2c port. This also restores i2c ordering back to the pre-2.6.22 state. Signed-off-by: Antonino Daplas <adaplas@gail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17nvidiafb: Add proper support for Geforce 7600 chipsetAntonino A. Daplas
Add proper support for the Geforce 7600 (device id 0x039x). This also sync's nvidiafb with the latest Xorg nv driver. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17nvidiafb: adjust flags to take advantage of new scroll methodAntonino A. Daplas
The SCROLL_MOVE method has been optimized such that it is significantly faster than SCROLL_REDRAW. Adjust flags to indicate that blitting is preferred over rendering. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11nvidiafb: Enable debugging messages a Kconfig optionJean Delvare
Let the user enable debugging messages in nvidiafb. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09frame buffer: geforce 7300 gtMichal Piotrowski
My geforce isn't supported by nvidia frame buffer. /sbin/lspci 01:00.0 VGA compatible controller: nVidia Corporation Unknown device 02e2 (rev a2) /usr/sbin/fbset -i mode "1024x768-60" # D: 65.003 MHz, H: 48.365 kHz, V: 60.006 Hz geometry 1024 768 1024 32767 8 timings 15384 160 24 29 3 136 6 accel true rgba 8/0,8/0,8/0,0/0 endmode Frame buffer device information: Name : NV2e Address : 0xe0000000 Size : 134217728 Type : PACKED PIXELS Visual : PSEUDOCOLOR XPanStep : 8 YPanStep : 1 YWrapStep : 0 LineLength : 1024 MMIO Address: 0xf6000000 MMIO Size : 16777216 Accelerator : Unknown (46) Here is a patch for this problem. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: fix return value of nvidiafb_open()Antonino A. Daplas
Fix return value of nvidiafb_open(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: VGA state save and restoreAntonino A. Daplas
Allow the saving and restoration of VGA text mode. The state is saved on the first open and restored on the last close. Because of the non-linear mapping of the VGA registers to the MMIO space, this will be done only on X86 platforms where the device is the primary display. An echo 0 > /sys/class/vtconsole/vtcon1/bind will convert the display from graphics to text mode. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: ensure that CRTC registers are accessibleAntonino A. Daplas
- Ensure that CRTC registers are accessible by unlocking them on set_par(), otherwise i2c reading will fail. - The function nvidia_vga_protect(), does not protect the VGA registers, but turns off the screen. Rename it to nvidia_screen_off(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05backlight: Allow enable/disable of fb backlights, fixing regressionsRichard Purdie
Enabling the backlight by default appears to cause problems for many users. This patch disables backlight controls unless explicitly enabled by users via a module parameter. Since PMAC users are known to work, default to enabled in that case. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Rework backlight/fb interaction simplifying, lotsRichard Purdie
fb_info->bl_mutex is badly thought out and the backlight class doesn't need it if the framebuffer/backlight register/unregister order is consistent, particularly after the backlight locking fixes. Fix the drivers to use the order: backlight_device_register() register_framebuffer() unregister_framebuffer() backlight_device_unregister() and turn bl_mutex into a lock for the bl_curve data only. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Remove uneeded nvidia set_power callsRichard Purdie
nvidia_bl_set_power isn't needed since the backlight class handles this by receiving fb events itself and calling update_status so remove it. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-12[PATCH] fbdev modedb: make more pointer parameters constGeert Uytterhoeven
fbdev modedb: make more input and output pointer parameters const Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] change nvidiafb_remove to __devexitPrarit Bhargava
Change nvidiafb_remove to __devexit to fix MODPOST warnings: WARNING: drivers/video/nvidia/nvidiafb.o - Section mismatch: reference to .exit.text:nvidiafb_remove from .data.rel.local after 'nvidiafb_driver' (at offset 0x28) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-By: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Video: fb, kzalloc changesJiri Slaby
Use kzalloc instead of kmalloc + memset(0). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-13[PATCH] Patch for nvidia divide by zero error for 7600 pci-express cardWink Saville
The following patch resolves the divide by zero error I encountered on my system: http://marc.10east.com/?l=linux-fbdev-devel&m=116058257024413&w=2 I accomplished this by merging what I thought was appropriate from: http://webcvs.freedesktop.org/xorg/driver/xf86-video-nv/src/ Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] nvidia fbdev: fix powerpc xmon scribblesPaul Mackerras
xmon writes garbage on the screen because the nvidia console driver has changed the line pitch from what the firmware set it to. Fix it by making the nvidia driver inform the btext engine (which xmon uses if the screen is its output device) about changes to display resolution. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] nvidiafb: Honor the return value of pci_enable_deviceAntonino A. Daplas
Check the return value of pci_enable_device(). Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25PM: video drivers and PM_EVENT_PRETHAWDavid Brownell
Video drivers which explicitly test for messages reporting PM_EVENT_FREEZE will now handle PM_EVENT_PRETHAW the same way. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] rivafb/nvidiafb: race between register_framebuffer and *_bl_initGuido Guenther
Since we now use the generic backlight infrastructure, I think we need to call rivafb_bl_init before calling register_framebuffer since otherwise rivafb_bl_init might race with the framebuffer layer already opening the device and setting up the video mode. In this case we might end up with a not yet fully intialized backlight (info->bl_dev still NULL) when calling riva_bl_set_power via rivafb_set_par/rivafb_load_video_mode and the kernel dies without any further notice during boot. This fixes booting current git on a PB 6,1. In this case radeonfb/atyfb would be affected too - I can fix that too but don't have any hardware to test this on. Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] nvidiafb: remove redundant CONFIG_PCI checkArthur Othieno
CONFIG_FB_NVIDIA already depends on CONFIG_PCI in drivers/video/Kconfig. Driver does an extra ``sanity check'' which is then redundant. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Cc: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] powermac: Combined fixes for backlight codeMichael Hanselmann
This patch fixes several problems: - pmac_backlight_key() is called under interrupt context, and therefore can't use mutexes or semaphores, so defer the backlight level for later, as it's not critical (original code by Aristeu S. Rozanski F. <aris@valeta.org>). - Add exports for functions that might be called from modules - Fix Kconfig depdencies on PMAC_BACKLIGHT. - Fix locking issues on calls from inside the driver (reported by Aristeu S. Rozanski F., too) - Fix wrong calculation of backlight values in some of the drivers - Replace pmac_backlight_key_up/down by inline functions [akpm@osdl.org: fix function prototypes] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Aristeu S. Rozanski F. <aris@valeta.org> Acked-by: Rene Nussbaumer <linux-kernel@killerfox.forkbomb.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Detaching fbcon: remove calls to pci_disable_device()Antonino A. Daplas
Detaching fbcon allows individual drivers to be unloaded. However several drivers call pci_disable_device() upon exit. This function will disable the BAR's which will kill VGA text mode and/or affect X/DRM. To prevent this, remove calls to pci_disable_device() from several drivers. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] nvidiafb: Add support for Geforce 6100 and related chipsetsAntonino A. Daplas
Add support for Geforce 6100 and related chipsets (PCI device id 0x024x) Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] nvidiafb: Revise pci_device_id tableAntonino A. Daplas
nVidia is churning out chipsets like there's no tomorrow. And even though the pci_device_id table now has numerous entries, it is still not guaranteed that all supported devices are included or will be included. Fortunately, nvidiafb has chipset detection logic built in. So, change the contents of the pci_device_id table so it will capture all nVidia devices of the display class. Unsupported chipsets will then be filtered out by nvidiafb's detection logic. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Rewritten backlight infrastructure for portable Apple computersMichael Hanselmann
This patch contains a total rewrite of the backlight infrastructure for portable Apple computers. Backward compatibility is retained. A sysfs interface allows userland to control the brightness with more steps than before. Userland is allowed to upload a brightness curve for different monitors, similar to Mac OS X. [akpm@osdl.org: add needed exports] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] Add ID for Quadro NVS280Pavel Roskin
Quadro NVS280 is a dual-head PCIe card with PCI ID 10de:00fd and subsystem ID 10de:0215. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] nvidiafb: Remove NULL checkAntonino A. Daplas
Remove unnecessary NULL check, as struct info will never be NULL. Coverity Bug 835 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] nvidiafb: add suspend and resume hooksAntonino A. Daplas
Add suspend and resume hooks to make software suspend more reliable. Resuming from standby should generally work. Resuming from mem and from disk requires that the GPU is disabled. Adding these to the suspend script... fbset -accel false -a /* suspend here */ fbset -accel true -a ... should generally work. In addition, resuming from mem requires that the video card has to be POSTed by the BIOS or some other utility. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] nvidiafb: Add support for Geforce4 MX 4000Antonino A. Daplas
Add support for Geforce4 MX 4000 (0x185) Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Reduce stack usageAntonino A. Daplas
Reduce stack usage of NVCommonSetup() Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Add boot option 'bpp'Antonino A. Daplas
Add boot/module option 'bpp' so user can specify at what color depth to boot into. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Add support for some pci-e chipsetsAntonino A. Daplas
Chipsets with PCI device ids & 0xf0 == 0x00f0 has their actual chipset type in offset 0x1800 of the mmio space. Add support for this. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: nvidiafb: Driver cleanupAntonino A. Daplas
- remove redundant casts - add mode_option to module parameter Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Fixes for new G5Benjamin Herrenschmidt
Recent X "nv" driver was fixed for various issues with modern 6xxx and 7xxx cards. This patch ports those fixes to nvidiafb. This makes it work fine on the 6600 bundled with the newest G5 macs. I've verified it still works on the 5200FX of the iMacG5. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] nvidiafb: Fix bug in nvidiafb_pan_displayAntonino A. Daplas
nvidiafb_pan_display() is incorrectly using the fields in info->var instead of var passed to the function. Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbdev: Convert a few drivers to use the fb_find_best_display helperAntonino A. Daplas
Convert i810fb, nvidiafb and savagefb to use the fb_find_best_display helper when searching for the initial video mode. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
