path: root/drivers/video/nvidia/nv_hw.c
2008-04-28fbdev: nv: fix sparse noiseAlexey Dobriyan
Mostly signedness fixes. nv10_sim_state existence in both drivers suggests that one of them should be removed, but that's for later. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17nvidiafb: Add proper support for Geforce 7600 chipsetAntonino A. Daplas
Add proper support for the Geforce 7600 (device id 0x039x). This also sync's nvidiafb with the latest Xorg nv driver. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11fbdev: geforce 7300 cleanupMichal Piotrowski
ups... coding style. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09frame buffer: geforce 7300 gtMichal Piotrowski
My geforce isn't supported by nvidia frame buffer. /sbin/lspci 01:00.0 VGA compatible controller: nVidia Corporation Unknown device 02e2 (rev a2) /usr/sbin/fbset -i mode "1024x768-60" # D: 65.003 MHz, H: 48.365 kHz, V: 60.006 Hz geometry 1024 768 1024 32767 8 timings 15384 160 24 29 3 136 6 accel true rgba 8/0,8/0,8/0,0/0 endmode Frame buffer device information: Name : NV2e Address : 0xe0000000 Size : 134217728 Type : PACKED PIXELS Visual : PSEUDOCOLOR XPanStep : 8 YPanStep : 1 YWrapStep : 0 LineLength : 1024 MMIO Address: 0xf6000000 MMIO Size : 16777216 Accelerator : Unknown (46) Here is a patch for this problem. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb/rivafb: switch to pci_get refcountingAlan Cox
Switch to pci_get refcounting APIs [adaplas] Fix a long-standing bug where the return value of pci_find_slot()/pci_get_bus_and_slot() is ignored. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-13[PATCH] Patch for nvidia divide by zero error for 7600 pci-express cardWink Saville
The following patch resolves the divide by zero error I encountered on my system: http://marc.10east.com/?l=linux-fbdev-devel&m=116058257024413&w=2 I accomplished this by merging what I thought was appropriate from: http://webcvs.freedesktop.org/xorg/driver/xf86-video-nv/src/ Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] nvidiafb: Add support for Geforce 6100 and related chipsetsAntonino A. Daplas
Add support for Geforce 6100 and related chipsets (PCI device id 0x024x) Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] drivers/video/: possible cleanupsAdrian Bunk
This patch contains the possible cleanups including the following: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static - kyro/STG4000Interface.h: #include video/kyro.h and linux/pci.h instead of a manual "struct pci_dev" - i810_main.{c,h}: prototypes for static functions belong to the C file Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] nvidiafb: Fixes for new G5Benjamin Herrenschmidt
Recent X "nv" driver was fixed for various issues with modern 6xxx and 7xxx cards. This patch ports those fixes to nvidiafb. This makes it work fine on the 6600 bundled with the newest G5 macs. I've verified it still works on the 5200FX of the iMacG5. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
