The drivers/video directory is a mess. It contains generic video related
files, directories for backlight, console, linux logo, lots of fbdev
device drivers, fbdev framework files.
Make some order into the chaos by creating drivers/video/fbdev
directory, and move all fbdev related files there.
No functionality is changed, although I guess it is possible that some
subtle Makefile build order related issue could be created by this
patch.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This contains the following changes:
* Overlay surface alpha is configured separately from the overlay. This
prevents display glitches (configure and fill the overlay first, set
alpha to a visible value next)
* Added an ioctl for configuring transparency of the Overlay and graphics
planes. Blend mode, colorkey mode and global alpha mode are supported.
* Added an ioctl for setting the plane order. The overlay plance can be placed
over or
under the graphics plane.
* Added an ioctl for setting and reading chip registers, with mask.
* Updated copyright for 2007
[adaplas]
* Coding style changes
Signed-off-by: Raphael Assenat <raph@8d.com>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
This patch adds register bits access macros for chip's Video Plane, Scaling
and interrupt registers.
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Acked-by: James Simmons <jsimmons@infradead.org>
Add frame buffer driver for the 2700G LCD controller present on CompuLab
CM-X270 computer module.
[adaplas]
- Add more informative help text to Kconfig
- Make DEBUG a Kconfig option as FB_MBX_DEBUG
- Remove #include mbxdebug.c, this is frowned upon
- Remove redundant casts
- Arrange #include's alphabetically
- Trivial whitespace
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
