path: root/drivers/video/imxfb.c
2013-07-08video: imxfb: Add DT supportMarkus Pargmann
Add devicetree support for imx framebuffer driver. It uses the generic display bindings and helper functions. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Mark Rutland <mark.rutland@arm.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2013-06-26video: imxfb: Make local symbols staticSachin Kamat
These symbols are used only in this file. Make them static. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-06-26video: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-23Merge tag 'imx-fixes-3.8-3' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes From Shawn Guo: This is yet another critical imxfb fixes held off by absence of FB maintainer for some time. * tag 'imx-fixes-3.8-3' of git://git.linaro.org/people/shawnguo/linux-2.6: video: imxfb: Do not crash on reboot
2013-01-17video: imxfb: Do not crash on rebootFabio Estevam
Issuing a "reboot" command after the LCD times out causes the following warnings: Requesting system reboot ------------[ cut here ]------------ WARNING: at drivers/clk/clk.c:471 clk_disable+0x24/0x50() Modules linked in: [<c001ad90>] (unwind_backtrace+0x0/0xf4) from [<c0025aac>] (warn_slowpath_common+0x48/0x60) [<c0025aac>] (warn_slowpath_common+0x48/0x60) from [<c0025ae0>] (warn_slowpath_null+0x1c/0x24) [<c0025ae0>] (warn_slowpath_null+0x1c/0x24) from [<c03960a0>] (clk_disable+0x24/0x50) [<c03960a0>] (clk_disable+0x24/0x50) from [<c02695a0>] (imxfb_disable_controller+0x48/0x7c) [<c02695a0>] (imxfb_disable_controller+0x48/0x7c) from [<c029d838>] (platform_drv_shutdown+0x18/0x1c) [<c029d838>] (platform_drv_shutdown+0x18/0x1c) from [<c02990fc>] (device_shutdown+0x48/0x14c) [<c02990fc>] (device_shutdown+0x48/0x14c) from [<c003d09c>] (kernel_restart_prepare+0x2c/0x3c) [<c003d09c>] (kernel_restart_prepare+0x2c/0x3c) from [<c003d0e4>] (kernel_restart+0xc/0x48) [<c003d0e4>] (kernel_restart+0xc/0x48) from [<c003d1e8>] (sys_reboot+0xc0/0x1bc) [<c003d1e8>] (sys_reboot+0xc0/0x1bc) from [<c0014ca0>] (ret_fast_syscall+0x0/0x2c) ---[ end trace da6b502ca79c854f ]--- ------------[ cut here ]------------ WARNING: at drivers/clk/clk.c:380 clk_unprepare+0x1c/0x2c() Modules linked in: [<c001ad90>] (unwind_backtrace+0x0/0xf4) from [<c0025aac>] (warn_slowpath_common+0x48/0x60) [<c0025aac>] (warn_slowpath_common+0x48/0x60) from [<c0025ae0>] (warn_slowpath_null+0x1c/0x24) [<c0025ae0>] (warn_slowpath_null+0x1c/0x24) from [<c0396338>] (clk_unprepare+0x1c/0x2c) [<c0396338>] (clk_unprepare+0x1c/0x2c) from [<c02695a8>] (imxfb_disable_controller+0x50/0x7c) [<c02695a8>] (imxfb_disable_controller+0x50/0x7c) from [<c029d838>] (platform_drv_shutdown+0x18/0x1c) [<c029d838>] (platform_drv_shutdown+0x18/0x1c) from [<c02990fc>] (device_shutdown+0x48/0x14c) [<c02990fc>] (device_shutdown+0x48/0x14c) from [<c003d09c>] (kernel_restart_prepare+0x2c/0x3c) [<c003d09c>] (kernel_restart_prepare+0x2c/0x3c) from [<c003d0e4>] (kernel_restart+0xc/0x48) [<c003d0e4>] (kernel_restart+0xc/0x48) from [<c003d1e8>] (sys_reboot+0xc0/0x1bc) [<c003d1e8>] (sys_reboot+0xc0/0x1bc) from [<c0014ca0>] (ret_fast_syscall+0x0/0x2c) ---[ end trace da6b502ca79c8550 ]--- ------------[ cut here ]------------ This happens because "reboot" triggers imxfb_shutdown(), which calls imxfb_disable_controller with the clocks already disabled. To prevent this, add a clock enabled status so that we can check if the clocks are enabled before disabling them. Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-16Merge branch 'v3.8-samsung-fixes-3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes From Kukjin Kim: That branch fixes build error for S3C24XX/S3C64xx. And corrects dw-mshc properties on EXYNOS5 DT and fixes IRQ mapping on Cragganmore board. * 'v3.8-samsung-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S3C64XX: Fix up IRQ mapping for balblair on Cragganmore ARM: dts: correct the dw-mshc timing properties as per binding ARM: S3C64XX: Fix build error with CONFIG_S3C_DEV_FB disabled + Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14video: imxfb: fix imxfb_info configuration orderGwenhael Goavec-Merou
The devtype field for fbi (struct imxfb_info) must be set after memset call to avoid some wrong behaviour (pixel size). Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-15video: imxfb: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-fbdev@vger.kernel.org
2012-10-12Merge tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: "This includes: - large updates for OMAP - basic OMAP5 DSS support for DPI and DSI outputs - large cleanups and restructuring - some update to Exynos and da8xx-fb - removal of the pnx4008 driver (arch removed) - various other small patches" Fix up some trivial conflicts (mostly just include line changes, but also some due to the renaming of the deferred work functions by Tejun). * tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits) gbefb: fix compile error video: mark nuc900fb_map_video_memory as __devinit video/mx3fb: set .owner to prevent module unloading while being used video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare drivers/video/exynos/exynos_mipi_dsi.c: fix error return code drivers/video/savage/savagefb_driver.c: fix error return code video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare da8xx-fb: save and restore LCDC context across suspend/resume cycle da8xx-fb: add pm_runtime support video/udlfb: fix line counting in fb_write OMAPDSS: add missing include for string.h OMAPDSS: DISPC: Configure color conversion coefficients for writeback OMAPDSS: DISPC: Add manager like functions for writeback OMAPDSS: DISPC: Configure writeback FIFOs OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup() OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup OMAPDSS: DISPC: Add function to set channel in for writeback OMAPDSS: DISPC: Don't set chroma resampling bit for writeback OMAPDSS: DISPC: Downscale chroma if plane is writeback OMAPDSS: DISPC: Configure input and output sizes for writeback ...
2012-09-22drivers/video/imxfb.c: fix error return codePeter Senna Tschudin
Convert a nonnegative error return code to a negative one, as returned elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-09-14ARM: imx: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the imx include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Sascha Hauer <kernel@pengutronix.de> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Dan Williams <djbw@fb.com> Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Cox <alan@linux.intel.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Javier Martin <javier.martin@vista-silicon.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2012-04-25video imxfb: do not depend on grouped clocksSascha Hauer
the current i.MX clock support groups together unrelated clocks to a single clock which is then used by the driver. This can't be accomplished with the generic clock framework so we instead request the individual clocks in the driver. For i.MX there are generally three different clocks: ipg: bus clock (needed to access registers) ahb: dma relevant clock, sometimes referred to as hclk in the datasheet per: bit clock, pixel clock This patch changes the driver to request the individual clocks. Currently all clk_get will get the same clock until the SoCs are converted to the generic clock framework Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-06-02drivers/video/imxfb.c: add missing clk_putJulia Lawall
Reorder the labels at the end of the function to correspond to the order in which the resources are allocated. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-19video i.MX: remove mx1 compile time dependenciesSascha Hauer
remove usage of CONFIG_ARCH_MX1. It's mostly unused anyway, replace it with cpu_is_mx1() where necessary. Also, depend on IMX_HAVE_PLATFORM_IMX_FB instead of the architectures directly. LAKML-Reference: 20110303141244.GQ29521@pengutronix.de Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12video: imx: Update the manufacturer's nameFabio Estevam
i.MX processors are currently manufactured by Freescale, not Motorola. Make the manufacturer's name consistent. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-27video: imxfb: Fix the maximum value for yresFabio Estevam
MX27 and MX25 have 10 bits in the YMAX field of LCDC Size Register. Fix the maximum value for yres. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-08-10ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICEEric Bénard
From: Eric Bénard <eric@eukrea.com> This fixes the following build failure: drivers/built-in.o: In function `imxfb_probe': mxcmmc.c:(.init.text+0xd04): undefined reference to `backlight_device_register' drivers/built-in.o: In function `imxfb_remove': mxcmmc.c:(.devexit.text+0x44): undefined reference to `backlight_device_unregister' that was introduced by 7a2bb23 (imxfb: add pwmr controlled backlight support) Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-26imxfb: add pwmr controlled backlight supportEric Bénard
Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-02-02imxfb: correct location of callbacks in suspend and resumeUwe Kleine-König
The probe function passes a pointer to a struct fb_info to platform_set_drvdata(), so don't interpret the return value of platform_get_drvdata() as a pointer to struct imxfb_info. The original imxfb_info *fbi backlight_power was NULL but in imxfb_suspend it was 4 resulting in an oops as imxfb_suspend calls imxfb_disable_controller(fbi) which in turn has if (fbi->backlight_power) fbi->backlight_power(0); Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <kernel@pengutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-07imxfb: Add support for multiple displaysSascha Hauer
2009-08-07imxfb: use resource_size() macroSascha Hauer
This fixes an off-by-one error. Also, use dev_err instead of printk in probe() function. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-08-07imxfb: calculate bpix value from bits_per_pixelSascha Hauer
2009-03-27imxfb: Fix TFT modeSascha Hauer
We read from the PCR reg to determine whether to use TFT mode or not. This is not possible because it may not have been initialized with the correct value yet. Select it using fbi->pcr instead. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-27imxfb: add clock supportSascha Hauer
v2: Added change from Martin Fuzzey: pixclock should be in pico seconds instead of MHz. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: Fix margin settingsSascha Hauer
The var->hsync_len, var->right_margin and var->left_margin fields should contain the real values, not the hardware dependent values. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: add mx27 supportSascha Hauer
2009-03-13imxfb: add 18 bit supportSascha Hauer
v2: As pointed out by Hans J. Koch we have to claim we can do 24bit to make software like X work. We are lucky on i.MX that 18bit support has the necessary gaps in the fields to do so. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: add platform specific init/exit functionsSascha Hauer
2008-12-16i.MX Framebuffer: add TFT supportSascha Hauer
With TFTs we can do 5/6/5 instead of 4/4/4. Add a bitfield for this and use it with TFTs. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: rename imxfb_mach_info to imx_fb_platform_dataSascha Hauer
rename imxfb_mach_info to a name more common to kernel hackers Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: Cleanup Coding styleSascha Hauer
2008-12-16i.MX Framebuffer: remove header fileSascha Hauer
Move contents of imxfb.h to imxfb.c since it is used only in this file Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: fix marginsSascha Hauer
The upper/lower and left/right margins are mixed up in the driver. Fix it Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: Use readl/writel instead of direct pointer derefJuergen Beisert
This patch prepares the current i.MX1 framebuffer driver for usage in the whole i.MX family. It switches to readl/writel for register accesses. Also it moves the register definitions to the driver where they belong. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: remove gpio setup functionSascha Hauer
Remove the gpio mux setup function from i.MX framebuffer driver. This function is platform specific and thus should be done by the board setup. As there are currently no in-kernel users of this driver we do not break anything. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16imxfb: fast read flag and nonstandard field configurablePavel Pisa
The i.MX frame-buffer read operation should be faster for all configurations then drawing each individual character again in response to scroll events. The nonstandard fields allows to configure frame-buffer special options flags for different display configurations by board specific initialization code. One of such specific options is reversed order of pixels in each individual byte. i.MX frame-buffer seems to be designed for big-endian use first. The byte order is correctly configured for little-endian ordering, but if 1, 2 or 4 bits per pixel are used, pixels ordering is incompatible to Linux generic frame-buffer drawing functions. The patch "Allow generic BitBLT functions to work with swapped pixel order in bytes" introduces required functionality into FBDEV core. The pixels ordering selection has to be enabled at compile time CONFIG_FB_CFB_REV_PIXELS_IN_BYTE and for each display configuration which requires it by flag FB_NONSTD_REV_PIX_IN_B in "nonstd" field of info structure. This patch provides way for board specific code to select this option. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23imxfb: fix memory holeSascha Hauer
info->pseudo_palette was previously kmalloced. Do not overwrite it afterwards Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23imxfb: remove ifdefsSascha Hauer
Here are some small fixes for the imxfb framebuffer driver: - remove ifndef for MX1FS2 platform which is not present in the kernel. - REV, CLS, PS and SPL_SPR are only needed with some sharp displays. Only setup the corresponding io pins when such a display is connected. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-07[ARM] 3232/1: i.MX Frame Buffer undeclared "dev" variable fixPavel Pisa
Patch from Pavel Pisa Correction of the code broken by update whole-tree platform devices update. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
