path: root/drivers/video/imxfb.c
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-07imxfb: Add support for multiple displaysSascha Hauer
2009-08-07imxfb: use resource_size() macroSascha Hauer
This fixes an off-by-one error. Also, use dev_err instead of printk in probe() function. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-08-07imxfb: calculate bpix value from bits_per_pixelSascha Hauer
2009-03-27imxfb: Fix TFT modeSascha Hauer
We read from the PCR reg to determine whether to use TFT mode or not. This is not possible because it may not have been initialized with the correct value yet. Select it using fbi->pcr instead. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-27imxfb: add clock supportSascha Hauer
v2: Added change from Martin Fuzzey: pixclock should be in pico seconds instead of MHz. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: Fix margin settingsSascha Hauer
The var->hsync_len, var->right_margin and var->left_margin fields should contain the real values, not the hardware dependent values. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: add mx27 supportSascha Hauer
2009-03-13imxfb: add 18 bit supportSascha Hauer
v2: As pointed out by Hans J. Koch we have to claim we can do 24bit to make software like X work. We are lucky on i.MX that 18bit support has the necessary gaps in the fields to do so. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-13imxfb: add platform specific init/exit functionsSascha Hauer
2008-12-16i.MX Framebuffer: add TFT supportSascha Hauer
With TFTs we can do 5/6/5 instead of 4/4/4. Add a bitfield for this and use it with TFTs. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: rename imxfb_mach_info to imx_fb_platform_dataSascha Hauer
rename imxfb_mach_info to a name more common to kernel hackers Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: Cleanup Coding styleSascha Hauer
2008-12-16i.MX Framebuffer: remove header fileSascha Hauer
Move contents of imxfb.h to imxfb.c since it is used only in this file Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: fix marginsSascha Hauer
The upper/lower and left/right margins are mixed up in the driver. Fix it Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: Use readl/writel instead of direct pointer derefJuergen Beisert
This patch prepares the current i.MX1 framebuffer driver for usage in the whole i.MX family. It switches to readl/writel for register accesses. Also it moves the register definitions to the driver where they belong. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-16i.MX Framebuffer: remove gpio setup functionSascha Hauer
Remove the gpio mux setup function from i.MX framebuffer driver. This function is platform specific and thus should be done by the board setup. As there are currently no in-kernel users of this driver we do not break anything. Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16imxfb: fast read flag and nonstandard field configurablePavel Pisa
The i.MX frame-buffer read operation should be faster for all configurations then drawing each individual character again in response to scroll events. The nonstandard fields allows to configure frame-buffer special options flags for different display configurations by board specific initialization code. One of such specific options is reversed order of pixels in each individual byte. i.MX frame-buffer seems to be designed for big-endian use first. The byte order is correctly configured for little-endian ordering, but if 1, 2 or 4 bits per pixel are used, pixels ordering is incompatible to Linux generic frame-buffer drawing functions. The patch "Allow generic BitBLT functions to work with swapped pixel order in bytes" introduces required functionality into FBDEV core. The pixels ordering selection has to be enabled at compile time CONFIG_FB_CFB_REV_PIXELS_IN_BYTE and for each display configuration which requires it by flag FB_NONSTD_REV_PIX_IN_B in "nonstd" field of info structure. This patch provides way for board specific code to select this option. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23imxfb: fix memory holeSascha Hauer
info->pseudo_palette was previously kmalloced. Do not overwrite it afterwards Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23imxfb: remove ifdefsSascha Hauer
Here are some small fixes for the imxfb framebuffer driver: - remove ifndef for MX1FS2 platform which is not present in the kernel. - REV, CLS, PS and SPL_SPR are only needed with some sharp displays. Only setup the corresponding io pins when such a display is connected. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-07[ARM] 3232/1: i.MX Frame Buffer undeclared "dev" variable fixPavel Pisa
Patch from Pavel Pisa Correction of the code broken by update whole-tree platform devices update. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-29[ARM] Don't include mach-types.h unnecessarilyRussell King
It's pointless to include mach-types.h if you're not going to use anything from it. These references were removed as a result of: grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-17[PATCH] Fix up some pm_message_t typesRichard Purdie
Fix up some pm_message_t types Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-17[PATCH] ARM: 2687/1: i.MX framebuffer: make dmacr register platform configurableSascha Hauer
Patch from Sascha Hauer The dmacr needs different settings on some boards. This patch makes the register configurable by the platform part. Also we have imxfb_disable_controller(), so lets use it. Signed-off-by: Steven Scholz Signed-off-by: Sascha Hauer Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-01[PATCH] imxfb: Add Freescale i.MX framebuffer driverSascha Hauer
This patch adds support for the framebuffer on the freescale i.MX SOC architecture. The driver has been tested on the mx1ads board, the pimx1 board and another custom board with different displays. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
