Pull fbdev updates from Florian Tobias Schandinat:
"This includes:
- large updates for OMAP
- basic OMAP5 DSS support for DPI and DSI outputs
- large cleanups and restructuring
- some update to Exynos and da8xx-fb
- removal of the pnx4008 driver (arch removed)
- various other small patches"
Fix up some trivial conflicts (mostly just include line changes, but
also some due to the renaming of the deferred work functions by Tejun).
* tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits)
gbefb: fix compile error
video: mark nuc900fb_map_video_memory as __devinit
video/mx3fb: set .owner to prevent module unloading while being used
video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare
drivers/video/exynos/exynos_mipi_dsi.c: fix error return code
drivers/video/savage/savagefb_driver.c: fix error return code
video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare
da8xx-fb: save and restore LCDC context across suspend/resume cycle
da8xx-fb: add pm_runtime support
video/udlfb: fix line counting in fb_write
OMAPDSS: add missing include for string.h
OMAPDSS: DISPC: Configure color conversion coefficients for writeback
OMAPDSS: DISPC: Add manager like functions for writeback
OMAPDSS: DISPC: Configure writeback FIFOs
OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup()
OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup
OMAPDSS: DISPC: Add function to set channel in for writeback
OMAPDSS: DISPC: Don't set chroma resampling bit for writeback
OMAPDSS: DISPC: Downscale chroma if plane is writeback
OMAPDSS: DISPC: Configure input and output sizes for writeback
The patch "drivers/video/gbefb.c: use devm_ functions" caused a
compile error.
drivers/video/gbefb.c:1159:16: error: implicit declaration of function
'devm_ioremap' [-Werror=implicit-function-declaration]
drivers/video/gbefb.c:1179:3: error: implicit declaration of function
'devm_ioremap_nocache' [-Werror=implicit-function-declaration]
Fix it by including linux/io.h which defines those functions.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Damien Cassou <damien.cassou@lifl.fr>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The various devm_ functions allocate memory that is released when a driver
detaches. This patch uses these functions for data that is allocated in
the probe function of a platform device and is only freed in the remove
function.
Signed-off-by: Damien Cassou <damien.cassou@lifl.fr>
This code is preceded by a call to framebuffer_alloc, which allocates
memory, so this memory should be freed before leaving the function in an
error case. out_release_framebuffer just frees the frame buffer and
returns.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = framebuffer_alloc(...);
<... when != x
when != true (x == NULL || ...)
when != if (...) { <+...x...+> }
when != I (...) { <+...x...+> }
x == NULL
x == E
x->f1
* return ...;
// </smpl>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
WARNING: drivers/video/built-in.o(.devinit.text+0x54): Section mismatch in reference from the function gbefb_probe() to the function .init.text:gbefb_setup()
The function __devinit gbefb_probe() references
a function __init gbefb_setup().
If gbefb_setup is only used by gbefb_probe then
annotate gbefb_setup with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x208): Section mismatch in reference from the function gbefb_probe() to the variable .init.data:mode_option
a variable __initdata mode_option.
If mode_option is only used by gbefb_probe then
annotate mode_option with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x214): Section mismatch in reference from the function gbefb_probe() to the variable .init.data:default_mode
a variable __initdata default_mode.
If default_mode is only used by gbefb_probe then
annotate default_mode with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x23c): Section mismatch in reference from the function gbefb_probe() to the variable .init.data:default_var
a variable __initdata default_var.
If default_var is only used by gbefb_probe then
annotate default_var with a matching annotation.
Fixing these results in more mismatches:
WARNING: drivers/video/built-in.o(.devinit.text+0x3c): Section mismatch in reference from the function gbefb_setup() to the variable .init.data:default_var_LCD
The function __devinit gbefb_setup() references
a variable __initdata default_var_LCD.
If default_var_LCD is only used by gbefb_setup then
annotate default_var_LCD with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x14c): Section mismatch in reference from the function gbefb_setup() to the variable .init.data:default_mode_LCD
a variable __initdata default_mode_LCD.
If default_mode_LCD is only used by gbefb_setup then
annotate default_mode_LCD with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x150): Section mismatch in reference from the function gbefb_setup() to the variable .init.data:default_var_CRT
a variable __initdata default_var_CRT.
If default_var_CRT is only used by gbefb_setup then
annotate default_var_CRT with a matching annotation.
WARNING: drivers/video/built-in.o(.devinit.text+0x154): Section mismatch in reference from the function gbefb_setup() to the variable .init.data:default_mode_CRT
a variable __initdata default_mode_CRT.
If default_mode_CRT is only used by gbefb_setup then
annotate default_mode_CRT with a matching annotation.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
A pointer to a probe callback is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Adrian Bunk <bunk@stusta.de>
Cc: Alberto Mardegan <mardy@users.sourceforge.net>
Cc: Andriy Skulysh <askulysh@gmail.com>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Chandramouli Narayanan <mouli@linux.intel.com>
Cc: Frans Pop <elendil@planet.nl>
Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Helge Deller <deller@gmx.de>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Ian Molton <spyro@f2s.com>
Cc: Joshua Kinard <kumba@gentoo.org>
Cc: Kaj-Michael Lang <milang@tal.org>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: linux-fbdev-devel@lists.sourceforge.net
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Magnus Damm <damm@igel.co.jp>
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Matthias Kaehlcke <matthias@kaehlcke.net>
Cc: Pavel Machek <pavel@suse.cz>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Vincent Sanders <vince@simtec.co.uk>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Acked-by: James Simmons <jsimmons@infradead.org>
Acked-by: Peter Jones <pjones@redhat.com>
Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
kernel/irq/chip.c
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
request_region should be used with release_region, not request_mem_region.
Geert Uytterhoeven pointed out that in the case of drivers/video/gbefb.c,
the problem is actually the other way around; request_mem_region should be
used instead of request_region.
The semantic patch that finds/fixes this problem is as follows:
// <smpl>
@r1@
expression start;
request_region(start,...)
@b1@
expression r1.start;
request_mem_region(start,...)
@depends on !b1@
expression E;
- release_mem_region
+ release_region
(start,E)
// </smpl>
The following symbols are needlessly defined global:
default_mode
default_var
gbe_mem_phys
gbe_turn_off
gbefb_exit
gbefb_init
gbefb_setup
This error was noticed by namespacecheck when compiling ip32_defconfig.
This patch makes the symbols static.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
unsigned var->pixclock cannot be less than 0
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Writes to the cmap fifo while the display is blanked caused cmap FIFO
timeout messages and a wrong colormap. To avoid this the driver now
maintains a colormap in memory and updates the colormap after the display
is unblanked.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Make 'default_mode' and 'default_var' be __initdata.
Fixes these section warnings:
WARNING: vmlinux.o(.data+0x128e0): Section mismatch: reference to .init.data:default_mode_CRT (between 'default_mode' and 'default_var')
WARNING: vmlinux.o(.data+0x128e4): Section mismatch: reference to .init.data:default_var_CRT (between 'default_var' and 'dev_attr_size')
The pseudo_palette is only 16 elements long.
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The gbefb driver does not update the framebuffer layers visual setting when
depth is changed with fbset, resulting in strange colors (very dark blue in
16-bit, almost black in 24-bit).
Signed-off-by: Kaj-Michael Lang <milang@tal.org>
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
Cc: <stable@kernel.org>
A sysfs function call uses the wrong parameter, and thus breaks a build on
SGI O2.
CC drivers/video/gbefb.o
drivers/video/gbefb.c: In function ‘gbefb_remove’:
drivers/video/gbefb.c:1246: error: ‘dev’ undeclared (first use in this function)
drivers/video/gbefb.c:1246: error: (Each undeclared identifier is reported only once
drivers/video/gbefb.c:1246: error: for each function it appears in.)
make[2]: *** [drivers/video/gbefb.o] Error 1
Signed-off-by: Joshua Kinard <kumba@gentoo.org>
No need for a file argument. If we'd really need it it's in vma->vm_file
already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but
the kernel alrady did that.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for
drivers that do not support hardware cursors is redundant. The soft_cursor
function is usable by all drivers because it is just a wrapper around
fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is
moved to the console directory.
Thus, drivers that do not support hardware cursors can leave the fb_cursor
field blank. For drivers that do, they can fill up this field with their own
version.
The end result is a smaller code size. And if the framebuffer console is not
loaded, module/kernel size is also reduced because the soft_cursor module will
also not be loaded.
Statically allocated devices in module data is a potential cause
of oopsen. The device may be in use by a userspace process, which
will keep a reference to the device. If the module is unloaded,
the module data will be freed. Subsequent use of the platform
device will cause a kernel oops.
Use generic platform device allocation/release code in modules.
Manual #include fixups for clashes - there may be some unnecessary
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
drivers/zorro/zorro-sysfs.c: update device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
infrastructure for it.
Let it rip!
