path: root/drivers/video/fbsysfs.c
2006-12-01Driver core: convert fb code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-03[PATCH] fbdev: Honor the return value of device_create_fileAntonino A. Daplas
Check the return value of device_create_file(). If return is 'fail', remove attributes by calling device_remove_file(). Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[PATCH] backlight: fix oops in __mutex_lock_slowpath during head ↵Michael Hanselmann
/sys/class/graphics/fb0/* Seems like not all drivers use the framebuffer_alloc() function and won't have an initialized mutex. But those don't have a backlight, anyway. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Olaf Hering <olaf@aepfle.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Daniel R Thompson <daniel.thompson@st.com> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Detaching fbcon: sdd sysfs class device entry for fbconAntonino A. Daplas
In order for this feature to work, an interface will be needed. The most appropriate is sysfs. However, the framebuffer console has no sysfs entry yet. This will create a sysfs class device entry for fbcon under /sys/class/graphics. Add a class_device entry 'fbcon' under class 'graphics'. Console-specific attributes which where previously under class/graphics/fb[x] are moved to class/graphics/fbcon. These attributes, 'con_rotate' and 'con_rotate_all', are also renamed to 'rotate' and 'rotate_all' respectively. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: tag by scantype in sysfsDaniel R Thompson
Modify the sysfs description of a video mode such that modes are tagged with their scan type, (p)rogessive, (i)nterlaced, (d)ouble scan. For example, U:1920x1080i-50. This is useful to disambiguate some of the 'consumer' video timings found in CEA-861 (especially those for EDTV). Signed-off-by: Daniel R Thompson <daniel.thompson@st.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Rewritten backlight infrastructure for portable Apple computersMichael Hanselmann
This patch contains a total rewrite of the backlight infrastructure for portable Apple computers. Backward compatibility is retained. A sysfs interface allows userland to control the brightness with more steps than before. Userland is allowed to upload a brightness curve for different monitors, similar to Mac OS X. [akpm@osdl.org: add needed exports] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-27[PATCH] Frame buffer: remove cmap sysfs interfaceJon Smirl
Remove it as it does not work properly due to sysfs core changes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] framebuffer: cmap-setting return valuesAlan Curry
A set of 3 small bugfixes, all of which are related to bogus return values of fb colormap-setting functions. First, fb_alloc_cmap returns -1 if memory allocation fails. This is a hard condition to reproduce since you'd have to be really low on memory, but from studying the contexts in which it is called, I think this function should be returning a negative errno, and the -1 will be seen as an EPERM. Switching it to -ENOMEM makes sense. Second, the store_cmap function which is called for writes to /sys/class/graphics/fb0/color_map returns 0 for success, but it should be returning the count of bytes written since its return value ends up in userspace as the result of the write() syscall. Third, radeonfb returns 1 instead of a negative errno when FBIOPUTCMAP is called with an oversized colormap. This is seen in userspace as a return value of 1 from the ioctl() syscall with errno left unchanged. A more useful return value would be -EINVAL. Signed-off-by: Alan Curry <pacman@TheWorld.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: Replace kmalloc with kzallocAntonino A. Daplas
Replace kmalloc with kzalloc Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: fbdev: CleanupAntonino A. Daplas
- remove unneeded casts Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Add sysfs entry to disable framebuffer accessMatthew Garrett
What
2005-11-09[PATCH] fbcon: Console Rotation - Add ability to control rotation via sysfsAntonino A. Daplas
Add ability to set rotation via sysfs. The attributes are located in /sys/class/graphics/fb[n] and accepts 0 - unrotated; 1 - clockwise; 2 - upside down; 3 - counterclockwise. The attributes are: con_rotate (r/w) - set rotation of the active console con_rotate_all (w) - set rotation of all consoles rotate (r/w) - set rotation of the framebuffer, if supported. Currently, none of the drivers support this. This is probably temporary, since con_rotate and con_rotate_all are console-specific and has no business being under the fb device. However, until the console layer acquires it's own sysfs class, these attributes will temporarily reside here. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[PATCH] Return the line length via sysfs for fbdevJames Simmons
This small patch returns the stride/line length of the framebuffer via sysfs. Signed-off-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-31[PATCH] Display name of fbdev deviceJames Simmons
This patch displays the name of the fbdev driver in sysfs. Down the road this will replace the current proc handle we have. Signed-off-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] fbdev: colormap fixes fixJon Smirl
Fix a buffer overflow vunerabilty in previous cmap patch Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] fbdev: colormap fixesJon Smirl
Color maps have up to 256 entries. 4096/256 allows for 16 characters per line. The format for a cmap entry is "%02x%c%4x%4x%4x\n" %02x entry %c transp %4x red %4x blue %4x green You can read the color_map with cat fb0/color_map. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] coverity: fix fbsysfs null pointer checkKAMBAROV, ZAUR
Correctly test for a null pointer before going and dereferencing it. This defect was found automatically by Coverity Prevent, a static analysis tool. Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fbdev: remove unneeded fbsysfs printkJon Smirl
Remove unneeded fbsysfs printk. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-13[PATCH] Typo in fbdev sysfs support, virtual_sizeJon Smirl
It prints out x,x instead of x,y. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Cc: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
