path: root/drivers/video/exynos/Makefile
2012-02-13video: support DP controller driverJingoo Han
Samsung EXYNOS SoC such Exynos5 has DP controller and embedded DP panel can be used. This patch supports DP driver based on Samsung EXYNOS SoC chip. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-02-13video: backlight: support s6e8ax0 panel driver based on MIPI DSIDonghwa Lee
An moled panel driver based MIPI DSI interface. S6E8AX0 means it may includes many other ldi controllers, for example, S6E8AA0, S6E8AB0, and so on. This patch can be modified depending on each panel properites. For example, second parameter of panel condition register can be changed depending on ldi controller or amoled type. [akpm@linux-foundation.org: fix Kconfig syntax error] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-02-13video: support MIPI-DSI controller driverDonghwa Lee
Samsung S5PC210 and EXYNOS SoC platform has MIPI-DSI controller and MIPI-DSI based LCD Panel could be used with it. This patch supports MIPI-DSI driver based Samsung SoC chip. LCD panel driver based MIPI-DSI should be registered to MIPI-DSI driver at machine code and LCD panel driver specific function registered to mipi_dsim_ddi structure at lcd panel init function called system init. In the MIPI-DSI driver, find lcd panel driver by using registered lcd panel name, and then initialize lcd panel driver. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
