path: root/drivers/video/console
2012-06-16Merge tag 'fbdev-fixes-for-3.5-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: - two fixes for s3c-fb by Jingoo Han (including a fix for a potential division by zero) - a couple of randconfig fixes by Arnd Bergmann - a cleanup for bfin_adv7393fb by Emil Goode * tag 'fbdev-fixes-for-3.5-1' of git://github.com/schandinat/linux-2.6: video: s3c-fb: fix possible division by zero in s3c_fb_calc_pixclk video: s3c-fb: clear SHADOWCON register when clearing hardware window registers drivers/tosa: driver needs I2C and SPI to compile drivers/savagefb: use mdelay instead of udelay video/console: automatically select a font video/ili9320: do not mark exported functions __devexit drivers/video: use correct __devexit_p annotation video: bfin_adv7393fb: Convert to kstrtouint_from_user
2012-06-09video/console: automatically select a fontArnd Bergmann
The frame buffer console needs at least one font to be built into the kernel, so add the necessary Kconfig magic to guarantee that one of the available font is always on. If a user accidentally disables all fonts manually, the 8x16 font will be selected anyway. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-05-10parisc: move definition of PAGE0 to asm/page.hRolf Eike Beer
This was defined in asm/pdc.h which needs to include asm/page.h for __PAGE_OFFSET. This leads to an include loop so that page.h eventually will include pdc.h again. While this is no problem because of header guards, it is a problem because some symbols may be undefined. Such an error is this: In file included from include/linux/bitops.h:35:0, from include/asm-generic/getorder.h:7, from arch/parisc/include/asm/page.h:162, from arch/parisc/include/asm/pdc.h:346, from arch/parisc/include/asm/processor.h:16, from arch/parisc/include/asm/spinlock.h:6, from arch/parisc/include/asm/atomic.h:20, from include/linux/atomic.h:4, from include/linux/sysfs.h:20, from include/linux/kobject.h:21, from include/linux/device.h:17, from include/linux/eisa.h:5, from arch/parisc/kernel/pci.c:11: arch/parisc/include/asm/bitops.h: In function ‘set_bit’: arch/parisc/include/asm/bitops.h:82:2: error: implicit declaration of function ‘_atomic_spin_lock_irqsave’ [-Werror=implicit-function-declaration] arch/parisc/include/asm/bitops.h:84:2: error: implicit declaration of function ‘_atomic_spin_unlock_irqrestore’ [-Werror=implicit-function-declaration] Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-01-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (119 commits) MIPS: Delete unused function add_temporary_entry. MIPS: Set default pci cache line size. MIPS: Flush huge TLB MIPS: Octeon: Remove SYS_SUPPORTS_HIGHMEM. MIPS: Octeon: Add support for OCTEON II PCIe MIPS: Octeon: Update PCI Latency timer and enable more error reporting. MIPS: Alchemy: Update cpu-feature-overrides MIPS: Alchemy: db1200: Improve PB1200 detection. MIPS: Alchemy: merge Au1000 and Au1300-style IRQ controller code. MIPS: Alchemy: chain IRQ controllers to MIPS IRQ controller MIPS: Alchemy: irq: register pm at irq init time MIPS: Alchemy: Touchscreen support on DB1100 MIPS: Alchemy: Hook up IrDA on DB1000/DB1100 net/irda: convert au1k_ir to platform driver. MIPS: Alchemy: remove unused board headers MTD: nand: make au1550nd.c a platform_driver MIPS: Netlogic: Mark Netlogic chips as SMT capable MIPS: Netlogic: Add support for XLP 3XX cores MIPS: Netlogic: Merge some of XLR/XLP wakup code MIPS: Netlogic: Add default XLP config. ... Fix up trivial conflicts in arch/mips/kernel/{perf_event_mipsxx.c, traps.c} and drivers/tty/serial/Makefile
2011-12-07MIPS: GIO bus support for SGI IP22/28Thomas Bogendoerfer
SGI IP22/IP28 machines have GIO busses for adding graphics and other extension cards. This patch adds support for GIO driver/device handling and converts the newport console driver to a GIO driver. [ralf@linux-mips.org: Fixed build error caused by the modules.h -> export.h changes.] Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> To: linux-fbdev@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2886/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-10-31Kconfig: remove a few puzzling commentsPaul Bolle
These comments mention CONFIG options that do not exist: not as a symbol in a Kconfig file (without the CONFIG_ prefix) and neither as a symbol (with that prefix) in the code. There's one reference to XSCALE_PMU_TIMER as a negative dependency. But XSCALE_PMU_TIMER is never defined (CONFIG_XSCALE_PMU_TIMER is also unused in the code). It shows up with type "unknown" if you search for it in menuconfig. Apparently a negative dependency on an unknown symbol is always true. That negative dependency can be removed too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-13locking, video: Annotate vga console lock as rawThomas Gleixner
The vga_lock lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-07Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: efifb: Add override for 11" Macbook Air 3,1 efifb: Support overriding fields FW tells us with the DMI data. fb: Reduce priority of resource conflict message savagefb: Remove obsolete else clause in savage_setup_i2c_bus savagefb: Set up I2C based on chip family instead of card id savagefb: Replace magic register address with define drivers/video/bfin-lq035q1-fb.c: introduce missing kfree video: s3c-fb: fix checkpatch errors and warning efifb: support AMD Radeon HD 6490 s3fb: fix Virge/GX2 fbcon: Remove unused 'display *p' variable from fb_flashcursor() fbdev: sh_mobile_lcdcfb: fix module lock acquisition fbdev: sh_mobile_lcdcfb: add blanking support viafb: initialize margins correct viafb: refresh rate bug collection sh: mach-ap325rxa: move backlight control code sh: mach-ecovec24: support for main lcd backlight
2011-04-06update David Miller's old email addressJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-31fbcon: Remove unused 'display *p' variable from fb_flashcursor()Sergey Senozhatsky
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22fbcon: fix situation where fbcon gets deinitialised and can't reinit.Dave Airlie
Situation as follow: 2 GPUs + vesafb + kms. GPU 1 is primary, vesafb binds to it as fb0 radeon loads GPU 0 loads as fb1 GPU 1 loads, vesafb gets kicked off which causes fb0 to unbind console, which causes the dummy console to rebind. this means fbcon_deinit gets called, which calls fbcon_exit since the console isn't bound anymore and we set fbcon_has_exited. GPU 1 creates a new fb0 which is primary and we want to be console. fbcon_fb_registered gets called sets the primary up and calls set_con2fb_map, however as fbcon_has_exited is set nothing further ever happens. This patch bypasses the fbcon_has_exited and checks if the console is unbound, if its unbound it calls the fbcon_takeover which calls the vt layer to call the fbcon_startup method and everthing works. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22fbcon: Bugfix soft cursor detection in Tile BlittingHenry Nestler
Use mask 0x10 for "soft cursor" detection on in function tile_cursor. (Tile Blitting Operation in framebuffer console). The old mask 0x01 for vc_cursor_type detects CUR_NONE, CUR_LOWER_THIRD and every second mode value as "software cursor". This hides the cursor for these modes (cursor.mode = 0). But, only CUR_NONE or "software cursor" should hide the cursor. See also 0x10 in functions add_softcursor, bit_cursor and cw_cursor. Signed-off-by: Henry Nestler <henry.nestler@gmail.com> Cc: stable@kernel.org Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: mailmap: Add an entry for Axel Lin. video: fix some comments in drivers/video/console/vgacon.c drivers/video/bf537-lq035.c: Add missing IS_ERR test video: pxa168fb: remove a redundant pxa168fb_check_var call video: da8xx-fb: fix fb_probe error path video: pxa3xx-gcu: Return -EFAULT when copy_from_user() fails video: nuc900fb: properly free resources in nuc900fb_remove video: nuc900fb: fix compile error
2011-01-25video: fix some comments in drivers/video/console/vgacon.cAmerigo Wang
Now vgacon_scrollback_startup() uses slab, not bootmem, the comment above it is obsolete, so does __init_refok. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13vgacon: check for efi machineYannick Heneault
It seems there is a small problem of VGA palette corruption on EFI machine. When the kernel initializes the architecture, it checks if the machine is a EFI machine and assumes that a VGA console can exist. When it initializes the console in vgacon_startup it checks if it can really use the VGA console. I think this is where a check is missing. Currently, the function can fail if a VESA boot mode is detected but not if a EFI boot mode was used. Thus vgacon_startup() doesn't fail and initialize the video card for a real VGA mode. This function changes the first 16entries of the VGA palette. When the efifb driver kicks in, the palette is not restored to default ramp value, thus the 16 first entry remain in a modified state. The following patch prevent this corruption. Signed-off-by: Yannick Heneault <yheneaul@matrox.com> Cc: Dave Airlie <airlied@linux.ie> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22fbcon: fix lockdep warning from fbcon_deinit()Jarek Poplawski
Fix the lockdep warning: [ 13.657164] INFO: trying to register non-static key. [ 13.657169] the code is fine but needs lockdep annotation. [ 13.657171] turning off the locking correctness validator. [ 13.657177] Pid: 622, comm: modprobe Not tainted 2.6.36-rc3c #8 [ 13.657180] Call Trace: [ 13.657194] [<c13002c8>] ? printk+0x18/0x20 [ 13.657202] [<c1056cf6>] register_lock_class+0x336/0x350 [ 13.657208] [<c1058bf9>] __lock_acquire+0x449/0x1180 [ 13.657215] [<c1059997>] lock_acquire+0x67/0x80 [ 13.657222] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230 [ 13.657227] [<c1042c23>] __cancel_work_timer+0x83/0x230 [ 13.657231] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230 [ 13.657236] [<c10582b2>] ? mark_held_locks+0x62/0x80 [ 13.657243] [<c10b3a2f>] ? kfree+0x7f/0xe0 [ 13.657248] [<c105853c>] ? trace_hardirqs_on_caller+0x11c/0x160 [ 13.657253] [<c105858b>] ? trace_hardirqs_on+0xb/0x10 [ 13.657259] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0 [ 13.657263] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0 [ 13.657268] [<c1042dea>] cancel_work_sync+0xa/0x10 [ 13.657272] [<c117f444>] fbcon_deinit+0xe4/0x1e0 ... The warning is caused by trying to cancel an uninitialized work from fbcon_exit(). Fix it by adding a check for queue.func, similarly to other places in this code. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11fbcon: uninline four foo_update_attr() functionsDenys Vlasenko
This patch uninlines four similar functions, foo_update_attr(), in four fbcon-related files. These functions contain loops, two of theam have _nested_ loops, and they have more than one callsite each. I think they should not be inlined. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11fbcon: uninline large static function get_color()Denys Vlasenko
This function's body is good two screenfuls and it has six callsites. No apparent reason why it is marked inline. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10tty: fix console_sem lock orderArnd Bergmann
vgacon_do_font_op releases and reacquires the BTM while holding console_sem. This violates the rule that BTM has to be the outer lock whenever we hold both. There does not seem to be any reason to give up the BTM here, so just stop doing that. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: replace BKL with a new tty_lockArnd Bergmann
As a preparation for replacing the big kernel lock in the TTY layer, wrap all the callers in new macros tty_lock, tty_lock_nested and tty_unlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10vt/console: try harder to print output when panicingJesse Barnes
Jesse's initial patch commit said: "At panic time (i.e. when oops_in_progress is set) we should try a bit harder to update the screen and make sure output gets to the VT, since some drivers are capable of flipping back to it. So make sure we try to unblank and update the display if called from a panic context." I've enhanced this to add a flag to the vc that console layer can set to indicate they want this behaviour to occur. This also adds support to fbcon for that flag and adds an fb flag for drivers to indicate they want to use the support. It enables this for KMS drivers. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (143 commits) omap: mailbox: reorganize headers omap: mailbox: standarize on 'omap-mailbox' omap: mailbox: only compile for configured archs omap: mailbox: simplify omap_mbox_register() omap: mailbox: reorganize registering omap: mailbox: add IRQ names omap: mailbox: remove unecessary fields omap: mailbox: don't export unecessary symbols omap: mailbox: update omap1 probing omap: mailbox: use correct config for omap1 omap: mailbox: 2420 should be detected at run-time omap: mailbox: reorganize structures omap: mailbox: trivial cleanups omap mailbox: Set a device in logical mbox instance for traceability omap: mailbox: convert block api to kfifo omap: mailbox: remove (un)likely macros from cold paths omap: mailbox cleanup: split MODULE_AUTHOR line omap: mailbox: convert rwlocks to spinlock Mailbox: disable mailbox interrupt when request queue Mailbox: new mutext lock for h/w mailbox configuration ...
2010-08-05fb: add hooks to handle KDB enter/exitJesse Barnes
Add fb ops to handle enter/exit of the kernel debugger. If present, the fb core will register them with KGDB and they'll be called when the debugger is entered and exited. The new functions are responsible for switching to an appropriate debug framebuffer and restoring the interrupted state at exit time. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-07-05ARM: Disable VGA console for ARM in most casesTony Lindgren
Otherwise we have to disable it manually to avoid compile errors. Now it's only enabled only for the selected machines as suggested by Anton Vorontsov <cbouatmailru@gmail.com>: $ git grep VGA_CONSOLE= arch/arm/configs/ arch/arm/configs/footbridge_defconfig:CONFIG_VGA_CONSOLE=y arch/arm/configs/integrator_defconfig:CONFIG_VGA_CONSOLE=y arch/arm/configs/netwinder_defconfig:CONFIG_VGA_CONSOLE=y Note that the Kconfig entry no longer needs separate entries for ARCH_ACORN, ARCH_EBSA110 ARCH_VERSATILE. Cc: linux-fbdev@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06console/vgacon.c: mark file-local symbol staticThiago Farina
warning: symbol 'vgacon_text_mode_force' was not declared. Should it be static? Signed-off-by: Thiago Farina <tfransosi@gmail.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06console: limit the range of VGACON_SOFT_SCROLLBACK_SIZEAmerigo Wang
BuraphaLinux reported that we will trigger a mm warning when we CONFIG_VGACON_SOFT_SCROLLBACK_SIZE=65536, this is because mm cann't allocate so many pages. We should limit the range of CONFIG_VGACON_SOFT_SCROLLBACK_SIZE, don't give a user any chance to trigger that. Reported-by: BuraphaLinux Server <buraphalinuxserver@gmail.com> Tested-by: BuraphaLinux Server <buraphalinuxserver@gmail.com> Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-01vga_switcheroo: initial implementation (v15)Dave Airlie
Many new laptops now come with 2 gpus, one to be used for low power modes and one for gaming/on-ac applications. These GPUs are typically wired to the laptop panel and VGA ports via a multiplexer unit which is controlled via ACPI methods. 4 combinations of systems typically exist - with 2 ACPI methods. Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method ATI/ATI - some ASUS - use ATPX ACPI Method Intel/Nvidia - - use _DSM ACPI method Nvidia/Nvidia - - use _DSM ACPI method. TODO: This patch adds support for the ATPX method and initial bits for the _DSM methods that need to written by someone with access to the hardware. Add a proper non-debugfs interface - need to get some proper testing first. v2: add power up/down support for both devices on W500 puts i915/radeon into D3 and cuts power to radeon. v3: redo probing methods, no DMI list, drm devices call to register with switcheroo, it tries to find an ATPX method on any device and once there is two devices + ATPX it inits the switcher. v4: ATPX msg handling using buffers - should work on more machines v5: rearchitect after more mjg59 discussion - move ATPX handling to radeon driver. v6: add file headers + initial nouveau bits (to be filled out). v7: merge delayed switcher code. v8: avoid suspend/resume of gpu that is off v9: rearchitect - mjg59 is always right. - move all ATPX code to radeon, should allow simpler DSM also proper ATRM handling v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv v11: fix bug in resuming Intel for 2nd time. v12: start fixing up nvidia code blindly. v13: blindly guess at finishing nvidia code v14: remove radeon audio hacks - fix up intel resume more like upstream v15: clean up printks + remove unnecessary igd/dis pointers mount debugfs /sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected + 2 cards. DIS - immediate change to discrete IGD - immediate change to IGD DDIS - delayed change to discrete DIGD - delayed change to IGD ON - turn on not in use OFF - turn off not in use Tested on W500 (Intel/ATI) and T500 (Intel/ATI) Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-13vgacon: Add support for setting the default cursor stateMatthew Garrett
Pass the vga cursor state to the vt layer, ensuring that we don't hide the cursor when the bootloader has deliberately disabled it. Signed-off-by: Matthew Garrett <mjg@redhat.com> LKML-Reference: <1258142222-16092-3-git-send-email-mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-13vc: Add support for hiding the cursor when creating VTsMatthew Garrett
Add support for setting a global default for whether or not a visible cursor should be enabled when creating VCs. The default will be to do so, unless overridden by the user at boot time or by a driver. Signed-off-by: Matthew Garrett <mjg@redhat.com> LKML-Reference: <1258143251-5818-1-git-send-email-mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-12fb: remove fb_save_state() and fb_restore_state operationsKrzysztof Helt
Remove fb_save_state() and fb_restore_state operations from frame buffer layer. They are used only in two drivers: 1. savagefb - and cause bug #11248 2. uvesafb Usage of these operations is misunderstood in both drivers so kill these operations, fix the bug #11248 and avoid confusion in the future. Tested on Savage 3D/MV card and the patch fixes the bug #11248. The frame buffer layer uses these funtions during switch between graphics and text mode of the console, but these drivers saves state before switching of the frame buffer (in the fb_open) and after releasing it (in the fb_release). This defeats the purpose of these operations. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reported-by: Jochen Hein <jochen@jochen.org> Tested-by: Jochen Hein <jochen@jochen.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23vgacon: prevent vgacon_deinit from touching the hardware for inactive consoles.Francisco Jerez
fbcon makes the (reasonable) assumption that it only needs to program the hardware once, when fbcon_init() is called for the foreground console. This doesn't always play well with vgacon because vgacon_deinit() is only doing its job when the last console it owns is closed (when switching from vgacon to fbcon, that's usually *after* fbcon_init() has set the new mode). Depending on the hardware this can cause the wrong framebuffer location to be scanned out (e.g. reproduced on nv05 with the nouveau framebuffer driver). Signed-off-by: Francisco Jerez <currojerez@riseup.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23fbcon: only unbind from console if successfully registeredIan Armstrong
Attempting to unload a framebuffer module calls unregister_framebuffer() which in turn gets fbcon to release it. If fbcon has no framebuffers linked to a console, it will also unbind itself from the console driver. However, if fbcon never registered itself as a console driver, the unbind will fail causing the framebuffer device entry to persist. In most cases this failure will result in an oops when attempting to access the now non-existent device. This patch ensures that the fbcon unbind request will succeed even if a bind was never done. It tracks if a successful bind ever occurred & will only attempt to unbind if needed. If there never was a bind, it simply returns with no error. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23fb: do not ignore fb_set_par errorsFlorian Tobias Schandinat
At the moment about half of the framebuffer drivers can return an error code in fb_set_par. Until now it would be silently ignored by fbmem.c and fbcon.c. This patch fixes fbmem.c to return the error code and restore var on error. But it is not clear in which video mode the device is when fb_set_par fails. It would be good and reasonable if it were in the old state but there is no guarantee that this is true for all existing drivers. Additionally print a message if a failing fb_set_par is detected in fbmem.c or fbcon.c. Although most errors should be caught by the previous fb_check_var some errors can't as they are dynamic (memory allocations, ...) and can only be detected while performing the operations which is forbidden in fb_check_var. This patch shouldn't have a negative impact on normal operation as all drivers return 0 on success. The impact in case of error depends heavily on the driver and caller but it's expected to be better than before. Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23video: console, use DIV_ROUND_UPJiri Slaby
Use DIV_ROUND_UP explicitly instead of manual shifts and adds. It makes the code more readable and consistent (sometimes there were shifts, sometimes divs). There is no change on the assembly level (compilers should do the right job). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23drivers/video/console/newport_con.c: fix read outside array boundsRoel Kluin
It reads linetable[] before checking bounds of index, and ARRAY_SIZE is required because linetable[] are unsigned shorts. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-20includecheck fix: drivers/video, vgacon.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/video/console/vgacon.c: linux/slab.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Martin Mares <mj@ucw.cz> Cc: mchehab@infradead.org Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <1247067624.4382.88.camel@ht.satnam>
2009-09-15sparc: Kill PROM console driver.David S. Miller
Many years ago when this driver was written, it had a use, but these days it's nothing but trouble and distributions should not enable it in any situation. Pretty much every console device a sparc machine could see has a bonafide real driver, making the PROM console hack unnecessary. If any new device shows up, we should write a driver instead of depending upon this crutch to save us. We've been able to take care of this even when no chip documentation exists (sunxvr500, sunxvr2500) so there are no excuses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-07fbcon: don't use vc_resize() on initializationJohannes Weiner
Catalin and kmemleak spotted a leak of a VC screen buffer in vc_allocate() due to the following chain of events: vc_allocate() visual_init(init=1) vc->vc_sw->con_init(init=1) fbcon_init() vc_resize() vc->screen_buf = kmalloc() vc->screen_buf = kmalloc() The common way for the VC drivers is to set the screen dimension parameters manually in the init case and only call vc_resize() for !init - which allocates a screen buffer according to the new dimensions. fbcon instead would do vc_resize() unconditionally and afterwards set the dimensions manually (again) for !init - i.e. completely upside down. The vc_resize() allocated buffer would then get lost by vc_allocate() allocating a fresh one. Use vc_resize() only for actual resizing to close the leak. Set the dimensions manually only in initialization mode to remove the redundant setting in resize mode. The kmemleak trace from Catalin: unreferenced object 0xde158000 (size 12288): comm "Xorg", pid 1439, jiffies 4294961016 hex dump (first 32 bytes): 20 00 20 00 20 00 20 00 20 00 20 00 20 00 20 00 . . . . . . . . 20 00 20 00 20 00 20 00 20 00 20 00 20 00 20 00 . . . . . . . . backtrace: [<c006f74b>] __save_stack_trace+0x17/0x1c [<c006f81d>] create_object+0xcd/0x188 [<c01f5457>] kmemleak_alloc+0x1b/0x3c [<c006e303>] __kmalloc+0xdb/0xe8 [<c012cc4b>] vc_do_resize+0x73/0x1e0 [<c012cdf1>] vc_resize+0x15/0x18 [<c011afc1>] fbcon_init+0x1f9/0x2b8 [<c0129e87>] visual_init+0x9f/0xdc [<c012aff3>] vc_allocate+0x7f/0xfc [<c012b087>] con_open+0x17/0x80 [<c0120e43>] tty_open+0x1f7/0x2e4 [<c0072fa1>] chrdev_open+0x101/0x118 [<c006ffad>] __dentry_open+0x105/0x1cc [<c00700fd>] nameidata_to_filp+0x2d/0x38 [<c00788cd>] do_filp_open+0x2c1/0x54c [<c006fdff>] do_sys_open+0x3b/0xb4 Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Tested-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07fbcon: fix rotate upside down crashStefani Seibold
Fix the rotate_ud() function not to crash in case of a font which has not a width of multiple by 8: The inner loop of the font pixel copy should not access a bit outside the font memory area. Subtract the shift offset from the font width will prevent this. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
