path: root/drivers/video/backlight/lm3630_bl.c
2013-11-13backlight: lm3630: apply chip revisionDaniel Jeong
The LM3630 chip was revised by TI and chip name was also changed to LM3630A. And register map, default values and initial sequences are changed. The files, lm3630_bl.{c,h} are replaced by lm3630a_bl.{c,h} You can find more information about LM3630A(datasheet, evm etc) at http://www.ti.com/product/lm3630a Signed-off-by: Daniel Jeong <gshark.jeong@gmail.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/video/backlight/lm3630_bl.c: remove ret = -EIO of ↵Jingoo Han
lm3630_backlight_register() There is no need to return -EIO, because backlight_device_register() already returns correct error values. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Jeong <daniel.jeong@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17backlight: lm3630: fix checkpatch warningJingoo Han
This patch fixes the checkpatch warning as below: WARNING: static const char * array should probably be static const char * const Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-28backlight: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28backlight: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28backlight: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-06backlight: add Backlight driver for lm3630 chipG.Shark Jeong
This driver is a general version for LM3630 backlgiht driver chip of TI. LM3630 : The LM3630 is a current mode boost converter which supplies the power and controls the current in two strings of up to 10 LEDs per string. Programming is done over an I2C compatible interface. www.ti.com [akpm@linux-foundation.org: make bled_name[] static, a few coding style tuneups, create new set_intensity(), partly to avoid awkward layout gymnastics] Signed-off-by: G.Shark Jeong <gshark.jeong@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Daniel Jeong <daniel.jeong@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
