The atmel-pwm-bl driver is now obsolete. It is not used by any mainlined boards
and is replaced by the generic pwm_bl with the pawm-atmel driver using the
generic PWM framework.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Use devm_gpio_request_one rather than requesting and setting direction
in two calls.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Add helper function to control the gpio_on signal.
Use gpio_is_valid rather than open coding the more restrictive != -1
test.
Remove unused include of clk.h.
Clean up get_intensity to increase readability.
Clean up probe error handling by checking parameters before any
allocations and removing an obsolete error label. Also remove unnecessary
reset of private gpio number.
Add missing module alias which is needed for module autoloading.
Make sure to honour gpio polarity also at remove so that the backlight is
actually disabled on boards with active-low enable pin.
Cc: <stable@vger.kernel.org>
The driver supports 16-bit brightness values, but the value returned
from get_brightness was truncated to eight bits.
Use devm_backlight_device_register() to make cleanup paths simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change to
make the code simpler and enhance the readability.
Move probe out of __init section and don't use platform_driver_probe
which cannot be used with deferred probing.
Since commit e9354576 ("gpiolib: Defer failed gpio requests by default")
this driver might return -EPROBE_DEFER if a gpio_request fails.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
The driver core clears the driver data to NULL after device_release or
on probe failure, since commit 0998d06310 ("device-core: Ensure drvdata
= NULL when no driver is bound").
Thus, it is not needed to manually clear the device driver data to NULL.
When platform_driver_probe() is used, bind/unbind via sysfs is disabled.
Thus, __init/__exit annotations can be added to probe()/remove().
Use the module_platform_driver_probe() macro which makes the code
smaller and simpler.
This patch fixes the checkpatch warning as below:
WARNING: quoted string split across lines
The devm_ functions allocate memory that is released when a driver
detaches. This patch uses devm_gpio_request() for these functions.
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
detaches. This patch uses devm_kzalloc of these functions.
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Values such as max_brightness should be set before backlights are
registered, but the current API doesn't allow that. Add a parameter to
backlight_device_register and update drivers to ensure that they
set this correctly.
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
Signed-off-by: Emese Revfy <re.emese@gmail.com>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
This patch adds a platform driver using the ATMEL PWM driver to control a
backlight which requires a PWM signal and optional GPIO signal for discrete
on/off signal. It has been tested on Favr-32 board from EarthLCD.
The driver is configurable by supplying a struct with the platform data. See
the include/linux/atmel-pwm-bl.h for details.
The board code for Favr-32 will be submitted to the AVR32 kernel list.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
