[ Upstream commit a39ee449f96a2cd44ce056d8a0a112211a9b1a1f ]
vhost fails to validate negative error code
from vhost_get_vq_desc causing
a crash: we are using -EFAULT which is 0xfffffff2
as vector size, which exceeds the allocated size.
The code in question was introduced in commit
8dd014adfea6f173c1ef6378f7e5e7924866c923
vhost-net: mergeable buffers support
CVE-2014-0055
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit d8316f3991d207fe32881a9ac20241be8fa2bad0 ]
When mergeable buffers are disabled, and the
incoming packet is too large for the rx buffer,
get_rx_bufs returns success.
This was intentional in order for make recvmsg
truncate the packet and then handle_rx would
detect err != sock_len and drop it.
Unfortunately we pass the original sock_len to
recvmsg - which means we use parts of iov not fully
validated.
Fix this up by detecting this overrun and doing packet drop
immediately.
CVE-2014-0077
[ Upstream commit 0ad8b480d6ee916aa84324f69acf690142aecd0e ]
vhost checked the counter within the refcnt before decrementing. It
really wanted to know that it is the one that has the last reference, as
a way to batch freeing resources a bit more efficiently.
Note: we only let refcount go to 0 on device release.
This works well but we now access the ref counter twice so there's a
race: all users might see a high count and decide to defer freeing
resources.
In the end no one initiates freeing resources until the last reference
is gone (which is on VM shotdown so might happen after a looooong time).
Let's do what we probably should have done straight away:
switch from kref to plain atomic, documenting the
semantics, return the refcount value atomically after decrement,
then use that to avoid the deadlock.
Reported-by: Qin Chuanyu <qinchuanyu@huawei.com>
Acked-by: Jason Wang <jasowang@redhat.com>
commit 6f6b5d1ec56acdeab0503d2b823f6f88a0af493e upstream.
This patch changes percpu_ida_alloc() + callers to accept task state
bitmask for prepare_to_wait() for code like target/iscsi that needs
it for interruptible sleep, that is provided in a subsequent patch.
It now expects TASK_UNINTERRUPTIBLE when the caller is able to sleep
waiting for a new tag, or TASK_RUNNING when the caller cannot sleep,
and is forced to return a negative value when no tags are available.
v2 changes:
- Include blk-mq + tcm_fc + vhost/scsi + target/iscsi changes
- Drop signal_pending_state() call
v3 changes:
- Only call prepare_to_wait() + finish_wait() when != TASK_RUNNING
(PeterZ)
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
This patch addresses a long-standing bug where the get_user_pages_fast()
write parameter used for setting the underlying page table entry permission
bits was incorrectly set to write=1 for data_direction=DMA_TO_DEVICE, and
passed into get_user_pages_fast() via vhost_scsi_map_iov_to_sgl().
However, this parameter is intended to signal WRITEs to pinned userspace
PTEs for the virtio-scsi DMA_FROM_DEVICE -> READ payload case, and *not*
for the virtio-scsi DMA_TO_DEVICE -> WRITE payload case.
This bug would manifest itself as random process segmentation faults on
KVM host after repeated vhost starts + stops and/or with lots of vhost
endpoints + LUNs.
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Asias He <asias@redhat.com>
Cc: <stable@vger.kernel.org> # 3.6+
Fix GFP_KERNEL -> GFP_ATOMIC usage of percpu_ida_alloc() within
vhost_scsi_get_tag(), as this code is expected to be called directly
from interrupt context.
v2 changes:
- Handle possible tag < 0 failure with GFP_ATOMIC
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Asias He <asias@redhat.com>
Cc: Kent Overstreet <kmo@daterainc.com>
Remove space at start of line that sneaked in.
As vhost scsi device struct is large, if the device is
created on a busy system, kzalloc() might fail, so this patch does a
fallback to vzalloc().
As vmalloc() adds overhead on data-path, add __GFP_REPEAT
to kzalloc() flags to do this fallback only when really needed.
Reviewed-by: Asias He <asias@redhat.com>
Reported-by: Dan Aloni <alonid@stratoscale.com>
the wake_up_process func is included by spin_lock/unlock in
vhost_work_queue,
but it could be done outside the spin_lock.
I have test it with kernel 3.0.27 and guest suse11-sp2 using iperf,
the num as below.
original modified
thread_num tp(Gbps) vhost(%) | tp(Gbps) vhost(%)
1 9.59 28.82 | 9.59 27.49
8 9.61 32.92 | 9.62 26.77
64 9.58 46.48 | 9.55 38.99
256 9.6 63.7 | 9.6 52.59
Signed-off-by: Chuanyu Qin <qinchuanyu@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Lots of activity again this round for I/O performance optimizations
(per-cpu IDA pre-allocation for vhost + iscsi/target), and the
addition of new fabric independent features to target-core
(COMPARE_AND_WRITE + EXTENDED_COPY).
The main highlights include:
- Support for iscsi-target login multiplexing across individual
network portals
- Generic Per-cpu IDA logic (kent + akpm + clameter)
- Conversion of vhost to use per-cpu IDA pre-allocation for
descriptors, SGLs and userspace page pointer list
- Conversion of iscsi-target + iser-target to use per-cpu IDA
pre-allocation for descriptors
- Add support for generic COMPARE_AND_WRITE (AtomicTestandSet)
emulation for virtual backend drivers
- Add support for generic EXTENDED_COPY (CopyOffload) emulation for
virtual backend drivers.
- Add support for fast memory registration mode to iser-target (Vu)
The patches to add COMPARE_AND_WRITE and EXTENDED_COPY support are of
particular significance, which make us the first and only open source
target to support the full set of VAAI primitives.
Currently Linux clients are lacking upstream support to actually
utilize these primitives. However, with server side support now in
place for folks like MKP + ZAB working on the client, this logic once
reserved for the highest end of storage arrays, can now be run in VMs
on their laptops"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (50 commits)
target/iscsi: Bump versions to v4.1.0
target: Update copyright ownership/year information to 2013
iscsi-target: Bump default TCP listen backlog to 256
target: Fix >= v3.9+ regression in PR APTPL + ALUA metadata write-out
iscsi-target; Bump default CmdSN Depth to 64
iscsi-target: Remove unnecessary wait_for_completion in iscsi_get_thread_set
iscsi-target: Add thread_set->ts_activate_sem + use common deallocate
iscsi-target: Fix race with thread_pre_handler flush_signals + ISCSI_THREAD_SET_DIE
target: remove unused including <linux/version.h>
iser-target: introduce fast memory registration mode (FRWR)
iser-target: generalize rdma memory registration and cleanup
iser-target: move rdma wr processing to a shared function
target: Enable global EXTENDED_COPY setup/release
target: Add Third Party Copy (3PC) bit in INQUIRY response
target: Enable EXTENDED_COPY setup in spc_parse_cdb
target: Add support for EXTENDED_COPY copy offload emulation
target: Avoid non-existent tg_pt_gp_mem in target_alua_state_check
target: Add global device list for EXTENDED_COPY
target: Make helpers non static for EXTENDED_COPY command setup
target: Make spc_parse_naa_6h_vendor_specific non static
Update copyright ownership/year information for target-core,
loopback, iscsi-target, tcm_qla2xx, vhost and iser-target.
This patch adds support for pre-allocation of per tv_cmd descriptor
scatterlist + user-space page pointer memory using se_sess->sess_cmd_map
within tcm_vhost_make_nexus() code.
This includes sanity checks within vhost_scsi_map_to_sgl()
to reject I/O that exceeds these initial hardcoded values, and
the necessary cleanup in tcm_vhost_make_nexus() failure path +
tcm_vhost_drop_nexus().
v3 changes:
- Rebase to v3.11-rc5 code
This patch changes vhost/scsi to use transport_init_session_tags()
pre-allocation logic for per-cpu session tag pooling with internal
ida_alloc() + ida_free() calls based upon the saved se_cmd->map_tag id.
FIXME: Make transport_init_session_tags() number of tags setup
configurable per vring client setting via configfs
v5 changes:
- Convert to percpu_ida.h include
v3 changes:
- Update to percpu-ida usage
As Michael point out, We used to limit the max pending DMAs to get better cache
utilization. But it was not done correctly since it was one done when there's no
new buffers submitted from guest. Guest can easily exceeds the limitation by
keeping sending packets.
So this patch moves the check into main loop. Tests shows about 5%-10%
improvement on per cpu throughput for guest tx.
Signed-off-by: Jason Wang <jasowang@redhat.com>
We used to poll vhost queue before making DMA is done, this is racy if vhost
thread were waked up before marking DMA is done which can result the signal to
be missed. Fix this by always polling the vhost thread before DMA is done.
Currently, even if the packet length is smaller than VHOST_GOODCOPY_LEN, if
upend_idx != done_idx we still set zcopy_used to true and rollback this choice
later. This could be avoided by determining zerocopy once by checking all
conditions at one time before.
Let vhost_add_used() to use vhost_add_used_n() to reduce the code
duplication. To avoid the overhead brought by __copy_to_user(). We will use
put_user() when one used need to be added.
We tend to batch the used adding and signaling in vhost_zerocopy_callback()
which may result more than 100 used buffers to be updated in
vhost_zerocopy_signal_used() in some cases. So switch to use
vhost_add_used_and_signal_n() to avoid multiple calls to
vhost_add_used_and_signal(). Which means much less times of used index
updating and memory barriers.
2% performance improvement were seen on netperf TCP_RR test.
None of its caller use its return value, so let it return void.
memcpy_fromiovec is moved from net/core/iovec.c to lib/iovec.c.
linux/uio.h provides the declaration for memcpy_fromiovec.
Include linux/uio.h instead of inux/socket.h for it.
Signed-off-by: Asias He <asias@redhat.com>
Pull vhost fixes from Michael Tsirkin:
"vhost: more fixes for 3.11
This includes some fixes for vhost net and scsi drivers.
The test module has already been reworked to avoid rcu usage, but the
necessary core changes are missing, we fixed this.
Unlikely to affect any real-world users, but it's early in the cycle
so, let's merge them"
(It was earlier when Michael originally sent the email, but it somehot
got missed in the flood, so here it is after -rc2)
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
vhost: Remove custom vhost rcu usage
vhost-scsi: Always access vq->private_data under vq mutex
vhost-net: Always access vq->private_data under vq mutex
"Lots of activity this round on performance improvements in target-core
while benchmarking the prototype scsi-mq initiator code with
vhost-scsi fabric ports, along with a number of iscsi/iser-target
improvements and hardening fixes for exception path cases post v3.10
merge.
The highlights include:
- Make persistent reservations APTPL buffer allocated on-demand, and
drop per t10_reservation buffer. (grover)
- Make virtual LUN=0 a NULLIO device, and skip allocation of NULLIO
device pages (grover)
- Add transport_cmd_check_stop write_pending bit to avoid extra
access of ->t_state_lock is WRITE I/O submission fast-path. (nab)
- Drop unnecessary CMD_T_DEV_ACTIVE check from
transport_lun_remove_cmd to avoid extra access of ->t_state_lock in
release fast-path. (nab)
- Avoid extra t_state_lock access in __target_execute_cmd fast-path
(nab)
- Drop unnecessary vhost-scsi wait_for_tasks=true usage +
->t_state_lock access in release fast-path. (nab)
- Convert vhost-scsi to use modern se_cmd->cmd_kref
TARGET_SCF_ACK_KREF usage (nab)
- Add tracepoints for SCSI commands being processed (roland)
- Refactoring of iscsi-target handling of ISCSI_OP_NOOP +
ISCSI_OP_TEXT to be transport independent (nab)
- Add iscsi-target SendTargets=$IQN support for in-band discovery
(nab)
- Add iser-target support for in-band discovery (nab + Or)
- Add iscsi-target demo-mode TPG authentication context support (nab)
- Fix isert_put_reject payload buffer post (nab)
- Fix iscsit_add_reject* usage for iser (nab)
- Fix iscsit_sequence_cmd reject handling for iser (nab)
- Fix ISCSI_OP_SCSI_TMFUNC handling for iser (nab)
- Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED (nab)
The last five iscsi/iser-target items are CC'ed to stable, as they do
address issues present in v3.10 code. They are certainly larger than
I'd like for stable patch set, but are important to ensure proper
REJECT exception handling in iser-target for 3.10.y"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits)
iser-target: Ignore non TEXT + LOGOUT opcodes for discovery
target: make queue_tm_rsp() return void
target: remove unused codes from enum tcm_tmrsp_table
iscsi-target: kstrtou* configfs attribute parameter cleanups
iscsi-target: Fix tfc_tpg_auth_cit configfs length overflow
iscsi-target: Fix tfc_tpg_nacl_auth_cit configfs length overflow
iser-target: Add support for ISCSI_OP_TEXT opcode + payload handling
iser-target: Rename sense_buf_[dma,len] to pdu_[dma,len]
iser-target: Add vendor_err debug output
target: Add (obsolete) checking for PMI/LBA fields in READ CAPACITY(10)
target: Return correct sense data for IO past the end of a device
target: Add tracepoints for SCSI commands being processed
iser-target: Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED
iscsi-target: Fix ISCSI_OP_SCSI_TMFUNC handling for iser
iscsi-target: Fix iscsit_sequence_cmd reject handling for iser
iscsi-target: Fix iscsit_add_reject* usage for iser
iser-target: Fix isert_put_reject payload buffer post
iscsi-target: missing kfree() on error path
iscsi-target: Drop left-over iscsi_conn->bad_hdr
target: Make core_scsi3_update_and_write_aptpl return sense_reason_t
Now, vq->private_data is always accessed under vq mutex. No need to play
the vhost rcu trick.
The return value wasn't checked by any of the callers. Assuming this is
correct behaviour, we can simplify some code by not bothering to
generate it.
nab: Add srpt_queue_data_in() + srpt_queue_tm_rsp() nops around
srpt_queue_response() void return
Signed-off-by: Joern Engel <joern@logfs.org>
We changed the type of dev.vqs field, update test
module accordingly.
$ make C=1 M=drivers/vhost
drivers/vhost/net.c:168:5: warning: symbol 'vhost_net_set_ubuf_info' was not declared. Should it be static?
drivers/vhost/net.c:194:6: warning: symbol 'vhost_net_vq_reset' was not declared. Should it be static?
drivers/vhost/scsi.c:219:6: warning: symbol 'tcm_vhost_done_inflight' was not declared. Should it be static?
Currently, vhost-net and vhost-scsi are sharing the vhost core code.
However, vhost-scsi shares the code by including the vhost.c file
directly.
Making vhost a separate module makes it is easier to share code with
other vhost devices.
This way, we use cmd for struct tcm_vhost_cmd and evt for struct
tcm_vhost_cmd.
vs is used everywhere, make the naming more consistent.
It was needed when struct tcm_vhost_tpg is in tcm_vhost.h
vhost_net_ubuf_put_and_wait has a confusing name:
it will actually also free it's argument.
Thus since commit 1280c27f8e29acf4af2da914e80ec27c3dbd5c01
"vhost-net: flush outstanding DMAs on memory change"
vhost_net_flush tries to use the argument after passing it
to vhost_net_ubuf_put_and_wait, this results
in use after free.
To fix, don't free the argument in vhost_net_ubuf_put_and_wait,
add an new API for callers that want to free ubufs.
This patch coverts vhost/scsi to se_cmd->cmd_kref TARGET_SCF_ACK_KREF
usage, instead of assuming that vhost_scsi_free_cmd() is always called
before TCM processing is completed in the response fast path.
This includes adding vhost_scsi_check_stop_free() -> target_put_sess_cmd()
to perform the second se_cmd->cmd_kref put, and moving vhost_scsi_free_cmd()
resource release into tcm_vhost_release_cmd() that is invoked once the last
se_cmd->cmd_kref put occurs.
Cc: Roland Dreier <roland@kernel.org>
Cc: Kent Overstreet <koverstreet@google.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Moussa Ba <moussaba@micron.com>
transport_generic_free_cmd
This patch changes vhost_scsi_free_cmd() to call transport_generic_free_cmd()
with wait_for_tasks=false in order to avoid the extra se_cmd->t_state_lock
access for the wait_for_tasks=true case.
This is unnecessary because vhost_scsi_free_cmd() is only ever called by
vhost_scsi_complete_cmd_work() after TCM completion handoff, and by
vhost_scsi_handle_vq() exception code before TCM submission handoff, so
there is never a case where se_cmd is still active from TCM's perspective
when transport_generic_free_cmd() is called.
vhost_net_clear_ubuf_info didn't clear ubuf_info
after kfree, this could trigger double free.
Fix this and simplify this code to make it more robust: make sure
ubuf info is always freed through vhost_net_clear_ubuf_info.
Reported-by: Tommi Rantala <tt.rantala@gmail.com>
If device has an owner, we shouldn't touch ubuf_info
since it might be in use.
When we decide not use zero-copy, msg.control should be set to NULL otherwise
macvtap/tap may set zerocopy callbacks which may decrease the kref of ubufs
wrongly.
Bug were introduced by commit cedb9bdce099206290a2bdd02ce47a7b253b6a84
(vhost-net: skip head management if no outstanding).
This solves the following warnings:
WARNING: at include/linux/kref.h:47 handle_tx+0x477/0x4b0 [vhost_net]()
Modules linked in: vhost_net macvtap macvlan tun nfsd exportfs bridge stp llc openvswitch kvm_amd kvm bnx2 megaraid_sas [last unloaded: tun]
CPU: 5 PID: 8670 Comm: vhost-8668 Not tainted 3.10.0-rc2+ #1566
Hardware name: Dell Inc. PowerEdge R715/00XHKG, BIOS 1.5.2 04/19/2011
ffffffffa0198323 ffff88007c9ebd08 ffffffff81796b73 ffff88007c9ebd48
ffffffff8103d66b 000000007b773e20 ffff8800779f0000 ffff8800779f43f0
ffff8800779f8418 000000000000015c 0000000000000062 ffff88007c9ebd58
Call Trace:
[<ffffffff81796b73>] dump_stack+0x19/0x1e
[<ffffffff8103d66b>] warn_slowpath_common+0x6b/0xa0
[<ffffffff8103d6b5>] warn_slowpath_null+0x15/0x20
[<ffffffffa0197627>] handle_tx+0x477/0x4b0 [vhost_net]
[<ffffffffa0197690>] handle_tx_kick+0x10/0x20 [vhost_net]
[<ffffffffa019541e>] vhost_worker+0xfe/0x1a0 [vhost_net]
[<ffffffffa0195320>] ? vhost_attach_cgroups_work+0x30/0x30 [vhost_net]
[<ffffffff81061f46>] kthread+0xc6/0xd0
[<ffffffff81061e80>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff817a1aec>] ret_from_fork+0x7c/0xb0
[ 624.286653] vringh: module license 'unspecified' taints kernel.
Signed-off-by: Dave Jones <davej@redhat.com>
Pull more vhost fixes from Michael Tsirkin:
"This fixes some minor issues in the patches that have been merged.
We also finally drop the workaround disabling event_idx for scsi: it
was always questionable, and now we know it's not needed.
There's also a memory leak fix"
vhost-scsi: Enable VIRTIO_RING_F_EVENT_IDX
vhost: drop virtio_net.h dependency
vhost-net: Cleanup vhost_ubuf and vhost_zcopy
vhost: Remove vhost_enable_zcopy in vhost.h
vhost: Remove comments for hdr in vhost.h
vhost: Move VHOST_NET_FEATURES to net.c
vhost-net: Free ubuf when vhost_dev_set_owner fails
vhost: Export vhost_dev_set_owner
It was disabled as a workaround. Now userspace bits work fine with it.
The broken version was not ever committed to QEMU, I guess the same is
true for nlkt.
So, let's enable it.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
There's no net specific code in vhost.c anymore,
don't include the virtio_net.h header.
- Rename vhost_ubuf to vhost_net_ubuf
- Rename vhost_zcopy_mask to vhost_net_zcopy_mask
- Make funcs static
It is net.c specific.
It is supposed to be removed when hdr is moved into vhost_net_virtqueue.
vhost.h should not depend on device specific marcos like
VHOST_NET_F_VIRTIO_NET_HDR and VIRTIO_NET_F_MRG_RXBUF.
