s/FEter/FEther/.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
That code doesn't do what its author apparently thought it would do...
The apple powerbook people are used to switch the pb_fnmode
setting at runtime through writing to sysfs, altering the
module parameter value. This was broken for them in 2.6.20-rc1
when generic HID layer was introduced, as the pb_fnmode flag
was made per-hiddevice, instead of global variable.
This patch moves the pb_fnmode module parameter from usbhid module
to hid module, but apart from that retains backward compatibility
with respect to changing the mode through sysfs.
commit d8c8a393166d6283003fb111d0b4a40931c0eda4 introduced a clash in
hid_blacklist for 0x08ca/0x0010 (GTCO vs. AIPTEK). As the vendor of
GTCO device doesn't seem to be interested in supporting their legacy
HW with this conflicting ids, it is OK to remove it.
In appendix a patch for the nokia 6233 mobile phone is included.
The patch is against 2.6.20-rc5. It is my first patch. Hopefully it has
the right format. The code makes my nokia 6233 on my computer work.
Attached patch fixes typo in USB driver reported by Chase Douglas on linux-cirrus mailing
list. http://www.freelists.org/archives/linux-cirrus/12-2006/msg00003.html
Signed-off-by: Petr Stetiar <ynezz@true.cz>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Disable the USB_MULTITHREAD_PROBE option because it causes crashes on
people's machines and they never remember to actually read the config
help files.
No one likes this, everyone hates it, I'm going to go eat worms...
The full logic will be ripped out later.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=7814
American Megatrends did something wrong in their floppy emulator. It breaks
with both kinds of MODE SENSE which our stack sends. Alan and I tried a few
tweaks, and got LUNs sensed right, but US_FL_NO_WP_DETECT is still needed.
I set the firmware bracket to 1.00 exactly, in case AMI or Sun fix it with a
firmware update. Hey, you never know.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
Signed-off-by: Phil Dibowitz <phil@ipom.com>
on request of the sourceforge project for this device, a kind of
robotized CD storage, it should be ignored by the generic driver.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Bug fix for driver rndis_host which fixes rndis_host probing certain
Nokia S60 (Series 60) mobiles. While the rndis_host get probed by usbnet
and tries to bind the Nokia mobile the bind is going to fail. The
rndis_host module tries to release the device, in a wrong way, which
cause the oops.
Fixes Bugzilla #7201
Signed-off-by: Daniel Gollub <dgollub@suse.de>
Different AX88772 dongles use different PHYs; the chip is capable of using
both a primary and secondary PHY, and supports an internal and external PHY.
It appears that some DUB-E100 devices use the internal PHY, so trying to use
an external one will not work (note that this is different across revisions,
as well; the "A" and "B" revs of the DUB-E100 use different PHYs!). The data
sheet for the AX88772 chip specifies that the internal PHY id will be 0x10,
so if that's read from the EEPROM, we should use that rather than attempting
to use an external PHY.
Thanks to Mitch Bradley for pointing this out!
Signed-off-by: Andres Salomon <dilinger@debian.org>
Cc: David Hollis <dhollis@davehollis.com>
Cc: Chris Ball <cjb@laptop.org>
ITM screens send invalid x/y data when not touched. this was fixes a while ago
but the problem is if the screen is not touched anymore the driver never does
not report BTN_TOUCH as zero. fix it by sending the report with the last valid
coordinates when pressure is released.
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
Cc: J.P. Delport <jpdelport@csir.co.za>
Adds GTCO CalComp Interwrite IPanels to the hid-core.c blacklist.
Signed-off-by: Jeremy A. Roberson <jroberson@gtcocalcomp.com>
breakage
The commit 4916b3a57fc94664677d439b911b8aaf86c7ec23 introduced a
hid regression between 2.6.19 and 2.6.20-rc1. The device put in
input_dev->cdev is now of type usb_device instead of usb_interface.
Before:
> # readlink -f /sys/class/input/input6/event4/device
> /sys/devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.1
After:
> # readlink -f /sys/class/input/input3/event3/device
> /sys/devices/pci0000:00/0000:00:10.0/usb1/1-1
This causes breakage:
> # udevinfo -q all -n /dev/input/event3
> P: /class/input/input3/event3
> N: input/event3
> S: input/by-path/pci-1-1--event-
> E: ID_SERIAL=noserial
> E: ID_PATH=pci-1-1-
No ID_MODEL, ID_VENDOR, ID_REVISION, ID_TYPE etc etc.
Fix this by assigning the intf->dev into hid->dev, and fixing
all the users.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
I've got a newer MacBook with core2duo. Two keys on the keyboard are
swapped, "unswaping" works with the same trick as GEYSER3_ISO.
Signed-off-by: Adrian Friedli <masteradi@gmx.ch>
We have USB_HID _newly_ selected in configurations which didn't
have it before, which overrides CONFIG_HID and builds HID without
input support.
Nevertheless, here's a patch to solve more of the same that my original
patch attempted to solve. The original patch is still required. Seems
to solve the final instance of this problem here.
Signed-off-by: Russell King <rmk+lkml@arm.linux.org.uk>
Fix void cast and re-enable on sparc.
Cc: Greg KH <greg@kroah.com>
A small typo in ax88772_bind() prevents the device from selecting the
proper PHY, leaving the device useless. The attached patch fixes this.
If this patch can be added to the 2.6.19.x series as well, that would be
helpful for end-users.
Signed-off-by: David Hollis <dhollis@davehollis.com>
This patch gets the Kyocera FS-820 working with cups 1.2 via usb again. It
adds the printer to the list of "quirky" printers. The printer seems not
answer to ID requests some seconds after plugging in. Patch is based on
linux-2.6.19.1.
Background:
As far as I could see (strace, usbmon), the Kyocera FS-820 answers to ID
requests only a few seconds after plugging it in. This applies to detecting
it with cups and is also true for the printing itself, which is initiated
with an ID request. Since I have little usb knowledge, maybe someone can
interpret the data, especially the fist bulk transfer - why request 8192
bytes? This is the second version of the patch.
usbmon output of printing an email without patch:
tail -F /tmp/printlog.txt
c636e140 3374734463 S Bi:002:02 -115 8192 <
c9d43b40 3374734494 S Ci:002:00 s a1 00 0000 0000 03ff 1023 <
c9d43b40 3379732301 C Ci:002:00 -104 0
c636e140 3379733294 C Bi:002:02 -2 0
[...repeating...]
with patch:
d9cb82c0 3729790131 S Ci:002:00 s a1 00 0000 0000 03ff 1023 <
d9cb82c0 3729791725 C Ci:002:00 0 91 = 005b4944 3a46532d 3832303b 4d46473a
4b796f63 6572613b 434d443a 50434c58 df956320 3732493190 S Bo:002:01 -115
1347 = 1b252d31 32333435 5840504a 4c0a4050 4a4c2053 4554204d 414e5541
4c464545 [...more data...]
Signed-off-by: Martin Williges <kernel@zut.de>
x86_64:
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_putc':
drivers/usb/misc/sisusbvga/sisusb_con.c:405: warning: cast from pointer to integer of different size
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_putcs':
drivers/usb/misc/sisusbvga/sisusb_con.c:440: warning: cast from pointer to integer of different size
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_clear':
drivers/usb/misc/sisusbvga/sisusb_con.c:494: warning: cast from pointer to integer of different size
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_bmove':
drivers/usb/misc/sisusbvga/sisusb_con.c:566: warning: cast from pointer to integer of different size
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_switch':
drivers/usb/misc/sisusbvga/sisusb_con.c:614: warning: cast from pointer to integer of different size
drivers/usb/misc/sisusbvga/sisusb_con.c: In function 'sisusbcon_scroll_area':
drivers/usb/misc/sisusbvga/sisusb_con.c:941: warning: cast from pointer to integer of different size
Cc: Thomas Winischhofer <thomas@winischhofer.net>
Error handling in usb_create_ep_files() is not correct unless
the minor number is freed in ep_device_release().
Signed-off-by: Sarah Bailey <saharabeara@gmail.com>
This patch from Pete fixes the 'ejecting problem' on yet another ipod. Please applyt.
Signed-off-by: Pete Zaitcev <zaitcev@yahoo.com>
This combines patches from Alan Stern and Robert Schedel for two "Super Top"
drives that need the IGNORE_RESIDUE flag but have different vendor IDs.
Resync the omap_udc driver with the latest from the Linux-OMAP tree.
Changes include DMA API updates (it builds again!), clock/pm updates,
minor bugfixes, whitespace.
drivers/usb/serial/funsoft.c: In function `funsoft_ioctl':
drivers/usb/serial/funsoft.c:35: warning: dereferencing `void *' pointer
drivers/usb/serial/funsoft.c:35: error: request for member `c_iflag' in something not a structure or union
drivers/usb/serial/funsoft.c:35: warning: type defaults to `int' in declaration of `type name'
drivers/usb/serial/funsoft.c:35: error: request for member `c_oflag' in something not a structure or union
drivers/usb/serial/funsoft.c:35: error: request for member `c_cflag' in something not a structure or union
drivers/usb/serial/funsoft.c:35: error: request for member `c_lflag' in something not a structure or union
drivers/usb/serial/funsoft.c:35: error: request for member `c_line' in something not a structure or union
drivers/usb/serial/funsoft.c:35: error: request for member `c_cc' in something not a structure or union
Cc: David Clare <david@funsoft.com>
Just the serial port in the first interface should control DTR and RTS
lines. This way, the closing of the rest of the ports does not produce a=
hangup in the communication.
Signed-off-by: Miguel Angel Alvarez <ma.alvarez@ziv.es>
Signed-off-by: Matthias Urlichs <matthias@urlichs.de>
This patch (as831) adds device_may_wakeup() support to uhci-hcd; it
has been lacking for a long time.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Instead of matching all motherboards whose name contains "A7V8X" for a
remote-wakeup hardware bug, this patch (as829) matches only those
boards whose name is exactly equal to "A7V8X". Later motherboards
don't seem to have the bug.
(In fact, it's possible that only one motherboard in the world has the
bug. With only one user reporting problems, it's hard to tell.)
The help text for CONFIG_HID might imply for someone that
it's necessary to enable it for any keyboard or mouse
attached to the system. This is obviously not correct, so
fix it to avoid confusing the users.
The apple fn keys don't work anymore with 2.6.20-rc1.
The reason is that USB_HID_POWERBOOK appears in several files although
USB_HIDINPUT_POWERBOOK is the thing to be used.
The patch fixes this.
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Marcel Holtmann <marcel@holtmann.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (68 commits)
ACPI: replace kmalloc+memset with kzalloc
ACPI: Add support for acpi_load_table/acpi_unload_table_id
fbdev: update after backlight argument change
ACPI: video: Add dev argument for backlight_device_register
ACPI: Implement acpi_video_get_next_level()
ACPI: Kconfig - depend on PM rather than selecting it
ACPI: fix NULL check in drivers/acpi/osl.c
ACPI: make drivers/acpi/ec.c:ec_ecdt static
ACPI: prevent processor module from loading on failures
ACPI: fix single linked list manipulation
ACPI: ibm_acpi: allow clean removal
ACPI: fix git automerge failure
ACPI: ibm_acpi: respond to workqueue update
ACPI: dock: add uevent to indicate change in device status
ACPI: ec: Lindent once again
ACPI: ec: Change #define to enums there possible.
ACPI: ec: Style changes.
ACPI: ec: Acquire Global Lock under EC mutex.
ACPI: ec: Drop udelay() from poll mode. Loop by reading status field instead.
ACPI: ec: Rename gpe_bit to gpe
How many times are we going to merge this entry...
Add USB vendor/device IDs for Novatel Wireless S720 and U720 CDMA/EV-DO
modems to airprime.c.
Signed-off-by: Eric Smith <eric@brouhaha.com>
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=7508
When the Nokia E70 Phone is plugged in to the USB port, I get:
end_request: I/O error, dev sda, sector 1824527
sd 0:0:0:0: SCSI error: return code = 0x10070000
end_request: I/O error, dev sda, sector 1824535
The fix is to add these lines to drivers/usb/storage/unusual_devs.h:
Cc: <honkkis@gmail.com>
When sending CONTROL URB's using the usual CONTROL ioctl, logging works
fine, but when sending them via SUBMITURB, like VMWare does, the
control fields are not logged. This patch fixes that.
I didn't see any major changes to devio.c recently, so this patch should apply
cleanly to even the latest kernel. I can resubmit if it doesn't.
This patch performs additional checks in at91_udc, just in case of
some spurious interrupts or device enumeration.
Signed-off-by: Wojtek Kaniewski <wojtekka@toxygen.net>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Andrew Victor <andrew@sanpeople.com>
This patch zeroes some variables when usb_gadget_register_driver()
fails. gadgetfs does a dummy registration to get the name of the USB
driver and then waits for user-land driver. If someone plugs the cable
in the meantime, bad things happen, because at91_udc has been left in
inconsistent state.
This patch allows gadget drivers that support high speed (e.g. gadgetfs)
to work properly with at91_udc.
Fix suggested by Milan Svoboda in
http://marc.theaimsgroup.com/?l=linux-usb-devel&m=115822184711817
ELAN's U132 is a USB to CardBus OHCI controller adapter,
designed specifically for CardBus 3G data cards to
function in machines without a CardBus slot.
The "ftdi-elan" module is a USB client driver, that detects
a supported CardBus OHCI controller plugged into the
U132 adapter and thereafter provides the conduit for
for access by the "u132-hcd" module.
The "u132-hcd" module is a (cut-down OHCI) host controller
that supports a single OHCI function of the CardBus
card inserted into the U132 adapter.
The problem with the initial implementation is that when
the CardBus card inserted into the U132 adapter has multiple
functions (and a CardBus card can support up to 4 functions),
it was the first function that was arbitrarily choosen.
The first batch of 3G cards tested, like the Merlin Qualcomm
V620, have two functions each supporting a seperate USB OHCI
host controller, of which it was that first function that is
wired up to the 3G modem.
Then along comes the Vodafone Mobile Connect 3G/GPRS data card,
aka "Option GT 3G Quad" as printed on it's rear or "Option N.V.
GlobeTrotter Fusion Quad Lite" as read with "lspci -v". And it
has the meaningful functionality in the second CardBus function.
That presents a problem because it was the "ftdi-elan" module
alone that knows how to communicate to the embedded CardBus slot
and the "u132-hcd" module alone that knows how to access the
pcmcia configuration and CardBus accessible memory space. And
of course, the information about attached (internally hardwired)
devices is contained within USB configuration embedded somewhere
within the CardBus card.
If only the "u132-hcd" module probe() interface could return a
result code that propagated back to the instigating function
platform_device_register() then the "ftdi-elan" module could
try an alternative CardBus function. However in spite of
the recent changes to the drivers/base/ routines that moved
device_attach() from bus_add_device() to bus_attach_device()
both of those routines lose the "failed to attach" 0 result
code and thus the calling routine, namely device_add() is
incapable of propaging the "failed to attach" condition back
to platform_device_add() and consequently back to the caller
of platform_device_register()
Experiments show that patching bus_attach_device() to return
ENODEV fails with the kernel locking up very early during
boot. But, however, if the patch is restricted to calls from
platform_device_add() then it does seem to work.
Unfortunately, until the kernel's drivers/base is properly
modified to propagate -ENODEV back to the caller of
platform_device_register(), it is necessary to "fix" the
"ftdi-elan" module by importing knowledge from the
"u132-hcd" module. This is the reason for the duplicated
functionality introduced in this patch.
Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com>
This is an update to the AT91 USB Device (Gadget) driver.
Adds support for the Atmel AT91SAM9260 and AT91SAM9261 processors. The
only difference is how they handle the pullup pin.
[Patch from Patrice Vilchez]
Need to clear any pending USB Device interrupts before registering the
interrupt handler. The bootloader might have been using the USB Device
port. [Patch from Peer Georgi]
VBUS detection is handled by a GPIO interrupt which only triggers on a
change. Is is therefore necessary to read the current VBUS state
explicitly at startup. [Patch from Peer Georgi]
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
The base I/O address provided in the platform_device resources is now
ioremap()'ed instead of using a statically mapped memory area. This
helps portability to the newer AT91sam926x processors.
The major change is that we now have to pass a 'struct at91_udc'
parameter to at91_udp_read() and at91_udp_write().
OHCI HCD (Host Controller Driver) for USB. Bus Glue for PNX8550.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
I have found a problem where the root_port_reset() goes into an infinite
loop and stalls the kernel.
This happens when a hardware fault inside the machine occurs during a small
timing window. In case of USB device connection, if a USB device responds to
hcd_submit_urb(), and later the controller fails before root_port_reset(),
root_port_reset() will loop infinitely because ohci_readl() will always
return "-1". Such a failure can include ejecting a CardBus OHCI controller.
The probability of this problem is low, but it will increase if PnP type
usage is frequent. The attached patch can solve this problem and I believe
that it is better to fix this problem.
Signed-off-by: Takamasa Ohtake <ohtake-txa@necst.nec.co.jp>
Remove a warning about an unused variable in the OHCI bus glue for at91.
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace
(space before tab, at end of line) as well as the obsolete inline changelog.
Allow gadget drivers to omit the unbind() method. When they're
statically linked, that's an appropriate memory saving tweak.
Similarly, provide consistent/simpler handling for a should-not-happen
error case: removing a peripheral controller driver when a gadget
driver is still loaded. Such code dates back to early versions of the
first implementation of the gadget API, and has never been triggered.
Includes relevant section annotation fixs for gmidi.c, file_storage.c,
and serial.c; we don't yet have an "init or exit" annotation. Also
some whitespace fixes in gmidi.c (space at EOL, before tabs, etc).
Certain boards seem to like to issue false overcurrent notifications,
for example on ports that don't have anything connected to them. This
looks like a hardware error, at the level of noise to those ports'
overcurrent input signals (or non-debounced VBUS comparators). This
surfaces to users as truly massive amounts of syslog spam from khubd
(which is appropriate for real hardware problems, except for the
volume from multiple ports).
Using this new "ignore_oc" flag helps such systems work more sanely,
by preventing such indications from getting to khubd (and spamming
syslog). The downside is of course that true overcurrent errors will
be masked; they'll appear as spontaneous disconnects, without the
diagnostics that will let users troubleshoot issues like
short-circuited cables. In addition, controllers with no devices
attached will be forced to poll for new devices rather than relying on
interrupts, since each overcurrent event would generate a new
interrupt.
This patch (as826) is essentially a copy of David Brownell's ignore_oc
patch for ehci-hcd, ported to uhci-hcd.
