path: root/drivers/usb
2010-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty_port,usb-console: Fix usb serial console open/close regression tty: cpm_uart: use resource_size() tty_buffer: Fix distinct type warning hvc_console: Fix race between hvc_close and hvc_remove uartlite: Fix build on sparc. tty: Take a 256 byte padding into account when buffering below sub-page units Revert "tty: Add a new VT mode which is like VT_PROCESS but doesn't require a VT_RELDISP ioctl call"
2010-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (45 commits) USB: gadget/multi: cdc_do_config: remove redundant check usb: r8a66597-hcd: fix removed from an attached hub USB: xhci: Make endpoint interval debugging clearer. USB: Fix usb_fill_int_urb for SuperSpeed devices USB: cp210x: Remove double usb_control_msg from cp210x_set_config USB: Remove last bit of CONFIG_USB_BERRY_CHARGE USB: gadget: add gadget controller number for s3c-hsotg driver USB: ftdi_sio: Fix locking for change_speed() function USB: g_mass_storage: fixed module name in Kconfig USB: gadget: f_mass_storage::fsg_bind(): fix error handling USB: g_mass_storage: fix section mismatch warnings USB: gadget: fix Blackfin builds after gadget cleansing USB: goku_udc: remove potential null dereference USB: option.c: Add Pirelli VID/PID and indicate Pirelli's modem interface is 0xff USB: serial: Fix module name typo for qcaux Kconfig entry. usb: cdc-wdm: Fix deadlock between write and resume usb: cdc-wdm: Fix order in disconnect and fix locking usb: cdc-wdm:Fix loss of data due to autosuspend usb: cdc-wdm: Fix submission of URB after suspension usb: cdc-wdm: Fix race between disconnect and debug messages ...
2010-03-19USB: gadget/multi: cdc_do_config: remove redundant checkPeter Korsgaard
cdc_do_config() had a double ret check after fsg_add(). Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: r8a66597-hcd: fix removed from an attached hubYoshihiro Shimoda
fix the problem that when a USB hub is attached to the r8a66597-hcd and a device is removed from that hub, it's likely that a kernel panic follows. Reported-by: Markus Pietrek <Markus.Pietrek@emtrion.de> Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: xhci: Make endpoint interval debugging clearer.Sarah Sharp
The xHCI hardware can only handle polling intervals that are a power of two. When we add a new endpoint during a bandwidth allocation, and the polling interval is rounded down to a power of two, print the original polling interval in the endpoint descriptor. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: Fix usb_fill_int_urb for SuperSpeed devicesMatthew Wilcox
USB 3 and Wireless USB specify a logarithmic encoding of the endpoint interval that matches the USB 2 specification. usb_fill_int_urb() didn't know that and was filling in the interval as if it was USB 1.1. Fix usb_fill_int_urb() for SuperSpeed devices, but leave the wireless case alone, because David Vrabel wants to keep the old encoding. Update the struct urb kernel doc to note that SuperSpeed URBs must have urb->interval specified in microframes. Add a missing break statement in the usb_submit_urb() interrupt URB checking, since wireless USB and SuperSpeed USB encode urb->interval differently. This allows xHCI roothubs to actually register with khubd. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: cp210x: Remove double usb_control_msg from cp210x_set_configMichael Brunner
This patch removes a double usb_control_msg that sets the cp210x configuration registers a second time when calling cp210x_set_config. For data sizes >2 the second write gets corrupted. The patch has been created against 2.6.34-rc1, but all cp210x driver revisions are affected. Signed-off-by: Michael Brunner <mibru@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: Remove last bit of CONFIG_USB_BERRY_CHARGEChristoph Egger
One last bit was missed while removing the USB_BERRY_CHARGE config option in a8d4211f33a9573f7b1bdcfd9c9c48631d1515ee which gets dropped by this patch. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: gadget: add gadget controller number for s3c-hsotg driverMaurus Cuelenaere
This prevents some drivers from complaining that no bcdDevice id was set. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: ftdi_sio: Fix locking for change_speed() functionAlessio Igor Bogani
The change_speed() function should be serialized against multiple calls. Use the cfg_lock mutex to do this. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: g_mass_storage: fixed module name in KconfigMichal Nazarewicz
The Kconfig help message for Mass Storage Gadget claimed the module will be named "g_file_storage" whereas it should be "g_mass_storage". Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: gadget: f_mass_storage::fsg_bind(): fix error handlingPeter Korsgaard
Contrary to the comment in fsg_add, fsg_bind calls fsg_unbind on errors, which decreases refcount and frees the fsg_dev structure, causing trouble when fsg_add does the same. Fix it by simply leaving up cleanup to fsg_add(). Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: g_mass_storage: fix section mismatch warningsMike Frysinger
The recent commit (0e530b45783f75) that moved usb_ep_autoconfig from the __devinit section to the __init section missed the mass storage device. Its fsg_bind() function uses the usb_ep_autoconfig() function from non __init context leading to: WARNING: drivers/usb/gadget/g_mass_storage.o(.text): Section mismatch in reference from the function _fsg_bind() to the function .init.text:_usb_ep_autoconfig() So move fsg_bind() into __init as well. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: gadget: fix Blackfin builds after gadget cleansingMike Frysinger
The recent change to clean out dead gadget drivers (90f7976880bbbf99) missed the call to gadget_is_musbhsfc() behind CONFIG_BLACKFIN. This causes Blackfin gadget builds to fail since the function no longer exists anywhere. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: goku_udc: remove potential null dereferenceDan Carpenter
"dev" is always null here. In the end it's only used to get the pci_name() of "pdev" which is redundant information and so I removed it. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: option.c: Add Pirelli VID/PID and indicate Pirelli's modem interface is ↵spark
0xff Signed-off-by: spark <spark@bandrich.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: serial: Fix module name typo for qcaux Kconfig entry.Stefan Schmidt
The module is called qcaux and not moto_modem. Also use help instead of ---help-- to be in sync with the other Kconfig entries. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix deadlock between write and resumeOliver Neukum
The new runtime PM scheme allows resume() to have no locks. This fixes the deadlock. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix order in disconnect and fix lockingOliver Neukum
- as the callback can schedule work, URBs must be killed first - if the driver causes an autoresume, the caller must handle locking Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm:Fix loss of data due to autosuspendOliver Neukum
The guarding flag must be set and tested under spinlock and cleared before the URBs are resubmitted in resume. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix submission of URB after suspensionOliver Neukum
There's a window under which cdc-wdm may submit an URB to a device about to be suspended. This introduces a flag to prevent it. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix race between disconnect and debug messagesOliver Neukum
dev_dbg() and dev_err() cannot be used to report failures that may have been caused by a device's removal Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix race between autosuspend and reading from the deviceOliver Neukum
While an available response is read the device must not be autosuspended. This requires a flag dedicated to that purpose. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: cdc-wdm: Fix race between write and disconnectOliver Neukum
Unify mutexes to fix a race between write and disconnect and shift the test for disconnection to always report it. Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: musb: core: declare mbase only where it's usedFelipe Balbi
... and avoid a compilation if we disable host side of musb. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: musb: fix warnings in Blackfin regsMike Frysinger
The recent commit "usb: musb: Add context save and restore support" added some stubs for the Blackfin code so things would compile, but it also added a bunch of warnings due to missing return statements. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: musb: abstract out ULPI_BUSCONTROL register reads/writesMike Frysinger
The USB PHY on current Blackfin processors is a UTMI+ level 2 PHY. However, it has no ULPI support - so there are no registers at all. That means accesses to ULPI_BUSCONTROL have to be abstracted away like other MUSB registers. This fixes building for Blackfin parts again. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb: musb: Fix compile error for omaps for musb_hdrcTony Lindgren
CONFIG_ARCH_OMAP34XX is now CONFIG_ARCH_OMAP3. But since drivers/usb/musb/omap2430.c use CONFIG_PM for these registers and functions, do the same for the header. Otherwise we get the following for most omap3 defconfigs: drivers/usb/musb/omap2430.c:261: error: expected identifier or '(' before 'do' drivers/usb/musb/omap2430.c:261: error: expected identifier or '(' before 'while' drivers/usb/musb/omap2430.c:268: error: expected identifier or '(' before 'do' drivers/usb/musb/omap2430.c:268: error: expected identifier or '(' before 'while' Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19usb/gadget: fix compile error on r8a66597-udc.cGrant Likely
C file uses IS_ERR and PTR_ERR, but doesn't include <linux/err.h> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: option: add support for a new CMOTECH device to usb/serial/optionNathaniel McCallum
Signed-off-by: Nathaniel McCallum <nathaniel@natemccallum.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: option: move hardcoded PID to a macro in usb/serial/optionNathaniel McCallum
2010-03-19USB: option: fix incorrect manufacturer name in usb/serial/option: ↵Nathaniel McCallum
MAXON->CMOTECH Signed-off-by: Nathaniel McCallum <nathaniel@natemccallum.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: serial: ftdi: add CONTEC vendor and product idDaniel Sangorrin
This is a patch to ftdi_sio_ids.h and ftdi_sio.c that adds identifiers for CONTEC USB serial converter. I tested it with the device COM-1(USB)H [akpm@linux-foundation.org: keep the VIDs sorted a bit] Signed-off-by: Daniel Sangorrin <daniel.sangorrin@gmail.com> Cc: Andreas Mohr <andi@lisas.de> Cc: Radek Liboska <liboska@uochb.cas.cz> Cc: stable <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: xHCI: re-initialize cmd_completionAndiry Xu
When a signal interrupts a Configure Endpoint command, the cmd_completion used in xhci_configure_endpoint() is not re-initialized and the wait_for_completion_interruptible_timeout() will return failure. Initialize cmd_completion in xhci_configure_endpoint(). Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: xhci: rename driver to xhci_hcdAlex Chiang
Naming consistency with other USB HCDs. Signed-off-by: Alex Chiang <achiang@hp.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: musb: fix build error introduced by isoc changeSonic Zhang
The recent commit "usb: musb: Fix for isochronous IN transfer" (f82a689fa) seems to have been against an older kernel version. It uses the old style naming of variables. Unfortunately, this breaks building for most MUSB users out there since "bDesiredMode" has been renamed to "desired_mode". Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: qcserial: add new device idsBernhard Rosenkraenzer
This patch adds various USB device IDs for Gobi 2000 devices, as found in the drivers available at https://www.codeaurora.org/wiki/GOBI_Releases Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: cdc-acm: Fix stupid NULL pointer in resume()Oliver Neukum
Stupid logic bug passing a just nulled pointer Signed-off-by: Oliver Neukum <neukum@b1-systems.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: EHCI: adjust ehci_iso_stream for changes in ehci_qhClemens Ladisch
The EHCI driver stores in usb_host_endpoint.hcpriv a pointer to either an ehci_qh or an ehci_iso_stream structure, and uses the contents of the hw_info1 field to distinguish the two cases. After ehci_qh was split into hw and sw parts, ehci_iso_stream must also be adjusted so that it again looks like an ehci_qh structure. This fixes a NULL pointer access in ehci_endpoint_disable() when it tries to access qh->hw->hw_info1. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com> Cc: stable <stable@kernel.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: EHCI: fix ITD list orderClemens Ladisch
When isochronous URBs are shorter than one frame and when more than one ITD in a frame has been completed before the interrupt can be handled, scan_periodic() completes the URBs in the order in which they are found in the descriptor list. Therefore, the descriptor list must contain the ITDs in the correct order, i.e., a new ITD must be linked in after any previous ITDs of the same endpoint. This should fix garbled capture data in the USB audio drivers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: Option: Add support for a variant of DLink DWM 652 U5Huang Ying
I found a DLink DWM 652 U5 USB 3G modem has product ID 0xce1e instead of orignal 0xce16. The new ID is added. And I found there are two entries for 0xce16, one has raw number, the other has symbol DLINK_PRODUCT_DWM_652_U5. This is fixed too. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: unusual_devs.h: Fix capacity for SL11R-IDE 2.6cOndrej Zary
SL11R-IDE 2.6c (at least) reports wrong capacity (one sector more). Reading that last sector causes the device not to work anymore (and looks like HAL or something does that automatically after plugging in): sd 5:0:0:0: [sdc] Device not ready sd 5:0:0:0: [sdc] Result: hostbyte=0x00 driverbyte=0x08 sd 5:0:0:0: [sdc] Sense Key : 0x2 [current] sd 5:0:0:0: [sdc] ASC=0x0 ASCQ=0x0 sd 5:0:0:0: [sdc] CDB: cdb[0]=0x28: 28 00 04 a8 b5 70 00 00 01 00 Add unusual_devs entry to fix the capacity. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: serial: use port endpoint size to determine if ep is availableJohan Hovold
It is possible to have a multi-port device with a port lacking an in or out bulk endpoint. Only checking for num_bulk_in or num_bulk_out is thus not sufficient to determine whether a specific port has an in or out bulk endpoint. This fixes potential null pointer dereferences in the generic open and write routines, as well as access to uninitialised fifo in write_room and chars_in_buffer. Also let write fail with ENODEV (instead of 0) on missing out endpoint (also on zero-length writes). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: serial: fix softint not being called on errorsJohan Hovold
Make sure usb_serial_port_softint is called on errors also when using multi urb writes. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: serial: fix error message on close in generic driverJohan Hovold
Resubmitting read urb fails with -EPERM if completion handler runs while urb is being killed on close. This should not be reported as an error. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19USB: fix usbfs regressionAlan Stern
This patch (as1352) fixes a bug in the way isochronous input data is returned to userspace for usbfs transfers. The entire buffer must be copied, not just the first actual_length bytes, because the individual packets will be discontiguous if any of them are short. Reported-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19tty_port,usb-console: Fix usb serial console open/close regressionJason Wessel
Commit e1108a63e10d344284011cccc06328b2cd3e5da3 ("usb_serial: Use the shutdown() operation") breaks the ability to use a usb console starting in 2.6.33. This was observed when using console=ttyUSB0,115200 as a boot argument with an FTDI device. The error is: ftdi_sio ttyUSB0: ftdi_submit_read_urb - failed submitting read urb, error -22 The handling of the ASYNCB_INITIALIZED changed in 2.6.32 such that in tty_port_shutdown() it always clears the flag if it is set. The fix is to add a variable to the tty_port struct to indicate when the tty port is a console. CC: Alan Cox <alan@linux.intel.com> CC: Alan Stern <stern@rowland.harvard.edu> CC: Oliver Neukum <oliver@neukum.org> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-16backlight: Allow properties to be passed at registrationMatthew Garrett
Values such as max_brightness should be set before backlights are registered, but the current API doesn't allow that. Add a parameter to backlight_device_register and update drivers to ensure that they set this correctly. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits) ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock ARM: S3C2443: Remove #if 0 for clk_mpll ARM: S3C2443: Update notes on MPLLREF clock ARM: S3C2443: Further clksrc-clk conversions ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation USB: Fix s3c-hsotg build following Samsung platform header moves ARM: S3C64XX: Reintroduce unconditional build of audio device ARM: 5961/1: ux500: fix CLKRST addresses ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted ASoC: Fix S3C64xx IIS driver for Samsung header reorg ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support [ARM] pxa: fix typo in mxm8x10.h [ARM] pxa/raumfeld: set GPIO drive bits for LED pins [ARM] pxa/zeus: Add support for mcp2515 CAN bus [ARM] pxa/zeus: Add support for onboard max6369 watchdog [ARM] pxa/zeus: Add Eurotech as the manufacturer [ARM] pxa/zeus: Correct the USB host initialisation flags [ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress [ARM] pxa: refactor uncompress.h for non-PXA uarts [ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs ...
