path: root/drivers/usb/usb-skeleton.c
2012-04-27USB: usb-skeleton.c: remove err() usageGreg Kroah-Hartman
err() was a very old USB-specific macro that I thought had gone away. This patch removes it from being used in the driver and uses dev_err() instead. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24Revert "USB: usb-skeleton.c: fix open/disconnect race"Greg Kroah-Hartman
This reverts commit 26c71a79cade5ccad80e0752cd82f3518df48fb3. It's not needed, to quote Ming Lei: Looks you have queued the patch into your tree, but just now I find the patch is not needed at all, since we have had minor_rwsem(drivers/usb/core/file.c) for this purpose, please drop the patch, sorry for it. Cc: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-04USB: usb-skeleton.c: cleanup open_countMing Lei
It is not necessary to use the 'open_count' for handling runtime pm only, because runtinme pm has built-in counter to handle this, so remove it to make code clean. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04USB: usb-skeleton.c: fix open/disconnect raceMing Lei
If usb device is disconnected between usb_get_intfdata() and kref_get() in skel_open(), kref_get may access a freed object. Also check if device is disconnected in ->open. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-18USB: convert drivers/usb/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/usb/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Simon Arlott <cxacru@fire.lp0.eu> Cc: Duncan Sands <duncan.sands@free.fr> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Oliver Neukum <oliver@neukum.name> Cc: Juergen Stuber <starblue@users.sourceforge.net> Cc: Cesar Miquel <miquel@df.uba.ar> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Michael Hund <mhund@ld-didactic.de> Cc: Zack Parsons <k3bacon@gmail.com> Cc: Melchior FRANZ <mfranz@aon.at> Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Cc: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23USB: use usb_endpoint_maxp() instead of le16_to_cpu()Kuninori Morimoto
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size instead of le16_to_cpu(desc->wMaxPacketSize). This patch fix it up Cc: Armin Fuerst <fuerst@in.tum.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: Johannes Erdfelt <johannes@erdfelt.com> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Oliver Neukum <oliver@neukum.name> Cc: David Kubicek <dave@awk.cz> Cc: Johan Hovold <jhovold@gmail.com> Cc: Brad Hards <bhards@bigpond.net.au> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de> Cc: David Brownell <david-b@pacbell.net> Cc: David Lopo <dlopo@chipidea.mips.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Xie Xiaobo <X.Xie@freescale.com> Cc: Li Yang <leoli@freescale.com> Cc: Jiang Bo <tanya.jiang@freescale.com> Cc: Yuan-hsin Chen <yhchen@faraday-tech.com> Cc: Darius Augulis <augulis.darius@gmail.com> Cc: Xiaochen Shen <xiaochen.shen@intel.com> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Ben Dooks <ben@simtec.co.uk> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Herbert Pötzl <herbert@13thfloor.at> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Cc: Roman Weissgaerber <weissg@vienna.at> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: Florian Floe Echtler <echtler@fs.tum.de> Cc: Christian Lucht <lucht@codemercs.com> Cc: Juergen Stuber <starblue@sourceforge.net> Cc: Georges Toth <g.toth@e-biz.lu> Cc: Bill Ryder <bryder@sgi.com> Cc: Kuba Ober <kuba@mareimbrium.org> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-10USB: usb-skeleton: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: BKL removal: usb-skeletonOliver Neukum
BKL not needed at all. Removed without replacement. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: Push BKL on open down into the driversOliver Neukum
Straightforward push into the drivers to allow auditing individual drivers separately Signed-off-by: Oliver Neukum <oliver@neukum.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB skeleton: make USB device id constantNémeth Márton
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: skeleton: Correct use of ! and &Julia Lawall
Correct priority problem in the use of ! and &. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E; constant C; @@ - !E & C + !(E & C) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: skeleton: fix coding style issues.Greg Kroah-Hartman
This fixes up the majority of the coding style issues in the usb-skeleton driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: O_NONBLOCK in read path of skeletonOliver Neukum
Non blocking IO is supported in the read path of usb-skeleton. This is done by just not blocking. As support for handling signals without stopping IO is already there, it can be used for O_NONBLOCK, too. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: make usb-skeleton honor O_NONBLOCK in write pathOliver Neukum
usb:usb-skeleton: honor O_NONBLOCK in write path nonblocking writes are allowed by using down_trylock if necessary to reserve an URB Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: skel_read really sucks royallyOliver Neukum
The read code path of the skeleton driver really sucks - skel_read works only for devices which always send data - the timeout comes out of thin air - it blocks signals for the duration of the timeout - it disallows nonblocking IO by design This patch fixes it by using a real urb, a completion and interruptible waits. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: skeleton: Use dev_info instead of infoMatt Kraai
338b67b0c1a97ca705023a8189cf41aa0828d294 removed the info macro and replaced its uses with dev_info. This patch does so for usb-skeleton.c, which was missed. Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: usb-skeleton leaking locks on openMark Gross
This weekend I was hacking around with a trivial USB driver for talking to the boot load firmware of a USB Bit Whacker. It's running the MicroChip Pic18 boot loader firmware and I'm putting together a flash program for writing new FW to the thing. Anyway in my use of the usb-skeleton.c as my starting point I discovered my test program was getting hung up after attempting to write a buffer. The application and driver where hung in a way that required me to reboot to get it to clean up so I could try again. It turned out the code path through skel_open can grap the driver's io_mutex lock and forget to release it. The following patch fixes the problem for me. Signed-off-by: Mark Gross <mgross@linux.intel.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: use anchors in pre/post resetOliver Neukum
use anchors in pre/post_reset Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton" use anchors in suspend/resume handlingOliver Neukum
use anchors in suspend/resume handling Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: use anchors in disconnect handlingOliver Neukum
use anchors in disconnect handling Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: usb anchor to implement flushOliver Neukum
This patch set introduces usb_anchor and uses it to implement all modern APIs in the skeleton driver. - proper error reporting in the skeleton driver - implementation of flush() Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: prevent char device open/deregister raceAlan Stern
This patch (as908) adds central protection in usbcore for the prototypical race between opening and unregistering a char device. The spinlock used to protect the minor-numbers array is replaced with an rwsem, which can remain locked across a call to a driver's open() method. This guarantees that open() and deregister() will be mutually exclusive. The private locks currently used in several individual drivers for this purpose are no longer necessary, and the patch removes them. The following USB drivers are affected: usblcd, idmouse, auerswald, legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and usb-skeleton. As a side effect of this change, usb_deregister_dev() must not be called while holding a lock that is acquired by open(). Unfortunately a number of drivers do this, but luckily the solution is simple: call usb_deregister_dev() before acquiring the lock. In addition to these changes (and their consequent code simplifications), the patch fixes a use-after-free bug in adutux and a race between open() and release() in iowarrior. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: kill BKL in skeleton driverOliver Neukum
Iet's kill BKL where we can. This is relative to the last patch to the skeleton driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: fix skeleton driverOliver Neukum
compilation of the skeleton driver is currently broken. It doesn't compile. So while I am it: - fix typo - add comments to answer common questions - actually allow autosuspend in the driver struct - increase paralellism by restricting code under locks Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: fix autosuspend race in skeleton driverOliver Neukum
as the skeleton driver was made ready for autosuspend a race condition was introduced. The reference to get device must be gotten before the autosuspend counter is upped, as this operation may sleep, dropping BKL. Dropping BKL means that the pointer to the device may become invalid. Here's the fix. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27usbcore: non-hub-specific uses of autosuspendAlan Stern
This patch (as741) makes the non-hub parts of usbcore actually use the autosuspend facilities added by an earlier patch. Devices opened through usbfs are autoresumed and then autosuspended upon close. Likewise for usb-skeleton. Devices are autoresumed for usb_set_configuration. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27usb-skeleton: small updateLuiz Fernando N. Capitulino
o CodingStyle fixes o Removes trailing spaces o Do not make not needed initialiation of automatic variables o Use usb_endpoint_* functions o If we get an error in the write URB callback print an error message instead of a debug one (Pretty unrelated changes, but spliting this up doesn't pay off as our main changes are just CodingStyle fixes). Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27usb-skeleton: don't submit URBs after disconnectionAlan Stern
This patch (as712b) is a slight revision of one submitted earlier. It fixes the usb-skeleton example driver so that it won't try to submit URBs after skel_disconnect() has returned. This could cause errors, if the driver was unbound and then a different driver was bound to the device. It also fixes a couple of small bugs in the skel_write() routine. The revised patch uses a slightly different test, suggested by Dave Brownell, for determining whether to free a transfer buffer. It's a little clearer than the earlier version. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: remove some left over devfs droppings hanging around in the usb ↵Greg Kroah-Hartman
drivers As there is no more usb devfs support, these bits would just confuse people. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: fix usb-skeleton limit resource usage patch.Sam Bishop
Prevents a compiler warning and uses down_interruptible() instead of down() in process context. Signed-off-by: Sam Bishop <sam@bishop.dhs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: fix buffer size limiting in skeleton driverOlav Kongas
Fix buffer size limiting. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Limiting of resource use in skeleton driverOliver Neukum
this introduces limits whose lack in the skeleton driver someone recently complained about. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] devfs: Remove the mode field from usb_class_driver as it's no longer ↵Greg Kroah-Hartman
needed Also fixes all drivers that set this field, and removes some other devfs specfic USB logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/class/usblp.c | 3 +-- drivers/usb/core/file.c | 19 ++++--------------- drivers/usb/image/mdc800.c | 3 +-- drivers/usb/input/aiptek.c | 2 +- drivers/usb/input/hiddev.c | 3 +-- drivers/usb/media/dabusb.c | 3 +-- drivers/usb/misc/auerswald.c | 3 +-- drivers/usb/misc/idmouse.c | 5 ++--- drivers/usb/misc/legousbtower.c | 5 ++--- drivers/usb/misc/rio500.c | 3 +-- drivers/usb/misc/sisusbvga/sisusb.c | 5 ----- drivers/usb/misc/usblcd.c | 9 ++++----- drivers/usb/usb-skeleton.c | 3 +-- include/linux/usb.h | 7 ++----- 14 files changed, 22 insertions(+), 51 deletions(-)
2005-07-29[PATCH] USB: fix Bug in usb-skeleton.cConger, Chris A
Compare endpoint address to USB_ENDPOINT_DIR_MASK to determine endpoint direction... From: "Conger, Chris A." <CHRIS.A.CONGER@saic.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
