path: root/drivers/usb/serial
2012-09-11USB: option: replace ZTE K5006-Z entry with vendor class ruleBjørn Mork
Fix the ZTE K5006-Z entry so that it actually matches anything commit f1b5c997 USB: option: add ZTE K5006-Z added a device specific entry assuming that the device would use class/subclass/proto == ff/ff/ff like other ZTE devices. It turns out that ZTE has started using vendor specific subclass and protocol codes: T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=19d2 ProdID=1018 Rev= 0.00 S: Manufacturer=ZTE,Incorporated S: Product=ZTE LTE Technologies MSM S: SerialNumber=MF821Vxxxxxxx C:* #Ifs= 5 Cfg#= 1 Atr=c0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=86 Prot=10 Driver=(none) E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=05 Driver=(none) E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=(none) E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=06 Prot=00 Driver=qmi_wwan E: Ad=85(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms We do not have any information on how ZTE intend to use these codes, but let us assume for now that the 3 sets matching serial functions in the K5006-Z always will identify a serial function in a ZTE device. Cc: Thomas Schäfer <tschaefer@t-online.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-10USB: ftdi_sio: do not claim CDC ACM functionBjørn Mork
The Microchip vid:pid 04d8:000a is used for their CDC ACM demo firmware application. This is a device with a single function conforming to the CDC ACM specification and with the intention of demonstrating CDC ACM class firmware and driver interaction. The demo is used on a number of development boards, and may also be used unmodified by vendors using Microchip hardware. Some vendors have re-used this vid:pid for other types of firmware, emulating FTDI chips. Attempting to continue to support such devices without breaking class based applications that by matching on interface class/subclass/proto being ff/ff/00. I have no information about the actual device or interface descriptors, but this will at least make the proper CDC ACM devices work again. Anyone having details of the offending device's descriptors should update this entry with the details. Reported-by: Florian Wöhrl <fw@woehrl.biz> Reported-by: Xiaofan Chen <xiaofanc@gmail.com> Cc: stable <stable@vger.kernel.org> Cc: Alan Cox <alan@linux.intel.com> Cc: Bruno Thomsen <bruno.thomsen@gmail.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05USB: ftdi_sio: PID for NZR SEM 16+ USBHorst Schirmeier
This adds the USB PID for the NZR SEM 16+ USB energy monitor device <http://www.nzr.de>. It works perfectly with the GPL software on <http://schou.dk/linux/sparometer/>. Signed-off-by: Horst Schirmeier <horst@schirmeier.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05USB: ftdi-sio: add support for more Physik Instrumente devicesÉric Piel
Commit b69cc672052540 added support for the E-861. After acquiring a C-867, I realised that every Physik Instrumente's device has a different PID. They are listed in the Windows device driver's .inf file. So here are all PIDs for the current (and probably future) USB devices from Physik Instrumente. Compiled, but only actually tested on the E-861 and C-867. Signed-off-by: Éric Piel <piel@delmic.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16USB: qcserial: fix port handling on Gobi 1K and 2K+Dan Williams
Bjorn's latest patchset does break Gobi 1K and 2K because on both devices as it claims usb interface 0. That's because usbif 0 is not handled in the switch statement, and thus the if0 gets claimed when it should not. So let's just make things even simpler yet, and handle both the 1K and 2K+ cases separately. This patch should not affect the new Sierra device support, because those devices are matched via interface-specific matching and thus should never hit the composite code. Signed-off-by: Dan Williams <dcbw@redhat.com> Tested-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15USB: serial: Fix mos7840 timeoutMark Ferrell
* mos7840 driver was using multiple of HZ for the timeout handed off to usb_control_msg(). Changed the timeout to use msecs instead. * Remove unused WAIT_FOR_EVER definition Signed-off-by: Mark Ferrell <mferrell@uplogix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15USB: option: add ZTE K5006-ZBjørn Mork
The ZTE (Vodafone) K5006-Z use the following interface layout: 00 DIAG 01 secondary 02 modem 03 networkcard 04 storage Ignoring interface #3 which is handled by the qmi_wwan driver. Cc: Thomas Schäfer <tschaefer@t-online.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: usb_wwan: resume/suspend can be called after port is goneBjørn Mork
We cannot unconditionally access any usb-serial port specific data from the interface driver. Both supending and resuming may happen after the port has been removed and portdata is freed. Treat ports with no portdata as closed ports to avoid a NULL pointer dereference on resume. No need to kill URBs for removed ports on suspend, avoiding the same NULL pointer reference there. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: serial: prevent suspend/resume from racing against probe/removeBjørn Mork
Some usb-serial drivers may access port data in their suspend/ resume functions. Such drivers must always verify the validity of the data as both suspend and resume can be called both before usb_serial_device_probe and after usb_serial_device_remove. But the port data may be invalidated during port_probe and port_remove. This patch prevents the race against suspend and resume by disabling suspend while port_probe or port_remove is running. Suggested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: usb_wwan: replace release and disconnect with a port_remove hookBjørn Mork
Doing port specific cleanup in the .port_remove hook is a lot simpler and safer than doing it in the USB driver .release or .disconnect methods. The removal of the port from the usb-serial bus will happen before the USB driver cleanup, so we must be careful about accessing port specific driver data from any USB driver functions. This problem surfaced after the commit 0998d0631 device-core: Ensure drvdata = NULL when no driver is bound which turned the previous unsafe access into a reliable NULL pointer dereference. Fixes the following Oops: [ 243.148471] BUG: unable to handle kernel NULL pointer dereference at (null) [ 243.148508] IP: [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.148556] PGD 79d60067 PUD 79d61067 PMD 0 [ 243.148590] Oops: 0000 [#1] SMP [ 243.148617] Modules linked in: sr_mod cdrom qmi_wwan usbnet option cdc_wdm usb_wwan usbserial usb_storage uas fuse af_packet ip6table_filter ip6_tables iptable_filter ip_tables x_tables tun edd cpufreq_conservative cpufreq_userspace cpufreq_powersave snd_pcm_oss snd_mixer_oss acpi_cpufreq snd_seq mperf snd_seq_device coretemp arc4 sg hp_wmi sparse_keymap uvcvideo videobuf2_core videodev videobuf2_vmalloc videobuf2_memops rtl8192ce rtl8192c_common rtlwifi joydev pcspkr microcode mac80211 i2c_i801 lpc_ich r8169 snd_hda_codec_idt cfg80211 snd_hda_intel snd_hda_codec rfkill snd_hwdep snd_pcm wmi snd_timer ac snd soundcore snd_page_alloc battery uhci_hcd i915 drm_kms_helper drm i2c_algo_bit ehci_hcd thermal usbcore video usb_common button processor thermal_sys [ 243.149007] CPU 1 [ 243.149027] Pid: 135, comm: khubd Not tainted 3.5.0-rc7-next-20120720-1-vanilla #1 Hewlett-Packard HP Mini 110-3700 /1584 [ 243.149072] RIP: 0010:[<ffffffffa0468527>] [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.149118] RSP: 0018:ffff880037e75b30 EFLAGS: 00010286 [ 243.149133] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88005912aa28 [ 243.149150] RDX: ffff88005e95f028 RSI: 0000000000000000 RDI: ffff88005f7c1a10 [ 243.149166] RBP: ffff880037e75b60 R08: 0000000000000000 R09: ffffffff812cea90 [ 243.149182] R10: 0000000000000000 R11: 0000000000000001 R12: ffff88006539b440 [ 243.149198] R13: ffff88006539b440 R14: 0000000000000000 R15: 0000000000000000 [ 243.149216] FS: 0000000000000000(0000) GS:ffff88007ee80000(0000) knlGS:0000000000000000 [ 243.149233] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 243.149248] CR2: 0000000000000000 CR3: 0000000079fe0000 CR4: 00000000000007e0 [ 243.149264] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 243.149280] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 243.149298] Process khubd (pid: 135, threadinfo ffff880037e74000, task ffff880037d40600) [ 243.149313] Stack: [ 243.149323] ffff880037e75b40 ffff88006539b440 ffff8800799bc830 ffff88005f7c1800 [ 243.149348] 0000000000000001 ffff88006539b448 ffff880037e75b70 ffffffffa04685e9 [ 243.149371] ffff880037e75bc0 ffffffffa0473765 ffff880037354988 ffff88007b594800 [ 243.149395] Call Trace: [ 243.149419] [<ffffffffa04685e9>] usb_wwan_disconnect+0x9/0x10 [usb_wwan] [ 243.149447] [<ffffffffa0473765>] usb_serial_disconnect+0xd5/0x120 [usbserial] [ 243.149511] [<ffffffffa0046b48>] usb_unbind_interface+0x58/0x1a0 [usbcore] [ 243.149545] [<ffffffff8139ebd7>] __device_release_driver+0x77/0xe0 [ 243.149567] [<ffffffff8139ec67>] device_release_driver+0x27/0x40 [ 243.149587] [<ffffffff8139e5cf>] bus_remove_device+0xdf/0x150 [ 243.149608] [<ffffffff8139bc78>] device_del+0x118/0x1a0 [ 243.149661] [<ffffffffa0044590>] usb_disable_device+0xb0/0x280 [usbcore] [ 243.149718] [<ffffffffa003c6fd>] usb_disconnect+0x9d/0x140 [usbcore] [ 243.149770] [<ffffffffa003da7d>] hub_port_connect_change+0xad/0x8a0 [usbcore] [ 243.149825] [<ffffffffa0043bf5>] ? usb_control_msg+0xe5/0x110 [usbcore] [ 243.149878] [<ffffffffa003e6e3>] hub_events+0x473/0x760 [usbcore] [ 243.149931] [<ffffffffa003ea05>] hub_thread+0x35/0x1d0 [usbcore] [ 243.149955] [<ffffffff81061960>] ? add_wait_queue+0x60/0x60 [ 243.150004] [<ffffffffa003e9d0>] ? hub_events+0x760/0x760 [usbcore] [ 243.150026] [<ffffffff8106133e>] kthread+0x8e/0xa0 [ 243.150047] [<ffffffff8157ec04>] kernel_thread_helper+0x4/0x10 [ 243.150068] [<ffffffff810612b0>] ? flush_kthread_work+0x120/0x120 [ 243.150088] [<ffffffff8157ec00>] ? gs_change+0xb/0xb [ 243.150101] Code: fd 41 54 53 48 83 ec 08 80 7f 1a 00 74 57 49 89 fc 31 db 90 49 8b 7c 24 20 45 31 f6 48 81 c7 10 02 00 00 e8 bc 64 f3 e0 49 89 c7 <4b> 8b 3c 37 49 83 c6 08 e8 4c a5 bd ff 49 83 fe 20 75 ed 45 30 [ 243.150257] RIP [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.150282] RSP <ffff880037e75b30> [ 243.150294] CR2: 0000000000000000 [ 243.177170] ---[ end trace fba433d9015ffb8c ]--- Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reported-by: Thomas Schäfer <tschaefer@t-online.de> Suggested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: serial: mos7840: Fixup mos7840_chars_in_buffer()Mark Ferrell
* Use the buffer content length as opposed to the total buffer size. This can be a real problem when using the mos7840 as a usb serial-console as all kernel output is truncated during boot. Signed-off-by: Mark Ferrell <mferrell@uplogix.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10USB: support the new interfaces of Huawei Data Card devices in option driverfangxiaozhi
In this patch, we add new declarations into option.c to support the new interfaces of Huawei Data Card devices. And at the same time, remove the redundant declarations from option.c. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10USB: ftdi_sio: Add VID/PID for Kondo Serial USBOzan Çağlayan
This adds VID/PID for Kondo Kagaku Co. Ltd. Serial USB Adapter interface: http://www.kondo-robot.com/EN/wp/?cat=28 Tested by controlling an RCB3 board using libRCB3. Signed-off-by: Ozan Çağlayan <ozancag@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: option: add ZTE MF821DBjørn Mork
Sold by O2 (telefonica germany) under the name "LTE4G" Tested-by: Thomas Schäfer <tschaefer@t-online.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: sierra: QMI mode MC7710 moved to qcserialBjørn Mork
The MC7710 in QMI mode does not support the vendor specific USB requests used by this driver. The most noticable effect of this is a 5 second delay as each serial port is probed, caused by the set_power_state command timing out: [ 17.434291] usbcore: registered new interface driver sierra [ 17.434383] USB Serial support registered for Sierra USB modem [ 17.434486] sierra 8-4:1.0: Sierra USB modem converter detected [ 22.432413] usb 8-4: Sierra USB modem converter now attached to ttyUSB0 [ 22.432563] sierra 8-4:1.2: Sierra USB modem converter detected [ 27.432410] usb 8-4: Sierra USB modem converter now attached to ttyUSB1 [ 27.432562] sierra 8-4:1.3: Sierra USB modem converter detected [ 32.432463] usb 8-4: Sierra USB modem converter now attached to ttyUSB2 The MC7710 provide the same Qualcomm serial interfaces as Gobi modules, and the qcserial driver has been extended to support the module instead of this driver. Cc: Anton Samokhvalov <pg83@yandex.ru> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: qcserial: adding Sierra Wireless devicesBjørn Mork
The QMI mode of the Sierra Wireless MC7710 is close to a Gobi device, and also identified as one by the Windows drivers provided by Sony. The serial interfaces are the same as for any other Gobi module, but the USB interface layout is different: 0: DM/DIAG (also present in bootloader mode) 2: NMEA 3: AT-capable modem port 8: QMI/net 19: QMI/net (not always present) 20: QMI/net (not always present) Note in particular that the NMEA and AT ports are reversed compared to a Gobi 2k+ device, and that the DM port appears as a QDL port in bootloader mode using the same device ID. The Sony driver also document two new devices with standard Gobi 2k+ layout (1199:68a5, 1199:68a9) having a QDL mode (1199:68a4, 1199:68a8). Adding these as well. Lenovo Windows drivers document the USB interface layout for a few additional Sierra Wireless devices. Adding these while at it: - MC7770 (1199:901b) with standard Gobi 2k+ layout - MC7700 (0f3d:68a2) with the same layout as MC7710 - MC7750 (114f:68a2) with the same layout as MC7710 - EM7700 (1199:901c) with the same layout as MC7710 Cc: Anton Samokhvalov <pg83@yandex.ru> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: qcserial: support generic Qualcomm serial portsBjørn Mork
No need to verify the interface layout when doing interface number based matching. We can safely trust the device ID table in this case. This allows the driver to support any USB interface layout for non-Gobi 1k/2k+ devices. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: qcserial: make probe more flexibleBjørn Mork
Preparing qcprobe support for more than just strict Gobi 1k or 2k+ devices. Many newer Qualcomm based devices provide the same serial ports, but using varying USB interface layouts. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: qcserial: centralize probe exit pathBjørn Mork
Creating a common exit path from qcprobe to make it easier to extend it. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: qcserial: consolidate usb_set_interface callsBjørn Mork
No need to replicate the same code all over the place. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: serial: keyspan: Removed unrequired parentheses.Ben Minerds
Changes to conform with checkpatch.sh script. - return is not a function, parentheses not required. Removed 1 checkpatch.sh error. Signed-off-by: Ben Minerds <puzzleduck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: serial: keyspan: Removed trailing whitespace.Ben Minerds
Changes to conform with checkpatch.sh script. - trailing whitespace. Removed 1 checkpatch.sh error. Signed-off-by: Ben Minerds <puzzleduck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: serial: keyspan: Fixed space near open parenthesis.Ben Minerds
Changes to conform with checkpatch.sh script. - space near open parenthesis '('. Removed 2 checkpatch.sh errors. Signed-off-by: Ben Minerds <puzzleduck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: serial: keyspan: Fixed space around equals.Ben Minerds
Changes to conform with checkpatch.sh script. - space around '='. Removed 1 checkpatch.sh error. Signed-off-by: Ben Minerds <puzzleduck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: serial: keyspan: Fix spacing around conditional.Ben Minerds
Changes to conform with checkpatch.sh script. - spaces around '?' and ':'. Removed 14 checkpatch.sh errors. Signed-off-by: Ben Minerds <puzzleduck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16Merge 3.5-rc7 into usb-nextGreg Kroah-Hartman
This resolves the merge issue with the drivers/usb/host/ehci-omap.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-05USB: metro-usb: fix tty_flip_buffer_push useJohan Hovold
Do not set low_latency flag at open as tty_flip_buffer_push must not be called in IRQ context with low_latency set. Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-05USB: option: Add MEDIATEK product idsGaosen Zhang
Signed-off-by: Gaosen Zhang <gaosen.zhang@mediatek.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-05USB: option: add ZTE MF60Bjørn Mork
Switches into a composite device by ejecting the initial driver CD. The four interfaces are: QCDM, AT, QMI/wwan and mass storage. Let this driver manage the two serial interfaces: T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 28 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=19d2 ProdID=1402 Rev= 0.00 S: Manufacturer=ZTE,Incorporated S: Product=ZTE WCDMA Technologies MSM S: SerialNumber=xxxxx C:* #Ifs= 4 Cfg#= 1 Atr=c0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-05Merge 3.5-rc5 into usb-nextGreg Kroah-Hartman
This resolves a merge issue with the option.c USB serial driver. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-26USB: CP210x Add 10 Device IDsCraig Shelley
This patch adds 10 device IDs for CP210x based devices from the following manufacturers: Timewave Clipsal Festo Link Instruments Signed-off-by: Craig Shelley <craig@microtron.org.uk> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-26USB: option: Add USB ID for Novatel Ovation MC551Forest Bond
This device is also known as the Verizon USB551L. Signed-off-by: Forest Bond <forest.bond@rapidrollout.com> Acked-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20USB: option: add id for Cellient MEN-200Dmitry Shmygov
Add vendor and product ID to option.c driver for Cellient MEN-200 EVDO Rev.B 450MHz data module. http://cellient.com Signed-off-by: Dmitry Shmygov <shmygov@rambler.ru> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20Merge 3.5-rc3 into usb-nextGreg Kroah-Hartman
This lets us catch the USB fixes that went into 3.5-rc3 into this branch, as we want them here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20USB: serial: Remove unused serial_priv variableBill Pemberton
qt2_open() and qt2_close() both set a serial_priv variable but never used it. Remove the variable from the functions. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20USB: serial: Remove unused s_priv variableBill Pemberton
s_priv was set but never used in keyspan_open() and keyspan_close(), remove it. This also makes the serial variable in keyspan_open() unused since it's only use was to set s_priv, so it is also removed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13usb: use usb_serial_put in usb_serial_probe errorsJan Safrata
The use of kfree(serial) in error cases of usb_serial_probe was invalid - usb_serial structure allocated in create_serial() gets reference of usb_device that needs to be put, so we need to use usb_serial_put() instead of simple kfree(). Signed-off-by: Jan Safrata <jan.nikitenko@gmail.com> Acked-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: option: handle send_setup blacklisting at probeJohan Hovold
Determine whether to use send_setup at probe time rather than at every call to send_setup. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: option: clean up probe coding styleJohan Hovold
Clean up option probe by introducing intermediate variables and fixing up comments. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13Merge branch 'usb-linus' into usb-nextGreg Kroah-Hartman
This is to pick up the changes to the option driver, which are needed for follow-on patches from Johan. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: option: use usb_{get,set}_serial_dataJohan Hovold
Use usb_{get,set}_serial_data to access usb-serial data. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: serial-generic: use a single set of device IDsAlan Stern
The usb-serial-generic driver uses different device IDs for its USB matching and its serial matching. This can lead to problems: The driver can end up getting bound to a USB interface without being allowed to bind to the corresponding serial port. This patch (as1557) fixes the problem by using the same device ID table (the one that can be altered by the "vendor=" and "product=" module parameters) for both purposes. The unused table is removed. Now the driver will bind only to the intended devices. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: serial: Enforce USB driver and USB serial driver matchBjørn Mork
We need to make sure that the USB serial driver we find matches the USB driver whose probe we are currently executing. Otherwise we will end up with USB serial devices bound to the correct serial driver but wrong USB driver. An example of such cross-probing, where the usbserial_generic USB driver has found the sierra serial driver: May 29 18:26:15 nemi kernel: [ 4442.559246] usbserial_generic 4-4:1.0: Sierra USB modem converter detected May 29 18:26:20 nemi kernel: [ 4447.556747] usbserial_generic 4-4:1.2: Sierra USB modem converter detected May 29 18:26:25 nemi kernel: [ 4452.557288] usbserial_generic 4-4:1.3: Sierra USB modem converter detected sysfs view of the same problem: bjorn@nemi:~$ ls -l /sys/bus/usb/drivers/sierra/ total 0 --w------- 1 root root 4096 May 29 18:23 bind lrwxrwxrwx 1 root root 0 May 29 18:23 module -> ../../../../module/usbserial --w------- 1 root root 4096 May 29 18:23 uevent --w------- 1 root root 4096 May 29 18:23 unbind bjorn@nemi:~$ ls -l /sys/bus/usb-serial/drivers/sierra/ total 0 --w------- 1 root root 4096 May 29 18:23 bind lrwxrwxrwx 1 root root 0 May 29 18:23 module -> ../../../../module/sierra -rw-r--r-- 1 root root 4096 May 29 18:23 new_id lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB0 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.0/ttyUSB0 lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB1 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.2/ttyUSB1 lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB2 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.3/ttyUSB2 --w------- 1 root root 4096 May 29 18:23 uevent --w------- 1 root root 4096 May 29 18:23 unbind bjorn@nemi:~$ ls -l /sys/bus/usb/drivers/usbserial_generic/ total 0 lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.0 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.0 lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.2 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.2 lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.3 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.3 --w------- 1 root root 4096 May 29 18:33 bind lrwxrwxrwx 1 root root 0 May 29 18:33 module -> ../../../../module/usbserial --w------- 1 root root 4096 May 29 18:22 uevent --w------- 1 root root 4096 May 29 18:33 unbind bjorn@nemi:~$ ls -l /sys/bus/usb-serial/drivers/generic/ total 0 --w------- 1 root root 4096 May 29 18:33 bind lrwxrwxrwx 1 root root 0 May 29 18:33 module -> ../../../../module/usbserial -rw-r--r-- 1 root root 4096 May 29 18:33 new_id --w------- 1 root root 4096 May 29 18:22 uevent --w------- 1 root root 4096 May 29 18:33 unbind So we end up with a mismatch between the USB driver and the USB serial driver. The reason for the above is simple: The USB driver probe will succeed if *any* registered serial driver matches, and will use that serial driver for all serial driver functions. This makes ref counting go wrong. We count the USB driver as used, but not the USB serial driver. This may result in Oops'es as demonstrated by Johan Hovold <jhovold@gmail.com>: [11811.646396] drivers/usb/serial/usb-serial.c: get_free_serial 1 [11811.646443] drivers/usb/serial/usb-serial.c: get_free_serial - minor base = 0 [11811.646460] drivers/usb/serial/usb-serial.c: usb_serial_probe - registering ttyUSB0 [11811.646766] usb 6-1: pl2303 converter now attached to ttyUSB0 [11812.264197] USB Serial deregistering driver FTDI USB Serial Device [11812.264865] usbcore: deregistering interface driver ftdi_sio [11812.282180] USB Serial deregistering driver pl2303 [11812.283141] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0 [11812.283272] usbcore: deregistering interface driver pl2303 [11812.301056] USB Serial deregistering driver generic [11812.301186] usbcore: deregistering interface driver usbserial_generic [11812.301259] drivers/usb/serial/usb-serial.c: usb_serial_disconnect [11812.301823] BUG: unable to handle kernel paging request at f8e7438c [11812.301845] IP: [<f8e38445>] usb_serial_disconnect+0xb5/0x100 [usbserial] [11812.301871] *pde = 357ef067 *pte = 00000000 [11812.301957] Oops: 0000 [#1] PREEMPT SMP [11812.301983] Modules linked in: usbserial(-) [last unloaded: pl2303] [11812.302008] [11812.302019] Pid: 1323, comm: modprobe Tainted: G W 3.4.0-rc7+ #101 Dell Inc. Vostro 1520/0T816J [11812.302115] EIP: 0060:[<f8e38445>] EFLAGS: 00010246 CPU: 1 [11812.302130] EIP is at usb_serial_disconnect+0xb5/0x100 [usbserial] [11812.302141] EAX: f508a180 EBX: f508a180 ECX: 00000000 EDX: f8e74300 [11812.302151] ESI: f5050800 EDI: 00000001 EBP: f5141e78 ESP: f5141e58 [11812.302160] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [11812.302170] CR0: 8005003b CR2: f8e7438c CR3: 34848000 CR4: 000007d0 [11812.302180] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [11812.302189] DR6: ffff0ff0 DR7: 00000400 [11812.302199] Process modprobe (pid: 1323, ti=f5140000 task=f61e2bc0 task.ti=f5140000) [11812.302209] Stack: [11812.302216] f8e3be0f f8e3b29c f8e3ae00 00000000 f513641c f5136400 f513641c f507a540 [11812.302325] f5141e98 c133d2c1 00000000 00000000 f509c400 f513641c f507a590 f5136450 [11812.302372] f5141ea8 c12f0344 f513641c f507a590 f5141ebc c12f0c67 00000000 f507a590 [11812.302419] Call Trace: [11812.302439] [<c133d2c1>] usb_unbind_interface+0x51/0x190 [11812.302456] [<c12f0344>] __device_release_driver+0x64/0xb0 [11812.302469] [<c12f0c67>] driver_detach+0x97/0xa0 [11812.302483] [<c12f001c>] bus_remove_driver+0x6c/0xe0 [11812.302500] [<c145938d>] ? __mutex_unlock_slowpath+0xcd/0x140 [11812.302514] [<c12f0ff9>] driver_unregister+0x49/0x80 [11812.302528] [<c1457df6>] ? printk+0x1d/0x1f [11812.302540] [<c133c50d>] usb_deregister+0x5d/0xb0 [11812.302557] [<f8e37c55>] ? usb_serial_deregister+0x45/0x50 [usbserial] [11812.302575] [<f8e37c8d>] usb_serial_deregister_drivers+0x2d/0x40 [usbserial] [11812.302593] [<f8e3a6e2>] usb_serial_generic_deregister+0x12/0x20 [usbserial] [11812.302611] [<f8e3acf0>] usb_serial_exit+0x8/0x32 [usbserial] [11812.302716] [<c1080b48>] sys_delete_module+0x158/0x260 [11812.302730] [<c110594e>] ? mntput+0x1e/0x30 [11812.302746] [<c145c3c3>] ? sysenter_exit+0xf/0x18 [11812.302746] [<c107777c>] ? trace_hardirqs_on_caller+0xec/0x170 [11812.302746] [<c145c390>] sysenter_do_call+0x12/0x36 [11812.302746] Code: 24 02 00 00 e8 dd f3 20 c8 f6 86 74 02 00 00 02 74 b4 8d 86 4c 02 00 00 47 e8 78 55 4b c8 0f b6 43 0e 39 f8 7f a9 8b 53 04 89 d8 <ff> 92 8c 00 00 00 89 d8 e8 0e ff ff ff 8b 45 f0 c7 44 24 04 2f [11812.302746] EIP: [<f8e38445>] usb_serial_disconnect+0xb5/0x100 [usbserial] SS:ESP 0068:f5141e58 [11812.302746] CR2: 00000000f8e7438c Fix by only evaluating serial drivers pointing back to the USB driver we are currently probing. This still allows two or more drivers to match the same device, running their serial driver probes to sort out which one to use. Cc: stable@vger.kernel.org # 3.0, 3.2, 3.3, 3.4 Signed-off-by: Bjørn Mork <bjorn@mork.no> Reviewed-by: Felipe Balbi <balbi@ti.com> Tested-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: option: add more YUGA device ids说不得
Signed-off-by: gavin zhu <gavin.zhu@qq.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: mos7840: Fix compilation of usb serial driverTony Zelenoff
The __devinitconst section can't be referenced from usb_serial_device structure. Thus removed it as it done in other mos* device drivers. Error itself: WARNING: drivers/usb/serial/mos7840.o(.data+0x8): Section mismatch in reference from the variable moschip7840_4port_device to the variable .devinit.rodata:id_table The variable moschip7840_4port_device references the variable __devinitconst id_table [v2] no attach now Signed-off-by: Tony Zelenoff <antonz@parallels.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: option: fix memory leakJohan Hovold
Fix memory leak introduced by commit 383cedc3bb435de7a2 ("USB: serial: full autosuspend support for the option driver") which allocates usb-serial data but never frees it. Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: option: fix port-data abuseJohan Hovold
Commit 8b4c6a3ab596961b78465 ("USB: option: Use generic USB wwan code") moved option port-data allocation to usb_wwan_startup but still cast the port data to the old struct... Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: mct_u232: Fix incorrect TIOCMSET returnAlan Cox
The low level helper returns 1 on success. The ioctl should however return 0. As this is the only user of the helper return, make the helper return 0 or an error code. Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=43009 Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: option: Updated Huawei K4605 has better idAndrew Bird
Later firmwares for this device now have proper subclass and protocol info so we can identify it nicely without needing to use the blacklist. I'm not removing the old 0xff matching as there may be devices in the field that still need that. Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12USB: serial: sierra: Add support for Sierra Wireless AirCard 320U modemTom Cassidy
Add support for Sierra Wireless AirCard 320U modem Signed-off-by: Tomas Cassidy <tomas.cassidy@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
