git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
USB: changes for v5.1 merge window
Dwc3 now works on TI's AM6xx platforms. Also on dwc3 we have a few
changes which improve request cancellation and some improvements to
how we print to the trace buffer.
Renesas_usb3 got support for r8a774c0 device.
Dwc2 got scatter-gather support.
Apart from these, the usual set of minor fixes and all sorts of small
details.
* tag 'usb-for-v5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb: (40 commits)
usb: phy: twl6030-usb: fix possible use-after-free on remove
usb: misc: usbtest: add super-speed isoc support
usb: dwc3: Reset num_trbs after skipping
usb: dwc3: gadget: don't enable interrupt when disabling endpoint
fotg210-udc: pass struct device to DMA API functions
fotg210-udc: remove a bogus dma_sync_single_for_device call
usb: gadget: Change Andrzej Pietrasiewicz's e-mail address
usb: f_fs: Avoid crash due to out-of-scope stack ptr access
usb: dwc3: haps: Workaround matching VID PID
usb: gadget: f_fs: preserve wMaxPacketSize across usb_ep_autoconfig() call
usb: gadget: move non-super speed code out of usb_ep_autoconfig_ss()
usb: gadget: function: sync f_uac1 ac header baInterfaceNr
usb: dwc2: gadget: Add scatter-gather mode
usb: gadget: fix various indentation issues
usb: dwc2: Fix EP TxFIFO number setting
udc: net2280: Fix net2280_disable
USB: gadget: Improve kerneldoc for usb_ep_dequeue()
usb: dwc3: debug: purge usage of strcat
usb: dwc3: trace: pass trace buffer size to decoding functions
usb: dwc3: gadget: remove DWC3_EP_END_TRANSFER_PENDING
In remove(), use cancel_delayed_work_sync() to cancel the
delayed work. Otherwise there's a chance that this work
will continue to run until after the device has been removed.
This issue was detected with the help of Coccinelle.
Cc: Tony Lindgren <tony@atomide.com>
Cc: Bin Liu <b-liu@ti.com>
Fixes: b6a619a883c3 ("usb: phy: Check initial state for twl6030")
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
We need the USB fixes in here as well.
power off the phy should be done before populate the phy. Otherwise,
am335x_init() could be called by the phy owner to power on the phy first,
then am335x_phy_probe() turns off the phy again without the caller knowing
it.
Fixes: 2fc711d76352 ("usb: phy: am335x: Enable USB remote wakeup using PHY wakeup")
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Bin Liu <b-liu@ti.com>
Fix link errors when CONFIG_FSL_USB2_OTG is enabled and USB_OTG_FSM is
set to module then the following link error occurs.
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_ioctl':
drivers/usb/phy/phy-fsl-usb.c:1083: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:1083:(.text+0x574): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_srp':
drivers/usb/phy/phy-fsl-usb.c:674: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:674:(.text+0x61c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_host':
drivers/usb/phy/phy-fsl-usb.c:593: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:593:(.text+0x7a4): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_hnp':
drivers/usb/phy/phy-fsl-usb.c:695: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:695:(.text+0x858): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `a_wait_enum':
drivers/usb/phy/phy-fsl-usb.c:274: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:274:(.text+0x16f0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o:drivers/usb/phy/phy-fsl-usb.c:619: more undefined references to `otg_statemachine' follow
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_peripheral':
drivers/usb/phy/phy-fsl-usb.c:619:(.text+0x1fa0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
make[1]: *** [Makefile:1020: vmlinux] Error 1
make[1]: Target 'Image' not remade because of errors.
make: *** [Makefile:152: sub-make] Error 2
make: Target 'Image' not remade because of errors.
Rework so that FSL_USB2_OTG depends on that the USB_OTG_FSM is builtin.
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
There are a few remaining drivers/usb/ files that do not have SPDX
identifiers in them, all of these are either Kconfig or Makefiles. Add
the correct GPL-2.0 identifier to them to make scanning tools happy.
Smatch complains that "reg" can be uninitialized if the
abx500_get_register_interruptible() call fails. It's an interruptable
function, so we should check if the user presses CTRL-C.
Trivial fix to spelling mistake in dev_dbg message
Acked-by: Peter Chen <peter.chen@nxp.com>
Fix build errors when built for PPC64:
These variables are only used on PPC32 so they don't need to be
initialized for PPC64.
../drivers/usb/phy/phy-fsl-usb.c: In function 'usb_otg_start':
../drivers/usb/phy/phy-fsl-usb.c:865:3: error: '_fsl_readl' undeclared (first use in this function); did you mean 'fsl_readl'?
_fsl_readl = _fsl_readl_be;
../drivers/usb/phy/phy-fsl-usb.c:865:16: error: '_fsl_readl_be' undeclared (first use in this function); did you mean 'fsl_readl'?
../drivers/usb/phy/phy-fsl-usb.c:866:3: error: '_fsl_writel' undeclared (first use in this function); did you mean 'fsl_writel'?
_fsl_writel = _fsl_writel_be;
../drivers/usb/phy/phy-fsl-usb.c:866:17: error: '_fsl_writel_be' undeclared (first use in this function); did you mean 'fsl_writel'?
../drivers/usb/phy/phy-fsl-usb.c:868:16: error: '_fsl_readl_le' undeclared (first use in this function); did you mean 'fsl_readl'?
_fsl_readl = _fsl_readl_le;
../drivers/usb/phy/phy-fsl-usb.c:869:17: error: '_fsl_writel_le' undeclared (first use in this function); did you mean 'fsl_writel'?
_fsl_writel = _fsl_writel_le;
and the sysfs "show" function return type should be ssize_t, not int:
../drivers/usb/phy/phy-fsl-usb.c:1042:49: error: initialization of 'ssize_t (*)(struct device *, struct device_attribute *, char *)' {aka 'long int (*)(struct device *, struct device_attribute *, char *)'} from incompatible pointer type 'int (*)(struct device *, struct device_attribute *, char *)' [-Werror=incompatible-pointer-types]
static DEVICE_ATTR(fsl_usb2_otg_state, S_IRUGO, show_fsl_usb2_otg_state, NULL);
Cc: Felipe Balbi <balbi@kernel.org>
Cc: linux-usb@vger.kernel.org
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
A built-in PHY driver cannot link against modular USB core code:
drivers/usb/phy/phy-tegra-usb.o: In function `tegra_usb_phy_probe':
phy-tegra-usb.c:(.text+0x6bc): undefined reference to `usb_get_dr_mode'
This uses a 'select' statement in Kconfig like we have for other such
PHY drivers.
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Tegra's EHCI driver has a build dependency on Tegra's PHY driver and
currently Tegra's PHY driver is built only when Tegra's EHCI driver is
built. Add own Kconfig entry for the Tegra's PHY driver so that drivers
other than ehci-tegra (like ChipIdea UDC) could work with ehci-tegra
driver being disabled in kernels config by allowing user to manually
select the PHY driver.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
UTMI pads are shared by USB controllers and reset of UTMI pads is shared
with the reset of USB1 controller. Currently reset of UTMI pads is done by
the EHCI driver and ChipIdea UDC works because EHCI driver always happen
to be probed first. Move reset controls from ehci-tegra to tegra-phy in
order to resolve the problem.
Tegra's PHY driver has a mix of pr_err() and dev_err(), let's switch to
dev_err() and use common errors message formatting across the driver for
consistency.
We should get drvdata from struct device directly. Going via
platform_device is an unneeded step back and forth.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
The legacy interface for associating controllers with phys from board
files and platform code has been unused since commit 9080b8dc761a ("ARM:
OMAP2+: Remove legacy usb-host.c platform init code"). Since then, all
calls to usb_get_phy_dev() and its devres version have been returning
-ENODEV.
Now that the final calls to these functions have been removed, we can
drop this legacy lookup interface altogether.
Signed-off-by: Johan Hovold <johan@kernel.org>
Drop the unused legacy usb_bind_phy() helper whose last user was removed
in 2016 when OMAP moved to device-tree boot (9080b8dc761a ("ARM: OMAP2+:
Remove legacy usb-host.c platform init code")).
Note that this means that for the last couple of years the phy_bind_list
has been empty (when using mainline kernels) and that consequently all
phy lookups using the usb_get_phy_dev() interface have failed with
-ENODEV. This helper along with its current users will be removed by
follow-on patches.
The AB8540 was an evolved version of the AB8500, but it was never
mass produced or put into products, only reference designs exist.
The upstream support was never completed and it is unlikely that
this will happen so drop the support for now to simplify
maintenance of the AB8500.
Cc: Loic Pallardy <loic.pallardy@st.com>
This fixes "utmi_phy_clk_enable: timeout waiting for phy to stabilize"
error message.
The nop_reset and shutdown methods are called in a context that can sleep,
so use gpiod_set_value_cansleep instead of gpiod_set_value.
If you've connected the reset line to a GPIO expander, you'd get a kernel
"slowpath" warning with gpiod_set_value.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
The local variable event is of type enum usb_phy_events. Use
the same enum value USB_EVENT_NONE instead of UX500_MUSB_NONE.
This avoids a warning when building with clang:
drivers/usb/phy/phy-ab8500-usb.c:906:30: warning: implicit conversion from
enumeration type 'enum ux500_musb_vbus_id_status' to different enumeration
type 'enum usb_phy_events' [-Wenum-conversion]
enum usb_phy_events event = UX500_MUSB_NONE;
Signed-off-by: Stefan Agner <stefan@agner.ch>
mxs_charger_secondary_detection() is only used in this file, so make
it static.
This fixes the following sparse warning:
drivers/usb/phy/phy-mxs-usb.c:581:23: warning: symbol 'mxs_charger_secondary_detection' was not declared. Should it be static?
Acked-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Commit e93650994a95 ("usb: phy: mxs: add usb charger type detection")
causes the following kernel hang on i.MX28:
[ 2.207973] usbcore: registered new interface driver usb-storage
[ 2.235659] Unable to handle kernel NULL pointer dereference at virtual address 00000188
[ 2.244195] pgd = (ptrval)
[ 2.246994] [00000188] *pgd=00000000
[ 2.250676] Internal error: Oops: 5 [#1] ARM
[ 2.254979] Modules linked in:
[ 2.258089] CPU: 0 PID: 1 Comm: swapper Not tainted 4.15.0-rc8-next-20180117-00002-g75d5f21 #7
[ 2.266724] Hardware name: Freescale MXS (Device Tree)
[ 2.271921] PC is at regmap_read+0x0/0x5c
[ 2.275977] LR is at mxs_phy_charger_detect+0x34/0x1dc
mxs_phy_charger_detect() makes accesses to the anatop registers via regmap,
however i.MX23/28 do not have such registers, which causes a NULL pointer
dereference.
Fix the issue by doing a NULL check on the 'regmap' pointer.
Fixes: e93650994a95 ("usb: phy: mxs: add usb charger type detection")
Cc: <stable@vger.kernel.org> # v4.15
Reviewed-by: Li Jun <jun.li@nxp.com>
Instead of "open coding" a DEVICE_ATTR() define, use the
DEVICE_ATTR_WO() macro instead, which does everything properly instead.
This does require a few static functions to be renamed to work properly,
but thanks to a script from Joe Perches, this was easily done.
Reported-by: Joe Perches <joe@perches.com>
Cc: Peter Chen <Peter.Chen@nxp.com>
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Johan Hovold <johan@kernel.org>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
DEVICE_ATTR_RO() macro instead, which does everything properly instead.
Cc: Matthieu CASTET <castet.matthieu@free.fr>
Cc: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Oliver Neukum <oneukum@suse.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
DEVICE_ATTR_RW() macro instead, which does everything properly instead.
Cc: Mathias Nyman <mathias.nyman@intel.com>
Acked-by: Bin Liu <b-liu@ti.com>
Factor out the guts of usb charger initialization into usb_charger_init()
function, to make the usb_add_extcon() only do the extcon related things.
Meanwhile we also should initialize the USB charger before registering
the extcon device, in case the extcon notification was issued earlier than
usb charger initialization.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY updates from Greg KH:
"Here is the big set of USB and PHY driver updates for 4.15-rc1.
There is the usual amount of gadget and xhci driver updates, along
with phy and chipidea enhancements. There's also a lot of SPDX tags
and license boilerplate cleanups as well, which provide some churn in
the diffstat.
Other major thing is the typec code that moved out of staging and into
the "real" part of the drivers/usb/ tree, which was nice to see
happen.
All of these have been in linux-next with no reported issues for a
while"
* tag 'usb-4.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (263 commits)
usb: gadget: f_fs: Fix use-after-free in ffs_free_inst
USB: usbfs: compute urb->actual_length for isochronous
usb: core: message: remember to reset 'ret' to 0 when necessary
USB: typec: Remove remaining redundant license text
USB: typec: add SPDX identifiers to some files
USB: renesas_usbhs: rcar?.h: add SPDX tags
USB: chipidea: ci_hdrc_tegra.c: add SPDX line
USB: host: xhci-debugfs: add SPDX lines
USB: add SPDX identifiers to all remaining Makefiles
usb: host: isp1362-hcd: remove a couple of redundant assignments
USB: adutux: remove redundant variable minor
usb: core: add a new usb_get_ptm_status() helper
usb: core: add a 'type' parameter to usb_get_status()
usb: core: introduce a new usb_get_std_status() helper
usb: core: rename usb_get_status() 'type' argument to 'recip'
usb: core: add Status Type definitions
USB: gadget: Remove redundant license text
USB: gadget: function: Remove redundant license text
USB: gadget: udc: Remove redundant license text
USB: gadget: legacy: Remove redundant license text
Now that the SPDX tag is in all USB files, that identifies the license
in a specific and legally-defined manner. So the extra GPL text wording
can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Jonathan Hunter <jonathanh@nvidia.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/usb/ and include/linux/usb* files with the correct
SPDX license identifier based on the license text in the file itself.
The SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
No Qualcomm SoC requires the "phy-qcom-8x16-usb.c" USB phy driver
support any more, so remove the code.
Suggested-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Alex Elder <elder@linaro.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Andy Gross <andy.gross@linaro.org>
No Qualcomm SoC requires the "phy-msm-usb.c" USB phy driver support
git://git.kernel.org/pub/scm/linux/kernel/git/chanwoo/extcon into usb-next
Chanwoo writes:
Update extcon for 4.15
Detailed description for this pull request:
1. Split out extcon header file for consumer and provider device
: The extcon has two type of extcon devices as following.
- 'extcon provider deivce' adds new extcon device and detect
the state/properties of external connector. Also, it notifies the
state/properties to the extcon consumer device.
- 'extcon consumer device' gets the change state/properties
from extcon provider device.
Prior to that, include/linux/extcon.h contains all exported API
for both provider and consumer device driver. To clarify the meaning
of header file and to remove the wrong use-case on consumer device.
- include/linux/extcon-provider.h includes API for the provider device driver.
- include/linux/extcon.h includes the API for the consumer device driver.
2. Support the SmartDock accessory on extcon-max77843.c device driver
- Support the SmartDock accessory which detects following connectors
at the same time.
: USB host throught USB hub for mouse, keyboard and so on.
: MHL connector for video output.
: Charger connector for battery charging.
- It tested with Unitek Y-2165 MHL+OTG Hub Smart Phone Dock.
3. Fix the minor issue of extcon driver
- Delete the unneeded initialization in extcon-max14577.
- Make extcon_info static const in order to fix the warning.
Felipe writes:
usb: changes for v4.15 merge window
Not much going on this time around. With only 51 non-merge commits,
this was one of the smallest pull requests from the Gadget tree.
Most of the changes are in the mtu3 driver which added support for
36-bit DMA, support for USB 3.1 and support for dual-role (along with
some non-critical fixes).
The dwc2 driver got a few improvements to how we handle gadget state
tracking and also added support for STM32F7xx devices.
Other than that, we just some minor non-critical fixes and
improvements all over the place.
If devm_extcon_dev_allocate() fails, we should disable clk before return.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Fixes: 860d2686fda7 ("usb: phy: tahvo: Use devm_extcon_dev_[allocate|register]() and replace deprecated API")
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Addresses-Coverity-ID: 1222118
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
- 'extcon provider deivce' adds new extcon device and detect the
Prior to that, include/linux/extcon.h contains all exported API for
both provider and consumer device driver. To clarify the meaning of
header file and to remove the wrong use-case on consumer device,
this patch separates into extcon.h and extcon-provider.h.
[Description for include/linux/{extcon.h|extcon-provider.h}]
- extcon.h includes the extcon API and data structure for extcon consumer
device driver. This header file contains the following APIs:
: Register/unregister the notifier to catch the change of extcon device
: Get the extcon device instance
: Get the extcon device name
: Get the state of each external connector
: Get the property value of each external connector
: Get the property capability of each external connector
- extcon-provider.h includes the extcon API and data structure for extcon
provider device driver. This header file contains the following APIs:
: Include 'include/linux/extcon.h'
: Allocate the memory for extcon device instance
: Register/unregister extcon device
: Set the state of each external connector
: Set the property value of each external connector
: Set the property capability of each external connector
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
mxs phy has data pin contact and usb charger detector blocks which
can be controlled by software to detect charger type for SDP, CDP and
DCP.
Reviewed-by: Baolin Wang <baolin.wang@linaro.org>
Signed-off-by: Li Jun <jun.li@nxp.com>
If the clock handle is given in the DT, it means the clock is required
for proper operation of the PHY. In that case a failure to obtain the
clock must be propagated to stop the driver from probing. This fixes
working with clocks, which request probe deferral.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: linux-omap@vger.kernel.org
We want the USB fixes in here as well.
Commit dfebb5f43a78 ("usb: chipidea: Add support for Tegra20/30/114/124")
added UDC support for Tegra but with UDC support enabled, is was found
that Tegra30, Tegra114 and Tegra124 would hang on entry to suspend.
The hang occurred during the suspend of the USB PHY when the Tegra PHY
driver attempted to disable the PHY clock. The problem is that before
the Tegra PHY driver is suspended, the chipidea driver already disabled
the PHY clock and when the Tegra PHY driver suspended, it could not read
DEVLC register and caused the device to hang.
The Tegra USB PHY driver is used by both the Tegra EHCI driver and now
the chipidea UDC driver and so simply removing the disabling of the PHY
clock from the USB PHY driver would not work for the Tegra EHCI driver.
Fortunately, the status of the USB PHY clock can be read from the
USB_SUSP_CTRL register and therefore, to workaround this issue, simply
poll the register prior to disabling the clock in USB PHY driver to see
if clock gating has already been initiated. Please note that it can take
a few uS for the clock to disable and so simply reading this status
register once on entry is not sufficient.
Similarly when turning on the PHY clock, it is possible that the clock
is already enabled or in the process of being enabled, and so check for
this when enabling the PHY.
Please note that no issues are seen with Tegra20 because it has a slightly
different PHY to Tegra30/114/124.
Fixes: dfebb5f43a78 ("usb: chipidea: Add support for Tegra20/30/114/124")
Tested-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Use setup_timer function instead of initializing timer with the
function and data fields.
Signed-off-by: Allen Pais <allen.lkml@gmail.com>
The .data assignment appears to be redundant to the WORK_STOP bit for
stopping the timer. Also, it appears this timer is entirely unused
as it is only ever started under #define VERBOSE, which is explicitly
undefined.
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Drivers
- RK805 Power Management IC (PMIC)
- ROHM BD9571MWV-M MFD Power Management IC (PMIC)
- Texas Instruments TPS68470 Power Management IC (PMIC) & LEDs
New Device Support:
- Add support for HiSilicon Hi6421v530 to hi6421-pmic-core
- Add support for X-Powers AXP806 to axp20x
- Add support for X-Powers AXP813 to axp20x
- Add support for Intel Sunrise Point LPSS to intel-lpss-pci
New Functionality:
- Amend API to provide register layout; atmel-smc
Fix-ups:
- DT re-work; omap, nokia
- Header file location change {I2C => MFD}; dm355evm_msp, tps65010
- Fix chip ID formatting issue(s); rk808
- Optionally register touchscreen devices; da9052-core
- Documentation improvements; twl-core
- Constification; rtsx_pcr, ab8500-core, da9055-i2c, da9052-spi
- Drop unnecessary static declaration; max8925-i2c
- Kconfig changes (missing deps and remove module support)
- Slim down oversized licence statement; hi6421-pmic-core
- Use managed resources (devm_*); lp87565
- Supply proper error checking/handling; t7l66xb
Bug Fixes:
- Fix counter duplication issue; da9052-core
- Fix potential NULL deference issue; max8998
- Leave SPI-NOR write-protection bit alone; lpc_ich
- Ensure device is put into reset during suspend; intel-lpss
- Correct register offset variable size; omap-usb-tll"
* tag 'mfd-next-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (61 commits)
mfd: intel_soc_pmic: Differentiate between Bay and Cherry Trail CRC variants
mfd: intel_soc_pmic: Export separate mfd-cell configs for BYT and CHT
dt-bindings: mfd: Add bindings for ZII RAVE devices
mfd: omap-usb-tll: Fix register offsets
mfd: da9052: Constify spi_device_id
mfd: intel-lpss: Put I2C and SPI controllers into reset state on suspend
mfd: da9055: Constify i2c_device_id
mfd: intel-lpss: Add missing PCI ID for Intel Sunrise Point LPSS devices
mfd: t7l66xb: Handle return value of clk_prepare_enable
mfd: Add ROHM BD9571MWV-M PMIC DT bindings
mfd: intel_soc_pmic_chtwc: Turn Kconfig option into a bool
mfd: lp87565: Convert to use devm_mfd_add_devices()
mfd: Add support for TPS68470 device
mfd: lpc_ich: Do not touch SPI-NOR write protection bit on Haswell/Broadwell
mfd: syscon: atmel-smc: Add helper to retrieve register layout
mfd: axp20x: Use correct platform device ID for many PEK
dt-bindings: mfd: axp20x: Introduce bindings for AXP813
mfd: axp20x: Add support for AXP813 PMIC
dt-bindings: mfd: axp20x: Add AXP806 to supported list of chips
mfd: Add ROHM BD9571MWV-M MFD PMIC driver
'ib-mfd-hwmon-4.14', 'ib-mfd-iio-pwm-4.14', 'ib-mfd-input-rtc-4.14', 'ib-mfd-many-4.14' and 'ib-mfd-pinctrl-regulator-4.14' into ibs-for-mfd-merged
include/linux/i2c is not for client devices. Move the header file to a
more appropriate location.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Felipe writes:
usb: changes for v4.14 merge window
Not a big pull request this time around. Only 49 non-merge
commits. This pull request is, however, all over the place. Most of
the changes are in the bdc driver adding support for USB Phy layer and
PM.
Renesas adds support for R-Car H3 ES2.0 and R-Car M3-W SoCs.
Also here is PM_RUNTIME support for dwc3-keystone.
UDC Core got a DMA unmap fix to make sure we only unmap requests that
were, indeed, mapped.
Other than these, we have a lot of cleanups, many of them adding
'const' to several places.
This patch introduces the usb charger support based on usb phy that
makes an enhancement to a power driver. The basic conception of the
usb charger is that, when one usb charger is added or removed by
reporting from the extcon device state change, the usb charger will
report to power user to set the current limitation.
Power user can register a notifiee on the usb phy by issuing
usb_register_notifier() to get notified by charger status changes
or charger current changes.
we can notify what current to be drawn to power user according to
different charger type, and now we have 2 methods to get charger type.
One is get charger type from extcon subsystem, which also means the
charger state changes. Another is we can get the charger type from
USB controller detecting or PMIC detecting, and the charger state
changes should be told by issuing usb_phy_set_charger_state().
