path: root/drivers/usb/otg/Kconfig
2013-03-18usb: phy: move all PHY drivers to drivers/usb/phy/Felipe Balbi
that's a much more reasonable location for those drivers. It helps us saving drivers/usb/otg/ for when we actually start adding generic OTG code. Also completely delete drivers/usb/otg/ as there's nothing left there. Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-12-13USB: fix fsl_otg config dependencyAnatolij Gustschin
USB_GADGET_FSL_USB2 has been changed to USB_FSL_USB2 by commit 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b (usb: gadget: allow multiple gadgets to be built). But old USB_GADGET_FSL_USB2 is still listed as dependency for fsl_otg driver, so the driver cannot be selected in the configuration currently. Fix it. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-10-30usb: otg: Fix build errors if USB_MUSB_OMAP2PLUS is selected as moduleRoger Quadros
TWL4030_USB & TWL6030_USB must depend on USB_MUSB_OMAP2PLUS in Kconfig else we get build errors with CONFIG_USB_MUSB_HDRC=m CONFIG_USB_MUSB_OMAP2PLUS=m CONFIG_TWL4030_USB=y CONFIG_TWL6030_USB=y LD init/built-in.o drivers/built-in.o: In function `twl4030_usb_irq': drivers/usb/otg/twl4030-usb.c:518: undefined reference to `omap_musb_mailbox' drivers/built-in.o: In function `twl4030_usb_phy_init': drivers/usb/otg/twl4030-usb.c:540: undefined reference to `omap_musb_mailbox' drivers/built-in.o: In function `twl6030_usb_irq': drivers/usb/otg/twl6030-usb.c:230: undefined reference to `omap_musb_mailbox' drivers/usb/otg/twl6030-usb.c:225: undefined reference to `omap_musb_mailbox' drivers/built-in.o: In function `twl6030_usbotg_irq': drivers/usb/otg/twl6030-usb.c:259: undefined reference to `omap_musb_mailbox' CC: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-06usb: otg: make twl6030_usb as a comparator driver to omap_usb2Kishon Vijay Abraham I
All the PHY configuration other than VBUS, ID GND and OTG SRP are removed from twl6030. The phy configurations are taken care by the dedicated usb2 phy driver. So twl6030 is made as comparator driver for VBUS and ID detection. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-07-09usb: otg: add basic mxs phy driver supportRichard Zhao
mxs phy is used in Freescale i.MX SoCs, for example imx23, imx28, imx6Q. This patch adds the basic host support. Signed-off-by: Richard Zhao <richard.zhao@freescale.com> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Peter Chen <peter.chen@freescale.com> Acked-by: Felipe Balbi <balbi@ti.com> Tested-by: Subodh Nijsure <snijsure@grid-net.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-01Merge tag 'xceiv-for-v3.4' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next USB: transceiver changes for 3.4 Here we have a big rework done by Heikki Krogerus (thanks) which splits OTG functionality away from transceivers. We have known for quite a long time that struct otg_transceiver was a bad name for the structure, considering transceiver is far from being OTG-specific (see 4e67185).
2012-02-13usb: otg: Rename otg_transceiver to usb_phyHeikki Krogerus
This is the first step in separating USB transceivers from USB OTG utilities. Includes fixes to IMX code from Sascha Hauer. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-02usb: otg: mv_otg: Add dependenceNeil Zhang
This otg driver depends on marvell EHCI driver, so add the dependence. It can fix the following build error on i386: ERROR: "usb_remove_hcd" [drivers/usb/otg/mv_otg.ko] undefined! ERROR: "usb_add_hcd" [drivers/usb/otg/mv_otg.ko] undefined! Signed-off-by: Neil Zhang <zhangwm@marvell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24drivers: usb: otg: Fix dependencies for some OTG driversFabio Estevam
Fix the following build warning: warning: (USB_LANGWELL_OTG && FSL_USB2_OTG && USB_MV_OTG) selects USB_OTG which has unmet direct dependencies (USB_SUPPORT && USB && EXPERIMENTAL && USB_SUSPEND) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-01-24usb: otg: kill langwell_otg driverAlexander Shishkin
The way this driver was added by f0ae849 (usb: Add Intel Langwell USB OTG Transceiver Driver) never even compiled together with langwell_udc, and that's the only way for it to be useful. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: stable@vger.kernel.org # v2.6.31+ Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-12-22Merge branch 'for-gadget/next' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next * 'for-gadget/next' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb: (24 commits) usb: dwc3: gadget: add support for SG lists usb: dwc3: gadget: don't force 'LST' always usb: dwc3: gadget: don't return anything on prepare trbs usb: dwc3: gadget: re-factor dwc3_prepare_trbs() usb: gadget: introduce support for sg lists usb: renesas: pipe: convert a long if into a XOR operation usb: gadget: remove useless depends on Kconfig usb: gadget: s3c-hsudc: remove the_controller global usb: gadget: s3c-hsudc: use release_mem_region instead of release_resource usb: gadget: s3c-hsudc: Add regulator handling usb: gadget: s3c-hsudc: use udc_start and udc_stop functions usb: gadget: s3c-hsudc: move device registration to probe usb: gadget: s3c-hsudc: add missing otg_put_transceiver in probe usb: gadget: s3c-hsudc: add __devinit to probe function usb: gadget: s3c-hsudc: move platform_data struct to global header USB: EHCI: Add Marvell Host Controller driver USB: OTG: add Marvell usb OTG driver support usb: gadget: mv_udc: drop ARCH dependency usb: gadget: mv_udc: fix bug in ep_dequeue usb: gadget: enlarge maxburst bit width. ...
2011-12-20usb: otg: trivial cleanupsFelipe Contreras
Spaces to tabs, proper alignment, and start sentences as they should. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-12-20USB: OTG: add Marvell usb OTG driver supportNeil Zhang
This driver is for ChipIdea USB OTG controller on Marvell Socs. PXA9xx/MMP2/MMP3/MGx all have this USB OTG controller. Signed-off-by: Neil Zhang <zhangwm@marvell.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-05-02USB: add Freescale USB OTG Transceiver driverLi Yang
Slightly reworked and cleaned up driver from Freescale LTIB for MPC5121E. The driver has been ported to the current kernel, proc interface "/proc/driver/fsl_usb2_otg" has been replaced by sysfs interface. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-11usb: otg: Add ulpi viewport access opsBenoit Goby
Add generic access ops for controllers with a ulpi viewport register (e.g. Chipidea/ARC based controllers). Signed-off-by: Benoit Goby <benoit@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07USB: Rename "msm72k_otg.c" to "msm_otg.c"Pavankumar Kondeti
This driver is used across all MSM SoCs. Hence give a generic name. All Functions and strutures are also using "msm_otg" as prefix. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04USB: Fix trout build failure with ci13xxx_msm gadgetPavankumar Kondeti
This patch fixes the below compilation errors. CC drivers/usb/gadget/ci13xxx_msm.o CC net/mac80211/led.o drivers/usb/gadget/ci13xxx_msm.c: In function 'ci13xxx_msm_notify_event': drivers/usb/gadget/ci13xxx_msm.c:42: error: 'USB_AHBBURST' undeclared (first use in this function) drivers/usb/gadget/ci13xxx_msm.c:42: error: (Each undeclared identifier is reported only once drivers/usb/gadget/ci13xxx_msm.c:42: error: for each function it appears in.) drivers/usb/gadget/ci13xxx_msm.c:43: error: 'USB_AHBMODE' undeclared (first use in this function) make[4]: *** [drivers/usb/gadget/ci13xxx_msm.o] Error 1 make[3]: *** [drivers/usb/gadget] Error 2 MSM USB driver is not supported on boards like trout (MSM7201) which has an external PHY. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-15Merge branch 'musb-hw' of git://gitorious.org/usb/usb into musbGreg Kroah-Hartman
* 'musb-hw' of git://gitorious.org/usb/usb: (43 commits) usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource arm: OMAP4430: musb: Configure musb to OTG mode usb: musb: Adding musb support for OMAP4430 usb: otg: TWL6030: Add twl6030_usb file for compilation mfd: TWL6030: OMAP4: Registering the TWL6030-usb device usb: musb: TWL6030: Selecting TWL6030_USB transceiver usb: otg: Kconfig: Add Kconfig option for TWL6030 transceiver. usb: otg: Adding twl6030-usb transceiver driver for OMAP4430 mfd: TWL6030: USBOTG VBUS event generation on usb: musb: add support for ux500 platform musb: am35x: fix compile error due to control apis arm: omap4: enable usb on 4430sdp usb: musb: drop board_set_vbus usb: musb: drop musb_platform_suspend/resume usb: musb: blackfin: usb dev_pm_ops structure usb: musb: am35x: usb dev_pm_ops structure usb: musb: omap2430: use dev_pm_ops structure usb: musb: omap2430: drop the nops usb: musb: mark musb_save/restore_context static ...
2010-12-10usb: add ab8500 usb transceiver driverMian Yousaf Kaukab
Basic driver for ab8500 usb otg transceiver TODO: -Regulators support -Host and OTG testing -Interface with PRCMU -Charging support Signed-off-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10USB: OTG: msm: Add support for power managementPavankumar Kondeti
Implement runtime and system pm ops to put hardware into low power mode (LPM). As part of LPM, USB clocks are turned off, PHY is put into suspend state and PHY comparators are turned off if VBUS/Id notifications are not required from PHY. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10USB: Add MSM OTG Controller driverPavankumar Kondeti
This driver implements PHY initialization, clock management, ULPI IO ops and simple OTG state machine to kick host/peripheral based on Id/VBUS line status. VBUS/Id lines are tied to a reference voltage on some boards. Hence provide debugfs interface to select host/peripheral mode. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10usb: otg: Kconfig: Add Kconfig option for TWL6030 transceiver.Hema HK
Added the TWL6030-usb transceiver option in the Kconfig Signed-off-by: Hema HK <hemahk@ti.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-10-22USB OTG Langwell: Update OTG Kconfig and driver version.Hao Wu
This patch updated Kconfig for langwell otg transceiver driver. Add ipc driver(INTEL_SCU_IPC) as a dependency. Driver version is updated too. Signed-off-by: Hao Wu <hao.wu@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb: Add Intel Langwell USB OTG Transceiver DriverHao Wu
This adds support for the USB transceiver driver in the Langwell chipset used on the Intel MID platforms. It folds up the original patch set which includes basic support for the device, PHY low power mode (Please notice that there is a limitation, after we drive VBus down, 2ms delay is required from SCU FW to sync up OTGSC register with USBCFG register), software timers (the hardware timers do not work in low power mode), HNP, SRP. Signed-off-by: Hao Wu <hao.wu@intel.com> Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: otg/ulpi: add support for SMSC USB3319 ulpi phyIgor Grinberg
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-16USB: otg Kconfig: let USB_OTG_UTILS select USB_ULPI optionValentin Longchamp
With CONFIG_USB_ULPI=y, CONFIG_USB<=m, CONFIG_PCI=n and CONFIG_USB_OTG_UTILS=n, which is the default used for mx31moboard, the build for all mx3 platforms fails because drivers/usb/otg/ulpi.c where otg_ulpi_create is defined is not compiled. Build error: arch/arm/mach-mx3/built-in.o: In function `mxc_board_init': kzmarm11.c:(.init.text+0x73c): undefined reference to `otg_ulpi_create' kzmarm11.c:(.init.text+0x1020): undefined reference to `otg_ulpi_create' This isn't a strong dependency as drivers/usb/otg/ulpi.c doesn't use functions defined in drivers/usb/otg/otg.o and is only needed to get ulpi.o linked into the kernel image. Signed-off-by: Valentin Longchamp <valentin.longchamp@epfl.ch> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB OTG: Add generic driver for ULPI OTG transceiverDaniel Mack
This adds a minimal generic driver for ULPI connected transceivers, using the OTG framework functions recently introduced. The driver got a table to match the ULPI chips, which currently only has one entry for NXP's ISP 1504 transceiver. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Revert "USB: Add Intel Langwell USB OTG Transceiver Drive"Greg Kroah-Hartman
This reverts commit 453f77558810ffa669ed5a510a7173ec49def396. The driver should not have been accepted as the MSRT code is not in the main kernel yet, which this depends on. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Hao Wu <hao.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: Add Intel Langwell USB OTG Transceiver DriveHao Wu
Description: This driver is used for Intel Langwell* USB OTG controller in Intel Moorestown* platform. It tries to implement host/device role switch according to OTG spec. The actual hsot and device functions are accomplished in modified EHCI driver and Intel Langwell USB OTG client controller driver. * Langwell and Moorestown are names used in development. They are not approved official name. Note: This patch is the first version Intel Langwell USB OTG Transceiver driver. The development is not finished, and the bug fixing is on going for some hardware and software issues. The main purpose of this submission is for code view. Supported features: - Data-line Pulsing SRP - Support HNP to switch roles - PCI D0/D3 power management support Known issues: - HNP is only tested with another Moorestown platform. - PCI D0/D3 power management support is not fully tested. - VBus Pulsing SRP is not support in current version. Signed-off-by: Hao Wu <hao.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: TWL: disable VUSB regulators when cable unpluggedJouni Hogander
This patch disables USB regulators VUSB1V5, VUSB1V8, and VUSB3V1 when the USB cable is unplugged to reduce power consumption. Added a depencency from twl4030 usb driver to TWL_REGULATOR. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@digia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: otg: adding nop usb transceiverAjay Kumar Gupta
NOP transceiver is used by all the usb transceiver which are mostly autonomous and doesn't require any programming or which are built into the usb ip itself.NOP transceiver only allocates the memory for struct xceiv and calls otg_set_transceiver() so function call to otg_get_transceiver() will return a valid transceiver. NOP transceiver device should be registered by calling usb_nop_xceiv_register() from platform files. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: omap1 ohci buildfix (otg related)David Brownell
> > drivers/built-in.o: In function `ohci_omap_init': > > hid-quirks.c:(.text+0x6c608): undefined reference to `otg_get_transceiver' > > drivers/built-in.o: In function `omap_udc_probe': > > hid-quirks.c:(.init.text+0x34c0): undefined reference to `otg_get_transceiver' > > hid-quirks.c:(.init.text+0x3d40): undefined reference to `otg_put_transceiver' Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: otg: twl4030 transceiver driverDavid Brownell
Add driver for the high speed USB-OTG transceiver in TI's TWL4030 family of chips. Given this and various other pending patches, OMAP3 hardware like that from beagleboard.org, gumstix.com (Overo), and openpandora.org should now have basic USB host and peripheral connectivity with mainline kernels. Ditto for less widely-available boards. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: otg: gpio_vbus transceiver stubPhilipp Zabel
gpio_vbus provides simple GPIO VBUS sensing for peripheral controllers with an internal transceiver. Optionally, a second GPIO can be used to control D+ pullup. It also interfaces with the regulator framework to limit charging currents when powered via USB. gpio_vbus requests the regulator supplying "vbus_draw" and can enable/disable it or limit its current depending on USB state. [dbrownell@users.sourceforge.net: use drivers/otg, cleanups ] Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: move isp1301_omap to drivers/usb/otgDavid Brownell
This moves the isp1301-omap driver from the drivers/i2c/chips directory (which will be shrinking) into a new drivers/usb/otg directory (which will grow, with more drivers and utilities). Note that OTG infrastructure needs to be initialized before either host or peripheral side USB support, and may be needed before for pure host or pure peripheral configurations. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
