qset_print() was not declared static although it is not used
outside of debug.c
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Print ep number, direction and type; and current window in asl and pzl
debugfs files.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
[akpm@linux-foundation.org: fix KVM]
Add asl, pzl and di debugfs files to uwb/uwbN/wusbhc for WHCI host
controller. These dump the current ASL, PZL and DI buffer.
