This pulls in a bunch of fixes that are in Linus's tree because we need them
here for testing and development.
This patch (as1651) adds calls to the new
usb_hcd_{start,end}_port_resume() functions to uhci-hcd. Now UHCI
root hubs won't be runtime suspended while they are sending a resume
signal to one of their ports.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
get rid of the line breaks in string constants.
let comments within 80 with limitation.
delete ' \' at the end of a statement.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1538) causes uhci_hub_status_data() to return a nonzero
value when any port is undergoing a resume transition while the root
hub is suspended. This will allow usbcore to handle races between
root-hub suspend and port wakeup.
This patch is part of a series that extend the UHCI HCD to support
non-PCI controllers.
This patch replaces in{b,w,l} and out{b,wl} with calls to local inline
functions. This is done so that the register access functions can be
extended to support register areas not mapped in PCI I/O space.
Signed-off-by: Jan Andersson <jan@gaisler.com>
non-PCI host controllers.
uhci-hub.c contained two PCI vendor checks for silicon quirks. Move
these checks into uhci-hcd.c and use bits in uhci_hcd structure to
mark that we need to use the quirks.
This patch is followed by other patches that will remove PCI
dependencies from uhci-hcd.c as well.
This patch (as1394) adds code to ehci-hcd, ohci-hcd, and uhci-hcd for
automatically resuming the root hub when the controller is resumed, if
the root hub has a wakeup request pending on some port.
During resume from system sleep this doesn't matter, because the root
hubs will naturally be resumed along with every other device in the
system. However it _will_ matter for runtime PM: If the controller is
suspended and a remote wakeup request is received then the controller
will autoresume, but we need to ensure that the root hub also
autoresumes. Otherwise the wakeup request would be ignored, the
controller would go back to sleep, and the cycle would repeat a large
number of times (I saw this happen before the patch was written).
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
This patch (as1330) fixes a bug in khbud's handling of remote
wakeups. When a device sends a remote-wakeup request, the parent hub
(or the host controller driver, for directly attached devices) begins
the resume sequence and notifies khubd when the sequence finishes. At
this point the port's SUSPEND feature is automatically turned off.
However the device needs an additional 10-ms resume-recovery time
(TRSMRCY in the USB spec). Khubd does not wait for this delay if the
SUSPEND feature is off, and as a result some devices fail to behave
properly following a remote wakeup. This patch adds the missing
delay to the remote-wakeup path.
It also extends the resume-signalling delay used by ehci-hcd and
uhci-hcd from 20 ms (the value in the spec) to 25 ms (the value we use
for non-remote-wakeup resumes). The extra time appears to help some
devices.
Cc: stable <stable@kernel.org>
Cc: Rickard Bellini <rickard.bellini@ericsson.com>
mark this array as const because it is read-only
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
This patch (as863) fixes a problem encountered sometimes when resuming
a port on a UHCI controller. The hardware may turn off the
Resume-Detect bit before turning off the Suspend bit, leading usbcore
to think that the port is still suspended and the resume has failed.
The patch makes uhci_finish_suspend() wait until both bits are safely
off.
Certain boards seem to like to issue false overcurrent notifications,
for example on ports that don't have anything connected to them. This
looks like a hardware error, at the level of noise to those ports'
overcurrent input signals (or non-debounced VBUS comparators). This
surfaces to users as truly massive amounts of syslog spam from khubd
(which is appropriate for real hardware problems, except for the
volume from multiple ports).
Using this new "ignore_oc" flag helps such systems work more sanely,
by preventing such indications from getting to khubd (and spamming
syslog). The downside is of course that true overcurrent errors will
be masked; they'll appear as spontaneous disconnects, without the
diagnostics that will let users troubleshoot issues like
short-circuited cables. In addition, controllers with no devices
attached will be forced to poll for new devices rather than relying on
interrupts, since each overcurrent event would generate a new
interrupt.
This patch (as826) is essentially a copy of David Brownell's ignore_oc
patch for ehci-hcd, ported to uhci-hcd.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
The UHCI controller in my laptop takes longer to turn off the
Resume-Detect bit than the 4 us allowed by uhci-hcd. Presumably other
computers will have the same problem.
This patch (as752) increases the maximum delay to 10 us, which should be
plenty, and uses polling to avoid penalizing systems which can turn the
bit off more quickly.
This patch (as706) removes the private hc_inaccessible flag from
uhci-hcd. It's not needed because it conveys exactly the same
information as the generic HCD_FLAG_HW_ACCESSIBLE bit.
In its place goes a new flag recording whether the controller is dead.
The new code allows a complete device reset to resurrect a dead
controller (although usbcore doesn't yet implement such a facility).
This patch (as683) re-implements Full-Speed Bandwidth Reclamation (FSBR)
properly. It keeps track of which endpoint queues have advanced, and
when none have advanced for a sufficiently long time, FSBR is turned
off. The next TD on each of the non-moving queues is modified to
generate an interrupt on completion, so that FSBR can be re-enabled as
soon as the hardware starts to make some progress.
Someone recently posted a bug report where it turned out that uhci-hcd
was disagreeing with the UHCI controller over whether or not a port was
suspended: The driver thought it wasn't and the hardware thought it was.
This patch (as665) fixes the problem and simplifies the driver by
removing the internal state-tracking completely. Now the driver just
asks the hardware whether a port is suspended.
This patch (as657) increases the port-reset completion delay in uhci-hcd
for HP's embedded controllers. Unlike other UHCI controllers, the HP
chips can take as long as 250 us to carry out the processing associated
with finishing a port reset.
This fixes Novell bug #148761.
This patch (as558) removes from the UHCI driver a kernel timer used for
checking Full Speed Bandwidth Reclamation (FSBR). The checking can be
done during normal root-hub polling; it doesn't need a separate timer.
This patch, which has as478b as a prerequisite, enables the uhci-hcd
driver to take advantage of root-hub IRQs rather than polling during the
time it is suspended. (Unfortunately the hardware doesn't support
port-change interrupts while the controller is running.) It also turns
off the driver's private timer while the controller is suspended, as it
isn't needed then. The combined elimination of polling interrupts and
timer interrupts ought to be enough to allow some systems to save a
noticeable amount of power while they are otherwise idle.
This patch implements (finally!) separate suspend and resume routines
for the root hub and the controller in the UHCI driver. It also
changes the sequence used to reset the controller during initial
probing, so as to preserve the existing state during a Resume-From-Disk.
(This new sequence is what should be used in the PCI Quirks code for
early USB handoffs, incidentally.) Lastly it adds a notion of the
controller being "inaccessible" while in a PCI low-power state, when
normal I/O operations shouldn't be allowed.
This patch starts making some serious changes to the UHCI driver.
There's a set of private states for the root hub, and the internal
routines for suspending and resuming work completely differently, with
transitions based on the new states. Now the driver distinguishes
between a privately auto-stopped state and a publicly suspended state,
and it will properly suspend controllers with broken resume-detect
interrupts instead of resetting them.
This patch makes a few small improvements in the UHCI driver. Some
code is moved between different source files and a more useful pointer
is passed to a callback routine.
infrastructure for it.
Let it rip!
