Individual controller driver has different requirement for wakeup
setting, so move it from core to itself. In order to align with
current etting the default wakeup setting is enabled (except for
chipidea host).
Pass compile test with below commands:
make O=outout/all allmodconfig
make -j$CPU_NUM O=outout/all drivers/usb
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Add a comment to explain why this driver doesn't call any of the DMA
API dma_set_mask() functions.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
dbg() was a very old USB-specific macro that should no longer
be used. This patch removes it from being used in the driver
and uses dev_dbg() instead.
CC: Alan Stern <stern@rowland.harvard.edu>
Add the .reset method to the HCD, and update the .start method
accordingly for this change.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add OHCI shutdown methods to cleanly shutdown the OHCI controller on
system shutdowns and reboots. This avoids the controller continuing
to run should be soft-reboot the platform, potentially scribbling
over system memory.
Combine usb_hcd_sa1111_probe() and ohci_hcd_sa1111_drv_probe(), doing
the same for the remove methods.
Move sa1111_start_hc and sa1111_stop_hc to be located next to these
the probe/release functions, as they're only called from them.
Get rid of the /*----*/ breaker lines.
Use dev_dbg() instead, it's more friendly.
Clean up the ohci-sa1111 driver formatting to be more compliant with
current standards, and add 'static' to various function definitions
to avoid sparse complaints about undeclared functions. Remove the
unnecessary local declaration of 'usb_disabled', which can be found
instead in linux/usb.h.
Move the USB interface register definitions into the driver, rather
than keeping them in a common place.
Acked-by: Nicolas Pitre <nico@linaro.org>
Move the handling of the 5v supply into badge4.c, removing this board
specific detail from the sa1111 ohci driver.
Add platform hooks to be called when individual sa1111 devices are
enabled and disabled. This will allow us to move some platform
specifics out of the individual drivers.
Add a .owner initializer to the sa1111 driver structures to allow
allow the modules to be associated with their driver structures.
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Reduces string space a bit
Neaten a macro redefine of dbg
This patch (as1069c) changes the way OHCI root-hub status-change
interrupts are enabled. Currently a special HCD method,
hub_irq_enable(), is called when the hub driver is finished using a
root hub. This approach turns out to be subject to races, resulting
in unnecessary polling.
The patch does away with the method entirely. Instead, the driver
automatically enables the RHSC interrupt when no more status changes
are present. This scheme is safe with controllers using
level-triggered semantics for their interrupt flags.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
This patch was created by
git grep -E -l 'Rus(el|s?e)l King' | xargs -r -t perl -p -i -e 's/Rus(el|s?e)l King/Russell King/g'
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
Most-Definitely-Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176.
Andrey Borzenkov reports that it resulted in a totally hung machine for
him when loading the OHCI driver. Extensive netconsole capture with
SysRq output shows that modprobe gets stuck in ohci_hub_status_data()
when probing and enabling the OHCI controller, see for example
http://lkml.org/lkml/2008/7/5/236
for an analysis.
The problem appears to be an interrupt flood triggered by the commit
that gets reverted, and Andrey confirmed that the revert makes things
work for him again.
Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
This patch (as1069b) changes the way OHCI root-hub status-change
The previous model had the module_init & module_exit function in the
bus glue .c files themselves. That's a problem if several glues need
to be selected at once and the driver is built has module. This case
is quite common in embedded system where you want to handle both the
integrated ohci controller and some extra controller on PCI.
The ohci-hcd.c file now provide the module_init & module_exit and
appropriate driver registering/unregistering is done conditionally,
using #ifdefs.
Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace
(space before tab, at end of line) as well as the obsolete inline changelog.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This teaches OHCI to use the root hub status change (RHSC) IRQ, bypassing
root hub timers most of the time and switching over to the "new" root hub
polling scheme. It's complicated by the fact that implementations of OHCI
trigger and ack that IRQ differently (the spec is vague there).
Avoiding root hub timers helps mechanisms like "dynamic tick" leave the
CPU in lowpower modes for longer intervals.
Cc: Greg KH <greg@kroah.com>
This patch (as580) is perhaps the only result from the long discussion I
had with David about his changes to the root-hub suspend/resume code. It
renames the hub_suspend and hub_resume methods in struct usb_hcd to
bus_suspend and bus_resume. These are more descriptive names, since the
methods really do suspend or resume an entire USB bus, and less likely to
be confused with the hub_suspend and hub_resume routines in hub.c.
It also takes David's advice about removing the layer of bus glue, where
those methods are called. And it implements a related change that David
made to the other HCDs but forgot to put into dummy_hcd.
This cleans up a small recent FIXME, ensuring that all the HCDs provide
root hub suspend/resume methods. It also wraps the calls to those root
suspend routines just like on the PCI "USB_SUSPEND not defined" cases,
so non-PCI bus glue won't be as tempted to behave very differently.
Several of the SOC based OHCI drivers forgot to list those methods;
the patch also adds those missing declarations.
drivers/usb/core/hcd.c | 42 +++++++++++++++++++++++++---------------
drivers/usb/host/ohci-au1xxx.c | 5 ++++
drivers/usb/host/ohci-lh7a404.c | 5 ++++
drivers/usb/host/ohci-pxa27x.c | 1
drivers/usb/host/ohci-s3c2410.c | 1
drivers/usb/host/ohci-sa1111.c | 1
6 files changed, 40 insertions(+), 15 deletions(-)
This simplifies some of the PM-related #ifdeffing by recognizing
that USB_SUSPEND depends on PM. Also, OHCI drivers were often
testing for USB_SUSPEND when they should have tested just PM.
drivers/usb/core/hcd.c | 2 ++
drivers/usb/host/ohci-hcd.c | 2 +-
drivers/usb/host/ohci-hub.c | 4 ++--
drivers/usb/host/ohci-omap.c | 2 +-
drivers/usb/host/ohci-pci.c | 2 +-
drivers/usb/host/ohci-ppc-soc.c | 4 ++--
drivers/usb/host/ohci-pxa27x.c | 2 +-
drivers/usb/host/ohci-s3c2410.c | 3 +--
drivers/usb/host/ohci-sa1111.c | 2 +-
9 files changed, 12 insertions(+), 11 deletions(-)
infrastructure for it.
Let it rip!
