This pulls in the latest USB bugfixes and helps a few of the drivers
merge nicer in the future due to changes in both branches.
Problems with NVIDIA's OHCI host controllers persist. After looking
carefully through the spec, I finally realized that when a controller
is reset it then automatically goes into a SUSPEND state in which it
is completely quiescent (no DMA and no IRQs) and from which it will
not awaken until the system puts it into the OPERATIONAL state.
Therefore there's no need to worry about controllers being in the
RESET state for extended periods, or remaining in the OPERATIONAL
state during system shutdown. The proper action for device
initialization is to put the controller into the RESET state (if it's
not there already) and then to issue a software reset. Similarly, the
proper action for device shutdown is simply to do a software reset.
This patch (as1499) implements such an approach. It simplifies
initialization and shutdown, and allows the NVIDIA shutdown-quirk code
to be removed.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Andre "Osku" Schmidt <andre.osku.schmidt@googlemail.com>
Tested-by: Arno Augustin <Arno.Augustin@web.de>
Cc: stable <stable@vger.kernel.org> [after tested in 3.2 for a while]
This patch (as1500) removes all uses of the objectionable hcd->state
variable from the ohci-hcd family of drivers. It is replaced by a
private ohci->rh_state field, just as in uhci-hcd and ehci-hcd.
This patch (as1463) fixes a regression caused by commit
3df7169e73fc1d71a39cffeacc969f6840cdf52b (OHCI: work around for nVidia
shutdown problem).
The original problem encountered by people using NVIDIA chipsets was
that USB devices were not turning off when the system shut down. For
example, the LED on an optical mouse would remain on, draining a
laptop's battery. The problem was caused by a bug in the chipset; an
OHCI controller in the Reset state would continue to drive a bus reset
signal even after system shutdown. The workaround was to put the
controllers into the Suspend state instead.
It turns out that later NVIDIA chipsets do not suffer from this bug.
Instead some have the opposite bug: If a system is shut down while an
OHCI controller is in the Suspend state, USB devices remain powered!
On other systems, shutting down with a Suspended controller causes the
system to reboot immediately. Thus, working around the original bug
on some machines exposes other bugs on other machines.
The best solution seems to be to limit the workaround to OHCI
controllers with a low-numbered PCI product ID. I don't know exactly
at what point NVIDIA changed their chipsets; the value used here is a
guess. So far it was worked out okay for all the people who have
tested it.
This fixes Bugzilla #35032.
Tested-by: Yury Siamashka <yurand2@gmail.com>
CC: <stable@kernel.org>
Commit ab1666c1364a209e6141d7c14e47a42b5f00eca2 (USB: quirk PLL power down mode)
added code that reads the revision ID from the PCI configuration register while
it's stored by PCI subsystem in the 'revision' field of 'struct pci_dev'...
This patch moves the AMD PLL quirk code in OHCI/EHCI driver to pci-quirks.c,
and exports the functions to be used by xHCI driver later.
AMD PLL quirk disable the optional PM feature inside specific
SB700/SB800/Hudson-2/3 platforms under the following conditions:
1. If an isochronous device is connected to OHCI/EHCI/xHCI port and is active;
2. Optional PM feature that powers down the internal Bus PLL when the link is
in low power state is enabled.
Without AMD PLL quirk, USB isochronous stream may stutter or have breaks
occasionally, which greatly impair the performance of audio/video streams.
Currently AMD PLL quirk is implemented in OHCI and EHCI driver, and will be
added to xHCI driver too. They are doing similar things actually, so move
the quirk code to pci-quirks.c, which has several advantages:
1. Remove duplicate defines and functions in OHCI/EHCI (and xHCI) driver and
make them cleaner;
2. AMD chipset information will be probed only once and then stored.
Currently they're probed during every OHCI/EHCI initialization, move
the detect code to pci-quirks.c saves the repeat detect cost;
3. Build up synchronization among OHCI/EHCI/xHCI driver. In current
code, every host controller enable/disable PLL only according to
its own status, and may enable PLL while there is still isoc transfer on
other HCs. Move the quirk to pci-quirks.c prevents this issue.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alex He <alex.he@amd.com>
This reverts commit b7d5b439b7a40dd0a0202fe1c118615a3fcc3b25.
It conflicts with commit baab93afc2844b68d57b0dcca5e1d34c5d7cf411 "USB:
EHCI: ASPM quirk of ISOC on AMD Hudson" and merging the two just doesn't
work properly.
Cc: Andiry Xu <andiry.xu@amd.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
make them cleaner;
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1417) fixes a problem affecting some (or all) nVidia
chipsets. When the computer is shut down, the OHCI controllers
continue to power the USB buses and evidently they drive a Reset
signal out all their ports. This prevents attached devices from going
to low power. Mouse LEDs stay on, for example, which is disconcerting
for users and a drain on laptop batteries.
The fix involves leaving each OHCI controller in the OPERATIONAL state
during system shutdown rather than putting it in the RESET state.
Although this nominally means the controller is running, in fact it's
not doing very much since all the schedules are all disabled. However
there is ongoing DMA to the Host Controller Communications Area, so
the patch also disables the bus-master capability of all PCI USB
controllers after the shutdown routine runs.
The fix is applied only to nVidia-based PCI OHCI controllers, so it
shouldn't cause problems on systems using other hardware. As an added
safety measure, in case the kernel encounters one of these running
controllers during boot, the patch changes quirk_usb_handoff_ohci()
(which runs early on during PCI discovery) to reset the controller
before anything bad can happen.
Reported-by: Pali Rohár <pali.rohar@gmail.com>
CC: David Brownell <david-b@pacbell.net>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
CC: stable <stable@kernel.org>
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend
method used by PCI-based host controller drivers. ehci-hcd in
particular needs to know whether or not to enable wakeup when
suspending a controller. Although that information is currently
available through device_may_wakeup(), when support is added for
runtime suspend this will no longer be true.
The following patch in the driver is required to avoid USB 1.1 device
failures that may occur due to requests from USB OHCI controllers may
be overwritten if the latency for any pending request by the USB
controller is very long (in the range of milliseconds).
Signed-off-by: Libin Yang <libin.yang@amd.com>
Cc: stable <stable@kernel.org>
This patch (as1237) changes the way the PCI host controller drivers
avoid retaining bogus hardware states during resume-from-hibernation.
Previously we had reset the hardware as part of preparing to reinstate
the memory image. But we can do better now with the new PM framework,
since we know exactly which resume operations are from hibernation.
The pci_resume method is changed to accept a flag indicating whether
the system is resuming from hibernation. When this flag is set, the
drivers will reset the hardware to get rid of any existing state.
Similarly, the pci_suspend method is changed to remove the
pm_message_t argument. It's no longer needed, since no special action
has to be taken when preparing to reinstate the memory image.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
This patch (as1236) converts the USB PCI power management routines
over to the new PM framework.
If a USB PCI controller is behind a cardbus bridge, we are trying to
restore its configuration registers too early, before the cardbus
bridge is operational. To fix this, call pci_restore_state() from
usb_hcd_pci_resume() and remove usb_hcd_pci_resume_early() which is
no longer necessary (the configuration spaces of USB controllers that
are not behind cardbus bridges will be restored by the PCI PM core
with interrupts disabled anyway).
This patch fixes the regression from 2.6.28 tracked as
http://bugzilla.kernel.org/show_bug.cgi?id=12659
[ Side note: the proper long-term fix is probably to just force the
unplug event at suspend time instead of doing a plug/unplug at resume
time, but this patch is fine regardless - Linus ]
Reported-by: Miles Lane <miles.lane@gmail.com>
Commit a0d4922da2e4ccb0973095d8d29f36f6b1b5f703
(USB: fix up suspend and resume for PCI host controllers) attempted
to fix the suspend-resume of PCI USB controllers, but unfortunately
it did that incorrectly and interrupts are left enabled by the USB
controllers' ->suspend_late() callback as a result. This leads to
serious problems during suspend which are very difficult to debug.
Fix the issue by removing the ->suspend_late() callback of PCI
USB controllers and moving the code from there to the ->suspend()
callback executed with interrupts enabled. Additionally, make
the ->resume() callback of PCI USB controllers execute
pci_enable_wake(dev, PCI_D0, false) to disable wake-up from the
full power state (PCI_D0).
Tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Tested-by: "Jeff Chua" <jeff.chua.linux@gmail.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Zdenek Kabelac" <zdenek.kabelac@gmail.com>
This patch (as1193b) enables wakeup during initialization for all PCI
host controllers, and it removes some code (and comments!) that are no
longer needed now that the PCI core automatically initializes wakeup
settings for all new devices.
The idea is that the bus should initialize wakeup, and the bus glue
or controller driver should enable it.
This patch (as1192) rearranges the USB PCI host controller suspend and
resume and resume routines:
Use pci_wake_from_d3() for enabling and disabling wakeup,
instead of pci_enable_wake().
Carry out the actual state change while interrupts are
disabled.
Change the order of the preparations to agree with the
general recommendation for PCI devices, instead of
messing around with the wakeup settings while the device
is in D3.
In .suspend:
Call the underlying driver to disable IRQ
generation;
pci_wake_from_d3(device_may_wakeup());
pci_disable_device();
In .suspend_late:
pci_save_state();
pci_set_power_state(D3hot);
(for PPC_PMAC) Disable ASIC clocks
In .resume_early:
(for PPC_PMAC) Enable ASIC clocks
pci_set_power_state(D0);
pci_restore_state();
In .resume:
pci_enable_device();
pci_set_master();
pci_wake_from_d3(0);
Call the underlying driver to reenable IRQ
generation
Add the necessary .suspend_late and .resume_early method
pointers to the PCI host controller drivers.
CC: Rafael J. Wysocki <rjw@sisk.pl>
This patch (as1069c) changes the way OHCI root-hub status-change
interrupts are enabled. Currently a special HCD method,
hub_irq_enable(), is called when the hub driver is finished using a
root hub. This approach turns out to be subject to races, resulting
in unnecessary polling.
The patch does away with the method entirely. Instead, the driver
automatically enables the RHSC interrupt when no more status changes
are present. This scheme is safe with controllers using
level-triggered semantics for their interrupt flags.
On some AMD 700 series southbridges, ISO OUT transfers (such as audio
playback through speakers) on the USB OHCI controller may be corrupted
when an A-Link express power saving feature is active.
PLL power down mode in conjunction with link power management feature
L1 being enabled is the bad combination ... this patch prevents them
from being enabled when ISO transfers are pending.
Signed-off-by: Crane Cai <crane.cai@amd.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176.
Andrey Borzenkov reports that it resulted in a totally hung machine for
him when loading the OHCI driver. Extensive netconsole capture with
SysRq output shows that modprobe gets stuck in ohci_hub_status_data()
when probing and enabling the OHCI controller, see for example
http://lkml.org/lkml/2008/7/5/236
for an analysis.
The problem appears to be an interrupt flood triggered by the commit
that gets reverted, and Andrey confirmed that the revert makes things
work for him again.
Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
This patch (as1069b) changes the way OHCI root-hub status-change
Drivers in the ohci-hcd family should perform certain tasks whenever
their controller device is resumed. These include checking for loss
of power during suspend, turning on port power, and enabling interrupt
requests.
Until now these jobs have been carried out when the root hub is
resumed, not when the controller is. Many drivers work around the
resulting awkwardness by automatically resuming their root hub
whenever the controller is resumed. But this is wasteful and
unnecessary.
To simplify the situation, this patch (as1066) adds a new core
routine, ohci_finish_controller_resume(), which can be used by all the
OHCI-variant drivers. They can call the new routine instead of
resuming their root hubs. And ohci-pci.c can call it instead of using
its own special-purpose handler.
The .suspend and .resume method pointers in struct usb_hcd have not
been fully understood by host-controller driver writers. They are
meant for use with PCI controllers; other platform-specific drivers
generally should not refer to them.
To try and clarify matters, this patch (as1065) renames those methods
to .pci_suspend and .pci_resume. It eliminates corresponding dead code
and bogus references in the ohci-ssb and u132-hcd drivers.
This patch (as1063) fixes a bug in the way ohci-hcd resumes its
controllers. It leaves the Master Interrupt Enable bit turned off.
If the root hub is resumed immediately this won't matter. But if the
root hub is suspended (say because no devices are plugged in), it won't
ever wake up by itself.
The ZF Micro OHCI controller exhibits unexpected behavior that seems to be
related to high load. Under certain conditions, the controller will
complete a TD, remove it from the endpoint's queue, and fail to add it to
the donelist. This causes the endpoint to appear to stop responding. Worse,
if the device is removed while in that state, OHCI will hang while waiting
for the orphaned TD to complete. The situation is not recoverable without
rebooting.
This fix enhances the scope of the existing OHCI_QUIRK_ZFMICRO flag:
1. A watchdog routine periodically scans the OHCI structures to check
for orphaned TDs. In these cases the TD is taken back from the
controller and completed normally.
2. If a device is removed while the endpoint is hung but before the
watchdog catches the situation, any outstanding TDs are taken back
from the controller in the 'sanitize' phase.
The ohci-hcd driver used to print "INTR_SF lossage" in this situation;
this changes it to the universally accurate "ED unlink timeout". Other
instances of this message presumably have different root causes.
Both this Compaq quirk and a NEC quirk are now properly compiled out for
non-PCI builds of this driver.
Signed-off-by: Mike Nuss <mike@terascala.com>
This patch fixes a silicon bug in some NEC OHCI chips. The bug appears
at random times and is very, very difficult to reproduce. Without the
following patch, Linux would shut the chip and its associated devices
down. In Apple PowerBooks this leads to an unusable keyboard and mouse
(SSH still working). The idea of restarting the chip is taken from
public Darwin code.
Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch>
This patch (as887) changes the way ehci-hcd and ohci-hcd handle a loss
of VBUS power during suspend. In order for the USB-persist facility
to work correctly, it is necessary for low- and full-speed devices
attached to a high-speed port to be handed back to the companion
controller during resume processing.
This entails three changes: adding code to ehci-hcd to perform the
handover, removing code from ohci-hcd to turn off ports during
root-hub reinit, and adding code to ohci-hcd to turn on ports during
PCI controller resume. (Other bus glue resume methods for platforms
supporting high-speed controllers would need a similar change, if any
existed.)
This fixes a bug in an OHCI quirk handler for Portege 4000; the
Subvendor is 0x1179 (PCI_VENDOR_ID_TOSHIBA)
not 0x102f (PCI_VENDOR_ID_TOSHIBA_2)
bugid 8510
00:02.0 USB Controller [0c03]: ALi Corporation USB 1.1 Controller
[10b9:5237] (rev 03) (prog-if 10 [OHCI])
Subsystem: Toshiba America Info Systems Unknown device [1179:0004]
Flags: bus master, medium devsel, latency 64, IRQ 11
Memory at f7eff000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
Here's a patch which adds my device to the list.
This patch enables the broken suspend quirk for the PCI OHCI controller
present in the IT8152F/G RISC-to-PCI Companion Chip.
Signed-off-by: Raphael Assenat <raph@8d.com>
Use the new ohci-pci quirk infrastructure to address the problem it was
created to address: a quirk specific to the Portege 4000, in buzilla as
http://bugzilla.kernel.org/show_bug.cgi?id=6723
Also fix a misuse of "__devinit" for the quirk functions. It must not
be used without first ensuring that the references from the quirk tables
are gone, and that the function using those quirk tables is also gone.
The previous model had the module_init & module_exit function in the
bus glue .c files themselves. That's a problem if several glues need
to be selected at once and the driver is built has module. This case
is quite common in embedded system where you want to handle both the
integrated ohci controller and some extra controller on PCI.
The ohci-hcd.c file now provide the module_init & module_exit and
appropriate driver registering/unregistering is done conditionally,
using #ifdefs.
Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This patch separates support for big endian MMIO register access
and big endian descriptors in order to support the Toshiba SCC
implementation which has big endian registers but little endian
in-memory descriptors.
It simplifies the access functions a bit in ohci.h while at it.
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
This patch applies David Brownell's suggestion for reworking the
OHCI quirk mechanism via a table of PCI IDs. It adapts the existing
quirks to use that mechanism.
This also moves the quirks to reset() as suggested by the comment
in there. This is necessary as we need to have the endian properly
set before we try to init the controller.
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace
(space before tab, at end of line) as well as the obsolete inline changelog.
We want to avoid legacy APIs like pci_find_slot().
Signed-off-by: Alan Cox <alan@redhat.com>
If some problem occurs during ehci startup, for instance, request_irq fails,
echi hcd driver tries it best to cleanup, but fails to unregister reboot
notifier, which in turn leads to crash on reboot/poweroff.
The following patch resolves this problem by not using reboot notifiers
anymore, but instead making ehci/ohci driver get its own shutdown method. For
PCI, it is done through pci glue, for everything else through platform driver
glue.
One downside: sa1111 does not use platform driver stuff, and does not have its
own shutdown hook, so no 'shutdown' is called for it now. I'm not sure if it
is really necessary on that platform, though.
Signed-off-by: Aleks Gorelov <dared1st@yahoo.com>
Cc: David Brownell <david-b@pacbell.net>
This teaches OHCI to use the root hub status change (RHSC) IRQ, bypassing
root hub timers most of the time and switching over to the "new" root hub
polling scheme. It's complicated by the fact that implementations of OHCI
trigger and ack that IRQ differently (the spec is vague there).
Avoiding root hub timers helps mechanisms like "dynamic tick" leave the
CPU in lowpower modes for longer intervals.
This teaches several USB host controller drivers to treat PRETHAW as a chip
reset since the controller, and all devices connected to it, are no longer in
states compatible with how the snapshotted suspend() left them.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
We could use the recently added PCI_CLASS_SERIAL_USB_UHCI,
PCI_CLASS_SERIAL_USB_OHCI and PCI_CLASS_SERIAL_USB_EHCI defines in
more places, for slightly shorter and clearer code.
This makes OHCI use the driver model wakeup control bits for its root hub
(e.g. disable on amd756, because of chip erratum) and for the controller
itself. It no longer uses the hcd glue bits with those roles, and depends
on the previous patch making the root hub available earlier.
Note that on most platforms (boot code properly setting the RWC bit) this
gives a partial workaround for the way PCI isn't currently flagging devices
that support PME# signals. (Because of odd PCI init sequencing on PPC.)
That's because many OHCI controllers support "legacy PCI PM" ... without
involving any PCI PM capability.
USB wakeup from STR, if it works on your system, may still involve
tweaking things by hand in /proc/acpi/wakeup.
This patch closes the IRQ race and makes various other OHCI & EHCI code
path safer vs. suspend/resume.
I've been able to (finally !) successfully suspend and resume various
Mac models, with or without USB mouse plugged, or plugging while asleep,
or unplugging while asleep etc... all without a crash.
Alan, please verify the UHCI bit I did, I only verified that it builds.
It's very simple so I wouldn't expect any issue there. If you aren't
confident, then just drop the hunks that change uhci-hcd.c
I also made the patch a little bit more "safer" by making sure the store
to the interrupt register that disables interrupts is not posted before
I set the flag and drop the spinlock.
Without this patch, you cannot reliably sleep/wakeup any recent Mac, and
I suspect PCs have some more sneaky issues too (they don't frankly crash
with machine checks because x86 tend to silently swallow PCI errors but
that won't last afaik, at least PCI Express will blow up in those
situations, but the USB code may still misbehave).
This should fix a suspend/resume issues that appear with OHCI on some
PPC hardware. The PCI layer should doesn't have the hooks needed for
such ASIC-specific hooks (in this case, software clock gating), so
this moves the code to do that into hcd-pci.c ... where it can be
done after the relevant PCI PM state transition (to/from D3).
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Add .owner initialisation to the device drivers
in drivers/usb/host so that when built as module
the device_driver refers to the owning module
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
This patch (as580) is perhaps the only result from the long discussion I
had with David about his changes to the root-hub suspend/resume code. It
renames the hub_suspend and hub_resume methods in struct usb_hcd to
bus_suspend and bus_resume. These are more descriptive names, since the
methods really do suspend or resume an entire USB bus, and less likely to
be confused with the hub_suspend and hub_resume routines in hub.c.
It also takes David's advice about removing the layer of bus glue, where
those methods are called. And it implements a related change that David
made to the other HCDs but forgot to put into dummy_hcd.
This simplifies the OHCI root hub suspend logic:
- Uses new usbcore root hub calls to make autosuspend work again:
* Uses a newish usbcore root hub wakeup mechanism,
making requests to khubd not keventd.
* Uses an even newer sibling suspend hook.
- Expect someone always made usbcore call ohci_hub_suspend() before bus
glue fires; and that ohci_hub_resume() is only called after that bus
glue ran. Previously, only CONFIG_USB_SUSPEND promised those things.
(Includes updates to PCI and OMAP bus glue.)
- Handle a not-noticed-before special case during resume from one of
the swsusp snapshots when using "usb-handoff": the controller isn't
left in RESET state. (A bug to fix in the usb-handoff code...)
Also cleans up a minor debug printk glitch, and switches an mdelay over
to an msleep (how did that stick around for so long?).
drivers/usb/host/ohci-dbg.c | 4 ----
drivers/usb/host/ohci-hcd.c | 2 +-
drivers/usb/host/ohci-hub.c | 42 ++++++++++++------------------------------
drivers/usb/host/ohci-mem.c | 1 -
drivers/usb/host/ohci-omap.c | 36 ++++++++++++------------------------
drivers/usb/host/ohci-pci.c | 40 ++++++++--------------------------------
drivers/usb/host/ohci.h | 1 -
7 files changed, 33 insertions(+), 93 deletions(-)
This simplifies some of the PM-related #ifdeffing by recognizing
that USB_SUSPEND depends on PM. Also, OHCI drivers were often
testing for USB_SUSPEND when they should have tested just PM.
drivers/usb/core/hcd.c | 2 ++
drivers/usb/host/ohci-hub.c | 4 ++--
drivers/usb/host/ohci-omap.c | 2 +-
drivers/usb/host/ohci-pci.c | 2 +-
drivers/usb/host/ohci-ppc-soc.c | 4 ++--
drivers/usb/host/ohci-pxa27x.c | 2 +-
drivers/usb/host/ohci-s3c2410.c | 3 +--
drivers/usb/host/ohci-sa1111.c | 2 +-
9 files changed, 12 insertions(+), 11 deletions(-)
This patch removes the extra usb_suspend_device() parameter. The original
reason to pass that parameter was so that this routine could suspend any
active children. A previous patch removed that functionality ... leaving
no reason to pass the parameter. A close analogy is pci_set_power_state,
which doesn't need a pm_message_t either.
On the internal code path that comes through the driver model, the parameter
is now used to distinguish cases where USB devices need to "freeze" but not
suspend. It also checks for an error case that's accessible through sysfs:
attempting to suspend a device before its interfaces (or for hubs, ports).
drivers/usb/core/hub.c | 34 +++++++++++++++++++++-------------
drivers/usb/core/usb.c | 23 +++++++++++++++++++++--
drivers/usb/host/ehci-hcd.c | 2 +-
drivers/usb/host/isp116x-hcd.c | 2 +-
include/linux/usb.h | 2 +-
6 files changed, 46 insertions(+), 19 deletions(-)
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now
split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some
powerbooks have, CONFIG_PM for power management related code, and just left
out of any CONFIG_* option for some generally useful stuff that can be used
on non-laptops as well.
