path: root/drivers/usb/host/ohci-hcd.c
2013-10-14Revert "USB: OHCI: Properly handle OHCI controller suspend"Greg Kroah-Hartman
This reverts commit 476e4bf939c9b947ea49923700fbac655cc9057c. Manjunath is no longer at Linaro, the email address bounces. Given that, and the fact that others have reported problems with these patches, I'm reverting them until someone from Linaro who can SUPPORT THEM submits them. I will no longer accept patches from linaro.com developers unless a senior Linaro developer has signed off on them, which did not happen with this patch set. Reported-by: Olof Johansson <olof@lixom.net> Cc: Manjunath Goudar <manjunath.goudar@linaro.org> Cc: Manjunath Goudar <csmanjuvijay@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de>
2013-10-05USB: OHCI: Properly handle OHCI controller suspendManjunath Goudar
Suspend scenario in case of OHCI was not properly handled in ochi_suspend()routine. Alan Stern suggested, properly handle OHCI suspend scenario. This does generic proper handling of suspend scenario to all OHCI SOC. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Manjunath Goudar <csmanjuvijay@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-30USB: OHCI: ohci_init_driver(): sanity check overridesKevin Hilman
Check for non-NULL overrides before dereferencing since platforms may pass in NULL overrides. Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-29Merge 3.12-rc3 into usb-nextGreg Kroah-Hartman
We want the USB fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-pxa27x a separate driverManjunath Goudar
Separate the OHCI pxa27x/pxa3xx host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-ep93xx a separate driverManjunath Goudar
Separate the OHCI EP93XX host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-nxp a separate driverManjunath Goudar
Separate the OHCI NXP host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Many place function name and struct name started with usb, current scenario replaced usb with ohci for proper naming. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-s3c2410 a separate driverManjunath Goudar
Separate the Samsung OHCI S3C24xx/S3C64xx host controller driver from ohci-hcd host code so that it can be built as a separate driver module.This work is part of enabling multi-platform. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-at91 a separate driverManjunath Goudar
Separate the TI OHCI Atmel host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-spear a separate driverManjunath Goudar
Separate the ST OHCI SPEAr host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-omap3 a separate driverManjunath Goudar
Separate the TI OHCI OMAP3 host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-omap a separate driverManjunath Goudar
Separate the TI OHCI OMAP1/2 host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Felipe Balbi <balbi@ti.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: OHCI: make ohci-exynos a separate driverManjunath Goudar
Separate the Samsung OHCI EXYNOS host controller driver from ohci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Jingoo Han <jg1.han@samsung.com> Cc: Vivek Gautam <gautam.vivek@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25USB: OHCI: accept very late isochronous URBsAlan Stern
Commit 24f531371de1 (USB: EHCI: accept very late isochronous URBs) changed the isochronous API provided by ehci-hcd. URBs submitted too late, so that the time slots for all their packets have already expired, are no longer rejected outright. Instead the submission is accepted, and the URB completes normally with a -EXDEV error for each packet. This is what client drivers expect. This patch implements the same policy in ohci-hcd. The change is more complicated than it was in ehci-hcd, because ohci-hcd doesn't scan for isochronous completions in the same way as ehci-hcd does. Rather, it depends on the hardware adding completed TDs to a "done queue". Some OHCI controller don't handle this properly when a TD's time slot has already expired, so we have to avoid adding such TDs to the schedule in the first place. As a result, if the URB was submitted too late then none of its TDs will get put on the schedule, so none of them will end up on the done queue, so the driver will never realize that the URB should be completed. To solve this problem, the patch adds one to urb_priv->td_cnt for such URBs, making it larger than urb_priv->length (td_cnt already gets set to the number of TD's that had to be skipped because their slots have expired). Each time an URB is given back, the finish_urb() routine looks to see if urb_priv->td_cnt for the next URB on the same endpoint is marked in this way. If so, it gives back the next URB right away. This should be applied to all kernels containing commit 815fa7b91761 (USB: OHCI: fix logic for scheduling isochronous URBs). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-26USB: ohci_usb warn "irq nobody cared" on shutdowncaizhiyong
When ohci-hcd is shutting down, call ohci_usb_reset reset ohci-hcd, the root hub generate an interrupt, but ohci->rh_state is OHCI_RH_HALTED, and ohci_irq ignore the interrupt, the kernel trigger warning "irq nobody cared". ehci-hcd is first disable interrupts, then reset ehci. This patch disable ohci interrupt before reset ohci. The patch is tested at the arm cortex-a9 demo board. Signed-off-by: caizhiyong <caizhiyong@huawei.com> Reviewed-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06USB: OHCI: remove bogus #errorArnd Bergmann
The OHCI host controller driver can be built standalone now, without enabling any of the available bus glue drivers, so there is not really a reason to error out here: drivers/usb/host/ohci-hcd.c:1258: error: #error "missing bus glue for ohci-hcd" #error "missing bus glue for ohci-hcd" This follows the same change done in ehci recently as 843e56c0 "USB: EHCI: remove bogus #error" and hopefully avoids future merge conflicts in this list. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03USB: OHCI: make ohci-platform a separate driverManjunath Goudar
This patch splits the ohci-platform code from ohci-hcd out into its own separate driver module.This work is part of enabling multi-platform kernels on ARM. In V2: -Passed "hcd" argument instead of "ohci" in ohci_setup() because it is using "struct usb_hcd" argument. In V3: -Directly passed "hcd" argument not required to call ohci_to_hcd() function. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-30USB: OHCI: make ohci-pci a separate driverManjunath Goudar
This patch splits the PCI portion of ohci-hcd out into its own separate driver module, called ohci-pci. The major point of difficulty lies in ohci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ohci_start() some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. The complete sb800_prefetch() function moved to ohci-q.c,because its only related to ohci-pci driver. USB_OHCI_HCD_PCI symbol no longer dependence on STB03xxx, PPC_MPC52xx and USB_OHCI_HCD_PPC_OF that's what removed. V2: - few specific content of pci related code in ohci_pci_start function has been moved to ohci_pci_reset and rest of the generic code is written in ohci_start of ohci-hcd.c file. V3: - ohci_restart() has been called in ohci_pci_reset() function for to reset the ohci pci. V4: -sb800_prefetch() moved to ohci-q.c,because its only related to ohci-pci. -no longer _creating_ CONFIG_USB_OHCI_PCI,creating CONFIG_USB_OHCI_HCD_PCI. -overrides renamed with pci_override,its giving proper meaning. V5: -sb800_prefetch() moved to pci-quirks.c,because its only related to pci. V6: -sb800_prefetch() function has been moved to pci-quirks.c made as separate patch in 2/3. -Most of the generic ohci pci changes moved in 2/3 patch,now this is complete ohci-pci separation patch. V7: -Unrelated include file has been removed from ohci.h file. V8: -USB_OHCI_HCD_PCI symbol does not dependence on STB03xxx, PPC_MPC52xx and USB_OHCI_HCD_PPC_OF. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-30USB: OHCI: Generic changes to make ohci-pci a separate driverManjunath Goudar
Note that this changes is part of separating the ohci pci host controller driver from ohci-hcd host code. This contains : -Moved sb800_prefetch() function from ohci-pci.c to pci-quirks.c file and EXPORTed, this is part of the effort to move the ohci pci related code to generic pci code. -Passed "device" argument instead of "ohci_hcd" in sb800_prefetch() function to avoid extra include file in pci-quirks.c. V2: -Passed "device" argment instead of "pci_dev", then we use to_pci_dev() to get the "pci_dev" structure. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-30USB: OHCI: prepare to make ohci-hcd a library moduleManjunath Goudar
This patch prepares ohci-hcd for being split up into a core library and separate platform driver modules. A generic ohci_hc_driver structure is created, containing all the "standard" values, and a new mechanism is added whereby a driver module can specify a set of overrides to those values. In addition the ohci_restart(),ohci_suspend() and ohci_resume() routines need to be EXPORTed for use by the drivers. Added ohci_setip(() and ohci_start() routine for to start the generic controller rather than each having its own idiosyncratic approach. This allow to clean duplicated code in most of SOC driver In V2: -ohci_hcd_init() ohci_run() and ohci_stop() are not made non-static. -Adds the ohci_setup() and ohci_start() routine. In V3: -purpose of ohci_setup() and ohci_start() function description written in the patch description. -ohci_init() are not made non-static but now called beginning of the ohci_restart(). -ohci_run() signature change reverted back. -unrelated changes removed. -duplicate comment line removed. -inline ohci_suspend() and ohci_resume() is not needed so removed from ohci.h file. In V4: -ohci-init() EXPORTed because it is called by all bus glue modules. -ohci-setup() removed from 1/2 added into 2/2 patch. In V5: -Again ohci_setup() is added and EXPORTed because to replace the ohci_init() from all bus glues. -ohci_init() is not made non-static function. In V6: -ohci_init() call is removed from ohci_quirk_nec_worker(), because it is already called in ohci_restart(). In V8: -ohci_hcd_init() is called by ohci_setup() to make generic ohci initialization in all ohci drivers. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-15USB: OHCI: fix logic for scheduling isochronous URBsAlan Stern
The isochronous scheduling logic in ohci-hcd has a bug. The calculation for skipping TDs that are too late should be carried out only in the !URB_ISO_ASAP case. When URB_ISO_ASAP is set, the URB is pushed back so that none of the TDs are too late, which would cause the calculation to overflow. The patch also fixes the calculation to avoid overflow in the case where the frame value wraps around. This should be applied to -stable kernels going back to 3.8. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-15USB: fix latency in uhci-hcd and ohci-hcdAlan Stern
Commits c44b225077bb1fb25ed5cd5c4f226897b91bedd4 (UHCI: implement new semantics for URB_ISO_ASAP) and 6a41b4d3fe8cd4cc95181516fc6fba7b1747a27c (OHCI: implement new semantics for URB_ISO_ASAP) increased the latency for isochronous URBs in uhci-hcd and ohci-hcd respectively to 2 milliseconds, in an attempt to avoid underruns. It turns out that not only was this unnecessary -- 1-ms latency works okay -- it also causes problems with certain application loads such as real-time audio. This patch changes the latency for both drivers back to 1 ms. This should be applied to -stable kernels going back to 3.8. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: Joe Rayhawk <jrayhawk@fairlystable.org> CC: Clemens Ladisch <clemens@ladisch.de> CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25USB: OHCI: avoid conflicting platform driversArnd Bergmann
Like the EHCI driver, OHCI supports a large number of different platform glue drivers by directly including them, which causes problems with conflicting macro definitions in some cases. As more ARM architecture specific back-ends are required to coexist in a single build, we should split those out into separate drivers. Unfortunately, the infrastructure for that is still under development, so to give us more time, this uses a separate *_PLATFORM_DRIVER macro for each ARM specific OHCI backend, just like we already do on PowerPC and some of the other ARM platforms. In linux-3.10, only the SPEAr and CNS3xxx back-ends would actually conflict without this patch, but over time we would get more of them, so this is a way to avoid having to patch the driver every time it breaks. We should still split out all back-ends into separate loadable modules, but that work is only needed to improve code size and cleanliness after this patch, not for correctness. While we're here, this fixes the incorrectly sorted error path for the OMAP1 and OMAP3 backends to ensure we always unregister the exact set of drivers that were registered before erroring out. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove Alchemy OHCI platform driver.Florian Fainelli
All users have been converted to use the OHCI platform driver instead, thus making ohci-au1xxx obsolete, remove it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove OHCI SH platform driverFlorian Fainelli
All users have been converted to use the OHCI platform driver instead, thus making ohci-sh obsolete, so remove it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove Netlogic XLS OHCI platform driverFlorian Fainelli
All users have been converted to use the OHCI platform driver instead, thus making ohci-xls obsolete, remove it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove CNS3xxx OHCI platform driverFlorian Fainelli
All users have been converted to use the OHCI platform driver instead, thus making ohci-cns3xxx, so remove it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove PNX8550 OHCI driverFlorian Fainelli
The users have been converted to use the platform OHCI driver instead, thus making the ohci-pnx8550 driver obsolete, so remove it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: ohci: merge ohci_finish_controller_resume with ohci_resumeFlorian Fainelli
Merge ohci_finish_controller_resume with ohci_resume as suggested by Alan Stern. Since ohci_finish_controller_resume no longer exists, update the various OHCI drivers to call ohci_resume() instead. Some drivers used to set themselves the bit HCD_FLAG_HW_ACCESSIBLE, which is now handled by ohci_resume(). Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: ohci: remove check for RH already suspended in ohci_suspendFlorian Fainelli
As suggested by Alan Stern, the code checking for the OHCI RH already suspended is no longer required since the bug it fixes has not been seen in ages. Remove that check making ohci_suspend much simpler. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: ohci: move ohci_pci_{suspend,resume} to ohci-hcd.cFlorian Fainelli
As suggested by Alan Stern, move the ohci-pci.c ohci_pci_{suspend,resume} routines to ohci-hcd.c. Due to their move, also rename them to ohci_{suspend,resume} to make it clear they operate on ohci_hcd. Since they are not necessarily called, annotate them with __maybe_unused, and make them enclosed within an #ifdef CONFIG_PM / #endif section. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: remove ohci-pcc-soc driver.Florian Fainelli
This driver is not registered by any in-tree users, and if really needed by some out of tree user, the same functionnality can be restored using the ohci-platform driver using the following platform_data parameters: big_endian_desc = 1 big_endian_mmio = 1 no_big_frame_no = 1 Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22OHCI: implement new semantics for URB_ISO_ASAPAlan Stern
This patch (as1614) updates the isochronous scheduling in ohci-hcd to match the new semantics for URB_ISO_ASAP. Testing revealed a hardware bug in the way my OHCI controller handles expired isochronous TDs; consequently the patch tries hard to avoid creating them (unlike the ehci-hcd and uhci-hcd drivers). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-08-26ARM: mach-pnx4008: Remove architectureRoland Stigge
This patch removes the ARM architecture mach-pnx4008. No direct support or user feedback since 2006. Acknowledgements from NXP/Philips and Linux arm-soc maintainers. Signed-off-by: Roland Stigge <stigge@antcom.de>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-18usb: add host support for the tilegx architectureChris Metcalf
This change adds OHCI and EHCI support for the tilegx's on-chip USB hardware. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-04-18USB: OHCI: remove old SSB OHCI driverHauke Mehrtens
This is now replaced by the new ssb USB driver, which also supports devices with an EHCI controller. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-15USB: use generic platform driver on ath79Hauke Mehrtens
The ath79 usb driver doesn't do anything special and is now converted to the generic ehci and ohci driver. This was tested on a TP-Link TL-WR1043ND (AR9132) Acked-by: Gabor Juhos <juhosg@openwrt.org> CC: Imre Kaloz <kaloz@openwrt.org> CC: linux-mips@linux-mips.org CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-15USB: OHCI: Add a generic platform device driverHauke Mehrtens
This adds a generic driver for platform devices. It works like the PCI driver and is based on it. This is for devices which do not have an own bus but their OHCI controller works like a PCI controller. It will be used for the Broadcom bcma and ssb USB OHCI controller. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-13USB: ohci-nxp: Support for LPC32xxRoland Stigge
This patch adds support for the LPC32xx to ohci-nxp Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-13USB: ohci-nxp: Rename symbols from pnx4008 to nxpRoland Stigge
Since this driver is compatible with several NXP devices, the driver was renamed accordingly. This patch also changes the respective symbol names. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-13USB: OHCI-HCD: Rename ohci-pnx4008 to ohci-nxpRoland Stigge
Since this driver is compatible with several NXP devices, the driver is renamed accordingly. Please combine with the following patch which also changes the respective symbol names. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-03ARM: S3C24XX: change the ARCH_S3C2410 to ARCH_S3C24XXKukjin Kim
This patch changes the ARCH name to "ARCH_S3C24XX" for Samsung S3C2410, S3C2412, S3C2413, S3C2416, S3C2440, S3C2442, S3C2443, and S3C2450 SoCs so that we can merge the mach-xxx directories and plat-s3c24xx dir. to just one mach-s3c24xx for them. I think this should be sent to upstream via samsung tree because this touches many samsung stuff. Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Greg Kroah-Hartman <gregkh@suse.de> [for the gadget part:] Acked-by: Felipe Balbi <balbi@ti.com> [for the framebuffer (video) part:] Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> [For the watchdog-part:] Acked-by: Wim Van Sebroeck <wim@iguana.be> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-01usb: core: hcd: make hcd->irq unsignedFelipe Balbi
There's really no point in having hcd->irq as a signed integer when we consider the fact that IRQ 0 means NO_IRQ. In order to avoid confusion, make hcd->irq unsigned and fix users who were passing -1 as the IRQ number to usb_add_hcd. Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-09Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Driver specific changes Again, a lot of platforms have changes in here: pxa, samsung, omap, at91, imx, ... * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: sa1100: clean up of the clock support ARM: pxa: add dummy clock for sa1100-rtc RTC: sa1100: support sa1100, pxa and mmp soc families RTC: sa1100: remove redundant code of setting alarm RTC: sa1100: Clean out ost register Input: zylonite-wm97xx - replace IRQ_GPIO() with gpio_to_irq() pcmcia: pxa: replace IRQ_GPIO() with gpio_to_irq() ARM: EXYNOS: Modified files for SPI consolidation work ARM: S5P64X0: Enable SDHCI support ARM: S5P64X0: Add lookup of sdhci-s3c clocks using generic names ARM: S5P64X0: Add HSMMC setup for host Controller ARM: EXYNOS: Add USB OHCI support to ORIGEN board USB: Add Samsung Exynos OHCI diver ARM: EXYNOS: Add USB OHCI support to SMDKV310 board ARM: EXYNOS: Add USB OHCI device net: macb: fix build break with !CONFIG_OF i2c: tegra: Support DVC controller in device tree i2c: tegra: Add __devinit/exit to probe/remove net/at91_ether: use gpio_is_valid for phy IRQ line ARM: at91/net: add macb ethernet controller in 9g45/9g20 DT ...
