Commit af4e1ee04026908086d7ed252db2619a8ceaa333 (usb-next)
"USB: remove err() macro"
was preceeded by a tree-wide cleanup of users, however this
one squeaked through the cracks because it had whitespace
between the function name and the bracket for the args.
Map it onto dev_err, just like all the "pre-commits" made
in advance of af4e1ee04026, such as the example seen in
the commit d57b177208b6ec20cacd7321ee32ef02f9f9e7fa:
"USB: ohci-xls.c: remove err() usage"
Build tested with the MIPS gpr_defconfig settings.
Cc: Alan Stern <stern@rowland.harvard.edu>
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (119 commits)
MIPS: Delete unused function add_temporary_entry.
MIPS: Set default pci cache line size.
MIPS: Flush huge TLB
MIPS: Octeon: Remove SYS_SUPPORTS_HIGHMEM.
MIPS: Octeon: Add support for OCTEON II PCIe
MIPS: Octeon: Update PCI Latency timer and enable more error reporting.
MIPS: Alchemy: Update cpu-feature-overrides
MIPS: Alchemy: db1200: Improve PB1200 detection.
MIPS: Alchemy: merge Au1000 and Au1300-style IRQ controller code.
MIPS: Alchemy: chain IRQ controllers to MIPS IRQ controller
MIPS: Alchemy: irq: register pm at irq init time
MIPS: Alchemy: Touchscreen support on DB1100
MIPS: Alchemy: Hook up IrDA on DB1000/DB1100
net/irda: convert au1k_ir to platform driver.
MIPS: Alchemy: remove unused board headers
MTD: nand: make au1550nd.c a platform_driver
MIPS: Netlogic: Mark Netlogic chips as SMT capable
MIPS: Netlogic: Add support for XLP 3XX cores
MIPS: Netlogic: Merge some of XLR/XLP wakup code
MIPS: Netlogic: Add default XLP config.
Fix up trivial conflicts in arch/mips/kernel/{perf_event_mipsxx.c,
traps.c} and drivers/tty/serial/Makefile
Add basic support for the Au1300 variant(s):
- New GPIO/Interrupt controller
- DBDMA ids
- USB setup
- MMC support
- enable various PSC drivers
- detection code.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2866/
This patch (as1500) removes all uses of the objectionable hcd->state
variable from the ohci-hcd family of drivers. It is replaced by a
private ohci->rh_state field, just as in uhci-hcd and ehci-hcd.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits)
MIPS: O32: Provide definition of registers ta0 .. ta3.
MIPS: perf: Add Octeon support for hardware perf.
MIPS: perf: Add support for 64-bit perf counters.
MIPS: perf: Reorganize contents of perf support files.
MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c
MIPS: Add accessor macros for 64-bit performance counter registers.
MIPS: Add probes for more Octeon II CPUs.
MIPS: Add more CPU identifiers for Octeon II CPUs.
MIPS: XLR, XLS: Add comment for smp setup
MIPS: JZ4740: GPIO: Check correct IRQ in demux handler
MIPS: JZ4740: GPIO: Simplify IRQ demuxer
MIPS: JZ4740: Use generic irq chip
MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines
MIPS: Alchemy: kill au1xxx.h header
MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines
MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep
MIPS: Alchemy: Redo PCI as platform driver
MIPS: Alchemy: more base address cleanup
MIPS: Alchemy: rewrite USB platform setup.
MIPS: Alchemy: abstract USB block control register access
Fix up trivial conflicts in:
arch/mips/alchemy/devboards/db1x00/platform.c
drivers/ide/Kconfig
drivers/mmc/host/au1xmmc.c
drivers/video/Kconfig
sound/mips/Kconfig
Alchemy chips have one or more registers which control access
to the usb blocks as well as PHY configuration. I don't want
the OHCI/EHCI glues to know about the different registers and bits;
new code hides the gory details of USB configuration from them.
To: Linux-MIPS <linux-mips@linux-mips.org>
Cc: linux-usb@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/2709/
create mode 100644 drivers/usb/host/alchemy-common.c
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
In file included from drivers/usb/host/ohci-hcd.c:1028:0:
drivers/usb/host/ohci-au1xxx.c:36:7: warning: "__BIG_ENDIAN" is not defined
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
move both ohci-au1xxx and ehci-au1xxx over to dev_pm_ops.
Tested on Au1200.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
This patch (as1069c) changes the way OHCI root-hub status-change
interrupts are enabled. Currently a special HCD method,
hub_irq_enable(), is called when the hub driver is finished using a
root hub. This approach turns out to be subject to races, resulting
in unnecessary polling.
The patch does away with the method entirely. Instead, the driver
automatically enables the RHSC interrupt when no more status changes
are present. This scheme is safe with controllers using
level-triggered semantics for their interrupt flags.
Copy the OHCI/EHCI PM callbacks of the PCI implementation since
they work equally well on Au1xxx hardware.
Tested on Au1200.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Cc: David Brownell <dbrownell@users.sourceforge.net>
- Fold multiple probe/remove callbacks into one function;
- minor style fixes, no functional changes.
Tested on Au1200.
This patch was created by
git grep -E -l 'Rus(el|s?e)l King' | xargs -r -t perl -p -i -e 's/Rus(el|s?e)l King/Russell King/g'
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
Most-Definitely-Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176.
Andrey Borzenkov reports that it resulted in a totally hung machine for
him when loading the OHCI driver. Extensive netconsole capture with
SysRq output shows that modprobe gets stuck in ohci_hub_status_data()
when probing and enabling the OHCI controller, see for example
http://lkml.org/lkml/2008/7/5/236
for an analysis.
The problem appears to be an interrupt flood triggered by the commit
that gets reverted, and Andrey confirmed that the revert makes things
work for him again.
Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
This patch (as1069b) changes the way OHCI root-hub status-change
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable USB HCDs,
to allow re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers; registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
The previous model had the module_init & module_exit function in the
bus glue .c files themselves. That's a problem if several glues need
to be selected at once and the driver is built has module. This case
is quite common in embedded system where you want to handle both the
integrated ohci controller and some extra controller on PCI.
The ohci-hcd.c file now provide the module_init & module_exit and
appropriate driver registering/unregistering is done conditionally,
using #ifdefs.
Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace
(space before tab, at end of line) as well as the obsolete inline changelog.
If some problem occurs during ehci startup, for instance, request_irq fails,
echi hcd driver tries it best to cleanup, but fails to unregister reboot
notifier, which in turn leads to crash on reboot/poweroff.
The following patch resolves this problem by not using reboot notifiers
anymore, but instead making ehci/ohci driver get its own shutdown method. For
PCI, it is done through pci glue, for everything else through platform driver
glue.
One downside: sa1111 does not use platform driver stuff, and does not have its
own shutdown hook, so no 'shutdown' is called for it now. I'm not sure if it
is really necessary on that platform, though.
Signed-off-by: Aleks Gorelov <dared1st@yahoo.com>
Cc: David Brownell <david-b@pacbell.net>
This teaches OHCI to use the root hub status change (RHSC) IRQ, bypassing
root hub timers most of the time and switching over to the "new" root hub
polling scheme. It's complicated by the fact that implementations of OHCI
trigger and ack that IRQ differently (the spec is vague there).
Avoiding root hub timers helps mechanisms like "dynamic tick" leave the
CPU in lowpower modes for longer intervals.
This patch has removed a unbalanced #endif from ohci-au1xxx.c .
Please apply before 2.6.18 release.
Error message was:
In file included from drivers/usb/host/ohci-hcd.c:909:
drivers/usb/host/ohci-au1xxx.c:113:2: #endif without #if
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
I received an DBAU1200 eval kit from AMD a few days ago and tried to
enable the USB2 port, but the current linux-2.6 GIT did not even
compile with CONFIG_SOC_1200, CONFIG_SOC_AU1X00, CONFIG_USB_EHCI and
CONFIG_USB_OHCI set.
Furthermore, in ehci-hcd.c, platform_driver_register() was called with
an improper argument of type 'struct device_driver *' which of course
ended up in a kernel oops. How could that ever have worked on your
machines?
Anyway, here's a trivial patch that makes the USB subsystem working
on my board for both OHCI and EHCI.
It also removes the /* FIXME use "struct platform_driver" */.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Compile fixes for au1200 ohci.
First part looks a bit hackish... but it works for me.
Signed-off-by: Domen Puncer <domen.puncer@ultra.si>
ALCHEMY: Add OHCI support for AU1200
Updated by moving the OHCI support out of the EHCI patch.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
au_readl() does needed byteswapping, etc.
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jaroslav Kysela <perex@perex.cz>
Acked-by: Jordan Crouse <jordan.crouse@amd.com>
Include fixes for 2.6.14-git11. Should allow to remove sched.h from
module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more
to come since I haven't yet checked the other archs.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Add .owner initialisation to the device drivers
in drivers/usb/host so that when built as module
the device_driver refers to the owning module
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
This patch (as580) is perhaps the only result from the long discussion I
had with David about his changes to the root-hub suspend/resume code. It
renames the hub_suspend and hub_resume methods in struct usb_hcd to
bus_suspend and bus_resume. These are more descriptive names, since the
methods really do suspend or resume an entire USB bus, and less likely to
be confused with the hub_suspend and hub_resume routines in hub.c.
It also takes David's advice about removing the layer of bus glue, where
those methods are called. And it implements a related change that David
made to the other HCDs but forgot to put into dummy_hcd.
This cleans up a small recent FIXME, ensuring that all the HCDs provide
root hub suspend/resume methods. It also wraps the calls to those root
suspend routines just like on the PCI "USB_SUSPEND not defined" cases,
so non-PCI bus glue won't be as tempted to behave very differently.
Several of the SOC based OHCI drivers forgot to list those methods;
the patch also adds those missing declarations.
drivers/usb/core/hcd.c | 42 +++++++++++++++++++++++++---------------
drivers/usb/host/ohci-au1xxx.c | 5 ++++
drivers/usb/host/ohci-lh7a404.c | 5 ++++
drivers/usb/host/ohci-pxa27x.c | 1
drivers/usb/host/ohci-s3c2410.c | 1
drivers/usb/host/ohci-sa1111.c | 1
6 files changed, 40 insertions(+), 15 deletions(-)
infrastructure for it.
Let it rip!
