commit ea16328f80ca8d74434352157f37ef60e2f55ce2 upstream.
Make sure we're using the new macro, so our
resume signaling will always pass certification.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 5cbcc35e5bf0eae3c7494ce3efefffc9977827ae upstream.
The roothub's index per controller is from 0, but the hub port index per hub
is from 1, this patch fixes "can't find device at roohub" problem for connecting
test fixture at roohub when do USB-IF Embedded Host High-Speed Electrical Test.
This patch is for v3.12+.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 3e8d6d85adedc59115a564c0a54b36e42087c4d9 upstream.
High-speed USB connections revert back to full-speed signalling when
the device goes into suspend. This takes several milliseconds, and
during that time it's not possible to tell reliably whether the device
has been disconnected.
On some platforms, the Wake-On-Disconnect circuitry gets confused
during this intermediate state. It generates a false wakeup signal,
which can prevent the controller from going to sleep.
To avoid this problem, this patch adds a 5-ms delay to the
ehci_bus_suspend() routine if any ports have to switch over to
full-speed signalling. (Actually, the delay was already present for
devices using a particular kind of PHY power management; the patch
merely causes the delay to be used more widely.)
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reviewed-by: Peter Chen <Peter.Chen@freescale.com>
This patch removes ehci_vdbg debugging statements from EHCI host controller
driver because they produce too much information, lowering the signal to noise
ratio when debugging, and because they are not used anymore.
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
commit 9841f37a1c ("usb: ehci: Add support for SINGLE_STEP_SET_FEATURE
test of EHSET") added additional code to the EHCI hub driver but it is
anticipated to only have a limited audience (e.g. embedded silicon
vendors and integrators). Avoid subjecting all EHCI (and in the future
maybe xHCI/OHCI, etc.) HCD users to code bloat by conditionally
compiling the EHSET-specific additions with a new Kconfig option,
CONFIG_USB_HCD_TEST_MODE.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v3.12 merge window
All patches here have been pending on linux-usb
and sitting in linux-next for a while now.
The biggest things in this tag are:
DWC3 learned proper usage of threaded IRQ
handlers and now we spend very little time
in hardirq context.
MUSB now has proper support for BeagleBone and
Beaglebone Black.
Tegra's USB support also got quite a bit of love
and is learning to use PHY layer and generic DT
attributes.
Other than that, the usual pack of cleanups and
non-critical fixes follow.
Signed-of-by: Felipe Balbi <balbi@ti.com>
drivers/usb/gadget/udc-core.c
drivers/usb/host/ehci-tegra.c
drivers/usb/musb/omap2430.c
drivers/usb/musb/tusb6010.c
The USB Embedded High-speed Host Electrical Test (EHSET) defines the
SINGLE_STEP_SET_FEATURE test as follows:
1) The host enumerates the test device with VID:0x1A0A, PID:0x0108
2) The host sends the SETUP stage of a GetDescriptor(Device)
3) The device ACKs the request
4) The host issues SOFs for 15 seconds allowing the test operator to
raise the scope trigger just above the SOF voltage level
5) The host sends the IN packet
6) The device sends data in response, triggering the scope
7) The host sends an ACK in response to the data
This patch adds additional handling to the EHCI hub driver and allows
the EHSET driver to initiate this test mode by issuing a a SetFeature
request to the root hub with a Test Selector value of 0x06. From there
it mimics ehci_urb_enqueue() but separately submits QTDs for the
SETUP and DATA/STATUS stages in order to insert a delay in between.
Signed-off-by: Manu Gautam <mgautam@codeaurora.org>
[jackp@codeaurora.org: imported from commit c2084930 on codeaurora.org;
minor cleanup and updated author email]
ehci-hcd currently unlinks an interrupt QH when it becomes empty, that
is, after its last URB completes. This works well because in almost
all cases, the completion handler for an interrupt URB resubmits the
URB; therefore the QH doesn't become empty and doesn't get unlinked.
When we start using tasklets for URB completion, this scheme won't work
as well. The resubmission won't occur until the tasklet runs, which
will be some time after the completion is queued with the tasklet.
During that delay, the QH will be empty and so will be unlinked
unnecessarily.
To prevent this problem, this patch adds a 5-ms time delay before empty
interrupt QHs are unlinked. Most often, during that time the interrupt
URB will be resubmitted and thus we can avoid unlinking the QH.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
The has_hostpc capability bit indicates that the host controller has the
HOSTPC register extensions, but at the same time enables clock disabling
power saving features with the PHY Low Power Clock Disable (PHCD) bit.
However, some host controllers have the HOSTPC extensions but don't
support the low-power feature, so the PHCD bit must not be set on those
controllers. Add a separate capability bit for the low-power feature
instead, and change all existing users of has_hostpc to use this new
capability bit.
The idea for this commit is taken from an old 2012 commit that never got
merged ("disociate chipidea PHY low power suspend control from hostpc")
Inspired-by: Matthieu CASTET <matthieu.castet@parrot.com>
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
In theory, an EHCI controller can turn off the PORT_RESUME or
PORT_RESET bits in a port status register all by itself (and some
controllers actually do this). We shouldn't depend on these bits
being set correctly.
This patch rearranges the code in ehci-hcd that handles completion of
port resets and resumes. We guarantee that ehci->reset_done[portnum]
is nonzero if a reset or resume is in progress, and that the portnum
bit is set in ehci->resuming_ports if the operation is a resume. (To
help enforce this guarantee, the patch prevents suspended ports from
being reset.) Therefore it's not necessary to look at the port status
bits to learn what's going on.
The patch looks bigger than it really is, because it changes the
indentation level of a sizeable region of code. Most of what it
actually does is interchange some tests. The only functional changes
are testing reset_done and resuming_ports rather than PORT_RESUME and
PORT_RESET, removing a now-unnecessary check for spontaneous
resets of the PORT_RESUME and PORT_RESET bits, and preventing a
suspended or resuming port from being reset.
The ehci-hcd driver isn't as careful as it should be about the way it
uses ehci->resuming_ports. One of the omissions was fixed recently by
commit 47a64a13d54 (USB: EHCI: Fix resume signalling on remote
wakeup), but there are other places that need attention:
When a port's suspend feature is explicitly cleared, the
corresponding bit in resuming_ports should be set and the core
should be notified about the port resume.
We don't need to clear a resuming_ports bit when a reset
completes.
Set the ehci->resuming flag for the port we receive a remote
wakeup on so that resume signalling can be completed.
Without this, the root hub timer will not fire again to check
if the resume was completed and there will be a never-ending wait on
on the port.
This effect is only observed if the HUB IRQ IN does not come after we
have initiated the port resume.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Cc: stable <stable@vger.kernel.org>
In order to split ehci-hcd.c into separate modules, handshake() must be
exported. Rename the symbol to add an ehci_ prefix, to avoid any naming
clashes.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
[swarren, split Manjunath's patches more logically, limit this change
to export just handshake()]
Tested-by: Thierry Reding <thierry.reding@gmail.com>
The current EHCI code sleeps a flat 110ms in the resume path if there
was a USB 1.1 device connected to its companion controller during
suspend, waiting for the device to reappear and reset so that it can be
handed back to the companion. This is necessary if the device uses
persist, so that the companion controller can actually see it during its
own resume path.
However, if the device doesn't use persist, this is entirely
unnecessary. We might just as well ignore it and have the normal device
detection/reset/handoff code handle it asynchronously when it eventually
shows up. As USB 1.1 devices are almost exclusively HIDs these days (for
which persist has no value), this can allow distros to shave another
tenth of a second off their resume time.
In order to enable this optimization, the patch also adds a new
usb_for_each_dev() iterator that is exported by the USB core and wraps
bus_for_each_dev() with the logic to differentiate between struct
usb_device and struct usb_interface on the usb_bus_type bus.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Commit 756aa6b3d536afe85e151138cb03a293998887b3 (ehci-hub: improved
over-current recovery) added port power cycling on overcurrent indications as
needed by the MPC8349 USB controller after resolving of the overcurrent
situation in order to have the host state machine assert the correct port
status again.
Commit 81463c1d707186adbbe534016cd1249edeab0dac (EHCI: only power off port if
over-current is active) solved a thus resulting issue of endless overcurrent
changes in combination with the MAX4967 USB power supply chip that signals
overcurrent when power is not enabled by only powering off a port if the
overcurrent is currently active.
Added quirks flag need_oc_pp_cycle in order to specify the needed behaviour as
there is no common behaviour that can comply with both requirements.
Activated the quirks handling for Freescale 83xx based boards.
Signed-off-by: Christian Engelmayer <christian.engelmayer@frequentis.com>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
This is to pick up the fixes in that branch, and let Alan fix the merge
error in drivers/usb/host/ehci-timer.c better than I just did (as I know
I messed it up...)
This patch (as1637) cleans up the way ehci-hcd handles end-of-resume
port signalling. When the PORT_RESUME bit in the port's status and
control register is cleared, we shouldn't be setting the PORT_SUSPEND
bit at the same time. Not doing this doesn't seem to have hurt so
far, but we might as well do the right thing.
Also, the patch replaces an estimated value for what the port status
should be following a resume with the actual register value.
This patch (as1634) simplifies some of the code associated with the
per-port change bits added in EHCI-1.1, and in particular it fixes a
bug in the logic of ehci_hub_status_data(). Even if the change bit
doesn't indicate anything happened on a particular port, we still have
to notify the core about changes to the suspend or reset status.
This patch (as1663) fixes a regression caused by commit
6e0c3339a6f19d748f16091d0a05adeb1e1f822b (USB: EHCI: unlink one async
QH at a time). In order to avoid keeping multiple QHs in an unusable
intermediate state, that commit changed unlink_empty_async() so that
it unlinks only one empty QH at a time.
However, when the EHCI root hub is suspended, _all_ async QHs need to
be unlinked. ehci_bus_suspend() used to do this by calling
unlink_empty_async(), but now this only unlinks one of the QHs, not
all of them.
The symptom is that when the root hub is resumed, USB communications
don't work for some period of time. This is because ehci-hcd doesn't
realize it needs to restart the async schedule; it assumes that
because some QHs are already on the schedule, the schedule must be
running.
The easiest way to fix the problem is add a new function that unlinks
all the async QHs when the root hub is suspended.
This patch should be applied to all kernels that have the 6e0c3339a6f1
commit.
Reported-and-tested-by: Adrian Bassett <adrian.bassett@hotmail.co.uk>
This patch (as1652) fixes a long-standing bug in ehci-hcd. The driver
relies on status polls to know when to stop port-resume signalling.
It uses the root-hub status timer to schedule these status polls. But
when the driver for the root hub is resumed, the timer is rescheduled
to go off immediately -- before the port is ready. When this happens
the timer does not get re-enabled, which prevents the port resume from
finishing until some other event occurs.
The symptom is that when a new device is plugged in, it doesn't get
recognized or enumerated until lsusb is run or something else happens.
The solution is to re-enable the root-hub status timer after every
status poll while a port resume is in progress.
This bug hasn't surfaced before now because we never used to try to
suspend the root hub in the middle of a port resume (except by
coincidence).
Reported-and-tested-by: Norbert Preining <preining@logic.at>
Tested-by: Ming Lei <ming.lei@canonical.com>
This patch (as1650) adds calls to the new
usb_hcd_{start,end}_port_resume() functions to ehci-hcd. Now EHCI
root hubs won't be runtime suspended while they are sending a resume
signal to one of their ports.
This patch (as1624) prepares ehci-hcd for being split up into a core
library and separate platform driver modules. A generic
ehci_hc_driver structure is created, containing all the "standard"
values, and a new mechanism is added whereby a driver module can
specify a set of overrides to those values. In addition the
ehci_setup(), ehci_suspend(), and ehci_resume() routines need to be
EXPORTed for use by the drivers.
As a side effect of this change, a few routines no longer need to be
marked __maybe_unused.
CC: Felipe Balbi <balbi@ti.com>
This patch (as1623) removes the ehci_port_power() routine and all the
places that call it. There's no reason for ehci-hcd to change the
port power settings; the hub driver takes care of all that stuff.
There is one exception: When the controller is resumed from
hibernation or following a loss of power, the ports that are supposed
to be handed over to a companion controller must be powered on first.
Otherwise the handover won't work. This process is not visible to the
hub driver, so it has to be handled in ehci-hcd.
This patch (as1622) removes the USB-2.1 Link Power Management code
from the ehci-hcd driver. This code was never integrated with
usbcore, it is full of bugs, and it was not getting used by anybody.
However, the debugging code for dumping the LPM-related fields in the
EHCI registers is left in place. In theory it might be useful to see
these values, even though we don't use them.
This essentially amounts to a partial revert of commit
aa4d8342988d0c1a79ff19b2ede1e81dfbb16ea5 (USB: EHCI: EHCI 1.1
addendum: preparation) and an almost full revert of commit
48f24970144479c29b8cee6d2e1dbedf6dcf9cfb (USB: EHCI: EHCI 1.1
addendum: Basic LPM feature support) plus its follow-ons.
Without this condition, all controllers will do this delay,
and increase the resume time.
Only enabled and unsuspended port needs this delay, but
Some buggy hardware(like Synopsys usb controller) will
clear suspend bit once they receive/send resume signal,
so it takes resume bit as consideration.
Tested it at Freescale i.mx6q Sabrelite board.
Just like for the in-tree early console debug port driver, the
hypervisor - when using a debug port based console - also needs to be
told about controller resets, so it can suppress using and then
re-initialize the debug port accordingly.
Other than the in-tree driver, the hypervisor driver actually cares
about doing this only for the device where the debug is port actually
in use, i.e. it needs to be told the coordinates of the device being
reset (quite obviously, leveraging the addition done for that would
likely benefit the in-tree driver too).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This patch (as1589) resolves some unlikely races involving system
shutdown or controller death in ehci-hcd:
Shutdown races with both root-hub resume and controller
resume.
Controller death races with root-hub suspend.
A new bitflag is added to indicate that the controller has been shut
down (whether for system shutdown or because it died). Tests are
added in the suspend and resume pathways to avoid reactivating the
controller after any sort of shutdown.
This patch (as1588) adjusts the locking in ehci-hcd's various halt,
shutdown, and suspend/resume pathways. We want to hold the spinlock
while writing device registers and accessing shared variables, but not
while polling in a loop.
In addition, there's no need to call ehci_work() at times when no URBs
can be active, i.e., in ehci_stop() and ehci_bus_suspend().
Finally, ehci_adjust_port_wakeup_flags() is called only in situations
where interrupts are enabled; therefore it can use spin_lock_irq
rather than spin_lock_irqsave.
This patch (as1586) replaces the kernel timer used by ehci-hcd as an
I/O watchdog with an hrtimer event.
Unlike in the current code, the watchdog event is now always enabled
whenever any isochronous URBs are active. This will prevent bugs
caused by the periodic schedule wrapping around with no completion
interrupts; the watchdog handler is guaranteed to scan the isochronous
transfers at least once during each iteration of the schedule. The
extra overhead will be negligible: one timer interrupt every 100 ms.
This patch (as1583) changes ehci-hcd to use an hrtimer event for
unlinking empty (unused) async QHs instead of using a kernel timer.
The check for empty QHs is moved to a new routine, where it doesn't
require going through an entire scan of both the async and periodic
schedules. And it can unlink multiple QHs at once, unlike the current
code.
This patch (as1582) changes ehci-hcd's strategy for unlinking async
QHs. Currently the driver never unlinks more than one QH at a time.
This can be inefficient and cause unnecessary delays, since a QH
cannot be reused while it is waiting to be unlinked.
The new strategy unlinks all the waiting QHs at once. In practice the
improvement won't be very big, because it's somewhat uncommon to have
two or more QHs waiting to be unlinked at any time. But it does
happen, and in any case, doing things this way makes more sense IMO.
The change requires the async unlinking code to be refactored
slightly. Now in addition to the routines for starting and ending an
unlink, there are new routines for unlinking a single QH and starting
an IAA cycle. This approach is needed because there are two separate
paths for unlinking async QHs:
When a transfer error occurs or an URB is cancelled, the QH
must be unlinked right away;
When a QH has been idle sufficiently long, it is unlinked
to avoid consuming DMA bandwidth uselessly.
In the first case we want the unlink to proceed as quickly as
possible, whereas in the second case we can afford to batch several
QHs together and unlink them all at once. Hence the division of
labor.
This patch (as1581) replaces the iaa_watchdog kernel timer used by
ehci-hcd with an hrtimer event, in keeping with the general conversion
to high-res timers.
This patch (as1579) adds an hrtimer event to handle deallocation of
iTDs and siTDs in ehci-hcd.
Because of the frame-oriented approach used by the EHCI periodic
schedule, the hardware can continue to access the Transfer Descriptor
for isochronous (or split-isochronous) transactions for up to a
millisecond after the transaction completes. The iTD (or siTD) must
not be reused before then.
The strategy currently used involves putting completed iTDs on a list
of cached entries and every so often returning them to the endpoint's
free list. The new strategy reduces overhead by putting completed
iTDs back on the free list immediately, although they are not reused
until it is safe to do so.
When the isochronous endpoint stops (its queue becomes empty), the
iTDs on its free list get moved to a global list, from which they will
be deallocated after a minimum of 2 ms. This delay is what the new
hrtimer event is for.
Overall this may not be a tremendous improvement over the current
code, but to me it seems a lot more clear and logical. In addition,
it removes the need for each iTD to keep a reference to the
ehci_iso_stream it belongs to, since the iTD never needs to be moved
back to the stream's free list from the global list.
This patch (as1577) adds hrtimer support for unlinking interrupt QHs
in ehci-hcd. The current code relies on a fixed delay of either 2 or
55 us, which is not always adequate and in any case is totally bogus.
Thanks to internal caching, the EHCI hardware may continue to access
an interrupt QH for more than a millisecond after it has been unlinked.
In fact, the EHCI spec doesn't say how long to wait before using an
unlinked interrupt QH. The patch sets the delay to 9 microframes
minimum, which ought to be adequate.
This patch (as1572) begins the conversion of ehci-hcd over to using
high-resolution timers rather than old-fashioned low-resolution kernel
timers. This reduces overhead caused by timer roundoff on systems
where HZ is smaller than 1000. Also, the new timer framework
introduced here is much more logical and easily extended than the
ad-hoc approach ehci-hcd currently uses for timers.
An hrtimer structure is added to ehci_hcd, along with a bitflag array
and an array of ktime_t values, to keep track of which timing events
are pending and what their expiration times are.
Only the infrastructure for the timing operations is added in this
patch. Later patches will add routines for handling each of the
various timing events the driver needs. In some cases the new hrtimer
handlers will replace the existing handlers for ehci-hcd's kernel
timers; as this happens the old timers will be removed. In other
cases the new timing events will replace busy-wait loops.
This patch (as1571) adds a new state for ehci-hcd's root hubs:
EHCI_RH_STOPPING. This value is used at times when the root hub is
being stopped and we don't know whether or not the hardware has
finished all its DMA yet.
Although the purpose may not be apparent, this distinction will come
in useful later on. Future patches will avoid actions that depend on
the root hub being operational (like turning on the async or periodic
schedules) when they see the state is EHCI_RH_STOPPING.
This patch (as1569) renames the ehci->reclaim list in ehci-hcd. The
word "reclaim" is used in the EHCI specification to mean something
quite different, and "unlink_next" is more descriptive of the list's
purpose anyway.
Similarly, the "reclaim" field in the ehci_stats structure is renamed
"iaa", which is more meaningful (to experts, anyway) and is a better
match for the "lost_iaa" field.
This patch (as1566) removes the code in ehci-hcd's resume routines
which tries to restart or cancel any transfers left active while the
root hub or controller was asleep. This code isn't necessary, because
all URBs are terminated before the root hub is suspended.
This patch (as1563) removes a lot of duplicated code by moving the
EHCI controller suspend/resume routines into the core driver, where
the various platform drivers can invoke them as needed.
Not only does this simplify these platform drivers, this also makes it
easier for other platform drivers to add suspend/resume support in the
future.
Note: The patch does not touch the ehci-fsl.c file, because its
approach to suspend and resume is so different from all the others.
It will have to be handled specially by its maintainer.
This patch (as1562) cleans up the definitions of the EHCI extended
registers to be consistent with the definitions of the standard
registers. This makes the code look a lot nicer, with no functional
change.
- to decrease redundant since both ehci_hcd and ohci_hcd have the same variable
- it helps access phy in usb core code
- phy is more meaningful than transceiver
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
The ehci-hcd driver is a little haphazard about keeping track of the
state of the USBCMD register. The ehci->command field is supposed to
hold the register's value (apart from a few special bits) at all
times, but it isn't maintained properly.
This patch (as1543) cleans up the situation. It keeps ehci->command
up-to-date, and uses that value rather than reading the register from
the hardware whenever possible.
This resolves the conflict in:
drivers/usb/host/ehci-fsl.c
And picks up loads of xhci bugfixes to make it easier for others to test
with.
In the ClearPortFeature/USB_PORT_FEAT_ENABLE case, ehci_hub_control()
would read from status_reg, clear PORT_PE, and write the result back to
status_reg. This would clear any bits in PORT_RWC_BITS that were set in
the registers. Fix this by masking these bits off before the write.
Since this masking is common across all ClearPortFeature cases, move it
into a single early location to avoid duplicating it.
Remove the same bugfix from ehci-tegra.c's tegra_ehci_hub_control(), now
that this case is correctly handled by the core.
It displays wrong debug message if we plug in a full/low
speed device at port for builtin TT controller. We can get
device/port speed information at following code of hub_port_init,
so it is better to replace it with debug message of "reset complete".
This patch (as1537) adds a bit-array to ehci-hcd for keeping track of
which ports are undergoing a resume transition. If any of the bits
are set when ehci_hub_status_data() is called, the routine will return
a nonzero value even if no ports have any status changes pending.
This will allow usbcore to handle races between root-hub suspend and
port wakeup.
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
CC: Chen Peter-B29397 <B29397@freescale.com>
USB: transceiver changes for 3.4
Here we have a big rework done by Heikki Krogerus (thanks) which
splits OTG functionality away from transceivers.
We have known for quite a long time that struct otg_transceiver was
a bad name for the structure, considering transceiver is far from
being OTG-specific (see 4e67185).
This changes the otg functions so that they receive struct
otg instead of struct usb_phy as parameter and
converts all users of these functions to pass the otg member
of their usb_phy.
Includes fixes to IMX code from Sascha Hauer.
[ balbi@ti.com : fixed a compile warning on ehci-mv.c ]
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Acked-by: Li Yang <leoli@freescale.com>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
not all platforms will use all of those ehci_*
symbols on their hc_driver structure. Sometimes
we might need to provide a modified version of
a certain method or not provide it at all, as is
the case with OMAPs which don't support port handoff
feature.
Whenever we compile a kernel for an OMAP board with
EHCI enabled, we get compile warnings:
drivers/usb/host/ehci-hub.c:1079: warning: 'ehci_relinquish_port' \
defined but not used
drivers/usb/host/ehci-hub.c:1088: warning: 'ehci_port_handed_over' \
In order to cleanup those warnings, we're adding
__maybe_unused annotation to those functions.
This was done to resolve a conflict in this file:
drivers/usb/host/xhci-ring.c
