The EHCI IP only needs the UTMI/UPLL (uclk) and the peripheral (iclk)
clocks to work properly. Remove the useless system clock (fclk).
Avoid calling set_rate on the fixed rate UTMI/IPLL clock and remove
useless IS_ENABLED(CONFIG_COMMON_CLK) tests (all at91 platforms have been
moved to the CCF).
This patch also fixes a bug introduced by 3440ef1 (ARM: at91/dt: fix USB
high-speed clock to select UTMI), which was leaving the usb clock
uninitialized and preventing the OHCI driver from setting the usb clock
rate to 48MHz.
This bug was caused by several things:
1/ usb clock drivers set the CLK_SET_RATE_GATE flag, which means the rate
cannot be changed once the clock is prepared
2/ The EHCI driver was retrieving and preparing/enabling the uhpck
clock which was in turn preparing its parent clock (the usb clock),
thus preventing any rate change because of 1/
Fixes: 3440ef169100 ("ARM: at91/dt: fix USB high-speed clock to select UTMI")
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch move Atmel EHCI global variables (clocks ptr and clocked
boolean) to private struct atmel_ehci_priv, stored in ehci->priv.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This patch add suspend/resume support for Atmel EHCI, mostly
about disabling and unpreparing clocks so USB PLL is stopped
before entering sleep state.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Sanity check on resource happening with devm_ioremap_resource().
Signed-off-by: Varka Bhadram <varkab@cdac.in>
Individual controller driver has different requirement for wakeup
setting, so move it from core to itself. In order to align with
current etting the default wakeup setting is enabled (except for
chipidea host).
Pass compile test with below commands:
make O=outout/all allmodconfig
make -j$CPU_NUM O=outout/all drivers/usb
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Pull DMA mask updates from Russell King:
"This series cleans up the handling of DMA masks in a lot of drivers,
fixing some bugs as we go.
Some of the more serious errors include:
- drivers which only set their coherent DMA mask if the attempt to
set the streaming mask fails.
- drivers which test for a NULL dma mask pointer, and then set the
dma mask pointer to a location in their module .data section -
which will cause problems if the module is reloaded.
To counter these, I have introduced two helper functions:
- dma_set_mask_and_coherent() takes care of setting both the
streaming and coherent masks at the same time, with the correct
error handling as specified by the API.
- dma_coerce_mask_and_coherent() which resolves the problem of
drivers forcefully setting DMA masks. This is more a marker for
future work to further clean these locations up - the code which
creates the devices really should be initialising these, but to fix
that in one go along with this change could potentially be very
disruptive.
The last thing this series does is prise away some of Linux's addition
to "DMA addresses are physical addresses and RAM always starts at
zero". We have ARM LPAE systems where all system memory is above 4GB
physical, hence having DMA masks interpreted by (eg) the block layers
as describing physical addresses in the range 0..DMAMASK fails on
these platforms. Santosh Shilimkar addresses this in this series; the
patches were copied to the appropriate people multiple times but were
ignored.
Fixing this also gets rid of some ARM weirdness in the setup of the
max*pfn variables, and brings ARM into line with every other Linux
architecture as far as those go"
* 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits)
ARM: 7805/1: mm: change max*pfn to include the physical offset of memory
ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function
ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit()
ARM: DMA-API: better handing of DMA masks for coherent allocations
ARM: 7857/1: dma: imx-sdma: setup dma mask
DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks
DMA-API: dcdbas: update DMA mask handing
DMA-API: dma: edma.c: no need to explicitly initialize DMA masks
DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks
DMA-API: crypto: remove last references to 'static struct device *dev'
DMA-API: crypto: fix ixp4xx crypto platform device support
DMA-API: others: use dma_set_coherent_mask()
DMA-API: staging: use dma_set_coherent_mask()
DMA-API: usb: use new dma_coerce_mask_and_coherent()
DMA-API: usb: use dma_set_coherent_mask()
DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent()
DMA-API: net: octeon: use dma_coerce_mask_and_coherent()
DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent()
Acked-by: Felipe Balbi <balbi@ti.com>
The correct way for a driver to specify the coherent DMA mask is
not to directly access the field in the struct device, but to use
dma_set_coherent_mask(). Only arch and bus code should access this
member directly.
Convert all direct write accesses to using the correct API.
The AT91 PMC (Power Management Controller) provides a USB clock used by
the different USB controllers (ehci, ohci and udc).
The atmel-ehci driver must configure the usb clock rate to 48Mhz in order
to get a fully functionnal USB host controller.
This configuration was formely done in mach-at91/clock.c, but will be
bypassed when moving to common clk framework.
This patch adds support for usb clock retrieval and configuration only if
CCF is enabled (CONFIG_COMMON_CLK).
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
Many USB host drivers contain code such as:
if (!pdev->dev.dma_mask)
pdev->dev.dma_mask = &tegra_ehci_dma_mask;
... where tegra_ehci_dma_mask is a global. I suspect this code originated
in commit 4a53f4e "USB: ehci-tegra: add probing through device tree" and
was simply copied everywhere else.
This works fine when the code is built-in, but can cause a crash when the
code is in a module. The first module load sets up the dma_mask pointer,
but if the module is removed and re-inserted, the value is now non-NULL,
and hence is not updated to point at the new location, and hence points
at a stale location within the previous module load address, which in
turn causes a crash if the pointer is de-referenced.
The simplest way of solving this seems to be to copy the code from
ehci-platform.c, which uses the coherent_dma_mask as the target for the
dma_mask pointer.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Separate the Atmel host controller driver from ehci-hcd host code
so that it can be built as a separate driver module.
This work is part of enabling multi-platform kernels on ARM;
however, note that other changes are still needed before Atmel can be
booted with a multi-platform kernel. This is currently planned for
Linux-3.11.
With the infrastructure added by Alan Stern in patch 3e0232039
"USB: EHCI: prepare to make ehci-hcd a library module", we can
avoid this problem by turning a bus glue into a separate
module, as we do here for the Atmel bus glue.
In V4 (arnd):
- reordered #include statements.
- removed call to ehci_shutdown and the corresponding export
In V3:
- Detailed commit message added here about why this patch is required.
- Replaced hcd_name string "ehci-atmel" to "atmel-ehci".
- Inserted blank line in the Makefile to separate the EHCI drivers from
the following non-EHCI drivers.
- Exported ehci_shutdown symbol as it is needed by the Atmel driver.
- Eliminated ehci_atmel_setup routine because hcd registers
can be directly set in the ehci_atmel_drv_probe function.
In V2:
Resolved below compiler error.
drivers/usb/host/ehci-atmel.c: In function 'ehci_atmel_drv_remove':
drivers/usb/host/ehci-atmel.c:167: error: implicit declaration of function 'ehci_shutdown'
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Cc: Geoff Levand <geoff@infradead.org>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
This patch (as1623) removes the ehci_port_power() routine and all the
places that call it. There's no reason for ehci-hcd to change the
port power settings; the hub driver takes care of all that stuff.
There is one exception: When the controller is resumed from
hibernation or following a loss of power, the ports that are supposed
to be handed over to a companion controller must be powered on first.
Otherwise the handover won't work. This process is not visible to the
hub driver, so it has to be handled in ehci-hcd.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The various devm_ functions allocate memory that is released when a driver
detaches. This patch uses these functions for data that is allocated in
the probe function of a platform device and is only freed in the remove
function.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This patch (as1564c) converts the EHCI platform drivers to use the
central ehci_setup() routine for generic controller initialization
rather than each having its own idiosyncratic approach.
The major point of difficulty lies in ehci-pci's many vendor- and
device-specific workarounds. Some of them have to be applied before
calling ehci_setup() and some after, which necessitates a fair amount
of code motion. The other platform drivers require much smaller
changes.
One point not addressed by the patch is whether ports should be
powered on or off following initialization. The different drivers
appear to handle this pretty much at random. In fact it shouldn't
matter, because the hub driver turns on power to all ports when it
binds to the root hub. Straightening that out will be left for
another day.
Compilation error in case of non-DT configuration without this
of.h header file.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
Signed-off-by: Jan Andersson <jan@gaisler.com>
Fix the following section mismatch warning:
WARNING: drivers/usb/built-in.o(.data+0x74c): Section mismatch in reference from the variable ehci_atmel_driver to the function .init.text:ehci_atmel_drv_probe()
The variable ehci_atmel_driver references
the function __init ehci_atmel_drv_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
Signed-off-by: Hubert Feurstein <h.feurstein@gmail.com>
Several of the EHCI glue drivers either predate or were merged in the
same timeframe as API changes at the USB core level, resulting in some
missing endpoint_reset and clear_tt_buffer_complete callbacks.
This fixes up all of ehci-atmel, mxc, w90x900, and xilinx-of to tie in
the new helpers, which brings them in line with everyone else.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Use resource_size().
Cc: David Brownell <dbrownell@users.sourceforge.net>
Add host USB High speed driver for at91sam9g45 series.
The host driver is an EHCI with its companion OHCI. EHCI is
handled by the new ehci-atmel.c whereas the OHCI is always
handled by ohci-at91.c.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
