path: root/drivers/usb/gadget/uvc_video.c
2011-09-09usb gadget: clean up FSF boilerplate textKlaus Schwarzkopf
remove the following two paragraphs as they are not needed: This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc.,59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-11V4L/DVB: uvc: Fix multiple symbols definitions with UVC gadget and host driversLaurent Pinchart
The UVC gadget driver borrowed code from the UVC host driver without changing the symbol names. This results in a namespace clash with multiple definitions of several symbols when compiling both drivers in the kernel. Make all generic UVC functions and variables static in the UVC gadget driver, as the symbols are not referenced outside of the gadget driver. Rename the uvc_trace_param global variable to uvc_gadget_trace_param. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-20USB gadget: video class function driverLaurent Pinchart
This USB video class function driver implements a video capture device from the host's point of view. It creates a V4L2 output device on the gadget's side to transfer data from a userspace application over USB. The UVC-specific descriptors are passed by the gadget driver to the UVC function driver, making them completely configurable without any modification to the function's driver code. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
